Author Topic: 60% PCB recommendations?  (Read 8117 times)
Offline vision-quest
« on: Sun, 02 June 2019, 10:46:15 »
I have a Fjell on the way, and I'm interested in what PCB I should grab? Is the Zeal Rev4 the best option going around at the moment?
Offline MarbleKeeb
  • Bring Marble to Keyboards
    • MarbleK Website
Re: 60% PCB recommendations?
« Reply #1 on: Fri, 07 June 2019, 22:35:33 »
I went for DZ60, I am quite satisfied with it :)
But I do not know if it is compatible with the Fjell..
Offline ArchDill
« Reply #2 on: Fri, 07 June 2019, 22:36:17 »
I Would get whatever can be programmed with QMK
Offline swedishpiehole
« Reply #3 on: Fri, 07 June 2019, 23:09:10 »
1uphse from 1up keyboards is a good choice. I love mine.
Offline nolan.hates.soymilk
« Reply #4 on: Fri, 28 June 2019, 20:33:31 »
I don't have a huge frame of reference, but the DZ60 is a solid option, and apparently it is compatible with the Fjell!
Offline nguyenhimself
« Reply #5 on: Fri, 28 June 2019, 22:08:49 »
Go for the Zeal60 if you really need per-key RGB. Emphasis because boy you will pay for that.
Otherwise, the DZ60 is more than good enough.
Offline ideus
  • Björkö.
« Reply #6 on: Fri, 28 June 2019, 22:42:43 »
Check kbdfans site for some options there, including the DZ. Zeal's products are overpriced.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #8 on: Sun, 30 June 2019, 21:15:46 »
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline deepalicious
« Reply #9 on: Wed, 03 July 2019, 17:01:21 »
DZ60, unless per key RGB is SUPER important to you.
Offline Curtis_55
« Last Edit: Fri, 13 December 2019, 22:42:19 by Curtis_55 »
