Author Topic: [GB] EnjoyPBT Extended 2048  (Read 162932 times)
Offline SteffeMK
Re: [GB] EnjoyPBT Extended 2048
« Reply #250 on: Tue, 03 December 2019, 18:08:41 »
Is anyone else still waiting for a shipping notification from candykeys? This is getting a little silly.
Mine shipped last week and arrived at the post office today. I would try and contact them if your order hasn't shipped yet.
Skickat från min ONEPLUS A6013 via Tapatalk
Offline arremkay
« Reply #251 on: Wed, 04 December 2019, 00:54:02 »
Thanks for the reply. The answer was "tomorrow," as of last Thursday.
Offline geewiz
« Reply #252 on: Wed, 04 December 2019, 02:23:12 »
According to the tracking information, mine is almost here. I hope it's not just the base kit but all the others I ordered later, too.
Offline SteffeMK
« Reply #253 on: Wed, 04 December 2019, 02:34:34 »
Have you checked the spam folder? My first shipping invoice from candykeys ended up there. It might be under DP Tastatur Ausstattung UG if you search your mail.
« Last Edit: Wed, 04 December 2019, 02:36:15 by SteffeMK »
Offline geewiz
« Reply #254 on: Wed, 04 December 2019, 07:40:03 »
Happy to report that I took full delivery earlier. ;D Here's the result.
Offline biip
    • @biipmk
« Reply #255 on: Wed, 04 December 2019, 08:50:45 »
such a nice vintage look! I hope you like the set :thumb:
Offline geewiz
« Reply #256 on: Wed, 04 December 2019, 12:42:14 »
I LUV it! You did such a great job.
Offline arremkay
« Reply #257 on: Thu, 05 December 2019, 01:23:41 »
I did check the spam folder. Also the order status is "processing" on their website.  :(
Looking good!
Offline Kawamashi
« Reply #258 on: Thu, 05 December 2019, 04:41:05 »
I’m in the same situation.
Offline skmn
« Reply #259 on: Mon, 09 December 2019, 04:13:49 »
Someone else have issues with the ISO enter? It seems like somehow the keycap doesn't seat properly, which results in a feeling that the stabilizers get "stuck", and the key feels very sluggish. I put on a GMK enter key, and I did not have the same issue.
Offline skmn
« Reply #260 on: Mon, 09 December 2019, 04:17:11 »
« Last Edit: Mon, 09 December 2019, 04:19:50 by skmn »
Offline eskimojo
    • KeycapLendar
« Reply #261 on: Mon, 09 December 2019, 06:52:30 »
Sounds like it's warped. To check, place it flat on a surface and press on either side. You should be able to notice that the side you aren't pressing lifts up slightly.
To fix this, you need to heat the keycap with either hot water or a hairdryer, then press it flat. KBDfans has a video demonstrating this.
Offline biip
    • @biipmk
« Reply #262 on: Mon, 09 December 2019, 06:56:53 »
That's weird. They told me they made new molds for spacebars.
Does anyone have any issues with wrapped spacebars?
Offline ctrlshiftba
    • ctrlshiftba
« Reply #263 on: Mon, 09 December 2019, 07:01:24 »
Just checked mine and they are very straight and perfect.
I’ve heard it’s more an PBT issue than a mold issue. Like it warps afterwards or something????
Offline SteffeMK
« Reply #264 on: Mon, 09 December 2019, 07:01:37 »
My 6.25 is a little bit warped, 7u is pretty straight
Offline skmn
« Reply #265 on: Mon, 09 December 2019, 07:09:42 »
My spacebars were fine, but it seems like my ISO Enter key has issues. Anyone got an ISO board they could try their enter key on?
Offline eskimojo
    • KeycapLendar
« Reply #266 on: Mon, 09 December 2019, 07:11:12 »
My spacebars were fine, but it seems like my ISO Enter key has issues. Anyone got an ISO board who could try their enter key on?
From what I recall, I also had warping issues with my ISO enter. I don't remember having any issues with my spacebar though.
Offline supermunny
« Reply #267 on: Mon, 23 December 2019, 03:17:49 »
« Reply #268 on: Tue, 14 April 2020, 18:31:41 »
Would love to see this one re-run :)
Offline kapowaz
    • kapowaz industries
« Reply #269 on: Sun, 03 May 2020, 03:17:56 »
I too would love to see a re-run of this set. What are the chances we could get another IC to see if there’s enough interest to justify one?
Offline tymofiy
« Reply #270 on: Wed, 20 May 2020, 18:25:36 »
+1 for a re-run. I was looking for a clean pretty Applish keycaps and just felt in love with Biip's creation. Awesome job!
« Last Edit: Wed, 20 May 2020, 23:13:06 by tymofiy »
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #271 on: Wed, 20 May 2020, 23:08:02 »
I picked up a set from the original GB and I'm hoping this runs again, although I'd love to see it offered with an alternate color way, like Olivia ++ was. Maybe in a dark gray? Hmmmm???
Offline coffeeshopcoder
« Reply #272 on: Thu, 21 May 2020, 01:27:31 »
Oh I like idea very much !! This would be pretty cool ! I’d be down for that !
Offline nulltorious
« Reply #273 on: Thu, 21 May 2020, 01:36:46 »
Extended 2048 on Keycult No.1 Rev.1 Navy Blue
The set is not as warm as the picture, but more on the warm side which I like.  :)
Offline toniwonkanobi
« Reply #274 on: Fri, 19 June 2020, 08:49:12 »
Has the creator said whether this will ever run again? If so, when?
Edit: I am an idiot
Offline biip
    • @biipmk
« Reply #275 on: Fri, 19 June 2020, 09:16:57 »
Not this year on this profile :D
« Reply #276 on: Fri, 19 June 2020, 19:42:53 »
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #277 on: Sat, 27 November 2021, 22:23:12 »
To honor this legendary set, some of the OP images thought to have been lost forever are posted below.
Final numbers
Base kit563
Calc kit202
Icono kit379
Intl kit72
Nomad kit236
Six pack69
Torii kit270
Nav kit156
Thanks you all for the awesome support.
I should receive the samples very soon!
I will keep you in touch here :slight_smile:
<-- source
Offline ogp3
« Reply #278 on: Sun, 28 November 2021, 05:12:55 »
would LOVE this set to run again with epbt - mt3 sadly not my preferred profile
