Author Topic: [IC] Zambumon Jules | Live at RAMA WORKS® FOUNDRY  (Read 114622 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« on: Sun, 31 March 2019, 17:00:11 »
JULES
CHECK OUT THE PROJECT PAGE
The core Jules feature is simplicity, going back to the essential elements of bespoke keyboards. A clean, beautifully functional design that makes the best with the least. An outstanding match for your desk space.
Case design by Zambumon. PCB design by wilba.tech
Manufactured and distributed by RAMA WORKS® FOUNDRY
STREAMLINED AND SEAMLESS.
Expertly milled down from a solid piece of aluminium to its final shape and bead-blasted to a high grit finish, Jules offers an elegant and streamlined aesthetic, with a breathtaking side profile that does not go unnoticed.
TOP-MOUNTED. AS IT SHOULD BE.
The Jules plate is attached to the top frame by eight mounting points that have been carefully placed to provide an optimal sound signature and feel. This simple and effective solution has been a mainstay of the custom keyboard scene as it provides a great typing experience.
FOUR EDITIONS TO RULE THEM ALL.
KURO - NAVY - HALT - OURO
MAKE IT YOUR OWN.
Personalize your Jules by pairing it with your favorite MX switches and custom keycap set.
SOLDERLESS OR SOLDERABLE, THE CHOICE IS YOURS.
The wilba.tech WT65-F and WT65-FX PCBs are designed specifically for Jules. A separate extension PCB provides USB-C connectivity that is low and centered at the rear of the keyboard.
The WT65-F uses Kailh hot-swap sockets for assembly without soldering and it's securely anchored to the plate using standoffs.
The WT65-FX variant is a solderable version without hot-swap sockets for those who prefer a different layout.
The Fixed layout plate is paired with the WT65-F Hotswap PCB. The Variable layout plate is paired with the WT65-FX Solderable PCB.
FIXED LAYOUT
VARIABLE LAYOUT
PROGRAMMING YOUR BOARD HAS NEVER BEEN EASIER.
The WT65-F and WT65-FX are QMK compatible and easily programmable in real-time with VIA.
RAMA × Zambumon
To celebrate the launch of Jules, A limited-edition Cherry Profile Row 1 keycap. MX stem and made from aluminium.
WHAT’S IN THE BOX
1 × Top Enclosure (Aluminium)
1 × Base Enclosure (Aluminium)
1 × Plate (PVD Coated Brass)
1 × wilba.tech WT65-F or WT65-FX PCB
1 × wilba.tech WT-USB-C extension PCB
8 × RW Black M2×6 T10 Fixtures (case)
10 × RW Black M2×4 T10 Fixtures (8x plate, 4x daughterboard)
6 × RW Black M2×3 T10 Fixtures (hotswap PCB only)
6 × RW Black M2×3 CSK T6 Fixtures (hotswap PCB only)
6 × RW Black M2×3.5 Spacers (hotswap PCB only)
1 × RW 65-A Feet
1 × XO Switchpuller
1 × RW T10 Torx Tool
1 × RW T6 Torx Tool
1 × RW Black Metal End USB-C to USB-A braided cable (USB 3.0) - 1.5m
1 × Various Packaging
TECHNICAL SPECS
WEIGHT AND DIMENSIONS
Weight: 1.56 kg (3.44 pound)
Front height: 1.92 cm (0.75 inch)
Width: 32.08 cm (12.63 inch)
Depth: 11.89 cm (4.68 inch)
GENERAL
7.0° slope
Two-piece bead-blasted anodized aluminium enclosure
Top-mounted PVD coated brass plate
USB-C interface
WT65-F or WT65-FX Jules designed by wilba.tech. QMK compatible PCB and fully programmable with VIA configurator
Follow me on Instagram
Website: zambumon.com
Wilba: wilba.tech
« Last Edit: Sat, 14 March 2020, 10:16:13 by Zambumon »
Offline Zambumon
    • Keyset projects
Re: [IC] Zambumon Jules Bespoke Customer 65% Mechanical Keyboard
« Reply #1 on: Sun, 31 March 2019, 17:00:31 »
stan loona
Offline SolidCactus
« Reply #2 on: Sun, 31 March 2019, 17:01:53 »
Looks awesome! I have been waiting for this one to pop up since I saw it in a few renders!
Seems to have a lot about Eurovision though and also lots of interest links to read through all the details  :p
« Last Edit: Sun, 31 March 2019, 17:05:36 by SolidCactus »
Offline cijanzen
« Reply #3 on: Sun, 31 March 2019, 17:02:35 »
Much ambition, such responsibility!
Offline Zambumon
    • Keyset projects
« Reply #4 on: Sun, 31 March 2019, 17:03:25 »
can't wait for the group buy
Offline Zambumon
    • Keyset projects
« Reply #5 on: Sun, 31 March 2019, 17:04:50 »
Good idea. Thanks!!
Offline DubbleYew
« Reply #6 on: Sun, 31 March 2019, 17:05:36 »
Congrats. You just made me Google how much a Eurovision ticket costs.
Sent from my SM-G955F using Tapatalk
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #7 on: Sun, 31 March 2019, 17:07:00 »
With all the key copyrights on these colours etc I'm expecting a strong price. Also hope that the Eurovision winner won't negatively influence the GB
« Reply #8 on: Sun, 31 March 2019, 17:12:46 »
Note: this keyboard cannot be built using Nathan Kim Specs due to some technical issues during the design phase.
im out
Offline lolafineday
« Reply #9 on: Sun, 31 March 2019, 17:14:29 »
Is this April fools or just a bad board?
jk
Offline Zambumon
    • Keyset projects
« Reply #10 on: Sun, 31 March 2019, 17:14:32 »
Probably less than a keyboard.
Offline Zambumon
    • Keyset projects
« Reply #11 on: Sun, 31 March 2019, 17:15:28 »
Great Britain won't be negatively influenced by the Zambumon Jules Bespoke Customer 65% Mechanical Keyboard.
Offline Zambumon
    • Keyset projects
« Reply #12 on: Sun, 31 March 2019, 17:16:19 »
im out
You were already out considering that you said that you wouldn't be purchasing any keyboard anymore.
Offline indiceiris
« Reply #13 on: Sun, 31 March 2019, 17:24:01 »
no pc
no gasket
is this even 2019
> nice april fools
Offline indiceiris
« Reply #14 on: Sun, 31 March 2019, 17:24:14 »
looks good though
Offline OtherAndrew
« Reply #15 on: Sun, 31 March 2019, 17:31:31 »
how do i cook meatball
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #16 on: Sun, 31 March 2019, 17:36:00 »
« Last Edit: Sun, 31 March 2019, 17:53:26 by zekkin »
Offline Zambumon
    • Keyset projects
« Reply #17 on: Sun, 31 March 2019, 17:38:18 »
no pc
no gasket
is this even 2019
> nice april fools
Apologies, but I'm not interested on inferior plastic materials.
Offline Zambumon
    • Keyset projects
« Reply #19 on: Sun, 31 March 2019, 17:40:31 »
im out
this is correct
Offline Starston3
« Reply #20 on: Sun, 31 March 2019, 17:43:31 »
Más Español por favor.
Offline Zambumon
    • Keyset projects
« Reply #21 on: Sun, 31 March 2019, 17:44:30 »
Entre nós en galego.
Offline NRbigfoot
« Reply #22 on: Sun, 31 March 2019, 17:49:03 »
Haha yes
This is the best IC I've seen yet!
HBCP | FLX Virgo | aanzee | Mira SE | Leaf 80 | HHKB pro 1 | qxp | Rukia | IDB60 | equinox | No1Rev1 | Whale | Montage | 268.2 | Anniversary Whale | Jer80 | Evolv
Offline Zambumon
    • Keyset projects
« Reply #23 on: Sun, 31 March 2019, 17:51:52 »
Haha yes
Sí, please check the HI-RES computer generated images on the IC by clicking on them!
Offline InvidiousIgnoramus
« Reply #24 on: Sun, 31 March 2019, 18:07:28 »
Hello yes I like keyboard you sell? I have many moneies for purchase
I long for the day when I find a beamspring. (At a not insane price)
Offline Zambumon
    • Keyset projects
« Reply #25 on: Sun, 31 March 2019, 18:08:24 »
Ask a responsible adult, not me.
Offline snelltrail
« Reply #26 on: Sun, 31 March 2019, 18:12:42 »
Hoping that this goes the way of Jambuman's other April Fool's projects...
Offline Zambumon
    • Keyset projects
« Reply #27 on: Sun, 31 March 2019, 18:13:19 »
I don't know what you are talking about.
Offline cijanzen
« Reply #28 on: Sun, 31 March 2019, 18:15:02 »
Probably some ham-fisted keycap set that a real designer made. They’re probably just confused…
Offline talizman
« Reply #29 on: Sun, 31 March 2019, 18:16:37 »
It's a "wet dream" of a KB. Amazing how it looks, simultaneously, VERY new and, yet, VERY familiar, at the same time.
I need to check my calendar for the availability of funds - What's tomorrow's date?
Offline snelltrail
« Reply #30 on: Sun, 31 March 2019, 18:18:54 »
Now you're just telling porkies!
Offline Zambumon
    • Keyset projects
« Reply #31 on: Sun, 31 March 2019, 18:21:04 »
GMK Jamón is a great set. Hope Zambumon releases a V2
Offline Starston3
« Reply #32 on: Sun, 31 March 2019, 18:25:05 »
R2 wen?
Offline Vigrith
« Reply #33 on: Sun, 31 March 2019, 18:27:21 »
Só participo no GB se for o Xondat a fazer a produção e inspeção de qualidade.
Offline Zambumon
    • Keyset projects
« Reply #34 on: Sun, 31 March 2019, 18:27:23 »
R2 wen?
Yes, the keyboard is gluten free.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #35 on: Sun, 31 March 2019, 18:44:40 »
NE brass weight avail
Offline Zambumon
    • Keyset projects
« Reply #36 on: Sun, 31 March 2019, 18:46:10 »
No. Reason is in the OP.
« Reply #37 on: Sun, 31 March 2019, 18:49:07 »
ne paper weight avail
Offline otanishock
  • ファーストラブ
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #39 on: Sun, 31 March 2019, 18:57:03 »
can you please be more describing of the Zambumon Minimal Contact™ Top Mounted mounting kthxbai
Offline cijanzen
« Reply #40 on: Sun, 31 March 2019, 19:00:27 »
can you please be more describing of the Zambumon Minimal Contact Top Mounted mounting kthxbai
Once he gets prototypes plz
Offline Zambumon
    • Keyset projects
« Reply #41 on: Sun, 31 March 2019, 19:01:29 »
Waiting for prototypes.
Offline Wilba
    • wilba.tech
« Reply #42 on: Sun, 31 March 2019, 19:05:21 »
i am demanding of answers now so i can decide whether buying is to happen and to commense saving for this or for other thing
pls attach 3d moddels
Offline PikaJoyce
« Reply #43 on: Sun, 31 March 2019, 19:51:49 »
Nice
Offline walie
« Reply #44 on: Sun, 31 March 2019, 20:25:41 »
No ISO no buy
Offline derznation
« Reply #45 on: Sun, 31 March 2019, 20:28:37 »
Neat
Offline Pwner
  • soon™
Offline appaboy
« Reply #47 on: Sun, 31 March 2019, 20:48:12 »
Looks like the MEME. Nice
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline Jinnnxxu
  • U only live once
« Reply #48 on: Sun, 31 March 2019, 21:04:29 »
Nicccce!! GL!!
Ins: Jinnnxxu     Discord:Jinnnxxu#9644
Exclusive: E8V1 | E7V1 x14 | E7-VX | E6V2 x1 | E6V2 PE x7 | E6.5 x9 | E7SE x3 | E8.5 x5
Matrix: 1.0RE | 1.2RE | Abel | Abel+ | Cain | 2.0 x8 | 2.2 x8 | Abel-x x4 | M6 x2 | 1.2OG x15 | Project F x2 | 2.0AD x15 | Noah x3 | Mr. Hat x3 | 2.0VK x1
Rama: M60-A x4 | M65-A x2 | M6-A 88edition | M6-B | KOYU x3 | M60-A SEQ2 X4 | M6-C x2 | U80 x5 | M10-C | M6-C | M60 LNY x2 | M60 Olivia x2 | M65-B x5
FOX: Leaf 80 x4 | Leaf 60 x4 | Key65 x5      TGR:Jane V2 | 910RE | Jane V2 CE x2     Percent: Canoe x3 | Maze x2 | Skog lite | Canoe FE x2
Others: Mira SE x2 | Jermini | C225 x2 | INETT Cross x2 | Kira 80 | Kira 60 | Zephyr 65 R2 | Space 65 x2 | Volcano 660 x3 | INETT Square80 x4 | INETT Square68 x6 | FMJ 80 x2 | Keycult No.2 x1 | Thermal x2
