Author Topic: [IC] Fallacy - An Aluminum Alice Layout Board (Group Buy Date Announced)  (Read 48853 times)
Offline cdhoffmann
Re: Fallacy - An Aluminum Alice Layout Board
« Reply #50 on: Mon, 09 December 2019, 12:20:18 »
Hope to see the price for this go down, especially if we have to provide our own PCB. Here is what the original Alice went for: "$463 for case + plate + weight + PCB (Pre-soldered with controller parts, LED's resistors, and diodess)". Cheers!
This includes a pcb.
Offline lolafineday
« Reply #51 on: Mon, 09 December 2019, 12:50:33 »
Feel like pcb should be optional addon, most have alice pcbs and configs already. And if they need they can just order off projectkb.
Sent from my SM-G975F using Tapatalk
Offline lolafineday
« Reply #52 on: Mon, 09 December 2019, 12:51:37 »
Actually I guess this pcb is unique so it might make sense to include.
Offline Esheu2
« Reply #53 on: Mon, 09 December 2019, 13:46:50 »
I just pre-ordered 2 of the "ALICE PCB REV2" (USB-C) and 1 POM plate and 1 fiberglass plate. Will your case fit any of those?
Plates, yes. PCB's no.
Let the haters hate, and the thread crappers spread their crap. Even with that, your ~50 units will be sold out in no time.
In for one, hoping to get 2.
Also, suggestion for the script for the bottom weight logo is attached.
Bruh, just keep it to one
Limit 1 per person.
The kit includes a PCB.
Ojou
Offline KingOfMemes
« Reply #54 on: Mon, 09 December 2019, 14:13:33 »
Hopefully the price is steep so I won't have to fight for 50 units.
Offline Mcnos
    • GMK Fuyu
« Reply #55 on: Mon, 09 December 2019, 17:49:13 »
Let's fight anyway  :)
Offline Esheu2
« Reply #56 on: Mon, 09 December 2019, 18:10:48 »
Are you hinting that I should increase the pricing? I would be ok with that  :D
Ojou
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #57 on: Mon, 09 December 2019, 19:14:21 »
"Similarly, a typing height of over 20mm results in my wrists losing contact with my desk, forcing me to keep my hands floating."
SMH. Proper typing means your wrists should be floating. And for that reason, I'm out.
Sent from my GM1915 using Tapatalk
aveyn is out huh. And for that reason, I'm in, nice kb chief :cool:
Sent from my iPhone12XE using Tapachat
Offline regionfree
« Reply #58 on: Mon, 09 December 2019, 20:58:29 »
You should price this so what you get is worth your time and effort.
Offline NathanielGoodtimes
    • n/a
« Reply #59 on: Tue, 10 December 2019, 09:12:52 »
Make it a bazillion dollars!!!
Offline MisterKnife
« Reply #60 on: Tue, 10 December 2019, 15:09:00 »
I’m in
Offline DJ Shoko
« Reply #61 on: Tue, 10 December 2019, 16:06:34 »
I’m in
In for a battle royale that is.
Offline Mekuno
« Reply #62 on: Tue, 10 December 2019, 16:21:24 »
Can't wait to see more of the proto. Pink looks really nice.
Offline Poesjuh
« Reply #63 on: Tue, 10 December 2019, 16:26:07 »
I’d say $400 range is already more than enough for a top mount board. Inflating the price just to create a luxury item only the rich can afford... ah well, my wallet will speak and do nothing I guess.
Offline thearctican
« Reply #64 on: Tue, 10 December 2019, 17:35:47 »
What sort of mount would you prefer? Top mount is the best I've used. Most gasket boards are a joke, bottom mount isn't bad. Get a POM plate cut for it.
On the board itself: thank you for not making it polycarbonate. If I wanted a plastic board I'd buy a Realforce.
Offline lolafineday
« Reply #65 on: Tue, 10 December 2019, 17:37:19 »
Dang plastic shaming... polycarbonate is epic plastic!
Offline Esheu2
« Reply #66 on: Tue, 10 December 2019, 23:06:14 »
Added manufacturer photos of the blue gray prototype to the main post!
Ojou
Offline nickaster1
« Reply #67 on: Wed, 11 December 2019, 00:34:25 »
The Fallacy
People were calling Alice clones "Falice". Sounded a lot like "Phallus" to me. Friend told me that wasn't a good idea. Fallacy it is.
Features
  • Top Mount
  • Anodized 5052 Aluminum for the Top and Bottom Case
  • Sandblasted Brass Weight
  • 6.5 Degree Typing Angle
  • 16.5mm Front Typing Height
  • USB Mini port
  • PCB Compatible With QMK
  • PCB features flex cuts
  • Brass weight spans the entirety of the alpha cluster
  • Side cutouts for grip
  • Pricing: most likely mid/low $400's (tentative estimate CAN CHANGE)
I chose to go with a relatively low typing angle at 6.5 degrees and front lip height of 16.5mm for my own comfort. I have found that my preferred range for typing angles is between 5 degrees and 7.5 degrees.
Any lower feels awkward. Any higher results in strain on my wrists. Similarly, a typing height of over 20mm results in my wrists losing contact with my desk, forcing me to keep my hands floating. I find this tiring so I made the typing height as low as possible.
Supported Layouts
Will have standard Alice supported layouts
  • Split/normal backspace
  • Split/normal right shift
  • Stepped/normal capslock
Plate
The plate will be the standard 1.5mm thickness. It will be compatible with the standard Alice plate.
There will be a few choices for plate material:
  • Aluminum
  • Brass
  • POM Plastic
PCB
  • QMK Compatible
  • USB Mini port
  • Flex Cuts
The board is also able to accept standard Alice PCBs if you already have those on hand.
Weight
  • "Fallacy" engraving
  • Sandblasted
  • Internally secured by screws
  • Alpha cluster has brass under it for acoustics
GIF of weight:https://i.imgur.com/yXv2Cm0.mp4
I enjoy patina so there will be no coating added. End users can apply a layer of wax or something if they would like to prevent patina from forming.
Colors
  • Black
  • Silver
  • Blue Gray
  • Pink
FAQ
Q: Polycarbonate?
A: No.
More Information and Updates
Discord Server Invite: https://discord.gg/CxjYT58
Please join the Discord server and subscribe to the !fallacy role if you would like to get updates on the project as soon as possible
Prototypes are almost done already. I will provide updates when I get them in my hands.
Special Thanks
Choobies, Trifelife, Exfinite (Vov), and Warren for helping me prototype and giving me feedback.
Trifelife for designing the PCB.
Yuktsi for open sourcing his Alice files and giving me the okay to manufacture this keyboard.
That blue is so hot jeez
Offline Poesjuh
« Reply #68 on: Wed, 11 December 2019, 02:46:08 »
O I'm not saying that top mount is bad by any means :) What I meant was that a topmount usually requires less material and a easier to manufacture plate. For that reason top mounts are usually a bit cheaper to manufacture than fancy gasket mounts with all sorts of extra stuff that comes with it.
Offline Esheu2
« Reply #69 on: Wed, 11 December 2019, 03:03:07 »
Let me clear some things up:
  • The price hiking was a joke. I'm not going to make the base cost higher than the $400's range.
  • The plate mounting style does not significantly change any costs. This board was more expensive for me to prototype than another design of mine that utilized isolation gasket mounting. The main contributors to costs are machining time (usually proportional to size) and material.
Ojou
Offline papayapyjamas
« Reply #70 on: Thu, 12 December 2019, 14:10:12 »
cant join the discord channel.
Offline Esheu2
« Reply #71 on: Thu, 12 December 2019, 19:21:14 »
Weird. The link was working for me. Posted a new one regardless. LMK if it still doesn't work!
Ojou
Offline xchangmanx
« Reply #72 on: Fri, 13 December 2019, 16:51:39 »
I'm behind this, but any chance on having a blank weight with no name?
Offline Esheu2
« Reply #73 on: Sun, 15 December 2019, 20:04:55 »
I have to admit that I am very hesitant to remove the engraving despite people expressing their distaste for it. I personally (and obviously there's a lot of bias to it) really like it and believe that it will look better in real life compared to the renders. So, I want to wait to receive the prototypes and take better pictures of the actual weight.
If people still dislike how it looks, then I will likely relent and just have a blank weight.
Ojou
Offline kaisn
« Reply #74 on: Tue, 17 December 2019, 15:14:29 »
I don't mind the engraving at all. However it's kinda bland imo
Offline VXQN
« Reply #75 on: Wed, 18 December 2019, 04:45:54 »
I'm okay with the engraving as a concept, but I definitely think the script should be re-worked to flow a little bit better (especially the F).
Offline Thighs
  • Thighs#0100
« Reply #76 on: Wed, 18 December 2019, 11:58:13 »
A custom engraving would be amazing. Take my money.
Offline p_blaze
« Reply #77 on: Thu, 19 December 2019, 18:39:28 »
Are the colors final? It kills me that no boards i want are in purple anymore
Offline Esheu2
« Reply #78 on: Fri, 20 December 2019, 22:52:08 »
Yes the colors are final.
Ojou
Offline jimboytacos
« Reply #79 on: Sat, 21 December 2019, 15:57:50 »
Is there a TBD date for launch? Or will this information all be shared on Discord first?
Offline Esheu2
« Reply #80 on: Sun, 22 December 2019, 02:53:02 »
No date yet. GB launch date should be decided before the New Year.
Ojou
Offline Esheu2
I have received the prototype units. Pictures have been added to the main post. Will hopefully have somebody else with a better camera than I do take pictures and a typing test for me soon-ish.
Ojou
Offline neojonathan
I love the pink color !!!
Offline vaughno
If the funds are right then I'll probably get in on the pink one  ;D
Unikorn | Orion v3 | GSKT-00
Offline KingOfMemes
will there be limited stock? Or will this be an unlimited buy
Offline nickaster1
I don’t see why this will be unlimited. He’ll prolly keep it down to a manageable size so nothing goes out of hand
Offline KingOfMemes
Nice, I've been thirsting for a good race :smiling_imp:
Offline Esheu2
Limited. ~50 units or so plus extras that will be sold off after everything is done.
Ojou
Offline KingOfMemes
Bless up, thanks.
Offline Esheu2
Hey guys! Please fill it out if you're interested. I'd like to gather some data and feedback.
Interest Check Form: https://forms.gle/9dJJL3cx34cppmsu7
Ojou
Offline Solotov
So, there are only 2 options for weight engraving: current design and blank?
Would prefer some engraving over blank. Any chance for an alternative design?
Flex is love, flex is life.
Offline lolafineday
Blank would look hot asf, just look at the rukia weight!
Offline swangful
i think the weight just needs a better logo. having the word fallacy isnt the problem IMO, its just the font/logo.
Offline sarsaparillagorilla
1000% interested can't wait loved but never got the chance to get the Alice and this could be a more than adequate alternative
Offline Esheu2
From what I have gathered, it seems like the controversial part of the engraving is the letter "F".
The issue is that this is the only cursive script font I've found that I felt tastefully did the letter "F" (imo) while keeping everything easily machinable.
Ojou
Offline swangful
thats fair, i didnt think about keeping things machinable. i saw the suggestion of the backward F like fender, seems like a neat idea. personally, the logo isn't a deal breaker for me. looks good with or without  ;D
Offline yui_
cad files for the weight should be released, so that i can get a custom weight with phallus on it.
looks great though !
Offline JJ
+1 for custom engraving for the weight. It makes it a custom and unique piece.
Sent from my SM-G9600 using Tapatalk
Offline KingOfMemes
I, too, would be down for a custom engraving of a Phallus on my weight
Offline Esheu2
Re: Fallacy - An Aluminum Alice Layout Board (Group Buy Date Announced)
« Reply #99 on: Mon, 06 January 2020, 15:35:22 »
Group Buy Date: January 25th, 2020. 5PM PST.
Price (not inclusive of any shipping or fees):
$420 for top + bottom + weight + PCB + POM/Alu plate (+$15 for brass)
$50 for additional PCB
$30 for additional POM or Aluminum plate
$45 for additional Brass plate
Ojou
