Author Topic: [IC] Polaris - GB has begun  (Read 287075 times)
Offline iNViSiBiLiTi
Re: [IC] Polaris - Gasket 60% for $265
« Reply #300 on: Tue, 14 May 2019, 00:08:50 »
btw this is polaris thread
Will the gasket be "squishy" at all, or will it be mostly firm to the touch?
No gasket mounts are squishy really, they are noticeable, but you won’t be surprised and it won’t change your life.
I own more than one gasket mount board, and I've typed on several more. There's no reason it couldn't be squishy -- that's up to the designer.
If you don't mind me asking, which gasket keyboard is squishy?
60%: Prophet, GSKT-00 x2, Poly GSKT-00-Z, Weaven, Sangeo60, Unikorn R2.1, Ciel60, DNworks DM
TKL: TGR Jane V2, Jane V2 CE, KFE, Noxary 280 S, Acrylic Unicorn, Igris V1, LZ-GHv2, Bias R2, HMKB
Misc: Bulgogi Board (VA104M), Belle En Rose, Treeleaf 917, TGR 910 ME, ai03 Vega
Offline nickaster1
« Reply #301 on: Tue, 14 May 2019, 00:26:13 »
Is it good or bad when normies like me find out more about these rare and well-kept knowledge when famous people beef over each other like this?
« Last Edit: Tue, 14 May 2019, 05:03:55 by nickaster1 »
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #302 on: Tue, 14 May 2019, 04:53:41 »
TLDR about whether a board is true Gasket or not:
You, like other "Gasket Experts" here, are just really dumb. I'm not saying the outcome is perfect, but I already explained the process and how we got here. The mistake was that you assumed that all gasket mounts are the same beforehand, when that is far from the truth. Second time I said this, god Puddsy you are dumb.
Also the ****ing durometer, I can choose any gasket and compare with a my 365 mini and they can feel very different from each other.
Everybody's a ****ing expert online.
Offline ai03
  • I do not reply to PMs; contact me via website
    • Website
« Reply #303 on: Tue, 14 May 2019, 05:20:23 »
Any color samples of the olive green would be greatly appreciated !
Kevinplus (handles communications, renders, proto testing, etc) is waiting on some physical ano samples from the factory. After they arrive, there'll be more "final" renders in terms of color matching.
Offline vegs
« Reply #304 on: Tue, 14 May 2019, 05:51:03 »
gasket expert :cool:
hhkb 4 life
buy less
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #305 on: Tue, 14 May 2019, 06:27:51 »
I couldn't tell you, it was just a question. The reason I asked is because in the 356 build video I watched the gasket was visibly squishy, but I don't know what it's like when it's all screwed down.
Imagine getting defensive over someone asking a question and then trying to defend their right to ask a damn question.
Offline ai03
    • Website
« Reply #306 on: Thu, 16 May 2019, 18:02:32 »
If you would like to argue about gaskets, please move somewhere else.
Also, waiting mainly on the weight now. Everything else is getting very close to completion, or has been completed and is awaiting shipment.
« Reply #307 on: Thu, 16 May 2019, 22:36:22 »
You trying to be passive aggressive or something?
Offline callmenox
« Reply #308 on: Thu, 16 May 2019, 23:01:42 »
is just keyboard why you haf to be mad?
Offline coffeeshopcoder
« Reply #309 on: Thu, 16 May 2019, 23:45:37 »
Still looking forward to some color samples - will this green be the same green as fusion60 that just started shipping ? I’m asking because both are being done by KBDfans, but I honestly don’t have any idea if they use multiple manufacturers and ano shops.
Offline username_87
« Reply #310 on: Fri, 17 May 2019, 09:54:21 »
i'm in...
« Last Edit: Fri, 17 May 2019, 10:33:31 by username_87 »
Polaris
Offline jusseppii
« Reply #311 on: Sat, 18 May 2019, 01:56:52 »
Yeah I'm buying 3 or 4 of these for sure.
Offline nickaster1
« Reply #312 on: Sat, 18 May 2019, 05:25:55 »
I’d be interested in seeing a pc proto of this one
« Reply #313 on: Sat, 18 May 2019, 11:47:36 »
Definitely in for this! Just have to find a good keycap set for that gorgeous red case!
E6-V2 [Tealios] | RAMA M60-A [Zealios] | QXP [Healios]
Offline ArchDill
« Reply #314 on: Sat, 18 May 2019, 12:55:39 »
That case would look great with a good beige set
Offline bobdenard
« Reply #315 on: Sat, 18 May 2019, 13:42:38 »
GMK Red Samurai is back on drop ;)
Offline LMNO
« Reply #316 on: Mon, 20 May 2019, 00:20:07 »
I'm really interested in this group buy but my question is in regards to the PCB. It seems like this keyboard will only fit the PCB it comes with due to the measurement of it. Let's just say the PCB would fail at any point, would I have trouble finding a replacement in the future?
Offline vision-quest
« Reply #317 on: Mon, 20 May 2019, 00:35:40 »
I don't know the answer in regards to the Polaris but this is the issue with most customs unfortunately.
Offline ai03
    • Website
« Reply #318 on: Mon, 20 May 2019, 01:06:02 »
I will likely be open-sourcing the PCB at some point. From the data, it should be possible to either recreate it 1:1 or modify it to whatever future standards exist at that point in the future.
Offline steezkeez
« Reply #319 on: Tue, 21 May 2019, 19:33:59 »
Stoked for this, been looking to get my first 60%. PC + gasket (and the PRICE  :eek:) makes this an auto-buy for me. Can't wait!!
Offline Vulcan
« Reply #320 on: Tue, 21 May 2019, 19:49:34 »
I am in !! Lets gooooo
Offline toddwardz
« Reply #321 on: Tue, 21 May 2019, 20:15:18 »
I'm in!
Offline iboosted
« Reply #322 on: Tue, 21 May 2019, 20:45:38 »
Count me in!
Offline phlux
« Reply #323 on: Wed, 22 May 2019, 08:37:35 »
Definitely in for this.
Any chance for an option to swap the weight engravings? I personally like how the POLARIS looks and would love see that on the outside.
Offline dubious
  • 쏘쿨
« Reply #324 on: Wed, 22 May 2019, 14:05:58 »
Trying to convince myself I don't need this...
but a PC, halfplate, gasket mount for around $300?  :eek:
Offline Aevyn
« Reply #325 on: Wed, 22 May 2019, 14:16:18 »
You would be one of the few. I think this was one of the most highly requested changes from previous designs from what I remember being mentioned in the discord
Sent from my SM-G950U using Tapatalk
Offline ai03
    • Website
« Reply #326 on: Wed, 22 May 2019, 16:11:42 »
I actually moved the text to internal after receiving an overwhelmingly negative reaction regarding the external text on the KBD8X MKII.
Offline dubious
  • 쏘쿨
« Reply #327 on: Wed, 22 May 2019, 17:04:59 »
I always found it odd that some people have such strong opinions about this. Who is using their keyboard upside down??
Offline phlux
« Reply #328 on: Wed, 22 May 2019, 17:23:23 »
Interesting, I feel like the text looks so clean. Well, it looks great either way. Can't wait for the GB!
Offline SantiGo
« Reply #329 on: Wed, 22 May 2019, 18:16:29 »
PCB for ALPS  ?
Offline ai03
    • Website
« Reply #330 on: Wed, 22 May 2019, 18:35:49 »
PCB for ALPS  ?
I personally don't have plans for one at this time; however, I will be open sourcing the PCB and plate files for any modders who wish to make their own alps compatible internals.
Offline Surefoot
« Reply #331 on: Thu, 23 May 2019, 03:43:18 »
I too like the text on bottom, looks clean and modern, and is indeed not visible in normal usage.
Offline ninjacore
« Reply #332 on: Thu, 23 May 2019, 10:46:06 »
+1 for internal text. I _do_, however, like the symbol on the bottom (outside) of the weight.
Offline cepp
« Reply #333 on: Thu, 23 May 2019, 12:13:31 »
Are there any renders of the polycarb case?
Offline ai03
    • Website
« Reply #334 on: Mon, 27 May 2019, 22:57:21 »
Here's one that Kevinplus did a while back:
Still waiting on prototypes. They are getting closer though.
Offline MdotMaxson
« Reply #335 on: Mon, 27 May 2019, 23:10:54 »
So this won’t fit a boardwalk PCB?
Offline lolafineday
« Reply #336 on: Tue, 28 May 2019, 01:47:50 »
No
Sent from my SM-G975F using Tapatalk
Offline MdotMaxson
« Reply #337 on: Tue, 28 May 2019, 02:51:04 »
No
Even if I have a custom Plate made? Is it just that this wants a PCB or 1.2mm thick I think it said and a boardwalk PCB is going to be thicker? Or are there other reasons it won’t fit? It also uses gaskets which add to the thickness... what if I removed a gasket. Basically is there anyway I can hack this case into working? I need a 60% white HHkB case for my boardwalk and they aren’t exactly easy to find. So I’m ready to do some modding.
Basically can anyone tell me exactly why a boardwalk PVB can’t fit in this case instead of just No.
Offline xondat
  • i'm not a star
« Reply #338 on: Tue, 28 May 2019, 02:58:09 »
No
It wouldn't fit by default, but you could "hack" it and it'd probably work at some point. Depends how badly you want it I suppose.
Offline InvidiousIgnoramus
« Reply #339 on: Tue, 28 May 2019, 03:00:48 »
No
There are cheaper and easier ways to get a hhkb boardwalk case in white, you know.
I long for the day when I find a beamspring. (At a not insane price)
Offline MdotMaxson
« Reply #340 on: Tue, 28 May 2019, 05:36:51 »
No
I am open to suggestions. I’m new here and don’t know where to look or really what to look for. I’d rather something quality though over cheap.
Offline befbef
« Reply #341 on: Tue, 28 May 2019, 07:17:04 »
The hole for the usb-connector is at a different location than the connector of the boardwalk pcb. You need a case that is complatible with standard 60% pcbs.
Offline nasp
« Reply #342 on: Tue, 28 May 2019, 07:29:57 »
Shensmobile said on the Discord channel that he would be willing to make a Boardwalk style custom PCB for the Polaris. He's one of the designers behind the original Boardwalk PCB.
I don't know his timetable for this though. He's currently working on another project.
Offline ptiede
« Reply #343 on: Tue, 28 May 2019, 08:02:03 »
No
Have you considered the Sirius pom board?
store.projectkeyboard.com/collections/sirius
You can get a white hhkb board that way and it will fit the boardwalk pcb. Pom is a pretty neat plastic and actually makes the board have a very pleasant sound profile. Top Clack did a typing test of you want to look at it.
Offline ai03
    • Website
« Reply #344 on: Tue, 28 May 2019, 19:23:09 »
I will be open sourcing the PCB and plate files later on, if anyone wants to adapt a PCB or make one of their own to fit into the Polaris.
Third party PCBs will likely not drop in without adjustments due to the exact positioning of the USB Type-C connector and the matching cutout on the case.
Offline shensmobile
« Reply #345 on: Wed, 29 May 2019, 00:52:51 »
Yeah I might as well just post here too since others have mentioned it. The Boardwalk PCB will not fit because the USB cutout is very precise and the 1.2mm PCB raises the port by 0.4mm. I will be designing a Polaris-specific Boardwalk with hot swap sockets and will mimic the Polaris’ cut-out in the middle of the PCB. I’ll also be producing plates.
I will only be making a PCB to support my preferred layouts though (HHKB and WKL 7u). If you’re interested in this, let me know. I’ll be hand soldering these PCBs due to low volume so there won’t be many but it is happening. I’m currently working on a few other keeb projects right now but I uh... might have accidentally  finished the layout of the new PCB already.
Ai03, this is all possible thanks to you. Kudos!
« Last Edit: Wed, 29 May 2019, 00:56:43 by shensmobile »
Offline pixelpusher
« Reply #346 on: Wed, 29 May 2019, 11:09:15 »
Oh man.  This is awesome news.
Offline hayt
« Reply #347 on: Wed, 29 May 2019, 11:12:00 »
Hey, a question on the Red Ano.
Do you anticipate the final real-life anodize to look similar to the rendering? Just curious cuz in the render, it looks like a slightly burnt/muted red. Was this your specific intention or just a render side effect? If you have any actual ano swatches you could post of the desired colors, that would be awesome!
Offline nguyenhimself
« Reply #348 on: Wed, 29 May 2019, 11:13:28 »
I kinda love the idea of keeping multiple PCB to use with one (great) case. Seems more... financially-conscious than buying multiple separate keyboards :)
Yeah if you ever plan to run that (small?) GB, I’m in.
« Reply #349 on: Wed, 29 May 2019, 11:19:58 »
Kbdfans will handle the production, so I suspect it will be more of a burgundy red, similar to their current Tofu case:
« Last Edit: Wed, 29 May 2019, 11:23:55 by nguyenhimself »
