Author Topic: [IC] Polaris - GB has begun  (Read 286084 times)
Offline whinmeister
Re: [IC] Polaris - Gasket 60% for $265
« Reply #200 on: Fri, 03 May 2019, 18:24:14 »
Oh my that red/gold combo is  :eek:
Offline dubious
  • 쏘쿨
« Reply #201 on: Fri, 03 May 2019, 18:37:07 »
intrigued
Offline b3nkei
« Reply #202 on: Fri, 03 May 2019, 18:59:50 »
Is it possible to get a stainless steel weight instead of brass?
Offline Kafka
  • i like clean things
« Reply #203 on: Fri, 03 May 2019, 20:10:11 »
I want SS too  :p
Offline born2relax
« Reply #204 on: Fri, 03 May 2019, 22:06:05 »
render of rose gold?
Offline spyruf
« Reply #205 on: Sat, 04 May 2019, 00:52:05 »
or silver PVD brass weight.
Offline ai03
  • I do not reply to PMs; contact me via website
    • Website
« Reply #206 on: Sat, 04 May 2019, 00:53:28 »
I want SS too  :p
Thought about it, but it would make price skyrocket so had to cancel.
As for PVD, I've never been super impressed by KBDfans' PVD quality, so decided to play it safe with matte + clear coat.
There's some floating around, but right now Kevinplus (The other person behind this project) is waiting on ano samples for more color-accurate renders.
Offline TuCZnak
« Reply #207 on: Sat, 04 May 2019, 01:22:50 »
I hate 60% but love this... 65%/75% variant when?
Offline nguyenhimself
« Reply #208 on: Sat, 04 May 2019, 01:44:17 »
So kind of curious on the colors again. Is space grey going to be like the new Macbook spacey grey? What kind of blue grey is it going to be and how deep a shade of red will the red be? I tried looking for some kbdfan stuff but it's hard to tell.
I assume it’s gonna be something similar to these renders.
« Last Edit: Sat, 04 May 2019, 01:46:21 by nguyenhimself »
Offline befbef
« Reply #209 on: Sat, 04 May 2019, 03:35:00 »
My guess the colors are only renamed and they are the same as the other kbd boards. If so, this is Tofu gray (space gray?) vs navy (blue gray)
Offline juaninamilli
« Reply #210 on: Sat, 04 May 2019, 11:19:58 »
You are correct. Kevin has stated this previously in discord. It may be the cause for the slight confusion, but his color naming seems a bit more accurate than it currently stands. For the Navy, at the very least.
Offline jrs
« Reply #211 on: Sun, 05 May 2019, 05:08:27 »
Does the WKL plate work with the HHKB layout?
Offline laserbeamspewpew
« Reply #212 on: Sun, 05 May 2019, 08:00:43 »
Yes but not with a PC case because you’ll see the switch holes in the corners.
« Reply #213 on: Sun, 05 May 2019, 09:04:39 »
You are correct in saying that you will see the switch holes, but that doesn’t mean it won’t work. There isn’t an HHKB dedicated plate, so the wkl plate is likely your best option.
Offline jrs
« Reply #214 on: Sun, 05 May 2019, 19:17:17 »
What about if I wanted to go with the standard top plate, not the WKL or HHKB top plate?  Would the WKL plate still be the best option?
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #215 on: Sun, 05 May 2019, 20:53:40 »
for the WKL plate
will it have the holes for the winkey?since it's also for HHKB?
Offline ai03
    • Website
« Reply #216 on: Sun, 05 May 2019, 23:28:38 »
for the WKL plate
Yes.
There is no HHKB plate, just WKL and Universal in terms of general compatibility. Your combination of plate and case top half will depend on what blockers you want, and what layout you want within the constraints of your chosen case top.
Offline liangalv
« Reply #217 on: Mon, 06 May 2019, 03:22:35 »
Any idea if we would be unable to install something like Mill-Max sockets for HS instead of Kailh's implementation?
Offline AlcoholEnthusiast
« Reply #218 on: Mon, 06 May 2019, 03:47:58 »
When are you expecting the proto to be done?
**edit**
nvm just read your answer to that in discord
« Last Edit: Mon, 06 May 2019, 04:33:24 by AlcoholEnthusiast »
Offline fly not fly
« Reply #219 on: Mon, 06 May 2019, 03:55:10 »
looks awesome!
Offline Aphidsc
« Reply #220 on: Mon, 06 May 2019, 07:55:57 »
Whew! Catching the 60 fever! Definitely interested in this :)
Offline monkt
« Reply #221 on: Mon, 06 May 2019, 08:40:40 »
**edit**
Mind sharing?
Offline Furikurichemy
« Reply #222 on: Mon, 06 May 2019, 18:47:09 »
**edit**
Mind sharing?
CNC is finished, being Anodized as we speak
Offline jrs
« Reply #223 on: Mon, 06 May 2019, 18:59:07 »
Will there be a configurator for the layout to generate the firmware file?  I'm assuming the PCB will use QMK.
Offline NimbleTortoise
« Reply #224 on: Mon, 06 May 2019, 19:40:56 »
Will silver be available? Or is it too unpopular?
Offline audax989
  • NOM NOM NOM
« Reply #225 on: Mon, 06 May 2019, 23:39:38 »
will there be an option to mix and match alu/poly tops and bottoms?
Offline ai03
    • Website
« Reply #226 on: Tue, 07 May 2019, 05:28:22 »
Likely, but I'll need to verify with KBDfans that it's fine before it runs, since it's quite a bit more effort logistics-side.
Going by KBD8X MKII sales, silver proved too unpopular to be worth over e-white.
I'm currently working on QMK for Polaris as I type this message; I'll definitely make it compatible with some GUI-based programming tool, whether it be configurator or VIA (depends on whether or not VIA is finished by the time Polaris ships).
« Reply #227 on: Tue, 07 May 2019, 17:46:19 »
How does e-white compare to cerakoting and MAO finishes?
Offline jrs
« Reply #228 on: Tue, 07 May 2019, 22:21:00 »
VIA would be nice.
Offline Macmutant
« Reply #229 on: Tue, 07 May 2019, 23:43:29 »
VIA would be nice.
VIA support would be ideal. Will be a determining factor for me.
Offline Digitize
« Reply #230 on: Tue, 07 May 2019, 23:50:31 »
What’s VIA?  Heard of QMK but not VIA
Offline mrpetrov
« Reply #231 on: Tue, 07 May 2019, 23:55:55 »
VIA is a GUI overlay based on QMK that OliVIA (and others?) have put together - so it makes it super easy to remap keys etc. I don't think it's a must-have for me, but it is super nice for sure.
Offline Digitize
« Reply #232 on: Wed, 08 May 2019, 00:01:40 »
Thanks for the explanation. Went googling it too. Kept popping ride share stuff but I guess that was just me not typing the right keyword combo. Found a video by Merlin. VIA does seem to make the key mapping look easier.
Offline Phoenix1611
« Reply #233 on: Wed, 08 May 2019, 02:31:39 »
Oof, I'm in, really glad E white is an option. Also, will extra PCBs be available to buy?
Offline ai03
    • Website
« Reply #234 on: Wed, 08 May 2019, 03:53:12 »
Super likely yes, along with extra plates.
Offline Phoenix1611
« Reply #235 on: Wed, 08 May 2019, 04:13:44 »
Awesome! Far as plates are concerned, any plans on making alu an option as well?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #236 on: Wed, 08 May 2019, 07:08:56 »
I asked about aluminum in Discord, and was told "no" due to logistics and splitting order quantity. I'm sure they will supply the plate files like with the 8X, in which case you can get an aluminum plate made very affordably (at least in the USA) by https://sendcutsend.com
Offline wholypantalones
  • text and icon mods plz.
« Reply #237 on: Thu, 09 May 2019, 07:09:20 »
They offer plates in 1.6mm, but isn't that too thick? Seems like the stabs would bottom out on the plate unless the plate was routed for them. Still pretty affordable though.
Edit: looks like 1.6 is within tolerance.
« Last Edit: Thu, 09 May 2019, 07:17:12 by wholypantalones »
Offline tonny950111
  • valar morghulis valar dohaeris
« Reply #238 on: Thu, 09 May 2019, 09:41:45 »
$265 for true gasket mount? I'm in.
Offline jrs
« Reply #239 on: Thu, 09 May 2019, 14:20:24 »
The mount is different from that used in keyboards such as the GSKT-00.
Offline Visionaire
« Reply #240 on: Thu, 09 May 2019, 14:42:25 »
Can't wait to see the prototype
« Reply #241 on: Thu, 09 May 2019, 15:02:03 »
here goes this debate again
ill get my popcorn
Offline regionfree
« Reply #242 on: Fri, 10 May 2019, 03:32:48 »
ill get my popcorn
I'll bring the drinks. Gotta get good seats  ;D
Offline vegs
« Reply #243 on: Fri, 10 May 2019, 04:06:29 »
Still gasket mount :p
hhkb 4 life
buy less
Offline adxlk
« Reply #244 on: Fri, 10 May 2019, 05:52:30 »
do you own one to say its different?
Offline vegs
« Reply #245 on: Fri, 10 May 2019, 06:30:56 »
Judging from the expanded pic in OP, it is different.
Similar to 356mini, GSKT uses a rubber o-ring/band that sits between the plate and the PCB
hhkb 4 life
buy less
Offline Kavik
« Reply #246 on: Fri, 10 May 2019, 10:44:38 »
Not really a 60% guy, but this looks like the one to get if I ever get one. I'll follow this.
Offline jrs
« Reply #247 on: Fri, 10 May 2019, 10:55:10 »
So is this still considered a "true" gasket mount?
« Reply #248 on: Fri, 10 May 2019, 11:00:06 »
Can’t say if he owns one, but I do believe he owns eyes. That’s how I was able to notice they are different styles of gaskets.
Offline iaman
« Reply #249 on: Fri, 10 May 2019, 11:03:12 »
I've tried looking around a bit and have mostly only found a couple images of full builds and a billion instances of forum signatures containing the board's name, but do you have a link handy (to something other than a video) that shows the gasket mounting on the GSKT-00 for folks to compare?
