Author Topic: Some good lubricant.  (Read 11870 times)
Offline Dr.Hades
  • "Trust me"
« on: Thu, 23 May 2019, 12:14:58 »
At the end of last year I ordered some pretty nice switches for my first build. I ordered some Holy Pandas and I know the general idea behind how and why to lube but now my question is... What lube? I've heard the whole grease vs. oil vs. hybrid thing but I was looking for recommendations on a good and available lube for these things.
Offline barrel
Re: Some good lubricant.
« Reply #1 on: Thu, 23 May 2019, 12:19:58 »
Personally, Tribosys 3204, if you're in the EU It's avaliable via https://mykeyboard.eu
Offline airyimbin
« Reply #2 on: Thu, 23 May 2019, 12:55:07 »
I've heard that Christo Lube 111 is a good choice as well. Right now it seems to be sold out on most keyboard sites. I'm trying to buy some myself.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #3 on: Thu, 23 May 2019, 13:09:47 »
I like a thicker lube with stronger tactile switches. The added softness of a thick grease like 3204, 205g0, or GHv4 offsets the harshess of Holy Pandas; also, because they are so tactile, you can lube the tactile bump directly and you will still keep most of the tactility.
Offline TeacherGeek
« Reply #4 on: Thu, 23 May 2019, 14:14:17 »
Where do you buy those?
Offline Dr.Hades
  • "Trust me"
« Reply #5 on: Thu, 23 May 2019, 22:12:06 »
Would you be able to direct me to where I could get these greases in the US? I think that I want to try a grease for this build as that will give the lube much more impact than oil from what I've heard.
Offline Dr.Hades
  • "Trust me"
« Reply #6 on: Thu, 23 May 2019, 22:18:51 »
Also I probably should have asked this before but does is really matter if you use the same lube on the stabs? I see almost everyone lubes the stabs with a different lube and it makes me wonder if it's really even worth it to get a seperate lube for the stabs considering that,well they're gonna be smooth either way.
Offline vegs
« Reply #7 on: Fri, 24 May 2019, 03:16:57 »
3204 works well with stabs, but it is recommended to have some even thicker grease for the stabilizer wires. I use Superlube Grease which is pretty cheap - you can get a big tube off ebay for ~$10.
hhkb 4 life
buy less
Offline typo
« Reply #8 on: Fri, 24 May 2019, 04:21:14 »
The best oil is Remoil for guns. It is a synthetic PTFE oil. The best grease is synthetic hub grease at an auto parts store. Both are cheap. Both will last forever on a keyboard.
Offline Dr.Hades
  • "Trust me"
« Reply #9 on: Fri, 24 May 2019, 11:31:37 »
I just recently found out about Triboysis 3204's limited stock so I might be getting some Krytox 204 and switch films for switch mods. Krytox 204 is very similar to Triboysis 3204 if I'm reading into the correct sources and Krytox 204 is also more readily available so if I'm making a mistake here then please let me know.
Offline poodude
« Reply #10 on: Mon, 27 May 2019, 21:06:38 »
i hear this is pretty good.
Offline Dr.Hades
  • "Trust me"
« Reply #11 on: Tue, 28 May 2019, 11:21:57 »
It should bring great feels of pleasure to my fingers yes? The pushing and in and out of the stem going into it's warm and tight housing?
Offline AcidBrain
« Reply #12 on: Thu, 30 May 2019, 16:10:23 »
I get my from switchmod_keyboards (Instagram) he updates you when he is in stock. He just shipped his last order out to customers so I assume he will be opening up again soon.
Offline phinix
« Reply #13 on: Sun, 21 June 2020, 07:02:07 »
Is this super lube ok for stabs?
How much of it should I apply?
I keep lubing stabs, but not too much. Should it fill up the whole space in stab slider?
245430-0
« Last Edit: Sun, 21 June 2020, 07:04:19 by phinix »
