Author Topic: [IC] Return 60% kustom keyboard !(GB will open on tomorrow)  (Read 27331 times)
Offline Water lee
« on: Sun, 07 April 2019, 11:09:22 »
Hello everyone
GB thread :https://geekhack.org/index.php?topic=101332.0
This is water lee from HK ,my first keyboard was Reborn 60% .
Due to as a new on keyboard designe  i learned a lot from first buy and very sorry it cause trouble to orders
apologize here !
But today  i am back and take this board come again  - Return 60%
Some info here :
                         # PC case - we have try this time
                         # PVD silver and PVD gold -  we have find a factory do that finish this time .cost much time
                         # White color not anode
                         # Top mount .
just fill this form  for you options if you are interested in this :https://docs.google.com/forms/d/e/1FAIpQLSeFz1xt-8QdJTJwFbsYEV7AIjSAmXW91aLpg7mszmsvVAI1MA/viewform?usp=pp_url&entry.48536702=wkl&entry.931295863=PC&entry.216570695=pvd+silver
I will do some prototypes accroding that form .
Just leave you suggestion, we will consider it and make it come true if much people approval that  :thumb:
Thanks  all .
« Last Edit: Tue, 25 June 2019, 01:43:59 by Water lee »
make it better!
Offline Water lee
Re: [IC] Return 60% kustom keyboard !
« Reply #1 on: Sun, 07 April 2019, 11:11:07 »
Reserved
make it better!
Offline fcoury
« Reply #2 on: Sun, 07 April 2019, 11:14:39 »
Really dig the case, super interested.
Offline ChrisSwires
« Reply #3 on: Sun, 07 April 2019, 11:15:54 »
Do you have an exploded view?
Sent from my Pixel 3 using Tapatalk
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #4 on: Sun, 07 April 2019, 11:16:14 »
Got a target for price?
Offline nickaster1
« Reply #5 on: Sun, 07 April 2019, 12:21:50 »
Not trying to offend you but the side profile and the feet design looks almost identical to a cheapo Revo case that we all used back in the days for Pokers. I’d rather you take inspiration from Duck Poker (generic rectangle design with engraved branding) and go from there
Offline Water lee
« Reply #6 on: Sun, 07 April 2019, 21:35:18 »
Almost start at $260
make it better!
Offline Aerizu
  • Professional Lurker
« Reply #7 on: Sun, 07 April 2019, 22:16:50 »
Interested in PC or Aluminum HHKB top. Can you provide more details regarding planned plate layout support?
Offline senryo
  • Problems are challenges.
    • Thic Thock
« Reply #8 on: Mon, 08 April 2019, 10:15:43 »
Will the screw tap defect be resolved in this latest design this time?
Offline Water lee
« Reply #9 on: Tue, 09 April 2019, 11:37:11 »
Yes for sure
we will check each part on prototype
make it better!
Offline Water lee
Re: [IC] Return 60% kustom keyboard !(sort interested )
« Reply #10 on: Tue, 09 April 2019, 11:39:23 »
We will make prototype soon
so  leave you suggstion we may make it come ture
one for PC case  and two alu case ,then pvd color .
« Last Edit: Tue, 09 April 2019, 11:45:19 by Water lee »
make it better!
Offline vicissitude
« Reply #11 on: Tue, 09 April 2019, 11:42:50 »
interested.
Offline kidpid
« Reply #12 on: Tue, 09 April 2019, 15:08:23 »
I'd love to see PVD rose gold.
« Reply #13 on: Tue, 09 April 2019, 20:51:31 »
It would be very helpful to see an "exploded" view of the case (like this), because it's hard to tell how this is put together. It looks like there's an outer "tray", and an inner piece that includes both the plate and part of the bezel. Is that right?
« Last Edit: Wed, 10 April 2019, 23:35:11 by tex_live_utility »
Offline Water lee
make it better!
Offline ArchDill
« Reply #17 on: Wed, 10 April 2019, 23:37:55 »
It would be very helpful to see an "exploded" view of the case (like this/url]), because it's hard to tell how this is put together. It looks like there's an outer "tray", and an inner piece that includes both the plate and part of the bezel. Is that right?
Thanks.
I don't know about anyone else but I'd be interested in a PC or acrylic insert with an aluminum case.
That said, I agree with the other poster that I don't like the bottom of the case raised off the desk. If it is a side cutout like Koala/QXP that is fine. But empty space under the keyboard could make it louder.
Offline equalunique
« Reply #18 on: Thu, 11 April 2019, 00:14:04 »
Interested!
Sent from my LG-H918 using Tapatalk
Offline Water lee
« Reply #19 on: Thu, 11 April 2019, 07:51:25 »
Thanks.
Get you point we are try fix bottom side
thanks
make it better!
Offline hhkbp2
« Reply #20 on: Sat, 13 April 2019, 00:15:13 »
How does the weight look like?
Offline matrixzj
« Reply #21 on: Sat, 13 April 2019, 07:37:10 »
What is the angle for this keyboard ?
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline Marutks
« Reply #22 on: Sat, 13 April 2019, 18:43:20 »
I am interested in HHKB layout,     would it be possible to have ANSI plate?   (no cutouts for ISO enter)
ANSI enter + split backpace
Offline Water lee
« Reply #23 on: Sun, 14 April 2019, 22:06:17 »
Thanks.
We have changed the bottom side like this
but we may cant add weight for the bottom ,becasue the bottom was too thinly
make it better!
Offline Water lee
« Reply #24 on: Sun, 14 April 2019, 22:08:52 »
Yes,we have hhkb layout and split backspace (only one typical plate )
it should be cutotuts for iso enter but support ANSI too
make it better!
Offline Water lee
« Reply #25 on: Sun, 14 April 2019, 22:10:42 »
Glad see you again sir
is 6 degree.
make it better!
Offline Water lee
Re: [IC] Return 60% kustom keyboard !(Ready yo make prototype)
« Reply #26 on: Tue, 16 April 2019, 21:12:10 »
We are gonna make some prototypes
but still not decide which bottom we will use
if still no more suggestion we will keep orginal
make it better!
Offline gnhuy91
« Reply #27 on: Wed, 17 April 2019, 06:29:34 »
for pc wkl blocker version, I hope the plate will not have win key cutouts
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #28 on: Wed, 17 April 2019, 17:31:07 »
I'm really liking this design. Would it be possible to do a PC case with a aluminum insert?
« Reply #29 on: Wed, 17 April 2019, 21:40:02 »
it says in the OP that they're already planning on it
Offline Water lee
« Reply #30 on: Thu, 18 April 2019, 23:48:37 »
For sure ,we will have this options .
such as -  aluminum bottom with pc top
            -  pc bottom with aluminum top
               pc bottom with pvd top etc
all things will settle down when start GB (if enough people interested in this one )
make it better!
Offline Sshimosawa
« Reply #31 on: Fri, 19 April 2019, 12:33:27 »
This is 1000% a must buy for me.
Offline macclack
    • Macclack
« Reply #32 on: Fri, 19 April 2019, 13:22:23 »
This is great thank you. If you ever decide to do more renders, I would love to see what a PC case would look like with a pvd brass top and pvd brass plate. My guess is it would be really cool  :thumb:
Offline lolafineday
« Reply #33 on: Fri, 19 April 2019, 15:45:23 »
So is the mounting style final? I would love if this board is heavy I would love it. Brass bottom?
Offline Water lee
« Reply #34 on: Sun, 21 April 2019, 07:29:22 »
Top mount.
make it better!
Offline Battouseye
« Reply #35 on: Mon, 22 April 2019, 07:28:59 »
intrested
Offline Water lee
Re: [IC] Return 60% kustom keyboard !(prototype is making)
« Reply #36 on: Mon, 22 April 2019, 21:27:48 »
Prototype is making !!
make it better!
Offline Water lee
« Reply #37 on: Sun, 02 June 2019, 03:23:11 »
Delay so long ,prototype will get in my hands tomorrow ! :thumb:
make it better!
Offline victorpre
« Reply #38 on: Sun, 02 June 2019, 06:57:08 »
Nice, awaiting for proto pics
Offline Ja3_420
« Reply #39 on: Fri, 21 June 2019, 14:20:46 »
Super interested, seems cool. Have you got the proto yet?
Offline mikkochu
« Reply #40 on: Sat, 22 June 2019, 00:25:47 »
looks great! super interested.
Offline Water lee
« Reply #41 on: Sat, 22 June 2019, 09:12:21 »
Pictures updated !
make it better!
Offline Water lee
« Reply #42 on: Sat, 22 June 2019, 09:16:01 »
Yep
make it better!
Offline Ja3_420
« Reply #43 on: Sat, 22 June 2019, 09:27:10 »
Yep
Looks awesome!  :thumb: Do you have an estimate date for gb?
Offline Water lee
« Reply #44 on: Sat, 22 June 2019, 09:38:13 »
Yep
24th! :thumb:
make it better!
Offline Ja3_420
« Reply #45 on: Sat, 22 June 2019, 09:46:59 »
Yep
24th! :thumb:
Awesome  ;D. Definately going to join. Can we have a look at the bottom?
Offline Water lee
« Reply #46 on: Sat, 22 June 2019, 11:13:16 »
Yep
24th! :thumb:
GB thread will have more pictures .: )
make it better!
Offline ChilliGilly
Re: [IC] Return 60% kustom keyboard !(prototype comes)
« Reply #47 on: Sat, 22 June 2019, 11:55:58 »
Pictures updated !
Also very interested. What’s the approximate weight?
Gesendet von iPhone mit Tapatalk
Offline Water lee
« Reply #48 on: Sat, 22 June 2019, 12:23:01 »
Pictures updated !
Alu case plus brass switch and weight .almost 3kg~
make it better!
« Reply #49 on: Sat, 22 June 2019, 14:24:28 »
Looks great!
