Author Topic: [GB] Return 60% kustom keyboard(Shipping invoice send out )  (Read 78155 times)
Offline Water lee
« on: Mon, 24 June 2019, 10:39:11 »
Thanks everyone make this come true
IC:https://geekhack.org/index.php?topic=100143.0
This is water lee from HK ,my first keyboard was Reborn 60%  https://geekhack.org/index.php?topic=96959.msg2647951#msg2647951
Due to as a newbie on keyboard designe  i learned a lot from first buy and very sorry it cause trouble to orders apologize here !
But today  i am back and take this board come again  - Return 60%
If you want purchase ,please fill it  :thumb:
Alu:https://docs.google.com/forms/d/e/1FAIpQLSetq2ca5C9lX8HC3XrxD525a1KdKg-Mr9nzTLhSqj8b0fnlhg/viewform?usp=pp_url
Pc:https://docs.google.com/forms/d/e/1FAIpQLSeeJblMAt1lKBfNMDH5f2Mxru_XEIp6rvpNKXHVJLExnYz5eQ/viewform?usp=pp_url
Keyboard details :
                             * Full kits includes(Pcb/case /box/rubber/screws)
                             * We try PC case this time and do the pvd parts with it
                             * Pcb were support GH60 & have RGB underglow (it only will show on PC case )
                             * Pvd cant be 100% (perfect) it will have some flaw so make sure you are not care about
                             * will take pictures to each buyer when shipping their keyboard .
Price tag            Pc and alu case start at $280
More photos    : Pc case with 9009
        https://imgur.com/a/6LoV84W
                             color match
                             https://imgur.com/a/EVj07JQ
                             underglow light
                             https://imgur.com/a/cHROTvE
« Last Edit: Sat, 04 January 2020, 10:07:19 by Water lee »
make it better!
Offline crosscutgymnast
[GB] Return 60% kustom keyboard !
« Reply #1 on: Mon, 24 June 2019, 23:09:50 »
support GH60 so it should work with a zeal60?
« Last Edit: Mon, 24 June 2019, 23:14:32 by crosscutgymnast »
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [GB] Return 60% kustom keyboard !
« Reply #2 on: Mon, 24 June 2019, 23:22:13 »
Is it possible to get aluminum top and polycarbonate bottom, or polycarbonate top and aluminum bottom?
« Last Edit: Mon, 24 June 2019, 23:24:56 by tex_live_utility »
Offline Mcnos
    • GMK Fuyu
« Reply #3 on: Mon, 24 June 2019, 23:48:24 »
I like it,
reminds me of the alu Anne Pro cases
Offline japanesehorrorwriter
« Reply #4 on: Mon, 24 June 2019, 23:52:14 »
1) we are missing the crazy bracelets from the pics.
2) anyone who was in on a reborn can tell you the quality of the anode, weight, etc was all interstellar. I highly recc this GB runner. quality was amazing.
Offline Water lee
« Reply #5 on: Mon, 24 June 2019, 23:55:04 »
Thanks sir !
 :thumb: :thumb:
make it better!
Offline Water lee
« Reply #6 on: Tue, 25 June 2019, 00:02:25 »
Sorry not support it
make it better!
Offline Ja3_420
« Reply #7 on: Tue, 25 June 2019, 00:11:24 »
How much is shipping to eu? Is it included in the price tag?
Offline nasp
« Reply #8 on: Tue, 25 June 2019, 00:13:29 »
Will you release the plate file so those that want to use non-standard layouts (Boardwalk/Ergo) can make their own plates?
Offline Water lee
« Reply #9 on: Tue, 25 June 2019, 00:18:49 »
Sure
make it better!
Offline Water lee
« Reply #10 on: Tue, 25 June 2019, 00:20:18 »
It depends on the package,to eu may costs $40~$50
not include shipping fee
make it better!
Offline simon94s
« Reply #11 on: Tue, 25 June 2019, 00:37:21 »
when is the expected shipping date
Offline catamscott
« Reply #12 on: Tue, 25 June 2019, 00:58:19 »
looks really nice! super tempted to grab one
« Reply #13 on: Tue, 25 June 2019, 09:24:02 »
How tall is the front?
Offline kidpid
« Reply #14 on: Tue, 25 June 2019, 16:59:35 »
It's a shame that the pink aluminum and the PVD brass tops didn't make it from the IC renders. Those are definitely the two that I was looking at.
« Reply #15 on: Tue, 25 June 2019, 17:17:25 »
Zeal60 r4 support? Also just PVD gold? No silver or black?
Offline Water lee
« Reply #16 on: Tue, 25 June 2019, 22:45:42 »
make it better!
Offline Water lee
« Reply #17 on: Tue, 25 June 2019, 22:53:26 »
If zeal60 r4 can use on GH60 then also work on my case ,no silver
make it better!
« Reply #18 on: Tue, 25 June 2019, 22:58:34 »
Its technically the same siZe, screw holes, etc. But the zeal60 r4 is USB-C so is the port cutout big enough for a usb c connector
Offline damsenviet
« Reply #19 on: Tue, 25 June 2019, 23:43:17 »
Could we get an estimated timeline or shipping date?
Offline Water lee
« Reply #20 on: Tue, 25 June 2019, 23:56:47 »
I have test the type c ,is works .
make it better!
Offline Water lee
« Reply #21 on: Wed, 26 June 2019, 00:18:30 »
Already upload the led pictures
make it better!
Offline siijunn
« Reply #22 on: Wed, 26 June 2019, 01:19:48 »
Can you comment on the "trouble" he speaks of in the OP? It looks as if English isn't his first language so I don't want to overreact over something that most likely be nothing. Haven't found anything specific but when you spend $300 on a GB, you wanna be at least somewhat sure :P
« Reply #23 on: Wed, 26 June 2019, 01:31:48 »
no idea. I didn't have issues. it was well packed was fine for me.
Offline damsenviet
« Reply #24 on: Wed, 26 June 2019, 01:36:07 »
According to the thread (the reborn 60), it looks like the screw tap was too close to the wall of the enclosure. After screwing in the plate to the top case, the screw taps became visible. Luckily, they're not so visible with the caps on, but still a defect nonetheless. Hopefully he gave some clearance for the screws this time.
https://geekhack.org/index.php?topic=96959.100
According to the current prototypes of this keeb he has on hand, it doesn't look like its an issue and that's probably why he's running this as a reserved GB + he's double checking the parts. I don't want to discredit him too much tho – the keyboard for this thread is absolutely a stunner. The two piece top surface reminds me of percent studio's volt and the square 80% that's being worked on.
« Last Edit: Wed, 26 June 2019, 01:41:00 by damsenviet »
Offline Vireca
« Reply #25 on: Wed, 26 June 2019, 02:40:16 »
Whats ithe price?
Offline Water lee
« Reply #26 on: Wed, 26 June 2019, 03:53:21 »
make it better!
Offline Water lee
« Reply #27 on: Wed, 26 June 2019, 03:54:08 »
Yep,thanks sir
so this time i do that myself to make sure everything go well
make it better!
« Reply #28 on: Wed, 26 June 2019, 09:31:06 »
The Alu form says "pc" is an option for bottom color. Is that incorrect?
Offline GRWLKG
« Reply #29 on: Wed, 26 June 2019, 10:32:36 »
Do you happen to have any pictures for white on white? Thanks
Offline glubazoid
« Reply #30 on: Wed, 26 June 2019, 11:55:41 »
Anode on my Reborn keyboard was amazing, top and bottom matched almost perfectly. If I had money this round I'd jump on this GB
Offline Water lee
« Reply #31 on: Thu, 27 June 2019, 19:25:09 »
:thumb:
make it better!
Offline Water lee
« Reply #32 on: Thu, 27 June 2019, 19:26:32 »
Is fixed now ,can have pc bottom with aluminum top
make it better!
Offline Tyson
« Reply #33 on: Fri, 28 June 2019, 11:05:49 »
Hey Water Lee! I'm a big fan of the Reborn60, I cerakoted my board and it's going to be built by TaehaTypes soon. I was wondering if you could post the plate files for the Reborn60 somewhere. I would really like to test out a Polycarb plate and a half plate for the board!
Offline Water lee
« Reply #34 on: Fri, 28 June 2019, 23:58:39 »
For sure ,pm me you email address
make it better!
Offline nug
« Reply #35 on: Sat, 29 June 2019, 00:14:41 »
Nice looking board! Is there a rough time line for this?
Also, is the purple going to be the same as from Reborn60?
Offline EMC Labs
« Reply #36 on: Sat, 29 June 2019, 00:33:08 »
Really like the PC!
Offline Ja3_420
« Reply #37 on: Sat, 29 June 2019, 07:29:32 »
Joined gb!  :D. How much does the brass weight weigh?
Offline Water lee
« Reply #38 on: Sat, 29 June 2019, 10:35:25 »
Same
make it better!
Offline Water lee
« Reply #39 on: Sun, 30 June 2019, 08:37:09 »
Last day to purchase :thumb:
make it better!
Offline siijunn
Re: [GB] Return 60% kustom keyboard !Last day to purchase
« Reply #40 on: Mon, 01 July 2019, 01:41:06 »
Wish I had the funds for this. In the market for a decent 60% and this would have hit the spot. Good luck!!
Offline Water lee
« Reply #41 on: Mon, 01 July 2019, 08:06:27 »
Thanks man.last chance for this keyboard,wont have extra
make it better!
Offline nug
« Reply #42 on: Mon, 01 July 2019, 08:32:34 »
Is there a rough timeline for this GB?
Offline Little4Real
« Reply #43 on: Mon, 01 July 2019, 17:32:58 »
Joined the GB two days ago for a PC HHKB. Hopefully you can start invoicing soon!
Offline SantiGo
« Reply #46 on: Wed, 03 July 2019, 10:49:42 »
hi ALPS ?
Offline Water lee
Re: [GB] Return 60% kustom keyboard(invoice check)
« Reply #48 on: Thu, 04 July 2019, 20:24:39 »
All invoice send out ,please check and pay in time
we will go for this board :thumb:
Thanks.
make it better!
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #49 on: Fri, 05 July 2019, 01:00:43 »
Paid  :D
October can't come too soon !
