Author Topic: Arrow40 - A 40% "TKL-style" keyboard  (Read 35506 times)
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« on: Tue, 09 July 2019, 06:10:30 »
The Arrow40
Hello, I'm Seb, a first time keyboard designer and two year enthusiast!
I wanted to make a post here about a project me and some fellas are working on. It's primarily a hobby project based on a long time desire to build and have a 40% keyboard.
I started sketching out what kind of layout I'd love to have in a 40% and ended up with what resembles a tenkeyless layout, only without the f-row and the number row.
It might sound like a contradicting layout, having it very compact but still expanding it to the right side, but I ended up really liking the look of it.
(Featuring GMK Pulse by MiTo, used with permission!)
I got a friend (w3bb0 https://geekhack.org/index.php?action=profile;u=77006 ) designing the PCB
and another friend planning to do the milling and production of the case.
We started out with an integrated plate design, but ended up doing a top mount design on it, for the purpose of helping the milling process as well as allowing for more layout options. After some feedback from some 40% guys we're gonna do an alternative top supporting a non-blocked layout and the PCB will offer the possibility of a split spacebar layout!
Here's a look at the drawings and plans for this, not very professional but I just wanted to try and explain and make the different parts clear:
As you can see there are three parts that needs to be screwed together.
  • Flat top M2 screws for the plate onto the top part.
  • M4 screws (counterbore) for the bottom part to the top part.
  • Flat top M3 screws for the legs onto the bottom part. They will fit in the milled holes in the bottom part, being exposed there, and with possibilities for logos to be carved into them, making it nice
    and premium.
Hoping to cut the holes in the plate a little bit bigger than the M2 screws so that the plate will be flush with the top part, and the bottom part can line up perfectly and seal everything neatly without having to make any cuts in the bottom parts for any screws sticking out.
The legs will have some sort of silicone/rubber material with an adhesive layer which can be attached to the bottom side of the leg, covering the holes for the screws (if they go through all the way that is).
As of right now I'm pretty much done with the model and I'm looking over things and I need to double check the measurements against the PCB model, we're soon starting to work on the prototype. Since this is my first ever case design and modeling something that's gonna be made to a physical model I'm quite nervous about having made any rookie mistakes when it comes to this kind of stuff.
I plan on doing more renders very soon, with different keycap sets on. Will also be posting pics and renders of the PCB eventually!
I'm also gladly accepting any tips/feedback or ideas, since this is my first design!
« Last Edit: Sat, 13 July 2019, 18:47:43 by snurrebassen »
Offline Moridin
    • Infinite Diaries
Re: Arrow40 - A 40% "TKL-style" keyboard
« Reply #1 on: Tue, 09 July 2019, 07:29:36 »
Basically, I always looked at 40% users with awe, trying to figure out how they were using those tiny keyboards effectively. This is the first layout that I've seen that is actually making me think that even I could use that layout!
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #2 on: Tue, 09 July 2019, 09:26:20 »
I think it looks great!
Offline Cameron831
« Reply #3 on: Wed, 10 July 2019, 01:26:35 »
I think it looks amazing  :thumb:
« Last Edit: Mon, 27 April 2020, 16:50:32 by Cameron831 »
Offline EMC Labs
« Reply #4 on: Wed, 10 July 2019, 02:34:37 »
Looks amazing! I will try to follow this and wishing it will make GB someday. Fond of the layout.
    • Linktree
« Reply #5 on: Wed, 10 July 2019, 06:58:10 »
Thank you! glad to hear it's appealing  :D
Planning on doing a limited GB for sure!
Offline Hueeeeeeeee
  • Your Friendly Neighborhood IT Guy
« Reply #6 on: Wed, 10 July 2019, 08:32:05 »
I would love to see encoder support for the three top right keys. :thumb:
Offline EMC Labs
« Reply #7 on: Wed, 10 July 2019, 08:57:18 »
Can't wait!
    • Linktree
« Reply #8 on: Thu, 11 July 2019, 01:32:34 »
We are working on achieving this!  :thumb:
Offline osamine
« Reply #9 on: Thu, 11 July 2019, 17:01:53 »
Im definitely in on this
Sent from my iPhone using Tapatalk Pro
    • Linktree
« Reply #10 on: Sat, 13 July 2019, 18:07:17 »
A few more renders featuring Moridin's GMK Phosphorous!
Adusted the case thickness to fit M4 screws and PCB design is nearly done!
Renders of alternative layouts coming soon!
Offline Full
« Reply #11 on: Sat, 13 July 2019, 18:47:12 »
Looks awesome! :)
Hi!
Offline PJE
« Reply #12 on: Tue, 16 July 2019, 14:41:22 »
Love the design, but given the space being used I would implement a 3x4 array on the right hand side which could be remapped into a number pad.
I'd use different color keys to highlight the cursor keys.
Offline funderburker
« Reply #13 on: Tue, 16 July 2019, 18:00:58 »
From the OP:
Code: [Select]
Don't want to be rude but OP mentions it quite clearly what's his vision for the board is that he's designing. But there is a board with your mentioned layout.
Keyboard design by Skepur
    • Linktree
« Reply #14 on: Wed, 17 July 2019, 15:48:38 »
All right! Update on this one. Our guy w3bb0 has pretty much finished the design of the PCB. I'm a designer and art-guy so I don't know much about circuit boards and all that but from my point of view it's looking pretty neat!
We're still deciding on the color scheme and additional art for the PCBs!
I'm off on a few week's vacation, in the meantime, stay tuned!
« Last Edit: Wed, 17 July 2019, 15:51:23 by snurrebassen »
Offline Sycomore
« Reply #15 on: Thu, 18 July 2019, 06:14:10 »
Oh man, oh jeez, i never thought i'd actually consider a 40% but... I guess i'm wrong. Looking forward to further updates!
Offline audiosl4ve
  • Just slave
« Reply #16 on: Thu, 18 July 2019, 06:39:57 »
looking really awesome! 40% needs more love  ;D
Offline hottrout
  • I'd Hit Dat Key
« Reply #17 on: Thu, 18 July 2019, 07:32:28 »
I love your design but I can't work without numbers.  Would you not consider adding a matching numpad, that would make this design just superb.  Great work by the way.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline chuckdee
« Reply #18 on: Thu, 18 July 2019, 13:03:46 »
I'll be watching this one with interest!  Out of curiosity, did you look at other 40s in designing the 40 part of this layout?  Just wondering without going over anything if there are any non-standard keys there.
From the OP:
Code: [Select]
This.  Also there's the TKC Candybar, which he should have extras of when it ships.
« Last Edit: Thu, 18 July 2019, 13:05:34 by chuckdee »
Offline hottrout
  • I'd Hit Dat Key
« Reply #19 on: Thu, 18 July 2019, 13:39:07 »
From the OP:
Code: [Select]
Thank you for posting the link.  Much appreciated.
Systems -
  Keyboards -
    • Linktree
« Reply #20 on: Sun, 28 July 2019, 06:15:28 »
Thanks for your comment! I based the layout on the JD40 actually, so most standard sets should be good for this. I think the most non-standard keys is the R3 small Tab. The smaller Shift keys should be pretty standard in most kits that come with alternative shift keys  :)
Offline PvtSkittles
« Reply #21 on: Mon, 29 July 2019, 17:40:14 »
OH man! That thing is heckin' cute. Love the design.
    • Linktree
« Reply #22 on: Fri, 06 September 2019, 07:20:32 »
All right! Slight update here. Been a little bit off this project, due to some revisions having to be made to the case design to make it more efficient and cost friendly for CNC milling.
I unfortunately had to get rid of the leg design (for now) and doing a Tofu style 5 degree angle to the case with rubber bumpers on the bottom. If the angle is too shallow in the proto, i'll increase it to 7 degrees like the tofu.
I also changed the solution to the plate, it's now a full rectangle (cutouts in the corner), no tabs, and now sits on a small little ledge, with 4 screws to tighten it up. I added a little 4mm circular cutout in the bottom part, to prevent the top of the plate screws to intersect. I hope there will be no extra space to cause rattling.
Here are some quick Fusion renders of the updated design:
Gonna prototype this in 3D along with w3bb0's awesome PCBs and see how it feels before moving over to alu cnc'ing and opening an actual IC thread.
Thanks for checking in!
Offline dingusxmcgee
« Reply #23 on: Fri, 06 September 2019, 07:27:48 »
This is awesome. Love the look!
    • Linktree
« Reply #24 on: Sun, 22 September 2019, 14:18:06 »
Another update on this little guy!
Project is going very well. I received the prototype plate already, and got to test the layout for the first time, physically. Mounted on some unholy pandas and my SA Pulse (Note: Put on the wrong cap where right shift should be)
3D Print of the case is done and being shipped to me for testing very soon!
Meanwhile, the great w3bb0 is finishing up the PCB and will start soldering very soon, and have it shipped to me so that I can assemble the whole thing. I'll make a video on it!
Here's a few bonus renders!
    • Linktree
« Reply #25 on: Wed, 23 October 2019, 12:49:44 »
Update!!
Received prototype of the case, and here's a video of me going through the current status!
Offline PvtSkittles
« Reply #26 on: Mon, 06 January 2020, 14:19:22 »
I still absolutely love this design having come across it a few months ago. Hope to see more updates in the future!
Offline w3bb0
  • Keyboard Moment
    • Breakpoint
« Reply #27 on: Mon, 06 January 2020, 14:22:25 »
Currently working on a new pcb design with some new features such as a daughter board and indicator LEDs, sorry about the slow updates had a lot of irl things that required attention!
Sent from my ONEPLUS A5010 using Tapatalk
Offline i luv chuletas
« Reply #28 on: Tue, 24 March 2020, 13:13:27 »
I know you're doing the eclipse now, but any chance of this seeing the light of day at any point? Love the design of this for a 40's keyboard.
    • Linktree
« Reply #29 on: Tue, 24 March 2020, 13:34:15 »
Yeah I really want to do this one too. Now that I’ve gotten more experience i feel i’m more able to do this smoothly. Once the Eclipse is done, i might come back to this, even make this one a gasket mount too!
Offline envyy24
« Reply #30 on: Fri, 27 March 2020, 17:46:51 »
Pretty sweet design I think. There is one thing i dont quite get yet. For the long space bar layout, how do you access the 1st and the 2nd layout of the keyboard? My assumption here is that there would be 2 FN keys. Are those the code and the sys key in your prototype? If yes I am a bit concern that they are not very easy to use.
Offline paperassgasket
« Reply #31 on: Mon, 15 February 2021, 10:42:34 »
So now that there's a working prototype of the eclipse...
    • Linktree
« Reply #32 on: Tue, 16 February 2021, 01:24:55 »
Now you really make me want to get started on it already....
