Author Topic: [IC] Ellipsis - 40% ortho split case inpired by The Ave  (Read 18577 times)
Offline rutomoda
  • I'm Lu! I love to design and build unusual keebs
    • rutomoda.com
« on: Sat, 12 October 2019, 14:55:58 »
Interest Check Form 1: https://forms.gle/Em7S5jEDpfpcRJpt9
Form 1 closed. Form 2 will open as soon as I manage to work all the feedback into the next prototype.
The Ellipsis is my homage to The_Royal's The Ave adapted to a Let's Split / Levinson form factor.
Most recent renders
Individualism: Screws, weight and removable plate
Minimalism: No screws and integrated plate
Older renders
3D printed prototype
Case versions
There will be two versions (individualism and minimalism) for the top case and for the bottom case each:
  • The top case will come with either an exchangable plate (up to 3mm) or an integrated 3mm plate.
  • The bottom case will come either with screw holes for mounting to the top case plus a weight or without any holes for a sleek and smooth bottom surface
Each top case will be compatible with each bottom case.
Exchangeable switch plate, screwable bottom with brass weight
STL files of the current revision at: https://github.com/rutomoda/keyboards
(Final versions still missing - will fix eventually!)
Link me on Instagram or Reddit if you make one yourself, I wanna see! (@rutomoda or /u/rutomoda)z
Due to several requests I designed an insert housing for a 32x128px OLED display. First prototype (will be improved):
« Last Edit: Sun, 10 November 2019, 15:42:23 by rutomoda »
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
Re: [IC] Ellipsis - 40% ortho split case inpired by The Ave
« Reply #1 on: Sat, 12 October 2019, 15:18:07 »
I really like this! Such a fun design!
Sent from my SM-G950U using Tapatalk
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline octix
« Reply #2 on: Sat, 12 October 2019, 16:07:24 »
Very cool design!
I’m interested :)
Discord: octix#0478
Offline ITzNybble
« Reply #3 on: Sat, 12 October 2019, 16:22:36 »
If the STL files are ever available, i would totally hand wire this thing for fun lol
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Sat, 12 October 2019, 16:31:58 »
I know I really want it, but I don't know if I want to pay for it to be aluminium.
The 3d printed proto is really cute, pls offer that?  ;D
Offline rutomoda
    • rutomoda.com
« Reply #5 on: Sat, 12 October 2019, 17:27:14 »
Added the repo link to the main post, so anyone who wants to make one for themselves can do so.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #6 on: Sat, 12 October 2019, 17:29:25 »
Dude you rock so hard. :thumb:
Offline equalunique
« Reply #7 on: Sat, 12 October 2019, 18:10:47 »
Love the design. I'm going to think about the IC questions before answering. I feel like I could go for both a low-end and high-end version of this.
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline rondg
« Reply #8 on: Sat, 12 October 2019, 18:25:17 »
Can we add a 128x64 OLED in there?  ;D
Offline rutomoda
    • rutomoda.com
« Reply #9 on: Fri, 18 October 2019, 07:09:55 »
Did a prototype for an insert housing for a 32x128px OLED (see main post). I am listening to suggestions if possible! That said, IC form 1 will be closed end of tomorrow (Saturday), so make your voices heard! (This thread will of course remain open until the GB.)
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #10 on: Fri, 18 October 2019, 11:34:35 »
This is the coolest dang thing I have seen in a loooong while. Really excited to see where this goes, this project is amazing!
Offline KuroTheCrazy
« Reply #11 on: Fri, 18 October 2019, 11:36:28 »
This looks super rad, I'll definitely try printing one out but interested in the GB still.
Offline KingOfMemes
« Reply #12 on: Fri, 18 October 2019, 11:54:16 »
I will take 1 pair please.
Offline amuri99
« Reply #13 on: Sun, 20 October 2019, 02:53:05 »
fantastic design!!   :-* :-*
Offline rutomoda
    • rutomoda.com
« Reply #14 on: Sun, 27 October 2019, 04:27:35 »
Little Work-In-Progress update. Working hard on a polycarbonate version with separate plate, weight and screwable bottom.
Offline amuri99
« Reply #15 on: Sun, 27 October 2019, 07:28:12 »
really awesome!
Offline ju6ju8Oo
« Reply #16 on: Mon, 28 October 2019, 07:31:20 »
Will there be a PCB?
Offline rutomoda
    • rutomoda.com
« Reply #17 on: Mon, 28 October 2019, 17:50:25 »
First of all: Thank you guys for the compliments! Much appreciated!
There will be a custom PCB as this was heavily requested in the IC.
Offline amuri99
« Reply #18 on: Mon, 28 October 2019, 19:01:35 »
really need it. pretty look
Offline psxndc
« Reply #19 on: Wed, 30 October 2019, 19:41:39 »
My body is ready.
Ortho. Always.
Offline prangano
« Reply #20 on: Wed, 30 October 2019, 19:45:20 »
Please give us the option to buy just one (half? Idk). I would like one as a macro pad. Specially with the screen and the rotary encoder.
Offline growler
« Reply #21 on: Wed, 30 October 2019, 20:45:16 »
Genius idea!
growler
Don't just stare at it ...
Offline MdotMaxson
« Reply #22 on: Thu, 31 October 2019, 06:04:44 »
I’ll take two
Offline hiddensong
  • this too shall pass
« Reply #23 on: Sun, 03 November 2019, 07:21:16 »
This....with an OLED and rotary. mmmhmmmm guud.
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #24 on: Mon, 04 November 2019, 20:15:29 »
I second the rotary idea.
Offline KevinSanToast
« Reply #25 on: Tue, 05 November 2019, 18:54:42 »
Thirded. Would absolutely be down for this. Also two 2u spacebars?
Offline amuri99
« Reply #26 on: Tue, 05 November 2019, 20:27:55 »
I also hope to use this as a macropad.
Offline growler
« Reply #27 on: Wed, 06 November 2019, 12:40:07 »
Just much more useful that most macro pads, SOAP looks cool, but this with display and rotary would be ace.
growler
Offline rutomoda
    • rutomoda.com
« Reply #28 on: Wed, 06 November 2019, 16:14:01 »
I finally got the design for the exchangeable switch plate done and finished! See main post!
Single side / macro pad option will be a thing!
Current to-do's (no particular order):
  • Rotary encoder housing similar to OLED housing, so the circle fits the square
  • PCB design!!
  • Finish OLED housing
  • Render final integrated plate design and screwless bottom
I currently have a lot of private things to take care of, so progress will be kind of slow. I would love to start the GB around the end of this year, but can make no promises. I will do my best!
Thank you again for all the positive feedback! This really helps me stay motivated!
Offline d00deitsnik
« Reply #29 on: Thu, 07 November 2019, 20:34:46 »
In your most recent renders, what are the 3 holes at the bottom of the case? I can't seem to figure it out.
Offline kmfmppl
« Reply #30 on: Fri, 08 November 2019, 01:54:34 »
Probably cutouts to show the brass weight.
Offline rutomoda
    • rutomoda.com
« Reply #31 on: Fri, 08 November 2019, 13:07:14 »
This exactly. I will add a render to make it clearer.
Offline d00deitsnik
« Reply #32 on: Sat, 09 November 2019, 22:03:01 »
Ohhhh dang! I just realized it creates an ellipsis. That's super cool!
Offline rutomoda
    • rutomoda.com
« Reply #33 on: Sun, 10 November 2019, 15:45:21 »
Yeah, trying to stay on theme as much as possible. Currently only the plate mounting screws are off, but those look weird with the spacer.
Renders added for minimalism version as well as an assembled bottom view.
Offline amuri99
« Reply #34 on: Mon, 11 November 2019, 20:37:39 »
Fantastic. I'm most looking forward to this product's gb.
Offline hottrout
  • I'd Hit Dat Key
« Reply #35 on: Tue, 12 November 2019, 03:39:13 »
Clear PC with brass looks da s**t.  This is a pointless and almost silly product.  I love it.  IN.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline rutomoda
    • rutomoda.com
« Reply #36 on: Mon, 02 December 2019, 13:33:54 »
Just a little update to keep you guys in the loop.
There is quite a lot of private stuff going on with me right now, so development is super slow. But I think I have the PCB schematic now where I want it to be. I had a **** ton to learn about ESD and EMI management I had not payed attention to so far, but I want to deliver the best product possible so I read through a wealth of forum posts and company white papers.
PSA: if my research is correct, most split keyboards are NOT ESD SAFE!
An ESD is a high voltage and therefore high energy pulse shocking a system due to electro static discharge. It is the same as touching a door handle and getting shocked. The Let's Split, Levinson Rev2 and Corne PCB all do not have ESD protection on the TRRS jack. Touching the contacts of the TRRS plug can easily raise the voltage level to several thousand volts and fry the circuits on the PCB.
Disclaimer: I think this should only be possible if the PCB has an active ground connection, meaning the USB is plugged in or there is another connection to ground, and if a TRRS contact other than the ground (usually sleeve) receives the ESD. Also I am a novice regarding this topic and have not done any actual ESD testing so far. I will however install the recommended measures to the Ellipsis PCB, since that boils down to just adding appropiate TVS ICs between signal path and ground.
Besides that figuring out how to connect the main cluster PCB to the PCB for the angled part took some tinkering and digging around. Since the angled PCB is not symmetrical but mirrored between sides I wanted to have it be flippable. I think I have a solution which should work, but I will have to see during actual layout if I have the space.
Speaking of space, there needs to be another revision for the top parts of the case to add more space for the angled PCB, which is currently to small for Kailh hotswap sockets.
And last but not least the angled part should support an encoder in any of the three positions and there might even be up to 8 different encoders available in the main cluster. This depends on a new QMK feature and I am not 100% certain that this will work as I currently understand. Fingers crossed that everything works out.
Offline amuri99
« Reply #37 on: Thu, 25 June 2020, 17:55:56 »
I'm still waiting for this gb to be implemented.
Is there any update added?
Offline econeuler
« Reply #38 on: Thu, 23 July 2020, 10:50:35 »
This is some crazy stuff right here  :cool:
Also hoping for an update!
Offline parablol
« Reply #39 on: Wed, 29 July 2020, 20:16:10 »
I can't print a benchy to save my life. Need the real thing to run! :D
Offline worldspawn
« Reply #40 on: Fri, 21 August 2020, 00:16:24 »
@Ruto
If you use serial and not I2C for the halves, it only takes 3 wires, you can then dedicate the 4th conductor in the TRRS for ESD to connect to the chassis/shield of both halves.
I can make acrylic laser cut cases/plates PM for info
Offline TaurusTrades
    • Taurus trades Etsy Store
« Reply #41 on: Fri, 21 August 2020, 01:14:04 »
Love the prototype!  :thumb:
Offline paperassgasket
« Reply #42 on: Wed, 07 April 2021, 15:22:41 »
GIB HALVE.
