Author Topic: [IC]Jupiter 75% keyboard (Update:GB finish)  (Read 37867 times)
Offline MU Studio-木妈妈
« on: Sat, 15 June 2019, 09:28:17 »
    If you interest it, please answer a IC form, the post: https://docs.google.com/forms/d/1S6Ox-2HdFAslNu8WFW1xFPp5X_TfFBpQ5gLZOXv1uas/edit
    Welcome to Discord group of DT.Heart: https://discord.gg/RteVhRY
    The GB link:https://geekhack.org/index.php?topic=101493.0
    GB time:2019.07.05-2019.7.15
Update on 14,July
    Typing testing and Bluetooth works on iphone
    the SA keycaps testing:
    The GMK-high keycaps testing:
Update on 6, July.
    Hi, friends. I'm sorry to have kept you waiting for some time. The other day, there's something wrong with my post.
    Now I'm bringing you some new physical photos.
  • F zone split
  • Small front teeth
  • Support ANSI, ISO arrangement
222291-0
222293-1
222295-2
222297-3
222299-4
  • Uniform plate
  • Oversized battery slot
  • Counterweight opening
222301-5
222303-6
222305-7
  • burger top mount
  • Type-c port length is carefully designed
  • Top acrylic signal port
  • Signal port mosaic assembly
222307-8
222309-9
  • Drawer type, front and back installation weight
  • Mass production is brass + stainless steel
  • Slotted RGB bottom lights on both sides
222311-10
222313-11
222315-12
Updated on 2, July
222051-13
222055-14
222057-15
222088-16
222090-17
222092-18
222059-19
222061-20
222094-21
222096-22
222098-23
222100-24
    Bluetooth PCB will be finished these days. And then I will do a test to update here.
    At the end of the post, I've written a progress list and question solution section, so you can keep an eye on the overall progress and some information of this keyboard. Thank you guys.
Update on 15, June
    Hi, friends. I am Mumama(木妈妈), a new one here. Today I want to share a new keyboard. It’s the Jupiter 75%.
    For this keyboard, my original intention in designing this drawing was to give us a small working keyboard. It is capable of doing all the work in daily life. So it is out. It’s a dual-mode 75% keyboard, Bluetooth or wired connection.
    Now, I also found a new processing team. Their products are doing very well. The team’s name is DT.Heart. I think we will hear more products made by this team in the future.
Details:
  • 5.5 degree slope
  • Dual mode Bluetooth
  • Aluminum Top and Bottom
  • Brass and steel weight
  • Type-C USB
  • Bottom RGB lights
  • Top signal exit
  • Signal and power indicator light
  • Top mount with apron
  • PC version
221189-25
221191-26
221193-27
221195-28
221197-29
221199-30
Layouts:
222053-31
Colors:
    The  final color has decided.
    White
222277-32
    Blue
222279-33
    Gray
222283-34
    Red
222281-35
    Black
222285-36
    Silvery
222287-37
    PC Version
222289-38
221217-39
    Now, the proofing product is coming out. I will update the physical picture in a few days. At that time, some GB information will be previewed.
To Do lists:
    Design - done
    Renders - done
    Housing prototype - done
    PCB prototype - testing 50%(Update bluetooth and typing test)
    GB - TBD
    Fulfillment (ETA 3 months after GB)
Question Solution Section
1 What about the firmware?
    Run QMK.
2 Will there be a PC option?
    PC will be support.
3 Brass plate?
    No.
4 ISO support?
    Yes, include 1.25U  lift shift.
5 Battery
    The battery cell is 137mm*65mm*5mm. You can choice a suit one by yourself. Because it is not easy for us to ship the battery.
6 Hot swap
    No.
« Last Edit: Sat, 18 April 2020, 18:25:09 by MU Studio-木妈妈 »
Customized keyboard assembly expert
Customized keyboard Designer
Customized keyboard enthusiasts
Offline _ODIN_
Re: [IC]Jupiter 75% keyboard Interest Checks by MU Studio
« Reply #1 on: Sat, 15 June 2019, 09:29:03 »
The pictures are not showing up.
« Reply #2 on: Sat, 15 June 2019, 09:39:30 »
The picture is now displayed
Offline nickaster1
« Reply #3 on: Sat, 15 June 2019, 09:39:52 »
Is the text on the nametag customizable? Also do you have any renders with caps on?
« Reply #4 on: Sat, 15 June 2019, 09:43:28 »
May be customized with laser lettering on weight.
Offline mkarlsson
« Reply #5 on: Sat, 15 June 2019, 09:50:10 »
Looks very good. Do you have a price estimation?
« Reply #6 on: Sat, 15 June 2019, 10:22:47 »
After the physical sample comes out, there is a price estimate.
Offline Warrenified
« Reply #7 on: Sat, 15 June 2019, 12:10:25 »
No split backspace?  :(
Offline vi0till
« Reply #8 on: Sat, 15 June 2019, 12:58:06 »
yeah...
Offline nasp
« Reply #9 on: Sat, 15 June 2019, 14:11:39 »
+1 for split backspace.
Also, what firmware will the PCB be running?
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #10 on: Sat, 15 June 2019, 15:08:14 »
Extremely excited to see a universal plate. ISO support is what I need. I’m definitely in for this! The polycarbonate version is gorgeous.
Offline chakkii
« Reply #11 on: Sat, 15 June 2019, 17:05:35 »
+1 ISO support + PC case and I'm 100% in  :thumb:
Offline Visionaire
« Reply #12 on: Sat, 15 June 2019, 18:59:31 »
IC form won't let you choose the same color for top and bottom
Offline randalbolts
« Reply #13 on: Sat, 15 June 2019, 19:39:11 »
Is the polycarb looking render at the bottom supposed to be a white render? Because there is no option to select polycarb in the IC form but there is the option to select white (and I don’t see a white render). Also you can’t select the same colour for the top and bottom on the form - is this an error?
If there is a polycarb version I’d be in for the GB!
« Reply #14 on: Sat, 15 June 2019, 20:04:57 »
yes,it has backspace!
« Reply #15 on: Sat, 15 June 2019, 20:07:24 »
I was not draw it, but it can split backspace. i wll modify later.
« Reply #16 on: Sat, 15 June 2019, 20:09:47 »
There will be a PC version
« Reply #17 on: Sat, 15 June 2019, 20:10:24 »
PCB run QMK
« Reply #18 on: Sat, 15 June 2019, 20:10:41 »
« Reply #19 on: Sat, 15 June 2019, 20:11:25 »
really? i will check it.
« Reply #20 on: Sat, 15 June 2019, 20:33:47 »
i will modify the form. white and PC will take out
« Reply #21 on: Tue, 02 July 2019, 09:02:14 »
Up up up for everyone. Have a cup of tea.
Offline Kevinsunbo
« Reply #22 on: Tue, 02 July 2019, 09:06:58 »
it's amazing.cannot wait to join the gb
Offline 我是流氓羽
« Reply #23 on: Tue, 02 July 2019, 09:13:58 »
This keyboard is great!I want to get one.
Offline Syrah94
« Reply #24 on: Tue, 02 July 2019, 12:23:32 »
Long time lurker and finally something I like. In for the PC version.
Offline DuellM
  • Keyboard Fatty
« Reply #25 on: Wed, 03 July 2019, 09:42:55 »
That PC and purple version looks awesome, really hope that version gets made. :))
« Reply #26 on: Wed, 03 July 2019, 10:52:01 »
I will take out the PC version in later updates.
Offline Chumbo
« Reply #27 on: Wed, 03 July 2019, 12:48:14 »
Looks gorgeous 😍
« Reply #28 on: Wed, 03 July 2019, 18:42:59 »
Looks gorgeous 😍
year,thank you!
Offline EMC Labs
« Reply #29 on: Wed, 03 July 2019, 18:56:38 »
Looks amazing!
« Reply #30 on: Wed, 03 July 2019, 23:29:15 »
Looks amazing!
Year, There will be more details in the updates later.
Offline rondg
« Reply #31 on: Thu, 04 July 2019, 00:11:51 »
Just to clarify, there is no polycarbonate version?
Offline Scarecrow
« Reply #32 on: Thu, 04 July 2019, 00:52:01 »
大卖!木妈妈牛逼~~ :thumb:
Offline EMC Labs
« Reply #33 on: Thu, 04 July 2019, 01:15:58 »
Looks amazing!
Can't wait.
Offline lac29
« Reply #34 on: Thu, 04 July 2019, 02:24:26 »
Looks good. I think the only big thing is split backspace for me.
« Reply #35 on: Thu, 04 July 2019, 04:39:05 »
The PC is not made out now,but the gb will has PC version
« Reply #36 on: Thu, 04 July 2019, 04:41:57 »
It supports split backspace. So it suits you! :)
Offline reccatyo
« Reply #37 on: Thu, 04 July 2019, 05:23:30 »
Whhat bluetooth version Will it use?
« Reply #38 on: Thu, 04 July 2019, 06:03:25 »
BT 4.0
Offline hicals
« Reply #39 on: Thu, 04 July 2019, 15:05:31 »
How do I buy overseas?
Do I only sell in China
« Reply #40 on: Thu, 04 July 2019, 18:44:23 »
there will be a GB for global players.
« Reply #41 on: Sat, 06 July 2019, 03:52:49 »
GB is begining. I will write a GB post soon.
Offline EMC Labs
« Reply #42 on: Sat, 06 July 2019, 05:25:34 »
I'm ready.
« Reply #43 on: Sat, 06 July 2019, 06:41:20 »
I'm ready.
it is GB now in en-zFront, you can join it
Offline chakkii
Just joined the GB for 1 PC + silver plate. Will the PC version be nicely frosted so the RGB underglow will diffuse nicely? Will you have prototype images / videos for light diffusion?
yes,and i will take the picture and video.
Offline juusu
Wow didn’t expect this GB so quick!
Is this zFrontier only or will there be proxies? If zFrontier only, can you give an estimate for shipping costs to the EU?
Offline rondg
I think you can try and fill up the form to see the shipping costs.
Only in zF. I think you can check the shipping fee yourself. Because i dont know,too :confused:
Offline Kelseer
Just picked one up in E- White. No shipping fee yet, that'll be invoiced separately based on what I saw on ZF's site.
Question. Will there be extra PCB's and plates for sale later on?
