Author Topic: [GB] Fox Lab - Key 65  (Read 763565 times)
Offline Mechalomania
Re: [GB] Fox Lab - Key 65
« Reply #1800 on: Sat, 27 June 2020, 13:14:13 »
So I might be the only person that wanted to add backlit LEDs to my keyboard, but in the case that someone else has tried, were you able to get it to work?  The LEDS wouldn't turn on for me (one did briefly, then faded almost immediately).  I've tried on 2 PCBs (the original I received and the replacement due to the split backspace issue), and neither of them turned the lights on.  I tried adjusting the settings with the original files on kbfirmware and the newer files in VIA.
Hopefully I'm not wrong, but I'm ruling out soldering-error since I was able to install LEDs on another keyboard without issue and I tested multiple slots to be sure that the issue is consistent.  It's not the end of the world if it won't work, but it would've been nice to have for my personal build.
7/19/20 Update:  In case anyone else sees this and wonders if there is an update, I'm just a big dum doodoo head and it works fine.
« Last Edit: Sun, 19 July 2020, 16:00:50 by Mechalomania »
Offline DuellM
  • Keyboard Fatty
« Reply #1801 on: Sat, 27 June 2020, 14:26:07 »
Your Teal Keeb Is Beautiful  ^-^
Offline Myk!
« Reply #1802 on: Sat, 27 June 2020, 20:04:49 »
Here's mine.
I finally fixed the split backspace. Since the solder pad is wide (due to alps compatible), I inserted the tip of solder iron and the lead to make sure the pad from top will make contact with the pin.
« Last Edit: Sat, 27 June 2020, 20:15:27 by Myk! »
Offline airyimbin
« Reply #1803 on: Mon, 29 June 2020, 14:24:17 »
I've gone ahead and created a PR for the Key 65 PCBs to QMK and VIA. Since I don't own a hotswap PCB, would appreciate someone testing the Hotswap variants and leaving a comment on the PRs with test results.
https://github.com/qmk/qmk_firmware/pull/9116
https://github.com/the-via/keyboards/pull/141
I'm not sure if it was intentional or not but you're lighting the caps lock led when it's off, instead of the usual when it's on.
Not what I had intended :)) Is this the case on both the universal and hotswap?
Yea it is. Fixed it up myself but I wasn't sure if it was intentional. I haven't tested the universal sicne I don't have led's on it, but I noticed it's the same function.
Could you fix the matrix for the universal board? I submitted a issue on github since the backspace is set to the wrong key.
Offline MxBlue
  • buy my keyboard
« Reply #1804 on: Mon, 29 June 2020, 17:16:34 »
Sure, mind linking your issue? I can't find it on the QMK github.
Offline airyimbin
« Reply #1805 on: Mon, 29 June 2020, 17:19:09 »
Here is the issue. https://github.com/the-via/keyboards/issues/186
I don't think it's a QMK issue, I just think ipse just needs to edit the matrix to select the correct backspace. Should be an easy fix.
Offline Instinct
« Reply #1806 on: Mon, 29 June 2020, 22:53:03 »
Is there a fix to make NKRO work on the universal VIA firmware?
Offline Gumberculese
  • Man, Machine, Scientist?
« Reply #1807 on: Wed, 01 July 2020, 15:15:57 »
Here is the picture of the result. Pretty happy. But yeah KB and VIA wasn't allowing me to enable NKEY rollover. So I'll figure that out in the future. Not sure if I really need it enabled or not, and not really sure if I need VIA now that I have ever thing that I need. So well see.
That looks great!  What LED strips did you use for that?   Got a link?  Thanks.
Offline Cujo96
« Reply #1808 on: Wed, 01 July 2020, 23:49:51 »
Anyone know whereabouts the ALPS Plate file is?
Offline Tyson
« Reply #1809 on: Sun, 12 July 2020, 15:56:16 »
Has anyone else experienced any bowing issues with a polycarb bottom piece, I feel like there shouldn't be gaskets stuck to the bottom of the mid piece. Here's the issue I ran into from my stream building the board. https://clips.twitch.tv/HappyDaintyVanillaCeilingCat
Offline Scottw
    • ScottW's Boards
« Reply #1810 on: Tue, 14 July 2020, 19:11:27 »
Have the non-iso plate files been released? Anyone know if there are any plans to release them?
Offline Fnzzy
« Reply #1811 on: Wed, 15 July 2020, 04:32:07 »
https://fox-lab.github.io/gbs/Key-65.html
Offline fault_lin3
« Reply #1812 on: Wed, 15 July 2020, 23:19:56 »
Did you get this worked out? I skimmed thru your stream and looks like you double gasketed the base and mid piece? You don't need gaskets on the bottom of the mid piece which is why you didn't need to cut your own. You should have had 2 extra long pieces. I'm 98% sure anyway lol, based on building my own. I've never seen anything that was meant to be rubber on rubber.
Offline mg53
« Reply #1813 on: Thu, 16 July 2020, 00:10:48 »
Yea, this sounds right. You put the 6 long gaskets on the bottom piece, and no gaskets on the underside of the middle. That is what I did too and have no issues with the polycarb bottom bowing.
Offline Tyson
« Reply #1814 on: Thu, 16 July 2020, 01:38:13 »
 I actually removed the gaskets from the bottom of the middle layer and it resolved the issue the board doesn't bow anymore. Thanks guys for your replies :)
Offline Kookiekurls
« Reply #1815 on: Thu, 16 July 2020, 09:58:22 »
On the hotswap board, the enter key stabs are south facing, which causes an issue with the rubber pad. It makes the rubber pad off center for all the keys below it... has anyone had this issue? I think the holes for the enter key stabs are upside down...
« Last Edit: Thu, 16 July 2020, 10:00:40 by Kookiekurls »
« Reply #1816 on: Thu, 16 July 2020, 10:08:05 »
Had same issue with hotswap.  I just used a box cutter and sliced off the notch.
Offline Kookiekurls
« Reply #1817 on: Thu, 16 July 2020, 10:45:39 »
Thanks, I was assuming I would have to do so, but just in case wanted to make sure it wasn’t the wrong thing to do!
Offline Kookiekurls
« Reply #1818 on: Thu, 16 July 2020, 14:56:35 »
Sorry one more issue. Having trouble using QMK Toolbox and flashing the keyboard. When attached, it doesn't recognize it, and says "No HID console interfaces found." I've been able to get it working with my other keyboards, but this one doesn't work :(
Offline olsen34
« Reply #1819 on: Fri, 17 July 2020, 05:26:12 »
If anyone has spare pcb they don't need, please sell it to me :thumb:
Offline dommyy13
« Reply #1820 on: Fri, 17 July 2020, 14:34:00 »
Senter has some extras: www.shorturl.at/hsJO6
Offline DZSlasher
« Reply #1821 on: Fri, 17 July 2020, 14:53:13 »
I emailed him earlier this week and still haven’t heard back. Hopefully, I’ll hear something soon.
Got a reply.
« Last Edit: Tue, 21 July 2020, 23:30:55 by DZSlasher »
Offline Surefoot
« Reply #1822 on: Fri, 17 July 2020, 19:01:22 »
I sent an email two weeks ago, and still no response - i suppose there's nothing left.
Strike that, just got a reply too.
« Last Edit: Sat, 18 July 2020, 01:11:56 by Surefoot »
Offline olsen34
« Reply #1823 on: Fri, 17 July 2020, 21:27:29 »
Sent him a PM about it and an email to order, haven't heard anything back nor got invoiced. So I assume extra PCBs are all sold out.
Nvm just got a reply.
« Last Edit: Fri, 17 July 2020, 23:45:41 by olsen34 »
Offline kchlam
« Reply #1824 on: Fri, 17 July 2020, 22:48:20 »
Is it just me or does the 7u plate file not upload onto ponoko? I've been trying for 2 days and it never uploads successfully.. :(
Offline thestateofmay
« Reply #1825 on: Mon, 20 July 2020, 11:43:52 »
Is anyone selling theirs? I'd love to get one D:
Offline Myk!
« Reply #1826 on: Tue, 21 July 2020, 03:53:50 »
Sharing my Acrylic Key65
https://imgur.com/a/b58VYNB
Sound test
Offline Dr0p
« Reply #1827 on: Tue, 21 July 2020, 04:48:48 »
WTB Hotswap pcb or
trade brand new solder pcb for hotswap pcb please.
Pm me.
Offline xthongyy
« Reply #1828 on: Tue, 21 July 2020, 17:23:36 »
Did Senter pull the Fox Lab store? Had a couple item in carts and it's been down since yesterday
« Reply #1829 on: Tue, 21 July 2020, 23:49:10 »
Any chance this goes for a rerun?
Offline DZSlasher
« Reply #1830 on: Wed, 22 July 2020, 08:57:12 »
Many people asked me if there will be a round 2 (no) and why not. I guess I need to give a public answer here.
Firstly, Key65 was not a limited GB. The IC was long enough that anyone care about the community would see it. The GB period was long enough that anyone wanted to join can join. It was a long journey to get the 600 kits manufactured and shipped in this special time. I'm deeply grateful for those who patiently waited and who had faith on me. I'm not interested in making their wait a little less meaningful by running a much quicker group buy for the same design.
Secondly, I'm not interested in running the group buys for the same design. I've mentioned it many times. I don't want to run a group buy if there's nothing new.
That being said, I do plan to run a group buy for Time 80% in the near future. The concept is the same but all the details have been improved. It will be a totally different Time. I'll IC it and collect feedbacks soon.
[mention]thestateofmay [/mention] see quote
« Reply #1831 on: Wed, 22 July 2020, 12:01:19 »
Ah that sucks. I only recently join the community and wasn't there for the group buy.
Offline crystalflame
« Reply #1832 on: Wed, 22 July 2020, 19:57:22 »
Hooked up 40 LEDs. I never want to open this up again. After all of that my left shift stab wire popped out and I somehow managed to pop it back in without having to desolder.
https://imgur.com/a/rhhwa8K
Offline bananafritters
« Reply #1833 on: Thu, 23 July 2020, 07:01:59 »
Did anyone use SK6812b for RGB? I used it it worked but I did not get RGB but only white warm light.
Offline namplanana
« Reply #1834 on: Thu, 23 July 2020, 21:44:19 »
This is my Double Key
Offline dommyy13
« Reply #1835 on: Tue, 28 July 2020, 14:09:42 »
Are there any òther PCBs that work with the key65?  I need a spare one..
Offline airyimbin
« Reply #1836 on: Tue, 28 July 2020, 14:17:09 »
It's possible that a generic 65% with the same layout might work. But there is no guarantee that it will fit the usb port/cutout.
Offline senter
« Reply #1837 on: Tue, 28 July 2020, 16:07:37 »
There are still several spare PCBs.
 Now they can only be shipped to CONUS tho.
Offline dommyy13
« Reply #1838 on: Tue, 28 July 2020, 17:38:08 »
Oh wow that would be great, sent you an email.
Offline axisean1
« Reply #1839 on: Tue, 28 July 2020, 17:42:24 »
Email sent. Any 7u plates left?
Offline DZSlasher
« Reply #1840 on: Tue, 28 July 2020, 18:39:08 »
That’s great! Any timeline of when the orders for the spare pcbs will be shipped?
Update: Received tracking number!
« Last Edit: Wed, 29 July 2020, 09:33:38 by DZSlasher »
Offline bustorblador
« Reply #1841 on: Tue, 28 July 2020, 19:21:05 »
Ive been looking for a spare pcb and plate too. Is there a site to order on?
Offline Myk!
« Reply #1842 on: Tue, 28 July 2020, 21:20:02 »
Sharing my 2nd Key65 in acrylic case
« Last Edit: Tue, 28 July 2020, 21:26:37 by Myk! »
Offline axisean1
« Reply #1843 on: Tue, 28 July 2020, 21:33:08 »
Does anyone have a 7u titanium plate for sale?
Offline airyimbin
« Reply #1844 on: Fri, 31 July 2020, 19:50:20 »
I accidentally bought a spare hotswap 7u PCB. Non of my plates fit it.
Does anyone want to buy it off of me or swap me for another 6.25u pcb?
Offline MK47
  • Don't talk to me
« Reply #1845 on: Mon, 03 August 2020, 05:25:35 »
Does anyone know what the foam between pcb and plate is called? I want to get some for my other boards.
Offline airyimbin
« Reply #1846 on: Mon, 03 August 2020, 12:21:22 »
Don't know what it is exactly, but it's probably sorbothane.
Sorbothane is high density acoustic dampener.
Offline Knoxx
  • Spends too much on keyboards
« Reply #1847 on: Mon, 03 August 2020, 12:33:26 »
Think KBDFans has module foam you can buy. Not too sure if it fits the Key65 layout so check that first before you pull the trigger.
Offline synztran
  • LOVE SA PROFILE & MECHANICAL KEYBOARD
« Reply #1848 on: Tue, 04 August 2020, 05:02:59 »
Help! Help! Help! Anyone can share me key65's wkl 7u spacebar plate file  ?
Offline //gainsborough
  • MATRIXの日常
« Reply #1849 on: Tue, 04 August 2020, 09:58:10 »
It's the last link on the "plate file" row.
