Author Topic: [IC]GMK Invictus  (Read 11978 times)
Offline TekladoDesignLab
[IC]GMK Invictus
« on: Mon, 05 August 2019, 07:49:30 »
GMK Invictus
Base Kit Concept
Let me know what other kits you would like to see!
Coming Soon: Finalize Font, Make an icon for Esc Key, More Kits, Realistic Renders, Boxart & Deskpad
Vendor list and price quotes will come later down the road
Offline The_Royal
  • That's what I call, a Sunday.
Re: [IC]GMK Invictus
« Reply #1 on: Mon, 05 August 2019, 07:50:37 »
InB4 “THATS OLIVIA”
Offline nyry43
« Reply #2 on: Mon, 05 August 2019, 07:53:50 »
Looks nice!
Offline InvidiousIgnoramus
« Reply #3 on: Mon, 05 August 2019, 07:58:18 »
You uh, should probably have a little more to go on for an IC. And maybe a comment history.
I long for the day when I find a beamspring. (At a not insane price)
Offline KingOfMemes
« Reply #4 on: Mon, 05 August 2019, 08:44:58 »
I'll be watching this closely
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #5 on: Mon, 05 August 2019, 09:10:38 »
Looks good and UK-ISO is in base! Maybe get some renders done and add some context? This IC could do with some fleshing out.
Offline dibkib
« Reply #6 on: Mon, 05 August 2019, 09:27:19 »
Looks interesting and a little softer than Olivia, which I think would work really well!
« Reply #7 on: Mon, 05 August 2019, 09:30:54 »
Will definitely add some context in the near future, just figuring out how to explain the color palette since the inspiration for it is pretty weird haha
Offline Bleddyn
« Reply #8 on: Mon, 05 August 2019, 10:01:19 »
No need. i know your inspo for this....
Offline depletedvespene
    • Keyboard-related resources.
« Reply #9 on: Mon, 05 August 2019, 10:15:33 »
Please take note that in your render, you have UK ISO support built into the base kit, but it's missing one key: the R3 '@ key; the R1 `¬ is rendered as `~. The former needs to be added and the latter, corrected.
Also note that you could add one more key, R3 \|, to the base kit and with it go from UK ISO support to US+UK ISO support.
Besides that, I find it strange that you'd add the R2 1.5U \| key twice.
I won't comment on the colourway itself, as that strictly subjective, but I also find it weird that you have only accent-colored ANSI and ISO Enter keys, but the numpad Enter is present twice (mod-colored and accent-colored).
« Reply #10 on: Mon, 05 August 2019, 11:16:53 »
Thanks for the tip! Will definitely fix the wrong keys in the next update. I made this from a kle template my friend sent to me and didn't bother to check the keys
« Reply #11 on: Mon, 05 August 2019, 11:19:21 »
Haha pretty close, that came into my mind too but i actually based the colorway off this image
Offline adxlk
« Reply #12 on: Mon, 05 August 2019, 11:26:09 »
Dude, please align the colorway to IG skin line. That's probably the best skin line
Offline ptrick3
« Reply #13 on: Mon, 05 August 2019, 11:30:01 »
Some dark keys with light blue accents would actually look real cool based on the inspo art.
Offline trg1234
« Reply #14 on: Mon, 05 August 2019, 13:39:41 »
This that skin line is one of the best in the game.
« Reply #15 on: Mon, 05 August 2019, 15:23:59 »
Sounds like a really cool idea, will experiment with this.
Offline forevermadrigal
« Reply #16 on: Mon, 05 August 2019, 16:14:36 »
Irelia op.
Offline Xynerorias
  • Lubin' with glicerin
« Reply #17 on: Tue, 06 August 2019, 19:01:22 »
Ooooh, I like some of that muted toned down look, and the colors too.
This looks sorta complementary to Firefly (in terms of colors).
I'll wait for more renders and more developpement to say if I'd like it/if I'd buy it.
Sent from my ONE A2001 using Tapatalk
Offline Desolace
« Reply #18 on: Fri, 09 August 2019, 04:09:33 »
I agree with some of the other posts, really like the muted colors. Hoopefully we can see some renders soon!
Offline TokyoExpress
  • bambino screech
« Reply #19 on: Fri, 09 August 2019, 05:10:37 »
not bad. consider me in
Offline appaboy
« Reply #20 on: Fri, 09 August 2019, 05:16:11 »
Please no forced accent spacebars.
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline Corgiattackkk
« Reply #21 on: Fri, 09 August 2019, 17:11:09 »
Please forced accent spacebars.
Offline KingOfMemes
« Reply #23 on: Fri, 09 August 2019, 17:33:19 »
Force Accent bars plx thx
Offline Dandogood
« Reply #24 on: Fri, 09 August 2019, 18:25:55 »
Looks good
Offline pheonix991
« Reply #25 on: Sat, 10 August 2019, 13:13:32 »
Is this Olivia?
Offline megaforce
« Reply #26 on: Sat, 10 August 2019, 13:19:25 »
does this come with the invictus leblanc or irelia skin?
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline MdotMaxson
« Reply #27 on: Sun, 11 August 2019, 00:09:38 »
I’d take this over Olivia any day.
Offline rockinkingdom
« Reply #28 on: Sun, 11 August 2019, 20:09:52 »
yes please
Offline ymaaan
« Reply #29 on: Sun, 11 August 2019, 20:48:39 »
yes pls. would immediately grab this set if this ever goes live
Offline Mcnos
    • GMK Fuyu
« Reply #30 on: Sun, 11 August 2019, 21:40:24 »
« Reply #31 on: Tue, 13 August 2019, 13:43:50 »
No but it will take you to challenger
Offline ecbob
« Reply #32 on: Tue, 13 August 2019, 13:54:16 »
This is more based off the splash art than the in game skin. Pink isnt really the in game skin color. The characters are mostly blonde so maybe if you can add some more blonde and blue, then this will match the skin line.
