Author Topic: [IC] Zambumon Jules | Live at RAMA WORKS® FOUNDRY  (Read 113427 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] Zambumon Jules | Foundry Announcement
« Reply #150 on: Thu, 02 May 2019, 17:24:31 »
I see one of the extras available is "stabilizers". Can we reasonably infer from this that the long awaited Rama stabs will be ready to buy with Jules (if so, very excite), or will it just be regular Cherry/GMK stabs?
GMK screw-ins. RAMA has been very transparent with their upcoming releases and if there's any development regarding the stabs, it will be posted through at the proto(type) blog.
Offline Takata
« Reply #151 on: Thu, 02 May 2019, 17:59:24 »
How many units?
Offline Zambumon
    • Keyset projects
« Reply #152 on: Thu, 02 May 2019, 18:01:46 »
Offline mrpetrov
« Reply #153 on: Thu, 02 May 2019, 18:03:13 »
Got it, thanks!
Offline Nevermore012
« Reply #154 on: Thu, 02 May 2019, 19:05:02 »
when this will be available  :D
Offline eyedrop
« Reply #155 on: Thu, 02 May 2019, 22:15:02 »
Are you planning to run this on RAMA's store?
Sent from my Pixel 3 using Tapatalk
Offline adxlk
« Reply #156 on: Thu, 02 May 2019, 22:36:30 »
Zambu, any possibility to add nautilus nightmare's green to the case color options?
Offline Zambumon
    • Keyset projects
« Reply #157 on: Fri, 03 May 2019, 05:00:26 »
That's the idea.
Unlikely. I'd like to lock the colors wit the 4 current ones.
Offline Moridin
    • Infinite Diaries
« Reply #158 on: Fri, 03 May 2019, 06:37:25 »
Looks like I won’t have much choice in colours...
218537-0
Offline vicissitude
« Reply #159 on: Fri, 03 May 2019, 09:31:22 »
Will there be a proxy in US or Asia?
Offline Zambumon
    • Keyset projects
« Reply #160 on: Fri, 03 May 2019, 09:56:55 »
The group buy will be done in a similar way as it was with the M60-A. The orders will be fulfilled by Rama Works.
Offline petamva
« Reply #161 on: Fri, 03 May 2019, 10:36:15 »
Sorry if this has been asked before (didn't go through all 4 pages of comments) but is there any weight estimation?
Also i have to admit that the design looks amazing, so clean and minimal...
Once again great work Zamb!
Can't wait for the GB!
Offline Zambumon
    • Keyset projects
« Reply #162 on: Fri, 03 May 2019, 10:52:35 »
Around 1.2 Kg
Offline frankh
« Reply #163 on: Fri, 03 May 2019, 15:36:14 »
boy so much choice. will pricing on jules be known when thermal starts? between these two and polaris ( heaper I know) I‘ll have to choose two out of three I‘m afraid.
Offline pcire
« Reply #164 on: Fri, 03 May 2019, 16:02:51 »
I’m on the same spot
Offline adxlk
« Reply #165 on: Fri, 03 May 2019, 19:05:14 »
deleted
« Last Edit: Mon, 06 May 2019, 07:33:28 by adxlk »
Offline reidd
« Reply #166 on: Mon, 06 May 2019, 10:52:32 »
Zambumon, any chance we could get Kuro PVD as on option for the plate?   ;D
Offline Jaxxstatic
  • Haptic Recon
« Reply #167 on: Mon, 06 May 2019, 23:26:17 »
Any chance for Hangul sublegends?
But really, so glad this is gonna be unlimited. The curves are ridiculous. Must cop.
Offline adxlk
« Reply #168 on: Mon, 06 May 2019, 23:35:47 »
hangul wait what? xd
Offline Zambumon
    • Keyset projects
« Reply #169 on: Tue, 07 May 2019, 06:34:12 »
I think that's an MT3 Serika joke.
Offline rdg
« Reply #170 on: Tue, 07 May 2019, 22:44:31 »
What layouts does the "standard" plate support - spilt space bar support?
Offline Zambumon
    • Keyset projects
« Reply #171 on: Wed, 08 May 2019, 00:04:32 »
No. I won't be offering split spacebar support.
Offline Carpelos
« Reply #172 on: Wed, 08 May 2019, 01:03:50 »
No green case?
Nautilus Nightmares combination with rose gold...no
« Last Edit: Wed, 08 May 2019, 01:14:23 by Carpelos »
Offline adxlk
« Reply #173 on: Wed, 08 May 2019, 02:48:38 »
No green case?
sadly not, that would be when Naughty Nights is in gb, i think
Offline sevenseacat
« Reply #174 on: Wed, 08 May 2019, 03:07:48 »
Well that's a bummer and maybe a dealbreaker.
Offline Macmutant
« Reply #175 on: Wed, 08 May 2019, 03:18:41 »
Agreed. This is a disappointment. Definitely less excited for it.
« Reply #176 on: Wed, 08 May 2019, 10:01:07 »
i can't even be mad at split spacebar people because i'm a split spacebar user
but zambu knows i don't have the cash anyway
Offline Zambumon
    • Keyset projects
« Reply #177 on: Sun, 12 May 2019, 05:07:48 »
The PCB doesn't support split bars. For Verne, my request for Wilba was "remove as many things as possible, I don't want a cheese plate". I don't use split spacebars (Alice aside), and the keyboard kit won't come with one.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #178 on: Sun, 12 May 2019, 05:26:26 »
Depending on pricing I will take part in this GB — I've always enjoyed your work Zambumon, and I'm delighted to see you foray into creating canvases for your keysets.
Offline Zambumon
    • Keyset projects
« Reply #179 on: Sun, 12 May 2019, 05:32:58 »
And regarding split spacebars, alternate layouts: the M65-A for me was almost a deal breaker. The RGB light leaking from everywhere, having to spend time aligning the switches, the uneven look the plate had (you could see the PCB in some parts)...
Definitely not my cup of tea.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #180 on: Sun, 12 May 2019, 05:41:36 »
Offline Zambumon
    • Keyset projects
« Reply #181 on: Sun, 12 May 2019, 05:43:33 »
Please remove more stuff from the PCB  :))
Offline cijanzen
« Reply #182 on: Sun, 12 May 2019, 07:32:56 »
Take out per-switch led support except caps lock!
Offline longnt
« Reply #183 on: Sun, 12 May 2019, 08:49:31 »
Can u let me know how weight is it?
Offline LXVRGS
« Reply #184 on: Sun, 12 May 2019, 08:51:53 »
scroll up dude..
around 1.2kg per Zambumon
Offline longnt
« Reply #185 on: Sun, 12 May 2019, 08:53:07 »
scroll up dude..
Thanks bro
Offline AlexAtPanc
    • Panc Interactive
« Reply #186 on: Sun, 12 May 2019, 09:02:31 »
Excited for this boi  ;D
Offline Macmutant
« Reply #187 on: Sun, 12 May 2019, 23:20:52 »
Thank you for responding. I had the idea of building this board with Nautilus Nightmares and split space. It just seems like such an intense combination. Knowing your reasons for making the design decisions you have helps me appreciate your goals for the board. Also feel valued that you take the trouble to explain. Looking forward to following along with development. Thanks again!
Offline suparnemo
« Reply #188 on: Thu, 16 May 2019, 19:08:39 »
Is there a timeline for when this might happen?
Offline Vireca
« Reply #189 on: Tue, 21 May 2019, 03:36:22 »
Any price idea?
Offline cinxelo
« Reply #190 on: Tue, 30 July 2019, 21:07:43 »
Hey, I'm exactly 432365 months late to the party. Just kidding, but seriously would love to get updates on this beautiful board :D
I saw the Rama Foundry site listing for both this and the Thermal and see that wilba is adding hot swap as an option to the Thermal. Any chance this will also be added as an option for your Jules, since the PCB is made by wilba as well?
Offline Gbanek
« Reply #191 on: Fri, 09 August 2019, 21:37:27 »
Any renders of the rose gold?!?
Offline JerkChicken456
« Reply #192 on: Sat, 10 August 2019, 01:51:24 »
yeah would like to see the rose gold as well. i need some form of pink to add in my collection
Offline vidoardes
« Reply #193 on: Sat, 10 August 2019, 13:12:20 »
Is there really no ISO support?  :'(
Offline sachin3767
« Reply #194 on: Fri, 16 August 2019, 06:49:31 »
Came to ask this but am guessing not based on the 'cheese plate' comment. shame, the case is clean af.
 Whitefox|Granite    Tex Yoda II     Exent | dev/tty      MX Master       Planck|Big Bang
Offline konstantin
  • Formerly constexpr
« Reply #195 on: Fri, 16 August 2019, 14:03:22 »
no split backspace
literally unusable
reported for harassment
Offline Xynerorias
  • Lubin' with glicerin
« Reply #196 on: Fri, 16 August 2019, 17:32:55 »
no split backspace
literally unusable
Split backspace is for people who make twice the mistakes
Sent from my ONE A2001 using Tapatalk
Offline SUB01
« Reply #197 on: Fri, 16 August 2019, 22:40:12 »
This might have already been said but... If it's a fixed layout non-cheese pcb anyway, will there be hotswap support?
« Reply #198 on: Fri, 16 August 2019, 22:45:09 »
no
Offline SUB01
« Reply #199 on: Sat, 17 August 2019, 01:00:14 »
no
icrievrytim
edit: if it uses the wt-60b pcb couldn't it also use the wt-60bx pcb which is hotswap? The new Thermal has compatibility for both so it should theoretically be possible right?
edit2: I'm dumb it doesn't use wt-60b it uses wt-60 jule edition and its the wt-60b that is hotswap. :c
« Last Edit: Sat, 17 August 2019, 07:23:42 by SUB01 »
