Author Topic: [IC] ePBT Aesthetic | $79 base kit! Group Buy starts March 8th  (Read 95461 times)
Offline Willtato
  • I like small Keyboards
Re: [IC] KAT Aesthetic - Renders and Kitting added!
« Reply #50 on: Fri, 28 August 2020, 16:48:43 »
Love the idea.  One of my favourite spring ink combinations are the iroshizuku chiku-rin with kosumosu.
Anyway, what I am trying to say is that I think a lighter shade of green should work better.  It's too strong of a green, and I believe that instead of complimenting the pink, I think it overpowers it instead.
Sent from my HD1913 using Tapatalk
Offline VagueOrigin
« Reply #51 on: Fri, 28 August 2020, 17:32:03 »
I just need a date, these are ready to go in my eyes lmaooo
Sent from my SM-G975U using Tapatalk
Offline konstantin
  • Formerly constexpr
« Reply #52 on: Fri, 28 August 2020, 18:09:23 »
A few points of feedback:
Minibars kit:
  • You can safely drop the 2x 1u green spacebars because they are already offered in the ortho/40s kit and there are not any larger layouts which utilize 2x 1u spacebars
  • Because you already offer them in green in the 40s/Ortho kit, I recommend dropping the white and pink 2x 1u spacebars. This frees up 6u of space in the minibars kits. I doubt anyone picking up the 40s/Ortho kit will also pick up minibars just for different colored 1u spacebars.
  • In my opinion, you can drop all of the 1.25u spacebars from the minibars kit as you have plenty of 1.25u mod options which can be utilized instead.
40s/Ortho kit:
  • There appears to be two R2 1.5u "Enter" keys offered. You only need one.
  • 40s layouts which utilize a 1.75u spacebar use two and not one (JD40/45). However, since you offer the R1 1.75u lock key (for Minivan), it is not strictly necessary to add a second 1.75u spacebar as this key could be used as a spacebar.
Novelties:
  • I really like these. Well done!
I mostly agree, except I think that 1.25u spacekeys should be kept as they are useful for several layouts: Alice & similar (2u+1.25u), standard 6.25u split spacebar (2.75u+1.25u+2.25u, 2.25u+1.25u+2.75u), etc. A 1u spacekey is also useful for Alice, so one (of each color) should be dropped and the other should be kept.
Some further feedback on the kits:
Alphas kits
  • The green R4 1u \| / ヲ keys can be removed from the alphas kits. See here for an explanation.
  • The katakana alphas kits are missing a R4 1u ー key. This is the prolonged sound mark character, which is required for proper coverage of JP layouts. Example (this is a hiragana kit, but it's the same with katakana).
  • ISO/JIS alpha keys are missing from both kits. I suggest including R2 1u \|, R1 1u <> in the Latin alphas (example); and R2 1u ム, R1 1u ロ in the katakana alphas (example).
Mods kits
  • I suggest moving R5 1u Del from the numpad kits to the mods kits because this key is useful for 75% layouts. Example.
  • I also suggest including a R5 1u F13 key (green) in the mods kits.
  • The second R1 1u Ctrl can be removed from the mods kits, as this key isn't used on any modern ≥60% layouts.
  • As for the second R1 1u Alt key, it isn't useful unless you're also going to have 1.5u Sys keys in the mods kits (for Mac and OG HHKB bottom rows). You have a few (mutually exclusive) options here:
    • remove the second R1 1u Alt; or
    • keep it and add two R1 1.5u Sys keys; or
    • keep it and add one R1 1.5u Sys key (leaving R1 1.5u Fn to serve as the second one).
  • The conventional icon for Tab is ⇆ rather than ⇄ (top arrow is left-facing).
40s/Ortho kit
  • The following keys can be removed as they are totally useless:
    • R3 1u ↩
    • second R2 1.5u ↩ — replace it with a R2 1.5u ⇆ or ≡ instead (this is for boards like Pearl)
    • R1 1.75u ↩
  • Adding R2 1u ↩ is a must (for ortho boards).
  • Mod-colored R2 1u '" is also a must (for Planck and similar orthos).
  • Consider adding a R3 2u ⌫ for Candybar and 13u staggered 40s (Pearl, JD45, Laplace...).
  • Optionally, add a 6.25u spacebar for staggered 40s, unless you intend for users of these boards to get the Spacebars kit.
International kits
  • All of the keys such as é2, à0, òç, ù§ should have lowercase legends for the alpha characters.
  • These two keys: can be removed from the French kit as they are not used in practice.
I may be missing a thing or two, but this is good enough for now.
« Last Edit: Sat, 29 August 2020, 09:57:03 by konstantin »
Offline konstantin
« Reply #53 on: Sat, 29 August 2020, 09:56:21 »
A few more notes on your katakana alphas:
It looks like you opted to come up with your own variation of the Japanese layout rather than use one of the standard ones? For example, ケ, ワ, ゛, ゜ keys are missing; ロ and ム are in the wrong positions; there are duplicate ク and ヲ legends; and ヲ and ヱ (an obsolete kana), which I haven't seen included as primary legends before, are present in the kit.
For reference, this is the standard ANSI-based Japanese katakana layout:
I recommend basing your kit off of this. So, for example:
  • ロ should be moved to the tilde position (in both white and green);
  • ム should be moved to the pipe position (on both the R4 1u and white/green R3 1.5u keys);
  • the green R4 1u pipe key should be removed, as mentioned in my previous post;
  • R4 ヲ should be replaced with ワ;
  • the second R2 ク should be replaced with ケ;
  • ゛, ゜ should be placed on the bracket keys (you can have dotted boxes around these symbols to help them fit in aesthetically; example).
In addition to this, you should include the following keys for ISO and JIS support:
  • R2 1u ム
  • R1 1u ロ
  • R4 1u ー
Further reading
« Last Edit: Sat, 29 August 2020, 10:14:29 by konstantin »
Offline Flexmaster
« Reply #54 on: Sat, 29 August 2020, 11:50:08 »
Yes, please
Offline dededecline
    • Linktree
« Reply #55 on: Sun, 30 August 2020, 19:04:53 »
Minibars kit:
40s/Ortho kit:
Novelties:
  • R2 1u ム
  • R1 1u ロ
  • R4 1u ー
Further reading
Minibars kit:
40s/Ortho kit:
Novelties:
Alphas kits
Mods kits
40s/Ortho kit
    • R3 1u ↩
    • R1 1.75u ↩
International kits
  • These two keys:
Thanks for the feedback y'all, super appreciate the depth. Going to go through this soon and make changes.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #56 on: Fri, 11 September 2020, 16:41:23 »
I'm very glad you're offering a Colevrak kit.  I have a few suggestions to make it even better:
   • It's probably just a mistake, but the R3 "I" isn't needed and an R3 "L" is missing.
   • Please consider adding an icon backspace, especially since icon mods are sometimes more popular than text.
   • Please consider adding an R2 "]}" keycap to support Wide mod.
Wide mod layout info for anyone interested:
Offline dededecline
    • Linktree
« Reply #57 on: Fri, 11 September 2020, 17:29:52 »
Thanks for the feedback!
  • Yep, that I is supposed to be an L. Will be updated in the next revision. I'm burning through a lot of changes right now.
  • I was not aware of the wide mod, that's interesting. I've never taken the alternate layout plunge so this is all very new to me. I will add the closing brackets key to R2.
  • Yes! Not adding an icon mod backspace was an oversight, it will be there with the new revisions.
Offline dvorcol
« Reply #58 on: Fri, 11 September 2020, 18:04:54 »
If you're curious, this post is my attempt at a summary of alternate layouts.
Offline SimplyJeevS
« Reply #59 on: Sat, 12 September 2020, 06:19:52 »
Any chance that there will be a kit with English and Japanese subs? Looks super dope btw
Offline dededecline
    • Linktree
« Reply #60 on: Sat, 12 September 2020, 17:20:12 »
I toyed with the idea but I found the sublegends too busy, so I won't be adding them.
Offline yorsem
« Reply #61 on: Sat, 12 September 2020, 21:26:02 »
Absolutely have to have this set.
Offline MIXO Cables
« Reply #62 on: Sun, 13 September 2020, 22:54:57 »
looks like a pastel version of miami theme actually....
Offline dededecline
    • Linktree
« Reply #63 on: Mon, 28 September 2020, 13:24:38 »
Big updates to the set today! Check out the OP for collabs, new green color, all new kitting, and more. Full changelog:
* "aesthetic" katakana novelty changed to "vaporwave" katakana novelty
* basic TKL compatibility kit added
* katakana numpad numbers added to katakana alpha kits
* french, south, and north kits consolidated into international kit
* international and colevrak kits are now white instead of pink
* palm tree novelty redone with birds and sunset
* statue head redone to helios bust from floral shoppe cover
* abstract vaporwave novelty added
* more detail added to cherry blossom novelty
* fuji artisan redone
* apple and windows novelties moved into separate OS kit
* debian novelty added to OS kit
* pink mod kits added: text mods, icon mods, pink alpha numpad, white alpha numpad, 40s, ortho, ergo
* novelties and OS kits split out into pink and green kits
* 6.25u and 7u spacebars added to alpha kits
* spacebars removed from text and icon mod kits
* removed text from deskmat
* added accent color keys to 40s kits
* added katakana 'b' keys to minibars kit in each alpha color
* removed 1x 1u spacebar key from minibars kit in each color
* removed mod colored pipe key from alphas
* fixed katakana legends
* added basic ISO compatibility to alpha kits
* moved R5 1u delete key from numpads to text and icon mods kits
* added F13 key to text and icon mods kits
* removed 1x 1u ctrl key from text and icon mods kits
* add 1x R1 1.5 sys key to text and icon mod kits
* fixed tab icon (flipped along the x axis)
* split 40s and ortho kits into separate kits
* removed R1 1.75u enter from 40s kit
* added R2 1u enter to ortho kits
* added R2 1u '" mod colored key to ortho kits
* added R3 2u backspace to 40s kits
* added 6.25u spacebar to 40s kits
* various changes to ergo kits for better compatibility
* added second 2u space to 40s and ortho kits
* fixed I --> L in colevrak kit
* added wide mod support to colevrak kit
* added icon backspace to colevrak kit
* added pink mod keys to colevrak and international kits
* changed white alpha kit text color from purple to pink
* removed ergo blank kit
* changed the green used for the mods
* added pink mod colored tilde and pipe to white alpha kits
* added white novelty kit
* add text pause key to numpad
Offline aadk5
  • AKA: feeebleminded
« Reply #64 on: Mon, 28 September 2020, 19:05:19 »
Now that's an update if I've ever seen one. Really exciting to see all the work you're putting in on this. Can't wait for the GB!
Offline dededecline
    • Linktree
Confirmed some vendors!
Canada: Deskhero
Europe: mykeyboard.eu
Australia: Daily Clack
Offline ManoliVisuals
I like it alot, but personally I think the pink alphas would be better with white graphics.
Offline paperassgasket
Canada: Deskhero
Fingers crossed for Cannonkeys or TX for US
Feedback:
There are a ****ton of keys in the ergo set. I love it.
I'll be honest through. I have tried to fill out the latest IC (honestly) like a dozen times and had to close it without completing each time.
There are so many sets I really just cannot decide. I love the fact that you have options for combinations of everything but also I've got decision paralysis because of it.
Maybe talk to vendors about taking a cue from SA Sculpted Bliss and put ALL THE KITS into a single slightly discounted package?
I mean you'd only have to sell like 2 of those to hit MOQ.
Offline Buburoo
 :thumb:
Offline dededecline
    • Linktree
Some good updates today!
Added US vendor CannonKeys!
Added artisan collabs with deagcaps and Capsmiths!
Offline aadk5
Let's go! Upas and CannonKeys are great peeps; glad to see them on board as the vendors
Offline dededecline
    • Linktree
Re: [IC] KAT Aesthetic - US vendor confirmed, more artisan collabs added!
« Reply #71 on: Sun, 25 October 2020, 14:34:46 »
One more artisan collab confirmed! Very excited to announce we'll be working with Latrialum
Offline dededecline
    • Linktree
Re: [IC] ePBT Aesthetic | New kits and renders, Group Buy starts March 1st
« Reply #72 on: Thu, 18 February 2021, 14:00:30 »
Well it's been an interesting month but we're just about ready for Group Buy, but with a ton of changes! Check out the new ePBT Aesthetic in the OP! Group Buy starts March 1st.
Offline keebnewb
« Reply #73 on: Thu, 18 February 2021, 14:34:48 »
This is definitely my GB purchase for March!
Offline kajahtaa
« Reply #74 on: Thu, 18 February 2021, 17:04:23 »
I only drink Pu'er but this is awesome.
Offline FootFingers
« Reply #75 on: Thu, 18 February 2021, 17:41:43 »
This is hot
Offline kight
« Reply #76 on: Thu, 18 February 2021, 18:26:38 »
Not sure if it's just the resolution, but it looks like there might be a typo on the novelty enter? I see ヴェイパーウェイウ instead of ヴェイパーウェイヴ, last kana is missing the " on the side.
Offline renderling
« Reply #77 on: Thu, 18 February 2021, 19:51:54 »
Came here to ask about this as well. Great looking set!
Offline HungHingDaiLo
  • 無間道
« Reply #78 on: Thu, 18 February 2021, 20:04:06 »
Nice to see this change,.. finally! A very good one, if I may add.
Great job to TS (dede) and amazing renders, Plop!
If it's not too much of a trouble, would you provide render of Aesthetic on full-sized board? Just for us full-sized user to be convinced on how awesome this set looks on a big board.
Thanks, and GLWGB!
IG: @rayhhdailo
Offline dededecline
    • Linktree
« Reply #79 on: Fri, 19 February 2021, 00:33:07 »
Thanks, and GLWGB!
Thanks bud! I'll see what I can do for you :)
Offline dededecline
    • Linktree
« Reply #80 on: Fri, 19 February 2021, 00:38:51 »
Thank you both for pointing that out! I'll look into it
Offline Rx003
« Reply #81 on: Fri, 19 February 2021, 03:28:26 »
Ill get one Alt and base kit plus 2 of the deskmat thank you  :p :p :p :p
Offline dededecline
    • Linktree
« Reply #82 on: Tue, 23 February 2021, 12:23:47 »
Thanks for the feedback everyone! Made some changes based on valuable feedback:
* row numbers for the Katakana alphas were mislabeled, that's been fixed
* the vaporwave katakana enter novelty had a slight typo, that's also been fixed
* an international kit has been added with NorDe support
Offline lakeboredom
« Reply #83 on: Tue, 23 February 2021, 14:26:50 »
This is looking pretty sweet, damn. And the deskmats are nice too. Only thing I would change are the nav cluster icons, they seem a little too boomboxy if that makes sense. Like the icons you'd see on radio buttons. I think they could be adjusted to be a little more artsy/minimal to go with the other more traditional looking mods.
Offline nu_types
  • Formerly Iredeus
« Reply #84 on: Wed, 24 February 2021, 23:57:16 »
Any thoughts on adding generic ISO support to the base and alt kits instead of having both an ISO kit and an international kit? Using R4 "><" and R3"\|" keys is a common way to accomplish this. I'm sure a lot of ISO folks would appreciate ISO in the base, and a NorDeUK kit for those that want to have more specific ISO keys.
Offline dededecline
    • Linktree
« Reply #85 on: Thu, 25 February 2021, 14:05:30 »
I may do this depending on pricing but no promises
Offline dededecline
    • Linktree
Re: [IC] ePBT Aesthetic | New kits and renders, Group Buy starts March 8th
« Reply #86 on: Thu, 25 February 2021, 14:06:06 »
We are delaying the GB start date just slightly so that everything can be ready to go on the start date; group buy will now begin March 8th!
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #87 on: Sat, 27 February 2021, 20:09:39 »
When I type will lo-fi start playing?
Offline Trivent
    • Trivent Keyboards
« Reply #88 on: Sat, 27 February 2021, 20:18:02 »
I do like the colorway, but I like the cityscape deskmat even more. Absolutely brilliant design.
Offline dededecline
    • Linktree
« Reply #89 on: Sun, 28 February 2021, 11:46:13 »
I need to get a board with a piezo speaker to do just that
1stGarden is fantastic! Be sure to check out his site https://1st.garden/ for his prints and stream. We're working on a last-minute third deskmat for the set, check out his streams to see it get made!
« Reply #90 on: Sun, 28 February 2021, 15:24:35 »
Is the deskmat going to be available through 1stGarden's site or vendors?
e: also I took it upon myself to make a forums profile signature to show support for the set.
Code: [Select]
[url=https://geekhack.org/index.php?topic=101594.0][img width=350 height=120]https://i.imgur.com/S1rhCD0.jpg[/img][/url]
« Last Edit: Sun, 28 February 2021, 15:26:20 by paperassgasket »
Offline dededecline
    • Linktree
« Reply #91 on: Sun, 28 February 2021, 15:27:17 »
It will be sold through vendors!
Offline dededecline
    • Linktree
Pricing information starting to come in! CannonKeys and KBDFans prices added, I can't tell you how excited I am about these! Get a ton of bang for your buck, and ePBT has been putting out some impressive sets recently so I know we're going to have a good GB experience here  :D
⠀CannonKeys (USA)KBDFans (CN)
Base Kit$79$79
Katakana Alphas$23$23
Alt Mods$44$44
Numpad$18$18
Spacebars$20$20
Minibars$19$19
40s/Ortho$28$28
ISO$10$10
International$18$18
Green Novelties$25$25
Pink Novelties$19$19
White Novelties$19$19
I will keep all prices up to date in the OP as they come in!
At these prices I'm about to be handing out keysets like Oprah
Offline SleepyJacky
Re: [IC] ePBT Aesthetic | $79 base kit! Group Buy starts March 8th
« Reply #94 on: Mon, 01 March 2021, 15:05:31 »
That Cityscape deskmat is GORGEOUS damn. <3 Excited for this.
Offline dededecline
    • Linktree
« Reply #95 on: Tue, 02 March 2021, 13:36:17 »
Pricing for Deskhero and Prototypist added!
Offline ZavaZ86
« Reply #96 on: Wed, 03 March 2021, 11:18:07 »
Considering it's ePBT 80$ for a small basekit without numpad is definitely not cheap which is pretty off putting
« Reply #97 on: Wed, 03 March 2021, 11:38:11 »
I disagree. I think it's exceptionally cheap, but I suppose it depends on what you're comparing it to and how much of a price difference qualifies as "cheap."
Keeping it to ePBT offerings, this is about $20 cheaper than most sets I can recall offhand.
ePBT Samurai was $100 and didn't include a numpad.
ePBT Be The One is $105.
ePBT Ivory  and ePBT ramenstop were only $75 but didn't have to use reverse dye sub and didn't have custom mods in base. (not that it really matters with dye sub)
This seems very consistent with other ePBT sets. The other kits outside of base is where this set REALLY shines though.
« Last Edit: Wed, 03 March 2021, 11:40:52 by paperassgasket »
Offline dededecline
    • Linktree
« Reply #98 on: Wed, 03 March 2021, 14:14:27 »
Respectfully, I'm not sure what your basis for ePBT pricing and kitting is, but there are few sets that I think have beat this in price and/or included numpad in the base kit. The few that beat it in price are generally ones that have a monochrome base alpha and mod color, such as ModernJA and Kon Momo, and those are not too much cheaper.
If you're referring to the sets made and sold by ePBT themselves (via KBDFans), those have the benefit of in-house development, single-kit kitting, and high production numbers; that's a very different beast. They also do not afford the same level of compatibility.
Offline dededecline
    • Linktree
« Reply #99 on: Thu, 04 March 2021, 19:40:06 »
Monokei and Daily Clack prices added!
