Author Topic: [IC] Koala Switches  (Read 46761 times)
Offline fropsie
[IC] Koala Switches
« on: Thu, 22 August 2019, 16:22:29 »
The Koala Switch
The koala switch, designed by creator biip, is a tactile switch using a POM stem and 62g gold spring inside a Nylon housing, with a color scheme matching that of Extended 2048.
First run of the group buy will be limited to 150 orders with an MOQ of 10,000 Switches sold, and if enough interest is generated, more runs will be launched in the future.
Switches will be produced by durock.
This IC has been authorized by biip
Interest Check - https://forms.gle/UmXCZFGm5FkCBhDY9
When will the GB Launch: TBA (Would like to run IC first to then make a decision)
Order Quantities: Minimum Order Quantity is 70 Switches per order.
Pricing: Current pricing is planned for $0.48 per switch, but is subject to change based on reception.
Shipping: Will Ship out 8-12 weeks after all invoices are paid.
« Last Edit: Fri, 23 August 2019, 00:37:57 by fropsie »
Offline biip
    • @biipmk
Re: [IC] Koala Switches
« Reply #1 on: Thu, 22 August 2019, 16:25:55 »
Offline Mcnos
    • GMK Fuyu
« Reply #2 on: Thu, 22 August 2019, 16:27:51 »
Thanks, I'm in.
Offline nasp
« Reply #3 on: Thu, 22 August 2019, 16:34:52 »
Can you explain more about the switch? What's the tactility like compared to other switches? Is this a Panda clone? Manufacturer?
Offline Walkerstop
« Reply #4 on: Thu, 22 August 2019, 16:38:43 »
Looks cool, interested.
What will the tops say on them?  (not KBDFans I'm guessing)
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #5 on: Thu, 22 August 2019, 16:40:05 »
Koala's are back!?!
After getting the time to mess with the T1s, are the tolerances still gonna be kinda poopy? T1s had a TON of wobble from inbetween the top and bottom housing, and needed films desperately. Hoping these are more tight!
Offline rondg
« Reply #6 on: Thu, 22 August 2019, 16:40:24 »
Interested  ;D
Offline lush_bunny
« Reply #7 on: Thu, 22 August 2019, 17:00:10 »
nice
« Last Edit: Sat, 21 September 2019, 19:30:17 by lush_bunny »
Offline Tequila_Heineken
« Reply #8 on: Thu, 22 August 2019, 17:04:36 »
yes
Offline kgorin
  • Formerly aka_gk
« Reply #9 on: Thu, 22 August 2019, 17:25:01 »
who's the manufacturer? same as T1?
Offline PikaJoyce
« Reply #10 on: Thu, 22 August 2019, 17:34:51 »
Curious about this as well.
Offline zekth
« Reply #11 on: Thu, 22 August 2019, 17:35:16 »
I'm in  :)
Offline KickDrumsandRedWine
« Reply #12 on: Thu, 22 August 2019, 17:41:36 »
I'm down for a new tactile switch for my next build
Offline Popopro
« Reply #13 on: Thu, 22 August 2019, 17:44:54 »
Will kbdfans be handling the buy like last time?
Offline EMC Labs
« Reply #14 on: Thu, 22 August 2019, 17:48:46 »
Thank you, I'm also in.
Offline dnmtbr
« Reply #15 on: Thu, 22 August 2019, 18:33:00 »
Durock is selling these on Alibaba right now.
Offline djmantis
« Reply #16 on: Thu, 22 August 2019, 18:35:43 »
I am interested. I didn't know these were already on sale on Alibaba, just in different spring weights.
Offline phunktional
« Reply #17 on: Thu, 22 August 2019, 18:36:29 »
Interested
Offline Loligagger
« Reply #18 on: Thu, 22 August 2019, 18:49:08 »
Color me interested.
Offline Solotov
« Reply #19 on: Thu, 22 August 2019, 19:03:53 »
I’m in  ;D Also, could you please describe a bit of the tactility and feel of the switch you expect them to be?
Flex is love, flex is life.
Offline Vigrith
« Reply #20 on: Thu, 22 August 2019, 19:09:54 »
Linear version when?
Offline Tre3Cycl3S
« Reply #21 on: Thu, 22 August 2019, 20:43:35 »
Definitely interested!
QFR           HHKB Pro-2     JD45         VE.A                    XMIT 61-Key       JD40 Mk.II                    Realforce 87U     M65-A                 Custom:Annie      NightFox      Pearl                  E6-V2 R2                          Norbaforce
MX Blue     45g Topre        MX Blue     R5 67g Zealios     50g Hall Effect     Modded Gateron Red     55g Topre           R5 78g Zealios     62g Ergo Grey     Hako True     R9 62g Zilent     Lubed Holy Trash Panda     OG Sony BKE Domes
Offline eniigma
    • Storefront:
« Reply #22 on: Thu, 22 August 2019, 21:14:09 »
Interested!
Sent from my SM-G973U using Tapatalk
Offline leexy
« Reply #23 on: Thu, 22 August 2019, 21:42:16 »
interested
Offline Lil
    • designedbydark
« Reply #24 on: Thu, 22 August 2019, 22:02:34 »
Int
Offline HoodrowThrillson
« Reply #25 on: Thu, 22 August 2019, 22:26:59 »
Guess I gotta buy some.
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline DasGnome
« Reply #26 on: Thu, 22 August 2019, 22:53:21 »
OP has stated on Reddit that this is the same manufacturer as T1. This is an important point depending on your interpretation of the stealios fiasco.
« Reply #27 on: Thu, 22 August 2019, 23:02:29 »
link?
Offline Nigolski
« Reply #28 on: Thu, 22 August 2019, 23:06:38 »
shieeet
Offline KingOfMemes
« Reply #29 on: Thu, 22 August 2019, 23:12:34 »
Either way, weren't the t1s great switches? No matter which way you want to interpret the drama, the switches were good. If that's the case, then why should I, as a consumer, care either way about the ethics of the manufacturer as long as they produce a quality, affordable switch?
Offline wholypantalones
  • text and icon mods plz.
« Reply #30 on: Thu, 22 August 2019, 23:19:01 »
link?
https://www.reddit.com/r/mechmarket/comments/cu59t1/ic_koala_switches/
Offline PotatoTM
« Reply #31 on: Thu, 22 August 2019, 23:58:56 »
was sad the first run got cancelled, interested.
Offline nguyenhimself
« Reply #32 on: Thu, 22 August 2019, 23:59:52 »
It depends on whether you want to support a bad actor, who had no problem stealing designs from other people giving them zero payment or credit.
I mean, "as a consumer", you can do a lot of stuffs that benefit you but hurt others. If a thief is selling you a laptop you know he stole from someone, would you still buy it?
You're free to be selfish. But sometimes it's nice to be selfless too.
« Last Edit: Fri, 23 August 2019, 00:02:04 by nguyenhimself »
« Reply #33 on: Fri, 23 August 2019, 00:11:22 »
imagine copying a switch design and selling it.
Offline AlcoholEnthusiast
« Reply #34 on: Fri, 23 August 2019, 00:13:21 »
Interested
Offline KingOfMemes
« Reply #35 on: Fri, 23 August 2019, 00:25:57 »
Lol seriously. My dollar goes to the goes to the best product at the best price. IP isn't a laptop. My ethics are tied to my wallet, just like the people 'stealing' IP, and just like the people getting upset about their IP getting 'stolen'.
Offline mSSM
« Reply #36 on: Fri, 23 August 2019, 02:38:50 »
I think also offering the 67g spring would be great.
Offline King4477
« Reply #37 on: Fri, 23 August 2019, 06:57:38 »
Supporting those who take advantage of or outright steal from other creators in a small market is a great way to stymie future developments, since the creators of new designs will have lower incentives to spend their time and money making something that can just be ripped off without repercussions. That ultimately means fewer and worse options for the consumer.
If you like this hobby, you don’t support its bad actors.
Offline kgorin
  • Formerly aka_gk
« Reply #38 on: Fri, 23 August 2019, 07:54:37 »
wow, just wow
Offline nyry43
« Reply #39 on: Fri, 23 August 2019, 08:07:27 »
These look neat. Looking forward to more info on them.
« Reply #40 on: Fri, 23 August 2019, 08:14:03 »
Let's not turn this into a stolen switch design **** show. Every switch out today is a blatant copy of another switch; tweaked design or not.
If you would like to pay a premium for certain switches, so be it. Many of us would like to see these switches get made regardless of who manufacturers them.
Offline KingOfMemes
« Reply #41 on: Fri, 23 August 2019, 08:17:17 »
But muh ethix
Offline DasGnome
« Reply #42 on: Fri, 23 August 2019, 08:35:30 »
I don't think anyone gives a **** about using the design like all other MX switches. A manufacturer knowingly produced and sold counterfeits. That's just outright deception.
Offline KaosJ
« Reply #43 on: Fri, 23 August 2019, 08:42:09 »
I would be in
Offline King4477
« Reply #44 on: Fri, 23 August 2019, 08:58:07 »
My point exactly. There’s a big difference between using a design from an expired MX patent after a lawful period of exclusivity, and making and selling counterfeit products.
If I were Zeal and I had an idea that might bloom into the next big thing, I might think twice about spending any effort in R&D or ever releasing it since some con-artist company might just copy it, sell it as its own and get away with it. Long run, supporting fraudsters undermines everyone’s best interests.
Offline KingOfMemes
« Reply #45 on: Fri, 23 August 2019, 09:11:40 »
But that wasn't your point at all when you said this:
Counterfeiting is being deceptive and selling a product that isn't what you say it is, which is bad and ACTUALLY terrible for the consumer... but that isn't the same as selling a copy of a switch, calling it something else, and doing so at a lower price than the original.
Offline lac29
« Reply #46 on: Fri, 23 August 2019, 09:14:07 »
I'm interested and also am someone who prefers 65-70g springs if they are an option.
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #47 on: Fri, 23 August 2019, 09:21:34 »
Seems like this could be a koala-tee switch.
Offline KingOfMemes
« Reply #48 on: Fri, 23 August 2019, 09:27:28 »
Oh no...
Offline King4477
« Reply #49 on: Fri, 23 August 2019, 09:38:19 »
Agreed... sorry for the nuanced argument, let me help spell it out:
Counterfeiting = bad
People who counterfeit = counterfeiters
Supporting counterfeiters when they come out with “new” designs gives the counterfeiter more $ and perpetuates their bad actions = bad
More counterfeiter bad actions = less innovation by others = bad
Sorry again for the big words. Hope this makes sense.
