Author Topic: [IC] Zambumon Jules | Live at RAMA WORKS® FOUNDRY  (Read 113428 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] Zambumon Jules | Foundry Announcement
« Reply #200 on: Sat, 17 August 2019, 10:53:16 »
This might have already been said but... If it's a fixed layout non-cheese pcb anyway, will there be hotswap support?
no
You are wrong.
Offline SUB01
« Reply #201 on: Sat, 17 August 2019, 12:48:56 »
no
You are wrong.
THE LORD HAS SPOKEN
OUR LORD AND
« Reply #202 on: Sat, 17 August 2019, 17:00:01 »
no
You are wrong.
this is not what you told me a few weeks back but we all living
Offline bthezebra
« Reply #203 on: Sat, 17 August 2019, 17:38:51 »
no
You are wrong.
Show the receipts
« Reply #204 on: Sat, 17 August 2019, 18:14:23 »
no
You are wrong.
Show the receipts
nope it actually turns out i was wrong and i was talking to someone else about a different board
there's no mention of it in my DM history with zambu
Offline ramblinrose
« Reply #205 on: Sat, 17 August 2019, 20:51:27 »
Looking forward to this one! I always loved the curves and design on the Verne so it is nice that Jules will be an open group buy. Any chances of plate choices besides brass?
Offline SUB01
« Reply #206 on: Sun, 18 August 2019, 04:00:03 »
Hey it takes a lot to admit a mistake. I can respect that. Now give us group buy or riot
Offline Zambumon
    • Keyset projects
« Reply #207 on: Sun, 18 August 2019, 05:27:49 »
We will see
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #208 on: Sun, 18 August 2019, 08:10:18 »
Man this a beautiful board for sure, which to me makes the fixed layout design even more of a shame IMO. I mean I get it, having a fixed layout on a board makes for a much better building experience & tighter end product, but having just one fixed layout really kills it for me & I'm sure some others. Has any thought been put into making alternate layout options available or is that completely off the table for this kit? I see that you are using a seperate plate with this kit. If there was the option to just buy a plate that did not have a fixed layout for this, even if I had to hunt down a compatible PCB, I'd be a lot more likely to consider jumping on one of these.
Offline Zambumon
    • Keyset projects
« Reply #209 on: Sun, 18 August 2019, 08:30:19 »
I like fixed plates, and we are offering a hotswap PCB and that will be the default configuration. For me, the deal breaker would be not having a fixed plate.
Offline Rob27shred
« Reply #210 on: Sun, 18 August 2019, 08:46:29 »
Honestly I do get it, I would go fixed plate over universal anyday if the fixed plate fit my layout preferences. I was just curious if there was any possibility of a fixed plate with a non standard layout or universal plate being offered as an add on, but you pretty much answered my question indirectly with your last line. Anyways the board is definitely beautifully designed (seriously I love the shape of this case!), but just not for me with the fixed layout. GL with the project moving forward man!
Offline ramblinrose
« Reply #211 on: Sun, 18 August 2019, 08:48:48 »
We will see
Cool - even just aluminum as another option would be great as it's a bit softer than brass. I like brass, but it is a bit too firm and loud for a board I'd use all day at work. POM is a great (and durable) option as well that has a great sound and soft bottom out.
Offline Mekuno
« Reply #212 on: Sun, 18 August 2019, 11:48:30 »
We will see
I agree, I'd honestly be all over this if it just had split bs.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #213 on: Sun, 18 August 2019, 12:25:26 »
Zambumon is being unintentionally vague.
Fixed layout plate is definitely happening. Offering a plate that supports split backspace and stepped caps lock is under consideration.
Offline Rob27shred
« Reply #214 on: Sun, 18 August 2019, 12:47:20 »
This is great to hear, thanks for the heads up Wilba! I can live without a tsangan bottom row in all honesty, but split backspace is pretty much a necessity for me. It's so ingrained in my typing style at this point I have actually programed any board I got with a full backspace to use that as the pipe key & the pipe key as backspace LOL.
Offline sachin3767
« Reply #215 on: Sun, 18 August 2019, 16:46:39 »
Any chance of ISO? :,(
 Whitefox|Granite    Tex Yoda II     Exent | dev/tty      MX Master       Planck|Big Bang
Offline jooobe
« Reply #216 on: Sun, 18 August 2019, 17:14:22 »
Sleek, hopefully not 360$
Sent from my SM-N960F using Tapatalk
Offline break
« Reply #217 on: Sun, 18 August 2019, 18:01:33 »
For a Rama Works 65%? The Thermal is a 60% for $360, the Koyu sold at what, $400?
IMO it's likely this will be 4 bills, and it'll sell regardless.
Offline jooobe
« Reply #218 on: Sun, 18 August 2019, 18:07:02 »
Cries is poor
Offline ShadeDream
« Reply #219 on: Sun, 18 August 2019, 19:20:54 »
This going to be hotswap only or have a solder-able PCB option also?
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #220 on: Sun, 18 August 2019, 19:55:55 »
I like the roundness you've been doing with your cases :cool:
Offline Jetstream
« Reply #221 on: Wed, 13 November 2019, 07:48:52 »
ne update avail??
Offline Zambumon
    • Keyset projects
« Reply #222 on: Wed, 13 November 2019, 15:41:44 »
ne update avail??
Major case redesign with:
- Seamless profile
- Centered USB-C daughterboard
- Rama Works rubber feet
- Rama Works torx screws
- Hotswappable PCB
- Back now has my glyph
- Mounting points tweaked
Available case finishes should be:
- Kuro (black): works with almost any set, elegant and simple.
- Navy (dark blue used for the RAMA × Striker Fuji-san keycaps): should look great with Nautilus, or Striker
- Halt (Wilba's red): should look great with Jamón, Burgundy, WoB
- Bronze: should look great with Sandstorm, WoB
- Plates will be PVD coated
Offline jooobe
« Reply #223 on: Wed, 13 November 2019, 15:46:31 »
ne update avail??
- Seamless profile
- Hotswappable PCB
Sounds dope
Offline Kerasan
« Reply #224 on: Wed, 13 November 2019, 15:48:31 »
ne update avail??
- Seamless profile
- Hotswappable PCB
sad to see the removal of rose gold, but very interested in bronze.
GL for project Zambu.
Offline Starston3
« Reply #225 on: Wed, 13 November 2019, 16:45:01 »
Bronze could be renamed SAND to keep the 4 letter word for colours. Just my 2 cents.
Offline Zambumon
    • Keyset projects
« Reply #226 on: Wed, 13 November 2019, 18:05:57 »
Good.
Offline Mekuno
« Reply #227 on: Wed, 13 November 2019, 18:07:22 »
ne update avail??
- Seamless profile
- Hotswappable PCB
I like everything except for having no more rose colour, however Bronze might look interesting. Also I am not seeing a split BS support but considering M65-B is supporting somewhat of a full or split BS layout I am hoping this would be the case as well.
« Last Edit: Wed, 13 November 2019, 18:09:57 by mikenogo »
Offline wonilcho
« Reply #228 on: Wed, 13 November 2019, 21:11:33 »
ne update avail??
- Seamless profile
- Hotswappable PCB
Wish you could've kept the more vibrant blue of Lake over Navy, but I guess this is fine too.
Offline blizzara01
« Reply #229 on: Wed, 13 November 2019, 21:28:30 »
When is the estimate gb date? After Thermal has been shipped?
Offline suparnemo
« Reply #230 on: Wed, 13 November 2019, 22:44:49 »
Any chance for rama works mute for this?
Getting one either way for use with striker :)
Offline ShadeDream
« Reply #231 on: Thu, 14 November 2019, 08:11:44 »
So... any chance on solderable PCBs?
« Last Edit: Thu, 14 November 2019, 13:47:25 by ShadeDream »
Offline Zambumon
    • Keyset projects
« Reply #232 on: Thu, 14 November 2019, 09:36:15 »
No.
Offline Hell-es
« Reply #233 on: Fri, 15 November 2019, 06:19:32 »
I guess no love for Milk?
Offline whyamihere
« Reply #234 on: Fri, 15 November 2019, 09:47:44 »
yes
Offline lookid
« Reply #235 on: Fri, 15 November 2019, 14:27:25 »
Milk version [e-white] would be superb nice!  :thumb:
VB
Offline ttom
  • Formerly tvaro
« Reply #236 on: Fri, 15 November 2019, 18:21:32 »
hopefully by the time this comes around i'll have funds for red to pair with metaverse, this board looks stunning
Hoarder Collector and designer
Classifieds
Offline eyedrop
« Reply #237 on: Fri, 15 November 2019, 19:48:51 »
I think Zambumon is lactose intolerant. ¯\_(ツ)_/¯
Sent from my Pixel 3 using Tapatalk
Offline jaonbe
« Reply #238 on: Sun, 17 November 2019, 14:20:40 »
From where will this be shipped?
Offline dydy124
« Reply #239 on: Sat, 30 November 2019, 23:47:37 »
+ 1 for plz split backspace
Offline Zambumon
    • Keyset projects
« Reply #240 on: Sun, 01 December 2019, 04:37:23 »
Australia
Not for the hotswap version.
I'm not lactose intolerant.
Offline vsrnth
« Reply #241 on: Sun, 01 December 2019, 06:36:53 »
Will there be solderable pcb's?
Sent from my SM-G975F using Tapatalk
Offline Zambumon
    • Keyset projects
« Reply #242 on: Sun, 01 December 2019, 10:33:01 »
Offline farmisen
« Reply #243 on: Mon, 02 December 2019, 02:53:47 »
Good.
Neat.
Offline hq
« Reply #244 on: Mon, 02 December 2019, 08:40:10 »
bump for ISO  :thumb:
Offline Zambumon
    • Keyset projects
« Reply #245 on: Mon, 02 December 2019, 08:43:47 »
Hotswap PCB. Fixed layout.
Offline Moridin
    • Infinite Diaries
« Reply #246 on: Mon, 02 December 2019, 08:54:43 »
Any news when approx. Jules will be open to pre-orders, so we can organise our budgets accordingly?
Offline Zambumon
    • Keyset projects
« Reply #247 on: Mon, 02 December 2019, 08:59:41 »
No concrete date yes, but I'd say now would be a great moment to start doing that.
Offline breckstar
« Reply #248 on: Thu, 05 December 2019, 11:46:14 »
Any renders of redesign or waiting for it to go live?
Edit: NVM, checked IG.
Offline ever9415
    • EVER STORY
« Reply #249 on: Thu, 05 December 2019, 17:39:13 »
You haven't started GB yet, have you?
I'll be waiting.
