Author Topic: [GB] Fox Lab - Key 65  (Read 763561 times)
Offline prangano
« Reply #1550 on: Wed, 20 May 2020, 09:59:24 »
Have some issues on my plate.
Seems these two parts are untreated. Will they rust?
Offline thecyangiant
Re: [GB] Fox Lab - Key 65
« Reply #1551 on: Wed, 20 May 2020, 10:07:38 »
It's possible that those may eventually rust, you could probably apply a thin coat of clear fingernail polish if you are concerned.
Sent from my SM-N950U using Tapatalk
Offline DZSlasher
« Reply #1552 on: Wed, 20 May 2020, 10:20:28 »
There is another Key 65 on zfrontier with a fox logo. Looks pretty cool!
https://www.zfrontier.com/app/flow/21303
Offline deathjester
« Reply #1553 on: Wed, 20 May 2020, 10:21:12 »
It shouldn't do it's aluminium not steel or iron. I might oxidize given time but that will be a streaky white appearance.
Offline OmniSzron
« Reply #1554 on: Wed, 20 May 2020, 10:27:24 »
Finally built mine. Its my first time to use a gasket/sandwich mount keyboard. Really loving it!
Sweet build. Love how the pink plate peeks out from in between the keycaps.
Fox Lab Key 65 split space
Offline finalarcadia
« Reply #1555 on: Wed, 20 May 2020, 11:24:00 »
So when is the next gb senter, loving that new fox logo
Sent from my Pixel 3 using Tapatalk
Offline senter
« Reply #1556 on: Wed, 20 May 2020, 12:14:44 »
I won't call it Key65 as there's no key logo or the kanji logo on it.
Offline DZSlasher
« Reply #1557 on: Wed, 20 May 2020, 12:59:59 »
Would you call it the Fox65?
Offline SolidCactus
« Reply #1558 on: Wed, 20 May 2020, 13:36:22 »
I have a Key65 but would love to pick up a Fox Logo one as well! Bring on Fox65 Senter :p
Offline senter
« Reply #1559 on: Wed, 20 May 2020, 13:49:05 »
The fox logo was not designed by me. A friend designed it. I only made several kits with that logo.
Personally I like the key logo better. I also designed a similar lock logo for potential future keyboard kits.
Offline DuellM
  • Keyboard Fatty
« Reply #1560 on: Wed, 20 May 2020, 17:35:14 »
Any chance you will release a 75% next?
Sent from my SM-T510 using Tapatalk
Offline suparnemo
« Reply #1561 on: Wed, 20 May 2020, 18:22:16 »
Anyone else having some pcb issues? Everytime I push 'X' my kb shuts off.
Offline Kohsta
« Reply #1562 on: Wed, 20 May 2020, 18:30:40 »
You'll need to open the case trim the reset switch with wire cutters then youll be all good.
Offline suparnemo
« Reply #1563 on: Wed, 20 May 2020, 18:44:28 »
[/quote]
Another Q, how do I use the VIA above? I can't get it to pull up in via configurator :(
Offline airyimbin
« Reply #1564 on: Wed, 20 May 2020, 18:48:02 »
[/quote]
You need to get the via firmware someone posted above and load the json in VIA. Will probably be a while for it to be officially pulled into QMK and VIA.
Sent from my SM-N960U using Tapatalk
Offline suparnemo
« Reply #1565 on: Wed, 20 May 2020, 18:51:24 »
I can't figure out how to download the JSON oops
Edit: NVM I am dumb af. I got it downloaded. But when I load it I can't change the mapping.
« Last Edit: Wed, 20 May 2020, 18:55:42 by suparnemo »
Offline suparnemo
« Reply #1566 on: Wed, 20 May 2020, 19:02:25 »
Edit: NVM I am dumb af. I got it downloaded. But when I load it I can't change the mapping. Also not seeing it come up in QMK.
Got it, FN + ESC for reset first
« Last Edit: Wed, 20 May 2020, 19:10:15 by suparnemo »
Offline Myk!
« Reply #1567 on: Wed, 20 May 2020, 23:21:33 »
Using camphone only
Offline Myk!
« Reply #1568 on: Thu, 21 May 2020, 00:53:40 »
Thanks IPSE
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #1569 on: Thu, 21 May 2020, 04:52:55 »
Using camphone only
Sounds really good myk
Offline Faust_
« Reply #1570 on: Thu, 21 May 2020, 08:33:09 »
Will there be extra tops/plates for purchase?
Offline spring4k
« Reply #1571 on: Thu, 21 May 2020, 10:53:39 »
There is no place to solder the led under the pcb. Is there a way to install the led under pcb?
Offline DuellM
  • Keyboard Fatty
« Reply #1572 on: Thu, 21 May 2020, 11:38:46 »
Offline DuellM
  • Keyboard Fatty
« Reply #1573 on: Thu, 21 May 2020, 11:44:09 »
Thanks for the tip. Will do a test fit first as well to see if I like it better with foam or without. Also, mine just landed in Germany a couple of hours ago. I expect to receive it some time next week.
It isn't actually foam. It's more like rubber. Mine turned out fine so I didn't really need to cut anything out.
I thought we had guidance from Senter about assembly in the original post or something. Trying to assemble this blind with maybe cutouts here on the foam, maybe cutouts there just makes me rather uncomfortable. For a board that took cost $400 and took six months to receive, we should have assembly instructions set-in-stone. Just going off the notifications I have received in the past two weeks about people's builds, I'm still not totally sure what's "correct" and what's not in terms of the order of gasket, plate, and case...
In other news, I saw you said you received your kit. Any pics - I want to see what you mean by the glossyness.
Yeah I was a tiny bit annoyed at the lack of the build guide. Would definitely be more reassuring to have a guide on where to put what and how to flash your PCB all in one place, especially since I'm coming off my Polaris.
As you can see in the picture, the red isn't exactly as matte as the black, but it's not serious enough to make me regret buying it.
Edit: For flashing on QMK, go to the site that senter linked in the post and download the JSON file and load it up to kbdfirmware. After you finish mapping, compile it into a HEX file and download it. Once done, boot up QMK firmware, connect your PCB and reset it. Once QMK has detected your PCB, manually select the HEX file that you compiled previously and then flash it. That should do the trick.
Nooooo I was so hoping you wouldn't like it so you would sell it to me  ;)
Offline vsrnth
« Reply #1574 on: Thu, 21 May 2020, 11:55:27 »
Plates probably, can't really say anything about tops
Sent from my SM-G975F using Tapatalk
Offline vi0till
« Reply #1575 on: Thu, 21 May 2020, 12:15:51 »
+1 for 75% as well.
Sent from my VOG-L29 using Tapatalk
« Reply #1576 on: Thu, 21 May 2020, 14:31:31 »
I think it's time for that tkl, and based on senter's Instagram I may be right.
Offline dumpling420
« Reply #1577 on: Thu, 21 May 2020, 15:48:43 »
What kind of LED strip is that?
Offline achan7942
« Reply #1578 on: Thu, 21 May 2020, 17:29:49 »
Ws2812B
Offline Instinct
« Reply #1579 on: Thu, 21 May 2020, 20:20:18 »
Ws2812B
Is it possible to change the brightness and turn off/on the lightstrip through a keybind with firmware? If so, what QMK keycodes are used?
Offline achan7942
« Reply #1580 on: Thu, 21 May 2020, 21:19:42 »
Ws2812B
Believe it was fn + q / w / e / r
The keymap files will show you exactly.
Offline Trixxur
« Reply #1581 on: Thu, 21 May 2020, 22:19:20 »
Just finished the build but I’m having clearance issues with the spacebar stabiliser bar hitting the plate. I have the 7U hotswap PCB.
Anyone else having this issue and any solutions?
Offline //gainsborough
  • MATRIXの日常
« Reply #1582 on: Fri, 22 May 2020, 00:35:43 »
Silly question, but just making sure: did you install the gaskets correctly?
Offline vsrnth
« Reply #1583 on: Fri, 22 May 2020, 00:37:23 »
A build guide would've helped avoid unnecessary confusion.
Offline Trixxur
« Reply #1584 on: Fri, 22 May 2020, 00:59:25 »
Yup everything fits well and I am very sure that gaskets are installed in the correct positions. Literally just the plate blocking the stab bars from coming up.
Offline Fnzzy
« Reply #1585 on: Fri, 22 May 2020, 04:05:20 »
Can you maybe show us a photo of the issue?
Offline ShadeDream
« Reply #1586 on: Fri, 22 May 2020, 07:44:24 »
Hmm... still sitting on "Shipping Information Received" for me since May 8th... little concerning.
Offline vsrnth
« Reply #1587 on: Fri, 22 May 2020, 07:46:12 »
It'll show up suddenly without any updates, atleast that's what happened to me.
Offline kurple
« Reply #1588 on: Fri, 22 May 2020, 08:14:36 »
There's a DHL tracking # in the PayPal email. For me, this number still states that shipping info isn't received.
I don't use that number.
After signing up for SMS notifications on the original tracking #, I received an SMS with a different tracking #.
This new tracking # actually gives me information.
Perhaps you (along with the others who have the same experience) need to do the same thing.
Sent from my SM-G988U using Tapatalk
Offline suparnemo
« Reply #1589 on: Fri, 22 May 2020, 09:31:40 »
I had the same experience, the original PP tracking number didn't end up being the one I used to track delivery. I got a text with one later on and that one gave me the info I needed.
Offline chrainer
« Reply #1590 on: Fri, 22 May 2020, 14:06:17 »
don't worry - i had this issue several times(including now - waiting since may 13th), when ordering from china! I got kind of used to waiting for 3-4+weeks
Offline att1cus
« Reply #1591 on: Fri, 22 May 2020, 16:02:39 »
Same experience here.  My board has been on hold in HK for a week now, waiting for room on a plane for transit.
Offline ShadeDream
« Reply #1592 on: Fri, 22 May 2020, 16:29:17 »
Ahh just checked the text message and it is a different number... not much help either though as it's just shipment on hold messages since the 14th. Will watch that one from now on.
« Last Edit: Sat, 23 May 2020, 22:45:31 by ShadeDream »
Offline MsCookz
« Reply #1593 on: Fri, 22 May 2020, 16:52:31 »
I am assuming that anyone in the US still have their shipment on hold (just like mine since may 8 ). Just sad to have to keep waiting longer, when we already waited so long ;(
Offline dwarflemur
« Reply #1594 on: Fri, 22 May 2020, 17:16:42 »
I got mine in California on Monday, text came sometime last week I don't remember. I had the same thing where the tracking number in the text was the one that actually tracked it.
Camp C225 | Norbatouch | ALF X2 + X3 | Orange TKL | CA66 | Leaf 60 | a bunch of others
Offline MsCookz
« Reply #1595 on: Fri, 22 May 2020, 17:33:04 »
maybe it's just the mid-east coast US? My tracking number that gives more details, didn't update for May 22, so maybe it got shipped, I'm just hoping at this point
Offline Bryan
« Reply #1596 on: Sat, 23 May 2020, 01:11:25 »
Built mine a few days ago, and finally got around to taking some glamour shots and a noob's type test.
It's my best sounding and feeling keyboard so far! I hope everyone enjoys theirs!
Thanks Senter/Fox Lab!
Gateron Black Inks (Krytox 205g0)
Top/Mid/Bot: E-white
Plate: Brass (E-white)
Weight/Logo: Brass (E-black)
Type Test: https://streamable.com/tf1raa
  • MATRIXの日常
« Reply #1597 on: Sat, 23 May 2020, 02:30:13 »
Very nice, dude!  That's a great color combo, and it sounds wonderful!
Offline Cresc3nt
« Reply #1598 on: Sat, 23 May 2020, 03:01:56 »
This looks and sounds amazing. Great build.
Offline jdbaker82
« Reply #1599 on: Sun, 24 May 2020, 08:25:25 »
Can someone PLEASE put an entire build video on YouTube for this keyboard I have no idea how to build it.....
