Author Topic: Polar Nights  (Read 16958 times)
Offline Gtrx
Polar Nights
« on: Wed, 27 November 2019, 08:12:55 »
Hey geekhack
this is Polar Nights. The set was inspired by the Iceberg vim theme.
Design
This set is probably going to be ran through infinikey, as they are the only manufacturer that I know that can do reverse dye sub with dark legends.
Main kit
The base kit covers most popular layouts (60%, HHKB, 75%, 65%, TKL).
Spacebars
Renders
Google Interest Check Form
Kit design
Kits will be added based on IC form responses.
« Last Edit: Wed, 27 November 2019, 10:53:32 by Gtrx »
Offline LXVRGS
Re: Polar Nights
« Reply #1 on: Wed, 27 November 2019, 08:22:00 »
ne text/icon mods avail?
Offline eskimojo
    • KeycapLendar
Re: Polar Nights
« Reply #2 on: Wed, 27 November 2019, 08:31:39 »
This seems like a small base kit for Infinikey, considering how big previous sets have been.
Considering these were barely over $100 (katakana was $95, sanctuary was $120), is there any reason to limit compatibility?
Offline pwade3
Re: Polar Nights
« Reply #3 on: Wed, 27 November 2019, 08:34:18 »
IC for this and Nord at the same time?
Big Brane.
Offline PocketAces
Re: Polar Nights
« Reply #4 on: Wed, 27 November 2019, 08:41:31 »
This is really pretty. I’m usually not into darker sets, but I might have to go for this one
Offline terrad
Re: Polar Nights
« Reply #5 on: Wed, 27 November 2019, 08:51:31 »
+1 for bigger "all in one kit". If not, please add  a icon+text mod kit and add a "b" to the spacebar kit
Sent from my SM-G955F using Tapatalk
« Last Edit: Wed, 27 November 2019, 09:56:24 by terrad »
Offline funderburker
Re: Polar Nights
« Reply #6 on: Wed, 27 November 2019, 08:56:50 »
I literally wouldn't tell this, GMK Nord and GMK Firefly apart. All of them look nice-ish though, just not for me.
Keyboard design by Skepur
Offline Gtrx
Re: Polar Nights
« Reply #7 on: Wed, 27 November 2019, 09:00:59 »
I dislike making huge main kits like those. Most people won't use half the kit, so why should they pay for it? I'd much rather have a base kit and 2 other kits than a huge base kit.
Offline zekkin
  • my entire life was unlimited zekk works
Re: Polar Nights
« Reply #8 on: Wed, 27 November 2019, 09:02:13 »
treading into violet tendencies territory with the lack of contrast on the alpha legend color/alpha key color
Offline eskimojo
    • KeycapLendar
Re: Polar Nights
« Reply #9 on: Wed, 27 November 2019, 09:10:03 »
From what I've gathered, the reason that Infinikey kits are structured this way is due to an extraordinarily large MOQ, which makes child kits infeasible. (Child kits apparently have a MOQ of 300 minimum)
If you want a kit structure like this, you should consider other manufacturers.
« Last Edit: Wed, 27 November 2019, 09:12:31 by eskimojo »
Offline Visionaire
Re: Polar Nights
« Reply #10 on: Wed, 27 November 2019, 09:11:00 »
I mean you are comparing 2 color sets to a 5 color set. That's doing to drive price pretty quickly.
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: Polar Nights
« Reply #11 on: Wed, 27 November 2019, 09:11:34 »
ne compatibility avail
Offline eskimojo
    • KeycapLendar
Re: Polar Nights
« Reply #12 on: Wed, 27 November 2019, 09:13:58 »
This is true, but when child kits for Infinikey have a MOQ of 300, is that really a viable alternative?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: Polar Nights
« Reply #13 on: Wed, 27 November 2019, 09:14:51 »
Not sure how to feel about the super low contrast. But Iceberg is a nice color scheme, so good luck.
Offline Gtrx
Re: Polar Nights
« Reply #14 on: Wed, 27 November 2019, 09:25:25 »
Offline Gtrx
Re: Polar Nights
« Reply #15 on: Wed, 27 November 2019, 09:26:35 »
I'll reach out to my infinikey contact about it.
Offline godinjointform
Re: Polar Nights
« Reply #16 on: Wed, 27 November 2019, 11:47:03 »
Not digging the low contrast alphas
or the mods
pretty much the whole set, especially with other sets that look the same being in IC right now
Offline modeseven
Re: Polar Nights
« Reply #17 on: Wed, 27 November 2019, 13:42:52 »
Supposedly PBT, big if true!
Offline Pheyn
Re: Polar Nights
« Reply #18 on: Wed, 27 November 2019, 14:29:45 »
I really like the colors in this set, more colorful pbt sets is always gonna get my interest  :thumb:
One suggestion I might have is, instead of using black text on the majority of keys, why not make those keys blanks instead? Those keys are very tough to read anyway, so the final product would still look pretty similar to what you have now.
Other benefits to doing that would be:
1. Lower costs (I'd assume)
2. Mostly solve the compatibility issue that others have mentioned (though I'd still add numpad keys at the very least)
Just a suggestion! I'll be keeping an eye on this set as it progresses  :D
Offline SoraNoTenshi
Re: Polar Nights
« Reply #19 on: Wed, 27 November 2019, 14:42:12 »
I just wonder why this set is called Polar Nights but has pink in it...
Offline Gtrx
Re: Polar Nights
« Reply #20 on: Wed, 27 November 2019, 15:46:33 »
from what I've seen,the aurora borealis has some very washed out pinkish tones and the set kind of resembles an aurora with saturation and contrast turned up. That's where the name came from.
Offline Acrimony
Re: Polar Nights
« Reply #21 on: Wed, 27 November 2019, 16:49:00 »
It looks fine. It's missing the green that is in the theme, that would make it pop more.
Offline J3ff_Leopard
    • Wishlist
Re: Polar Nights
« Reply #22 on: Wed, 27 November 2019, 21:47:44 »
No Numpad? No thank you. Design looks good. Low contrast is fine since the theme is nights after all.
WTB Resin Cast Click Clack Leaf
Offline AlcoholEnthusiast
Re: Polar Nights
« Reply #23 on: Thu, 28 November 2019, 22:29:31 »
If it sticks with PBT then I'm likely in
Offline benfrain
    • benfrain.com
Re: Polar Nights
« Reply #24 on: Thu, 05 December 2019, 08:30:20 »
Much as I like those two Vim/iTerm themes I also like your Nord design and this. However, having had a black HHKB I found low contrast alpha’s are only really great in pictures!
I’m looking to buy a keycap set, especially one sympathetic to Vim but at present this would come third to Nord, then Doubleshot. I might put it before Doubleshot if there were more legible alphas
Offline modeseven
Re: Polar Nights
« Reply #25 on: Sun, 12 January 2020, 15:50:15 »
Any updates/progress on this?
Offline NitPik
Re: Polar Nights
« Reply #26 on: Mon, 08 November 2021, 23:49:30 »
I still believe
Offline AstralYT
Re: Polar Nights
« Reply #27 on: Tue, 09 November 2021, 00:25:48 »
White alpha legends please?
