Author Topic: [GB] Fox Lab - Key 65  (Read 752003 times)
Offline olsen34
Re: [GB] Fox Lab - Key 65
« Reply #1850 on: Wed, 05 August 2020, 09:47:28 »
« Last Edit: Wed, 05 August 2020, 11:54:56 by olsen34 »
Offline suparnemo
« Reply #1851 on: Fri, 14 August 2020, 15:14:19 »
There are still several spare PCBs.
 Now they can only be shipped to CONUS tho.
Do you still have some? My PCB keeps turning off. The reset button is not there.
Offline axisean1
« Reply #1852 on: Sat, 15 August 2020, 16:25:44 »
has anyone tried a build with a pom plate? or does someone have an extra PC plate for sale?
Offline jordanchan_
« Reply #1853 on: Wed, 19 August 2020, 16:50:33 »
If anyone has a spare hotswap PCB or any spare parts they'd like to sell, please let me know!!
« Last Edit: Thu, 20 August 2020, 10:55:51 by jordanchan_ »
Offline olsen34
« Reply #1854 on: Sun, 23 August 2020, 00:07:13 »
Am I just really unlucky or what? I purchased an extra pcb from senter and it malfunctioned upon plugging in. Then he replaced it with a new one and it also malfunctioned.
Offline dommyy13
« Reply #1855 on: Sun, 23 August 2020, 03:41:37 »
then it might be the cable you're using
Offline olsen34
« Reply #1856 on: Sun, 23 August 2020, 11:45:51 »
Nah, my key65 GB pcb is working just fine. Same cable same laptop. These 2 extra pcbs were busted the moment I plugged them in. Even tried with different cable / port still broken.
Offline PantoneC
« Reply #1857 on: Sun, 23 August 2020, 15:13:43 »
Same here got extra pcb no issue everything worked just fine.
Offline axisean1
« Reply #1858 on: Tue, 25 August 2020, 19:01:12 »
has anyone done a half plate build yet?
Offline mambamental1ty
« Reply #1859 on: Tue, 25 August 2020, 23:14:39 »
Has anyone had any luck filling in their kanji logo with acrylic paint themselves? I purchased mine on the after market and it's blank. Would I just use a small brush to fill it in myself?
Offline airyimbin
« Reply #1860 on: Wed, 26 August 2020, 00:21:17 »
Here's a written guide.
https://topclack.com/textclack/2019/7/30/infilling-by-jae-a-text-guide-to-infilling-logos-and-designs-on-keyboard-parts
Here's a video example at around 2:07:45.
Sent from my SM-N960U using Tapatalk
Offline olsen34
« Reply #1861 on: Wed, 26 August 2020, 02:51:53 »
Update to my extra PCBs situation:
Apparently the extra PCB I ordered from senter recently used a USB-C connector that only works in 1 direction, i.e. if you plug in your cable in the wrong orientation the pcb won't be detected and your pc will throw a malfunction warning.
I'm wondering if any of you guys has also encountered the same issue as I do regarding leftover PCBs.
Offline suparnemo
« Reply #1862 on: Fri, 04 September 2020, 08:24:00 »
How'd you order the PCB? I sent an email to runninghack and nothing back :(
Offline Dr0p
« Reply #1863 on: Fri, 04 September 2020, 08:38:04 »
WTB Polycarb 7u plate please.
Also wtb a hotswap pcb.
« Last Edit: Fri, 04 September 2020, 08:41:31 by Dr0p »
Offline airyimbin
« Reply #1864 on: Fri, 04 September 2020, 09:09:55 »
You might have to keep an eye on r/mechmarket for pcbs. Plates I cut one from ponoko with the file and it works great. It's a good option.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #1865 on: Fri, 04 September 2020, 22:45:27 »
where did you get them cut? also, what thickness did you ask them to do?
Offline airyimbin
« Reply #1866 on: Fri, 04 September 2020, 22:46:45 »
I got them cut from ponoko with 1.5mm.
Offline isot0nic
« Reply #1867 on: Mon, 07 September 2020, 21:36:59 »
Really interesting board
Offline jmsp0511
« Reply #1868 on: Mon, 07 September 2020, 21:55:52 »
does anyone have a solder pcb & plate combo for sale with the plate dampener?
Would love to purchase one, thank you!
Offline airyimbin
« Reply #1869 on: Mon, 07 September 2020, 23:49:39 »
Check /r/mechmarket there's a few that people are selling all the time.
Offline snoofy
« Reply #1870 on: Tue, 08 September 2020, 01:32:12 »
My PCB keeps turning off too.
How can i?
I was checked my usb port
Offline jmsp0511
« Reply #1871 on: Tue, 08 September 2020, 01:50:27 »
I'm actually on there all the time and no one is selling a solder pcb and plate combo lol
Offline dommyy13
« Reply #1872 on: Tue, 08 September 2020, 06:30:22 »
How can i?
did it come with the reset button removed or did you desolder it?  I had the same issue until I removed it
Offline snoofy
« Reply #1873 on: Wed, 09 September 2020, 17:25:41 »
How can i?
oh god!
thank you! so much!
Offline cyanide814
« Reply #1874 on: Thu, 10 September 2020, 13:30:44 »
Senter, can I buy an extra PCB or are there zero?
Does anyone have an extra PCB for sale?
"Solder Version" plz
Offline axisean1
« Reply #1875 on: Fri, 11 September 2020, 04:43:16 »
anyone want to do a gb on pom plates for the 7u?
Offline audax989
  • NOM NOM NOM
« Reply #1876 on: Sat, 12 September 2020, 01:41:33 »
I'd join it. but, I'm just looking to make one through ponoko
Offline axisean1
« Reply #1877 on: Sat, 12 September 2020, 17:17:44 »
i was planning to do that but its a lot cheaper if i could gather a group of people. or if anyone has a pc or pom plate for trade, i have an extra fr4 plate.
Offline audax989
  • NOM NOM NOM
« Reply #1878 on: Fri, 25 September 2020, 06:23:01 »
I got my rgb strip in. but it seems I may have gotten the wrong one. it has 4 wires instead of 3. I tried soldering just the V D and G but it didn't seem to do the trick.
Offline aj90k
« Reply #1879 on: Tue, 29 September 2020, 21:07:26 »
does anyone know where i can get extra of the bumpons for the plate gasket? I ordered two plates in the group buy but only have enough for my 1st plate. Looking to get 16 more for my second.
Offline fault_lin3
« Reply #1880 on: Tue, 29 September 2020, 21:39:27 »
Not sure where you're based but you're probably better off finding an adhesive sheet of 'gasket' off like amazon or something and making your own. I believe the common materials are rubber, silicone, poron, or foam. Its all preference.
That said, hate to say this but you installed the gaskets wrong. The 16 gaskets go on the mid and top case, which makes the plates interchangeable.
Offline aj90k
« Reply #1881 on: Tue, 29 September 2020, 22:43:37 »
:( my smooth brain makes me sad
Offline M4ZEZ
« Reply #1882 on: Sat, 03 October 2020, 17:36:34 »
Will there be a rev 2 cause I really want to get this. :(
Offline PantoneC
« Reply #1883 on: Sun, 04 October 2020, 11:05:49 »
You can buy 3m silcone gasket patches off amazon and cut with a knife to size.
Offline Knoxx
  • Spends too much on keyboards
« Reply #1884 on: Sun, 18 October 2020, 03:23:51 »
So, tried to infill my key65. Is this supposed to happen? I thought the paint on the case wouldn't wipe off.
Offline PantoneC
« Reply #1885 on: Sun, 18 October 2020, 03:46:43 »
It is paint what did you use to wipe it? Personally tried using enamel paint kind of failed and used acetone free nail polish remover to wipe it clean. Even then I washed it with mild soap and water to be certain none of the nail polish remover got leftover.
Offline Knoxx
« Reply #1886 on: Sun, 18 October 2020, 03:56:51 »
Thought the whole point of electrophoresis was so it didnt wipe off. I used isopropyl alcohol.
Offline Draxion
« Reply #1887 on: Tue, 02 February 2021, 12:03:27 »
Does anyone know where to buy replacement gaskets. I'm getting my board cerakoated since my board came with tiny scratch on top case.
Offline Slyceth
« Reply #1888 on: Fri, 21 May 2021, 10:28:15 »
I ordered my keyboard a year ago, and still got no updates. Did I get scammed?
Offline victorpre
« Reply #1889 on: Fri, 21 May 2021, 11:20:47 »
This was shipped months ago
Offline OmniSzron
« Reply #1890 on: Tue, 05 December 2023, 17:40:19 »
Just finished building my Key65 and wanted to share my findings with using split backspace. My PCB also had the issue with the pads on the front and back sides not connecting. I was able to fix this using a mill-max socket on the pad. With the use of the dampening pad, you can't even tell that one side of switch is in a mill-max socket since the dampening pad is so thick.
Hope this helps anyone experiencing the split backspace issue. (Please ignore the poor choice of keycaps. This is temporary until Camping R2 ships...)
I know it's been a while, but I just wanted to thank you for posting this. I built my Key65 a couple weeks ago and it turns out I also got a bum PCB. I tried the factory suggested method of just jamming a buttload of solder into the socket, but that didn't feel good and in the end - didn't work. I also tried contacting Senter, but he hasn't responded yet.
I was pretty bummed out about the whole build when I found your post, but it gave me some hope of actually salvaging it. I ordered some mill max sockets and they just got here today. I had never worked with them before, so that was also a learning experience. In the end, I soldered two for the switch in question, just to be safe and diligent (and hey, now I'll have one hot-swappable switch on the board).
304686-0
All I can say is that it worked! The key was immediately picked up in the VIA keytester. I'm so happy now. Not sure if you'll read this, but thank you for sharing your method.
Fox Lab Key 65 split space
