Author Topic: [GB] Fox Lab - Key 65  (Read 763517 times)
Offline merkz
Re: [GB] Fox Lab - Key 65
« Reply #1600 on: Sun, 24 May 2020, 09:01:35 »
I'm still stuck in shipment on hold hell
Offline johnny2304
« Reply #1601 on: Sun, 24 May 2020, 09:19:32 »
Same here,  shipment on hold for over a week already!  :-[
Offline merkz
« Reply #1602 on: Sun, 24 May 2020, 09:23:51 »
Is this your first group buy as well?
Offline att1cus
« Reply #1603 on: Sun, 24 May 2020, 09:30:51 »
Same here gents.  This is my first GB board.
Offline Myk!
« Reply #1604 on: Sun, 24 May 2020, 09:33:00 »
Looks like problem to US only? I have another key65 to be delivered on Tuesday. Its already here in PH.
Sent from my Mi 9T using Tapatalk
Offline att1cus
« Reply #1605 on: Sun, 24 May 2020, 09:34:43 »
Yes, DHL told me when I called that there's only X number of shipments going to the US per day, and our parcels just have to wait for a spot.
Offline Myk!
« Reply #1606 on: Sun, 24 May 2020, 09:34:44 »
Can someone PLEASE put an entire build video on YouTube for this keyboard I have no idea how to build it.....
There is a twitch build stream posted few page back.
Also there is step by step assembly with photos on zfrontier.com
Offline DZSlasher
« Reply #1607 on: Sun, 24 May 2020, 09:56:26 »
Hoping that they will be able to combine some of the US boards in one shipment!
Offline olsen34
« Reply #1608 on: Sun, 24 May 2020, 10:19:21 »
Just want to confirm, use 8 short gaskets on top, 8 short gaskets and 6 long gaskets on middle case, so the total gaskets used should be 16 short and 6 long ones right?
Offline vsrnth
« Reply #1609 on: Sun, 24 May 2020, 10:19:29 »
https://www.twitch.tv/hugokeys - key 65 build stream.
https://www.zfrontier.com/app/flow/19498 - Zfrontier build guide
Gasket positions:
- https://i.imgur.com/tqlbabP.jpg
- https://i.imgur.com/k6zpnxl.jpg
- https://i.imgur.com/jEUy7ng.jpg
I got the gasket position images from the OP.
Offline vsrnth
« Reply #1610 on: Sun, 24 May 2020, 10:21:25 »
Check the starting post, gasket positions are provided :)
Sent from my SM-G975F using Tapatalk
Offline olsen34
« Reply #1611 on: Sun, 24 May 2020, 10:22:40 »
Still not clear whether to use 8 short gaskets on either top / middle case or 8 on each top and middle case (so 16 in total).
Edit: After watching the linked stream I guess I should use 16 of them.
« Last Edit: Sun, 24 May 2020, 10:28:09 by olsen34 »
Offline matrixzj
« Reply #1612 on: Sun, 24 May 2020, 11:54:31 »
All should be used on both top and bottom of PCB. And you can also put them on case.
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline Kasterborous
    • HEX Keyboards
« Reply #1613 on: Sun, 24 May 2020, 13:10:19 »
Hi, small question but, does anyone know what sort of PCBs are compatible with this keyboard? Thanks  :thumb:
Offline Myk!
« Reply #1614 on: Sun, 24 May 2020, 20:22:14 »
I positioned the gaskets
Top (bottom part)
Middle (top part)
Bottom (top part)
I did not put gaskets on plate. Do not put gaskets on middle (bottom part) for it will stick on pcb.
Offline Felt
« Reply #1615 on: Sun, 24 May 2020, 20:40:17 »
Does the pcb have another reset method if i remove the reset button?
Offline Myk!
« Reply #1616 on: Sun, 24 May 2020, 20:42:02 »
Fn+Esc
Or you simply change the key or combination.
Offline finalarcadia
« Reply #1617 on: Mon, 25 May 2020, 14:44:18 »
Some pics of the build
Striker will have to do until GMK Lux.
Offline MadsMe
« Reply #1618 on: Mon, 25 May 2020, 14:52:38 »
I'm in EU an in the same situation. I guess the shipping case is the same here as well. Good insight thank you!
Offline Willtham
    • @pump_upp - best crypto pumps on telegram !
« Reply #1619 on: Mon, 25 May 2020, 17:58:06 »
Is it still worth putting a foam plate on the back of the pcb or do you guys think its sounds good with its switch foams.
Offline MxBlue
  • buy my keyboard
« Reply #1620 on: Mon, 25 May 2020, 17:58:39 »
I went and put the gaskets on the case parts, since you can't swap out PCB/plates otherwise. The different methods contact the same places, so they should all work out.
Offline suparnemo
« Reply #1621 on: Mon, 25 May 2020, 20:10:02 »
I did the same, gaskets on the case parts and it seems to be working out just fine.
Offline Cujo96
« Reply #1622 on: Mon, 25 May 2020, 23:51:42 »
Don't want to come off as condescending, but it isn't hard to build at all.
Offline //gainsborough
  • MATRIXの日常
« Reply #1623 on: Tue, 26 May 2020, 01:13:35 »
+1
Offline Se1nZ
« Reply #1624 on: Tue, 26 May 2020, 01:20:20 »
what a nice idea of yours. hahaha gonna try later for new pcb and plate.
KBDfans Tofu60 | KBDfans 5degree | Klippe T R3 | NorbaTouch | Fjell R4 | TX-84v1 | FoxLab Key65 | Leopold FC660M | KBDfans Tofu60 Acry | KKINGKKONG 660
Offline MxBlue
  • buy my keyboard
« Reply #1625 on: Tue, 26 May 2020, 01:44:11 »
It's not very, once you figure out where to stick those weird rubber things lmao. But yea, for someone who's trying a gasket board for the first time, it can be a little confusing. Just a pic like the one I provided would go a long way.
Offline bananafritters
« Reply #1626 on: Tue, 26 May 2020, 03:04:35 »
Thanks @MxBlue for the contribution to qmk_firmware, finally I am able to use GESC.
Offline molotov87
« Reply #1627 on: Tue, 26 May 2020, 03:23:21 »
i have a question about my board. when I hold down the F Key like if im  playing a game where that key bind requires me to hold it down for a certain amount of time my board loses its functionality and disconnects, LEDs stay on. is this an issue or am i activating a modifier ? im using the modifier button from the stock flash set up
Offline Se1nZ
« Reply #1628 on: Tue, 26 May 2020, 03:33:01 »
have you clipped your reset button below the PCB?
Offline johnny2304
« Reply #1629 on: Tue, 26 May 2020, 18:54:31 »
Departed Facility in HONG KONG  :p :p :)) :)) Finally, it's moving
Offline Riskymilk
« Reply #1630 on: Tue, 26 May 2020, 19:24:36 »
grats! still no update on mine since april 28th. any other April waiters :P ?
Offline att1cus
« Reply #1631 on: Tue, 26 May 2020, 19:37:02 »
Aww yeah, mine has moved as well! Strange I didn't get a text notification this time around.
Offline MsCookz
« Reply #1632 on: Tue, 26 May 2020, 19:50:51 »
yep just refreshed mine, says it has been processed and departed hk at 7:20!
Offline Myk!
« Reply #1633 on: Wed, 27 May 2020, 03:13:02 »
Second key65 arrived
Offline Surefoot
« Reply #1634 on: Wed, 27 May 2020, 04:55:59 »
Is there a way to get an extra PCB ? (i want to experiment with plates) Will there be a sale for extras ?
Offline Arithmetics
« Reply #1635 on: Wed, 27 May 2020, 13:26:33 »
would also love to do an extra PCB / plate post GB. saw senter ran one for his older boards recently so maybe this one will pop up again.
Offline merkz
« Reply #1636 on: Wed, 27 May 2020, 15:26:26 »
Mine hasn't updated since yesterday but still on hold was the last update I received :(
Offline Willtham
« Reply #1637 on: Wed, 27 May 2020, 17:15:00 »
As I was screwing in the last screw I think it striped on me and won't tighten is there a fix for this or is that a total loss :(
Offline Myk!
« Reply #1638 on: Wed, 27 May 2020, 18:11:15 »
You over tighten it, lost its thread. Maybe you can use a little wider screw. Wait for other's opinion.
Is it PC?
Offline Willtham
« Reply #1639 on: Wed, 27 May 2020, 23:10:25 »
Is it PC?
Nope is All ewhite. Man sad life it just some of its value uwu
Offline Se1nZ
« Reply #1640 on: Wed, 27 May 2020, 23:23:07 »
My build, the blue and yellow goes well with Nautilus.
sorry for blurry pics  :))
Offline SoraNoTenshi
« Reply #1641 on: Thu, 28 May 2020, 07:11:37 »
Does anyone of you have a weird 'Pink' colour on their board?
I am kinda sad that it turned out to look more salmon than the pink in the render....
Offline Myk!
« Reply #1642 on: Thu, 28 May 2020, 07:17:08 »
Im happy with the color. Mine have pink logo, plate, bottom
Offline kipawazi
« Reply #1643 on: Thu, 28 May 2020, 10:56:29 »
Have some issues on my plate.
Seems these two parts are untreated. Will they rust?
Same here.
It's not too visible but the surface is not coated ^^.
Here is a big scratch of a tool :s
And a failling pcb :s
One key press => two keys pressed. I reflashed with QMK but no effect.
Someone have his email address please?
Thank you :s
« Last Edit: Thu, 28 May 2020, 12:07:55 by kipawazi »
Offline Knoxx
  • Spends too much on keyboards
« Reply #1644 on: Thu, 28 May 2020, 11:14:27 »
Same here.
Thank you :s
PM him on geekhack. He usually responds faster that way
Offline johnny2304
« Reply #1645 on: Thu, 28 May 2020, 13:33:06 »
waiting for mine delivery TODAY  :p :p :p ;D ;D ;D
Offline att1cus
« Reply #1646 on: Thu, 28 May 2020, 13:36:01 »
Mine just arrived!
Offline DZSlasher
« Reply #1647 on: Thu, 28 May 2020, 14:20:08 »
Mine just arrived!
Nice! Hoping that I will get lucky and the next shipment will include NYC orders.
Offline Felt
« Reply #1648 on: Thu, 28 May 2020, 14:59:43 »
Arrived to chicago today<33333 Have not assembled yet but the board looks pristine :cool:
Offline oldcat
  • 65% is Life
« Reply #1649 on: Thu, 28 May 2020, 16:56:04 »
Will be hard to fix once stripped
Custom keebs, Handle with care :(
