Author Topic: [GB] Fox Lab - Key 65  (Read 763559 times)
Offline LazyJackfruit
Re: [GB] Fox Lab - Key 65
« Reply #1150 on: Tue, 05 May 2020, 14:01:42 »
Just received my invoice. If its any consolation for those yet to receive one, there was a (370) beside the invoice which may refer to the current order that was just processed, out of the 480 total boards ordered.  The (370) didn't refer to my order # nor the invoice # on the spreadsheet for reference. $71 shipping to TX.
Offline Tyson
« Reply #1151 on: Tue, 05 May 2020, 14:26:03 »
If anyone gets there's in and isn't happy with it I'd love to buy it from you, I don't mind the color combination either, I have the resources to change the color if I really want to (Unless it's polycarb lol).
Offline deathjester
« Reply #1152 on: Tue, 05 May 2020, 14:40:48 »
Just paid my invoice. Absolutely stoked!!
Offline Wongstongs
« Reply #1153 on: Tue, 05 May 2020, 14:54:05 »
Do these PCBs have a keycode to enter bootmapper/reset mode?  I dont want to desolder the reset button only to find out that there isn't a way to flash the board going forward.
Fn+esc
Just flashed mine using QMK toolbox
Offline Aiwanei
    • ThocKeys.com
« Reply #1154 on: Tue, 05 May 2020, 15:10:18 »
Hmm, how did that happen? It's an alu full plate, right?
Yeah full alu plate. I'm assuming one of my switch legs in the middle of the board was touching the bottom of the case, but can't be certain. The foam did fix it.
With all of the gaskets installed, you really do have to screw this thing together tight, so it might be the gaskets forcing things closer together?
I actually had to loosen mine, had tightened it up and the board stopped working, because the reset switch was being hit constantly, even after trimming it.  So I guess I'm going to possibly remove the reset switch.
ThocKeys.com
Offline InediblePi
« Reply #1155 on: Tue, 05 May 2020, 15:25:56 »
Looking to trade my PC Key65 with WK and brass key logo for an e-black Key65 with e-pink key logo. If interested, please PM me for complete build details!
Offline noodleman
« Reply #1156 on: Tue, 05 May 2020, 15:34:55 »
ne via avail?
Offline Felt
« Reply #1157 on: Tue, 05 May 2020, 16:07:24 »
Quick room poll, is there anyone who got an alu case that HAS NOT had an issue with the reset button/board not working? There's just no way this issue made it through QC D:
Also, wouldn't any layer (foam, rubber, etc.) in between the pcb and the bottom of the case --> eliminate space and make it more likely for the reset button to unintentionally trigger? Or is the reset button not on the face-down side of the pcb like I think it is...?
Offline toanta
« Reply #1158 on: Tue, 05 May 2020, 16:19:44 »
This is pretty concerning as people are finding out this issue now.
Offline airyimbin
« Reply #1159 on: Tue, 05 May 2020, 16:33:26 »
I have a PC plate/case and not having this issue
Sent from my SM-N960U using Tapatalk
Offline 4nalee
« Reply #1160 on: Tue, 05 May 2020, 17:29:49 »
Mine came in the mail today but I received a 6.25u spacebar plate instead of a 7u spacebar plate. Does anyone have an extra plate they don't need that they can sell me?
Offline noideawhatsgoing
« Reply #1161 on: Tue, 05 May 2020, 17:40:56 »
[Deleted]
« Last Edit: Tue, 12 May 2020, 00:07:40 by noideawhatsgoing »
Offline edctog
« Reply #1162 on: Tue, 05 May 2020, 19:50:57 »
Thing of Beauty!
Offline edctog
« Reply #1163 on: Tue, 05 May 2020, 19:54:35 »
Nope, not for me. I installed all 16 gaskets for the plate and the silicone sound dampener. There is plenty of space between the bottom of the case and the reset button.
Offline thecyangiant
« Reply #1164 on: Tue, 05 May 2020, 19:57:22 »
Thing of Beauty!
Ohh looks nice! What is the cable solution, looks like you have an aviation adapter on the board at the USB port?
Sent from my SM-N950U using Tapatalk
Offline Knoxx
  • Spends too much on keyboards
« Reply #1165 on: Tue, 05 May 2020, 20:13:08 »
Just got mine as well. 392
Offline clankgy1
  • Formerly digifiend
« Reply #1166 on: Tue, 05 May 2020, 21:24:14 »
Not directly addressed at you, but why would you have plenty of space between bottom of case and reset button while others are having issues with button contacting plate?  Seems like a very big variance.  I'm waiting on switches before putting mine together. but this is a curious development.
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
Offline edctog
« Reply #1167 on: Tue, 05 May 2020, 22:12:36 »
Well, I read people reviews on Zfrontier and some have this problem. But they also didn't install all of the gaskets correctly as mentioned by some other people.  I might exaggerate by plenty of space, but I didn't have any difficulty put the bottom part on the case. It didn't feel like I pressed the PCB back or anything. The reset button is not at the lowest part of the PCB so if the lowest part made it, the reset button should be fine. Mine is a hotswap though, so I can't say for sure for the universal one.
Offline edctog
« Reply #1168 on: Tue, 05 May 2020, 22:40:30 »
I apologize. In my haste, I didn't see that you are asking specifically Alu buyers. Mine is PC. However, I can answer the part about the placement of the reset button. It's on the bottom side (face-down side like you said). The silicone pad included with this case is to sandwich between the PCB and the plate, not for the bottom of the case. It doesn't push the PCB any further down. I think maybe Alu users are tightening the screws more than they should and/or they didn't install all of the gasket pieces (16 for the plates and 6 for the middle case).
Offline merkz
« Reply #1169 on: Tue, 05 May 2020, 23:50:52 »
Just got my shipping invoice, twas $68 to Florida
Offline clankgy1
« Reply #1170 on: Tue, 05 May 2020, 23:52:55 »
This makes a lot of sense as to why some builds are having issues.  Lack of gasket installation would certainly affect bottom clearance.
Edit: Question on gaskets: (16 for the plates and 6 for the middle case).  I understand the gaskets on top and middle case for plates, what do the other 6 do and where do they go?  I have my keeb packed up until switches arrive, but I dont want to miss any gasket locations.
« Last Edit: Wed, 06 May 2020, 00:06:23 by clankgy1 »
Offline vsrnth
« Reply #1171 on: Wed, 06 May 2020, 00:19:51 »
I'm just gonna wait for a streamer to build it, and only them am I gonna build mine.
Sent from my SM-G975F using Tapatalk
Offline clankgy1
« Reply #1172 on: Wed, 06 May 2020, 00:32:32 »
Thought about having a streamer build mine tbh, but I am anal retentive about my stabs.  Yes even more so than some of the streamers I have seen.  (and it prob wouldn't end up on stream unless i was first one).
Offline karmbit klacks
« Reply #1173 on: Wed, 06 May 2020, 03:21:28 »
Seeing everyone's builds is making me sad that I have yet to receive my shipping invoice :( anyone else on the same boat?
Offline MsCookz
« Reply #1174 on: Wed, 06 May 2020, 05:07:34 »
got my invoice yesterday and I'm in the last batch
Offline Cujo96
« Reply #1175 on: Wed, 06 May 2020, 06:54:31 »
You can pull off the middle layer and you put the 6 gaskets between the bottom and the middle layer, there's grooves where they need to go. Or at least I hope, if not I just ****ed up my keyboard badly LMAO
also, when will firmware be available on gmk
Offline Knoxx
« Reply #1176 on: Wed, 06 May 2020, 07:16:28 »
If only this thing had a build guide like polaris did. That thing was bloody helpful.
Also think u mixed up GMK and QMK. I don't think anyone knows when it'll be up.
Offline matrixzj
« Reply #1177 on: Wed, 06 May 2020, 07:25:00 »
have you put all gaskets rubber on ? as tested, if all rubbers were put on the right position and reset key was clipped, it will not be happened
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline kabocha
« Reply #1178 on: Wed, 06 May 2020, 07:39:12 »
Just finished my build. Love the board. However, as mentioned in the thread, the physical reset button on the universal pcb ends up pressing against the bottom case. I ended up desoldering the reset switch from the pcb. Another issue I had was the soldering pad around the split backspace, the pad was not registering from the back and I ended up having to add some solder from the switch side.
« Last Edit: Wed, 06 May 2020, 07:41:26 by kabocha »
Offline Cujo96
« Reply #1179 on: Wed, 06 May 2020, 09:13:35 »
I can't speak for everyone else, but I have all the gaskets on correctly as far as I know, button has been trimmed and I still get the reset button problem (full pc board if it matters) if I press down on caps hard enough. Obvious solution is to not press down caps hard.
Offline Myk!
« Reply #1180 on: Wed, 06 May 2020, 09:19:07 »
Why they use a big reset button? >.<
It would be better just use short pins on gap of space bar plate accessible from top.
« Last Edit: Wed, 06 May 2020, 09:26:33 by Myk! »
Offline vsrnth
« Reply #1181 on: Wed, 06 May 2020, 09:23:17 »
That's scary to know, that there is something fundamentally wrong with pcb's.
« Reply #1182 on: Wed, 06 May 2020, 09:26:26 »
Might be a dumb question, but I'll shoot it off anyway: If the reset button is desoldered, can the pads be jumped manually for resetting if needed?
Offline Wongstongs
« Reply #1183 on: Wed, 06 May 2020, 09:27:06 »
Yes I installed all of the gaskets. 8 on either side where the plate rests and 6 between the bottom and middle pieces.
Offline Myk!
« Reply #1184 on: Wed, 06 May 2020, 09:27:49 »
Of course. Or use combination on keymap for reset.
I always use Fn+Space+R. With this, you do not need to open the case just to flash.
« Reply #1185 on: Wed, 06 May 2020, 09:41:40 »
I definitely use a reset combo/layer, but it is nice to know that I have a hardware method of resetting if things get too sideways.
If jumping is possible I don't really think there is a problem de-soldering the button, assuming the aluminum case or weight won't  jump the reset pads.
Offline achan7942
« Reply #1186 on: Wed, 06 May 2020, 10:16:52 »
Easy to add a ws2812 rgb led strip !
« Reply #1187 on: Wed, 06 May 2020, 10:21:13 »
Nice! Do you have any control over it with the default firmware?
EDIT: also, when the strip is affixed, will it have clearance issues with the case? Thinking about the reset button issue and how little clearance there is makes me wonder if this will fit.
« Last Edit: Wed, 06 May 2020, 10:26:10 by thecyangiant »
Offline achan7942
« Reply #1188 on: Wed, 06 May 2020, 10:26:44 »
default firmware for the solder version has fn+ q / w/ e/ r mapped to RBG controls..
However, the default firmware only allows 6 leds so you are going to have to import the universal firmware from the front page on to kbfirmware and set to the number of leds you want.
Offline airyimbin
« Reply #1189 on: Wed, 06 May 2020, 10:29:58 »
I have a PC case and plate and noticed that pressing hard on caps lock does reset my board as well.
It hasn't triggered while I've been normally using the board since I also have caps mapped to lctrl.
I too might just de solder the reset button.
Offline Tyson
« Reply #1190 on: Wed, 06 May 2020, 10:35:49 »
I take back my request to buy this board, this reset pin issue is a big yikes. I'll just wait for another 65 to come out. No biggie.
Offline achan7942
« Reply #1191 on: Wed, 06 May 2020, 10:50:48 »
i mean...i wouldn't really say its that big of an issue that you disqualify any interest in the board, the pcb functions perfectly fine otherwise. You have to press really hard (which you would never do when typing normally) to get it to reset when gaskets are put in. plus, de-soldering is a 5 second job and mapping the reset key is easy(already mapped stock).
Still a sweet board imo.
Offline airyimbin
« Reply #1192 on: Wed, 06 May 2020, 10:54:04 »
I totally agree with you. I just unsoldered it right now and it took no time at all. This is a fantastic board and just one reset button doesn't change it at all. Could probably get a flatter reset button anyway the area seems like it fit anything.
Offline Wongstongs
« Reply #1193 on: Wed, 06 May 2020, 10:55:23 »
I didn't have to press whatsoever on mine to get it to trip.
Offline Felt
« Reply #1194 on: Wed, 06 May 2020, 11:09:57 »
This looks like the move. Going to desolder the reset button and adore this board to the fullest but darn what a QC botch lol
Offline senter
« Reply #1195 on: Wed, 06 May 2020, 11:18:37 »
Sorry about the rest button issue.
We identified the reset button issue after sending out the Chinese orders. It happened because the PCB supplier changed the BOM after the prototype was tested. We have removed the physical reset buttons for all the following PCBs. Only the first 40 or so PCBs still have the physical reset button. You can simply remove it with a wirecutter or soldering iron. It's not a necessary part for the PCB.
Offline Arithmetics
« Reply #1196 on: Wed, 06 May 2020, 11:20:01 »
why is this not in qmk???
theoretically this could have been done a long time ago
Offline clankgy1
« Reply #1197 on: Wed, 06 May 2020, 13:02:45 »
I'm selling my Key65 (layoff from work announced) unassembled.  #562 in google doc below.  PM me if interested.  (EDIT: SOLD, thanks)
https://docs.google.com/spreadsheets/d/1Ke59MgAsZ6ndgRrGKoOHbbexn5sZshrAS9p2pbRq0U0/edit#gid=0
« Last Edit: Wed, 06 May 2020, 15:43:37 by clankgy1 »
Offline thecheeselouise
« Reply #1198 on: Wed, 06 May 2020, 14:00:49 »
Has anyone had any luck with programming their key65 yet? When I head into QMK confiq the pcb isn't listed. I saw the .hex and .json files, but I am unsure what use these are without the keyboard being listed in the config. I've always just used VIA in the past but, it doesnt seem that VIA is able to recognize this PCB.
Offline dommyy13
« Reply #1199 on: Wed, 06 May 2020, 14:07:57 »
you can use the website linked (https://kbfirmware.com/) and upload the json file.  after you change the keymap and stuff you'll see and option to compile as a hex file.  The hex file you use in qmk to flash keyboard with.  Use it as a local file in the QMK toolbox instead of selecting your keyboard from the list.
