Author Topic: [IC] GMK nude  (Read 39222 times)
Offline onefivenine
    • Project Keyboard LLC
[IC] GMK nude
« on: Fri, 11 October 2019, 20:36:43 »
GMK nude
IC Form/suggestions: https://forms.gle/rcgz66Md1Lph3h1U7
The set:
Kendo:
Valkyrie (renamed from Sirius 65+):
Nebula: (needs color correction - have a color accurate monitor coming in this weekend which i'll re-render)
Vendors:
US: projectkeyboard
EU: mykeyboard
Notes:
Set is using custom color
Pretty sure I missed some keys for compatibility, let me know - some keys were omitted like convex 2u since numpad 2u can be used.
Need to re-render nebula as polycarb is a bit tricky.
More renders coming soon.
Thanks for looking
« Last Edit: Sat, 12 October 2019, 03:06:05 by onefivenine »
Offline onefivenine
Re: [IC] GMK nude
« Reply #1 on: Fri, 11 October 2019, 20:36:59 »
reserved
Offline would?
  • Formerly wouldworks
    • Finder Works
Re: [IC] GMK nude
« Reply #2 on: Fri, 11 October 2019, 20:38:07 »
Super cute! lovely set of blanks
Offline Rumai
Re: [IC] GMK nude
« Reply #3 on: Fri, 11 October 2019, 20:39:41 »
oh **** yes
Offline biothermal
  • Art
Re: [IC] GMK nude
« Reply #4 on: Fri, 11 October 2019, 20:40:00 »
I've been seduced
Offline heyjaykay
Re: [IC] GMK nude
« Reply #5 on: Fri, 11 October 2019, 20:40:16 »
It may be kinda against the purpose of the set but... Would  totally get the alphas for this
Sent from my SM-G950F using Tapatalk
Offline o3okevin
Re: [IC] GMK nude
« Reply #6 on: Fri, 11 October 2019, 20:41:59 »
how about in PBT?
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK nude
« Reply #7 on: Fri, 11 October 2019, 20:44:07 »
If legends aren't of relevance here, why not PBT or a different ABS manufacturer?
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] GMK nude
« Reply #8 on: Fri, 11 October 2019, 20:44:10 »
What will the custom color be like? Any sort of comparisons?
Offline adxlk
Re: [IC] GMK nude
« Reply #9 on: Fri, 11 October 2019, 20:47:12 »
R5 Bottom Row please
Offline fcoury
Re: [IC] GMK nude
« Reply #10 on: Fri, 11 October 2019, 20:47:19 »
We definitely need this. 100% in!
Offline adxlk
Re: [IC] GMK nude
« Reply #11 on: Fri, 11 October 2019, 20:51:11 »
try to find out if you can can it done in premium pbt
https://mitormk.com/mythos/
maybe you could work with iLouis
[IC] PBT Vintage/Modern Cherry Logo Novelties Pack: https://geekhack.org/index.php?topic=102526.0
they are going via TYL PBT
Offline onefivenine
Re: [IC] GMK nude
« Reply #12 on: Fri, 11 October 2019, 20:52:01 »
Offline onefivenine
Re: [IC] GMK nude
« Reply #13 on: Fri, 11 October 2019, 20:54:26 »
how about in PBT?
If there is a manufacturer that can offer the same color matching expertise, no warping, and correct stem then sure. I'm open to explore other options.
I'll take some photos of some swatches I picked out in the morning against stock color gmk caps.
Offline chriszhu
  • (* ̄(エ) ̄*)''
Re: [IC] GMK nude
« Reply #14 on: Fri, 11 October 2019, 21:19:50 »
Offline KingOfMemes
Re: [IC] GMK nude
« Reply #15 on: Fri, 11 October 2019, 21:25:11 »
Can't wait to put this on my white and Rose gold kendo
Offline Dissitesuxba11s
Re: [IC] GMK nude
« Reply #16 on: Fri, 11 October 2019, 21:26:42 »
Can there be a pair of homing bumps with nipples as legends (artisans?)? Use male nipples, female nipples are a no no.
Offline megaforce
Re: [IC] GMK nude
« Reply #17 on: Fri, 11 October 2019, 21:27:23 »
as a person of colour, why are these all off white?
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] GMK nude
« Reply #18 on: Fri, 11 October 2019, 21:38:54 »
Might also need 1800/CP support for this. I'm not sure the keys cover for that.
Offline onefivenine
Re: [IC] GMK nude
« Reply #19 on: Fri, 11 October 2019, 21:46:23 »
The name is a double entendre of the lack of legends, accents, etc. The term "nude" is also commonly used in the fashion industry for pale shades mixed of white, brown, and pink. I am also a PoC and don't see the name of this keyset racially/ethnically offensive.
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
Re: [IC] GMK nude
« Reply #20 on: Fri, 11 October 2019, 21:50:24 »
Looks like it does for R1 and R2, and you can use the R3 ISO 1u for the 1u numpad+, but if you use ISO you can't use it there. Might be worth considering a spare R3 1u in with the numpad to cover that like, 1% use case.
Also came here to say numpad in base plx :P For something like this those keys in the split off kit are gonna cost probs over twice as much with the per-kit costs, vs the like ≤$15 for having it in base and the potential utility.
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] GMK nude
« Reply #21 on: Fri, 11 October 2019, 21:55:27 »
I would be in favor of one big base kit. Makes it so much easier.
Offline ullr
Re: [IC] GMK nude
« Reply #22 on: Fri, 11 October 2019, 22:42:55 »
I really like the render with the Kendo, I'd like to get both. Blanks are my kryptonite, I would buy GMK or any good PBT probably.
Offline SwitchKeys
    • SwitchKeys
Re: [IC] GMK nude
« Reply #23 on: Fri, 11 October 2019, 22:47:16 »
Mind is wandering thinking about Novelty possibilities  ;)
Re: [IC] GMK nude
« Reply #24 on: Fri, 11 October 2019, 23:07:21 »
i see blanks i like
Offline AlcoholEnthusiast
Re: [IC] GMK nude
« Reply #25 on: Fri, 11 October 2019, 23:08:49 »
I'm usually a fan of splitting off numpad, but for a set like this total keys should be down so I think it makes sense to make everything one big base kit.
Offline joric
Re: [IC] GMK nude
« Reply #26 on: Sat, 12 October 2019, 00:22:37 »
Will there be a novelties pack? A few pink dots and a pink asterisk maybe?
Re: [IC] GMK nude
« Reply #27 on: Sat, 12 October 2019, 00:24:58 »
them homing keys better be nipples
Offline joric
Re: [IC] GMK nude
« Reply #28 on: Sat, 12 October 2019, 00:32:46 »
Homing scoops could feel pretty nice too.
Offline onefivenine
Re: [IC] GMK nude
« Reply #29 on: Sat, 12 October 2019, 00:33:15 »
lol the original render had nipples.
i prefer having numpad in base will add updated questions to the ic form to see what the community thinks
Offline Sycomore
Re: [IC] GMK nude
« Reply #30 on: Sat, 12 October 2019, 00:39:27 »
Very clean, I like it.
Offline mrpetrov
Re: [IC] GMK nude
« Reply #31 on: Sat, 12 October 2019, 00:45:03 »
so sensual, in
Offline donutcat
    • Donut Cables
Re: [IC] GMK nude
« Reply #32 on: Sat, 12 October 2019, 01:05:39 »
Get permission to use the GMK Dots molds and make a couple dark pink dot keys for R3 for F and J. Big brain novelties right there.
Edit: only issue would that you're adding another color to the set which would increase the cost to that of the average two color set, probably not worth it.
Offline adxlk
Re: [IC] GMK nude
« Reply #33 on: Sat, 12 October 2019, 01:46:17 »
Get GMK Dots mold and make an FPS/MOBA Gamer set with limpet shell dots or Dark pink dots
« Last Edit: Sat, 12 October 2019, 01:50:08 by adxlk »
Offline piit79
Re: [IC] GMK nude
« Reply #34 on: Sat, 12 October 2019, 01:46:23 »
Oh my. I really hope the question was meant as a stab at the extreme political correctness disease and not seriously. The correct response would have been "".
Offline piit79
Re: [IC] GMK nude
« Reply #35 on: Sat, 12 October 2019, 01:50:49 »
Also came here to say numpad in base plx For something like this those keys in the split off kit are gonna cost probs over twice as much with the per-kit costs, vs the like ≤$15 for having it in base and the potential utility.
True, with GMK, and I hate that. I don't think we need this to be GMK...
Offline piit79
Re: [IC] GMK nude
« Reply #36 on: Sat, 12 October 2019, 01:52:52 »
... some keys for compatibility, let me know - some keys were omitted like convex 2u since numpad 2u can be used.
But numpad 2u is concave, so it's not a proper replacement...
Offline Emir
  • icon mods
  • Bandit
    • Discord
Re: [IC] GMK nude
« Reply #37 on: Sat, 12 October 2019, 04:59:48 »
Wow great beige and concept! Consider me interested! 🙏
Offline joric
Re: [IC] GMK nude
« Reply #38 on: Sat, 12 October 2019, 07:46:21 »
Offline mlev6
Re: [IC] GMK nude
« Reply #39 on: Sat, 12 October 2019, 09:05:02 »
Epic name, epic design.
Offline adxlk
Re: [IC] GMK nude
« Reply #40 on: Sat, 12 October 2019, 09:13:39 »
GMK Dots style MOBA Set
« Last Edit: Sat, 12 October 2019, 10:02:23 by adxlk »
Offline 0Name
Re: [IC] GMK nude
« Reply #41 on: Sat, 12 October 2019, 12:10:32 »
I don't think the MOBA kits are necessary. We want true "nude" after all.
Offline juliandoucette
Re: [IC] GMK nude
« Reply #42 on: Sat, 12 October 2019, 13:53:22 »
I'm a fan.
Offline donutcat
    • Donut Cables
Re: [IC] GMK nude
« Reply #43 on: Sat, 12 October 2019, 14:04:07 »
Personally not that big on the "moba kits" but if they're to be included I think it best to make them a child kit so the base isn't seeing the cost increase from a second color.
Offline pikku-allu
  • IG: @kinnalek
Re: [IC] GMK nude
« Reply #44 on: Sat, 12 October 2019, 18:21:10 »
Those MOBA sets are straight up trypophobia nightmare fuel.
« Last Edit: Sat, 12 October 2019, 18:23:16 by pikku-allu »
Offline adxlk
Re: [IC] GMK nude
« Reply #45 on: Sat, 12 October 2019, 20:19:09 »
haha xd
Offline vicissitude
Re: [IC] GMK nude
« Reply #46 on: Sat, 12 October 2019, 20:54:46 »
This set surpasses GMK dots in some way.
Hope someday we'll see GMK all transparent or even GMK nothing-to-see-but-can-feel.
Nice creativity.  :thumb:
Offline gotham
Re: [IC] GMK nude
« Reply #47 on: Sun, 13 October 2019, 19:18:55 »
Would go amazingly well with all the rose gold cases that are coming out lately!
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
Re: [IC] GMK nude
« Reply #48 on: Sun, 13 October 2019, 19:34:27 »
Ooo bby
Offline depletedvespene
    • Keyboard-related resources.
Re: [IC] GMK nude
« Reply #49 on: Mon, 14 October 2019, 09:46:17 »
I'm a very freckled man. Should I go with GMK Dots instead of these?
 ;D :D ;D :D ;D :D ;D :thumb:
