Author Topic: [IC] SP-111 - Split Southpaw keyboard - GB Opens November 22nd @ TheKey.Company!  (Read 35223 times)
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
229014-0
I originally created this keyboard as a personal project earlier this year as a keyboard with a layout that would work best for me in CAD and was only planning on getting one made for myself and a friend but when others heard of the board either via me or my keyset renders for GMK Night Runner they would always ask about when they could get it. So here it is, after a bit of work getting the prototypes made and ironing the bugs out, I introduce my baby the SP-111!
What does the name mean?
It has a ton of meanings to the name that most don't even realize.
 - SP: Split, Southpaw, Special. 3 meanings tied to the 3 ones in the name.
 - 111: The numbers from my username. Original meaning for the numbers in my username is my b-day, November 1st, so I had to incorporate it somehow.
 - 111: Wait, there is more meaning? Yep! The 3 prototypes (once again representing the 3 ones in the name and the 3 people with them) have a layout that has exactly 111 switches (one of the layout options).
Why is this board laid out like it is?
 - Southpaw to allow you to use the numpad and mouse at the same time (helpful for CAD and other data entry)
 - Split to allow placement in a comfortable manner for long sessions of data entry or work in general.
 - Right side layout to maintain the functionality of a full size in a much more compact manner. Hence the 1800 style arrows and vertical nav.
What mounting style is it?
 - Sandwich mount, with the plate visible around the edges and locating tabs for alignment.
What are the specs?
 - Board has a typing angle of 7 degrees (yes it is like a normal board but split, no tenting available unless you plan on drilling and tapping the case...)
 - Left side weights 1.49 Kg (3.29 lb) and the right side weights 1.3 Kg (2.87 lb). This is without pcbs, switches or caps, and there are no weights, just case and plate.
 - Board interconnect is Type-C, I am not a heathen!
 - Board connects via Type-C as well.
Is the buy limited or unlimited?
 - Unlimited of course! I don't like to run buys with a max for the sake of making it exclusive.
Will I be able to buy an extra set of pcbs?
 - Yes, the plan is to sell extra pcbs alongside this board so you can have spares.
Will I be able to buy extra plates?
 - Not sure at the moment, I would like to but no guarantees they will be available.
Will the plate files be posted so I can make my own plates?
 - That is the plan, not sure exactly when I will post them (probably around delivery time?). This means you can do mirrored numpad plates and different materials to your liking just know that for the usb ports to align properly 1.5mm plates need to be used unless you make a spacer below the plate.
When will I be able to get my SP-111?
 - It will ship probably early to mid Q2 to be safe as it entirely depends on the quantity ordered for the lead time.
My favorite feature?
 - The smooth slope on the bottom side, which is really nice to touch when either picking it up or just thinking.
228997-1
Renders:
Featuring KAT WoB by OneCreativeMind.
Renders by MetallicCharles
228990-2
228992-3
228994-4
Layouts:
 - Before anyone asks, mirrored numpad is not supported on the plates due to the issues it brought to the table for that corner of the board (basically a super flex section that would feel horrible compared to the rest of the board). It IS supported on the PCB though if you want to get your own plates cut.
 - And as a side note, you can mix and match the bottom row options, they don't have to be both the same spacebar size, each side layout is independent of each other and the included plate supports 2.75u and 2.25u options on both halves. 3u will require a different plate just because it made the plate a bit too light on material to include. So if you feel like a 2.25u and 3u you can go for it (if you get a plate made).
228986-5
 - The following are PCB only to not have the plate be too weak and flex more than intended.
229983-6
Colors:
 - Black with sandblasted brass plate.
 - E-white with sandblasted brass plate.
 - Blue-gray with a sandblasted brass plate.
 - Renders: https://imgur.com/a/4uA4ECX
Vendors/Dates:
 - This will be run by The Key Dot Company and proxies most likely (TBD)
 - GB opens November 22nd!
Timeline:
 - November 22nd start date, end date not set atm.
Pricing:
 - Black or blue kit: $399
- E-white kit: $419
Special Thanks:
 - OneCreativeMind for helping me come up with this board in the beginning and the logo for the board
 - MetallicCharles for the renders
IC Form:
 - https://forms.gle/mw4HBTwS9uLArfkf7
« Last Edit: Wed, 13 November 2019, 15:22:35 by BlindAssassin111 »
Offline bthezebra
Re: [IC] SP-111 - Split Southpaw keyboard
« Reply #1 on: Mon, 28 October 2019, 19:12:42 »
Hype hype
Offline walston
« Reply #2 on: Mon, 28 October 2019, 19:13:52 »
That split tho
Offline Jhambone9160
« Reply #3 on: Mon, 28 October 2019, 19:16:03 »
This is exciting
Offline eskimojo
    • KeycapLendar
« Reply #4 on: Mon, 28 October 2019, 19:18:34 »
hell yea
Offline GraffitiDecos
« Reply #5 on: Mon, 28 October 2019, 19:23:49 »
Very nice!!
Sent from my Pixel 3 using Tapatalk
Offline xanserkx
« Reply #6 on: Mon, 28 October 2019, 19:28:11 »
Interesting
Oblotzky AIS65 - Rama Zenith - RME Studio Emery65 - TGR Tomo - Hex 4B - Cablecar Design Angel - Cablecar Design Phoenix - Cablecar Design Cypher - Hand Engineering Haus - TX HJ75 - Parallel Limited Portal -  SingaKBD Kohaku -  and bunch of prototypes that I made :(
Sold: Merisi Ottantaquatro
Offline jrfhoutx
  • Post count is meaningless if the content is trash.
« Reply #7 on: Mon, 28 October 2019, 19:51:23 »
Thanks for not loading the page with renders!
Such a nice board, the prototypes are so very nice to type on.
Offline IOVERCALLHISTIOCYTES
« Reply #8 on: Mon, 28 October 2019, 20:10:32 »
I F5 this site cause I'm waiting to see this board. In 2024 noobs are gonna post keyboards not in this layout as a look what I found for karma because literally everyone with two hands or some sort of prosthetic is gonna buy one including kingnestea's friend who puts his feet in the picture with his keyboard
uh, actual feedback: Bottom row options reworked so we can all use our 2.25u / 2.75 split bars is awesome.
Offline !Q
« Reply #9 on: Mon, 28 October 2019, 21:24:43 »
consider me interested
Offline Macmutant
« Reply #10 on: Tue, 29 October 2019, 00:15:17 »
Love this design. Perfect work board. Super interested!
Offline Nigolski
« Reply #11 on: Tue, 29 October 2019, 00:26:51 »
nice
Offline CF73
« Reply #12 on: Tue, 29 October 2019, 04:42:58 »
stunning board. prefer this over the VE.A  ;D
will there be any weights on the bottom, or is it gonna be a clean flat bottom?
« Reply #13 on: Tue, 29 October 2019, 07:54:25 »
"Left side weights 1.49 Kg (3.29 lb) and the right side weights 1.3 Kg (2.87 lb). This is without pcbs, switches or caps, and there are no weights, just case and plate."
Online pixelpusher
« Reply #14 on: Tue, 29 October 2019, 09:08:09 »
I'll just rename it "The Beast."  Look at it RAWR!   :thumb:
Offline ocm
  • Formerly OneCreativeMind
« Reply #15 on: Tue, 29 October 2019, 10:33:25 »
Can confirm. It's beefy as **** (in a good way).
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #16 on: Tue, 29 October 2019, 16:25:58 »
What's the front height?
    • Viktus
« Reply #17 on: Tue, 29 October 2019, 17:26:32 »
The front edge is ~21mm tall.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #18 on: Tue, 29 October 2019, 17:59:50 »
I know this one ain't gonna be cheap, but I really want one! Awesome layout & split, I'm sold. I've been stashing money to the side for my next custom, depending on the timing of the GB I'm hopefully gonna get in on one of these.
Offline CF73
« Reply #19 on: Tue, 29 October 2019, 19:50:26 »
oh right right, idk how i missed that, thanks.
« Reply #20 on: Tue, 29 October 2019, 20:22:57 »
Chunky but I'll live with it for the layout.
« Reply #21 on: Tue, 29 October 2019, 22:03:16 »
PSA for those who love this layout like I do: GMK Dracula-ending in less than 2 days- has an F13 key.
Curious to see how all of you occupy F13, scroll lock, pause, and the 4 atop the numpad.
Offline davisthegreat
    • 3DKeebs
« Reply #22 on: Wed, 30 October 2019, 10:28:48 »
Yes Please.
Offline joshipoo23
« Reply #23 on: Wed, 30 October 2019, 21:22:24 »
Will the pcb support QMK?
    • Viktus
« Reply #24 on: Wed, 30 October 2019, 23:42:33 »
Yes, it will support QMK out of the box.
Offline RDaneelOlivaw
  • Don't Panic.
« Reply #25 on: Thu, 31 October 2019, 09:27:26 »
Very interested! Filled out the form and will await updates here.
He felt that his whole life was some kind of dream and he sometimes wondered whose it was and whether they were enjoying it.
Offline p_blaze
« Reply #26 on: Thu, 31 October 2019, 22:15:36 »
2020 YEAR OF THE SPLIT BOARDS I HAVE BEEN WAITING!!!!!
    • Viktus
« Reply #27 on: Fri, 01 November 2019, 15:53:24 »
Update:
Got some new renders for you all from my friend MetallicCharles.
Pics of the color options:
229229-0
E-white and brass plate
229231-1
Blue ano and brass plate
229233-2
Black ano and brass plate
229235-3
And a sexy angle for good measures.
« Last Edit: Fri, 01 November 2019, 16:02:55 by BlindAssassin111 »
« Reply #28 on: Fri, 01 November 2019, 16:00:24 »
I went from I'll get the two non blue ones to def in for the blue. That's beautiful.
If I ask nicely will spare PCBs be available? If it's not part of the group buy and it's separate/down the road thats fine too. I hope to use these boards for years to come.
    • Viktus
« Reply #29 on: Fri, 01 November 2019, 16:07:14 »
I already have black and was thinking of getting white, now I want white and blue...I might have too many if I did that though.
Offline Rejeckted
  • Fe, Fi, Fo, Fum... I smell Kraft dinnah
« Reply #30 on: Fri, 01 November 2019, 16:19:45 »
I'll take it
Offline mr scooty
« Reply #31 on: Fri, 01 November 2019, 16:21:13 »
blue is beautiful :eek:
« Reply #32 on: Fri, 01 November 2019, 16:37:01 »
Lost me at "too many." Home, work, spare.
    • Viktus
« Reply #33 on: Fri, 01 November 2019, 16:44:53 »
Well they wouldn't be my only boards...I have about 20 already  :-[
« Reply #34 on: Fri, 01 November 2019, 18:18:10 »
I hear you. I have display keycaps boards and let's work boards. To me, this is the latter; albeit pretty enough to be the former.
« Reply #35 on: Fri, 01 November 2019, 19:43:46 »
I was curious about the Blue-gray, definitely not disappointed.
  • Don't Panic.
« Reply #36 on: Fri, 01 November 2019, 21:11:15 »
OMG that blue brass is gorgeous. Definitely the one I will choose.
I apologize in advance because I know you must hear a million suggestions from everyone. This is your board and I love it! That said: Would you ever consider offering the board with no angle whatsoever, just flat? Tilt forward is so bad for ergo, and it being split will definitely target the ergo community. In fact I would love a decline tilt if anything but I know those are not very popular, so just a flat board would be awesome!
Other than that this is a dream board. I already have a separate numpad to the left of my quefrency.. So this all being together and mappable via qmk is so awesome. Thank you for your hard work!
« Last Edit: Fri, 01 November 2019, 21:29:53 by RDaneelOlivaw »
    • Viktus
« Reply #37 on: Fri, 01 November 2019, 21:49:25 »
Maybe in the future I can offer a bottom replacement to do just that, but no plans to do so atm.
  • Don't Panic.
« Reply #38 on: Fri, 01 November 2019, 22:03:13 »
It was worth an ask :)
Totally fine, I'm still all in, thanks for the quick reply!
« Reply #39 on: Fri, 01 November 2019, 22:41:52 »
RDaneelOlivaw-my preferences are the same as yours. I dont mind an overall taller board (I'm tall) but I do like the flat angle...and yet would completely give it up for using one of these.
Blinadassassin111: If you offered different bottom parts down the line (weights, flat angles)...I'm buying what you're selling.
« Reply #40 on: Sat, 02 November 2019, 07:30:45 »
I would at least put in a vote for a shallower angle. 5° or less.
Offline Polyzhu
« Reply #41 on: Sun, 03 November 2019, 11:30:54 »
The more I think about this, the more I find myself loving the design. This looks incredible and I can't wait for the GB to start!
Offline nathanchere
« Reply #42 on: Sun, 03 November 2019, 17:28:13 »
it's like everything I like about the VE.A minus all the things I don't like. Can't wait
    • Viktus
« Reply #43 on: Mon, 04 November 2019, 15:42:43 »
Update:
Added support for mirrored numpad to the PCB only, the plate will support a non-mirrored numpad only as the plate would basically be nonexistent for the numpad otherwise.
« Reply #44 on: Mon, 04 November 2019, 21:34:30 »
TKC said Nov 22nd on their reddit update, is that true? Gotta make sure my moneys ready.
    • Viktus
« Reply #45 on: Mon, 04 November 2019, 22:17:21 »
It is! I didn't have time to make a big update for this today so...yes. Will update tomorrow most likely.
Offline lush_bunny
November 22? Here I thought I could make myself unbroke before the GB.
Offline thornkin
Is there a price range?
Laser ALT sporting red Sky Pandas
Offline yrneh
where the heck am i supposed to get a f13 key for this, anyways im interested in this board
    • Viktus
You can do an F13 or one of the other R1 nav cluster caps, it just happened to line up like an F13 when I did it.
