Author Topic: [TMK] HHKB Alt Controller with USB Type-C connector  (Read 146354 times)
Offline hasu
  •  Moderator
  • @tmk
« on: Wed, 20 November 2019, 23:18:31 »
Check this post for order information.
Difference is only its USB conector, USB Type-C vs USB Mini-B. Other part of controller is completely identical.
You don't have to file connector opening of its case and the Type-C connector fits into the existent opening.
Type-C connector is implemented on castellated daughter pcb to tune its height to the existent opening.
CAVEAT
NOT USB 3. The controller works with USB 2 full speed.
NOT PD. Power delivery is not supported.
USE COMPLIANT CABLE. Don't use obscure cable. Get cable from reliable soruce.
UPDATE
2020-04-12 Revised price of controller and shipping rate
2022-03-09 Revised price of controller
2022-04-12 Remove ORDER instruction
« Last Edit: Mon, 11 April 2022, 19:29:00 by hasu »
Offline hasu
  •  Moderator
  • @tmk
Re: [TMK] HHKB Alt Controller with USB Type-C connector
« Reply #1 on: Sun, 11 April 2021, 19:36:26 »
Revised price and shipping rate
