Author Topic: [IC] Return 60% kustom keyboard !(GB will open on tomorrow)  (Read 26715 times)
Offline sakodo
Re: [IC] Return 60% kustom keyboard !(prototype comes)
« Reply #50 on: Sat, 22 June 2019, 20:36:05 »
This looks great! What is the elevation angle, is it 5 or 7?
Offline Water lee
« Reply #51 on: Sat, 22 June 2019, 22:17:59 »
7
make it better!
Offline Water lee
Re: [IC] Return 60% kustom keyboard !(prototype is making)
« Reply #52 on: Sun, 23 June 2019, 07:55:48 »
Delay so long ,prototype will get in my hands tomorrow ! :thumb:
Super interested, seems cool. Have you got the proto yet?
Yep
Looks awesome!  :thumb: Do you have an estimate date for gb?
24th! :thumb:
Awesome  ;D. Definately going to join. Can we have a look at the bottom?
Updated bottom pic and PC case
make it better!
Offline ChilliGilly
« Reply #53 on: Sun, 23 June 2019, 08:00:27 »
Yep
24th! :thumb:
Nice!
Pictures of a full build and sound test?
Offline Water lee
« Reply #54 on: Sun, 23 June 2019, 09:15:52 »
One more things,PCB support RGB underglow
This time when shipping i will take a picture to each buyer
:thumb:
« Last Edit: Sun, 23 June 2019, 09:17:33 by Water lee »
make it better!
Offline Ja3_420
« Reply #55 on: Sun, 23 June 2019, 09:28:38 »
:thumb:
Will this be a standard pcb? Like dz60?
Offline Ja3_420
« Reply #56 on: Sun, 23 June 2019, 09:29:52 »
Yep
24th! :thumb:
Looks great but the font on the brass weight (in my opinion) looks super cheap and I think having a different font or an option for blank weight would be great
Offline Water lee
« Reply #57 on: Sun, 23 June 2019, 09:48:04 »
Yep
24th! :thumb:
Yes blank is also allow ,it can use GH 60
make it better!
Offline NoEndGame
« Reply #58 on: Sun, 23 June 2019, 10:06:05 »
In.
Offline Water lee
« Reply #59 on: Sun, 23 June 2019, 23:49:51 »
GB will open tomorrow :thumb:
make it better!
Offline dav1k
Re: [IC] Return 60% kustom keyboard !(GB will open on tomorrow)
« Reply #60 on: Mon, 24 June 2019, 02:25:12 »
Where will I be able to purchase this at? Any details?
Offline Water lee
« Reply #61 on: Mon, 24 June 2019, 07:30:18 »
Will post on GB thread later . :thumb:
make it better!
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #62 on: Mon, 24 June 2019, 09:59:11 »
Have you done a typing test with the prototype? I'm curious to hear how this sounds.
Is there a reason you use an atypical design for this? Or do you just like how it looks?
Offline Water lee
« Reply #63 on: Mon, 24 June 2019, 10:17:23 »
Hi,sorry my pcb get some issue so not have solder it
thus,personally more like the different color match ,some people do the typical design so i want make it a little different
Then, i am newbie on keyboards .originally start at GH60 ,apologize again not have Professional recording equipment: )
« Last Edit: Mon, 24 June 2019, 10:21:56 by Water lee »
make it better!
Offline Water lee
make it better!
Offline crosscutgymnast
« Reply #65 on: Mon, 24 June 2019, 10:42:30 »
Ia it just me or the GB thread does not work
Offline Water lee
« Reply #66 on: Mon, 24 June 2019, 10:45:29 »
Wait mods to check it  : (
make it better!
Offline Water lee
« Reply #67 on: Mon, 24 June 2019, 21:48:22 »
Weird i have ask mods to check thread ,still no any reply :(
make it better!
Offline senryo
  • Problems are challenges.
    • Thic Thock
« Reply #68 on: Mon, 24 June 2019, 22:11:43 »
Can you at least list out the detail specification of the board here? Thanks!
« Reply #69 on: Mon, 24 June 2019, 22:12:41 »
Yes please that way we can see the specifics while the gb post gets approved
Offline Water lee
« Reply #70 on: Mon, 24 June 2019, 23:01:16 »
OKay,i will edit it later except the purchase link.
make it better!
Offline Water lee
« Reply #71 on: Mon, 24 June 2019, 23:22:48 »
Already open! :thumb:
make it better!
