Author Topic: Custom cables with parachord, choosing the right cable size and others questions  (Read 11558 times)
Offline 4sStylZ
Hi,
I want to sleeve paracord on a usb cable, if I can make coiled cable all by myself I will be even more happy.
I have some 550 paracord, and a 28AWG usb cable. I cannot put the paracord on the usb cable. The paracord seem’s too thin.
Every video I look mention this size of cable but it seem’s that I miss a point.
Did I need to remove the original plastic sleeve ?
Can I achieve a coiled cable by myself with paracord. What’s the process for this ? For example, did I need to fill the paracord on the cable before I use the heat gun or did I need to put it after it for not damaging the cord ?
Bépo user here : AEK64 White linear dampened, XD75 Cherry Blue Jailhoused, TypeMatrix2030 black skin, Lenovo 0B47200 w/ trackpoint, G13, G512. Kensington Expert Trackball & Orbit, Magic touchpad 2.
Offline Leslieann
You really want 750, and even that can be tight (and not real paracord, if that matters)..
Here's the problem, need more power, got backlights, you should have thicker wire and it's easy to exceed what paracord can handle. I ordered some did two cables and called it quits when only my thinnest, lowest powered cables were able to fit through it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline 4sStylZ
Thank you for your replies,
I don’t know that a better tool can help me. I don’t think so. This is just a question of dimension.
I definitively take the tips of a 750 cord. Too bad that I have many 550 in stock :|
Offline MarbleKeeb
  • Bring Marble to Keyboards
    • MarbleK Website
I had a very similar issue. I ordered a cable sleeve kit somewhere, but it was impossible for me to sleeve the cable. I tried every trick in the book, but I could not get it. I ended removing the plastic Isolation of the cable..
Sent from my SM-G930F using Tapatalk
Offline ihateregister
  • I like cookies. Yum!
Zap Cables is pretty nice:
https://zapcables.com/diy-kits/
There is probably somewhere cheaper... but they do have 550 paracord that fits on their small 3.5 mm thick USB 2.0 4-core cable wire, with ground/mylar. They also "TechFlex" double sleeving, which stretches up to 8 mm, and shrinks down to about 4.5 mm or so. (Inner Diameter)
It's not a good idea to remove the outer shell for the entire length because it makes the shielding more likely to tear.
Offline 4sStylZ
Finally I have buyed 750 and 1250 paracord.
The last one is huge and can deal with the size of my standard cable but I get 24 meters AWG cable from another source and for some reason my cable is now also at the good size to work even with 550.
For others who want a exact reference, this is this one : https://fr.rs-online.com/web/p/cables-multiconducteurs/1115374/?sra=pstk
I also got some proper techflex and did my first custom cable.
