Author Topic: [IC] Fallacy - An Aluminum Alice Layout Board (Group Buy Date Announced)  (Read 48315 times)
Offline Esheu2
The Fallacy
People were calling Alice clones "Falice". Sounded a lot like "Phallus" to me. Friend told me that wasn't a good idea. Fallacy it is.
Group Buy Date: January 25th, 2020. 5PM PST.
GB Post: https://geekhack.org/index.php?topic=104300.0
Interest Check Form:
https://forms.gle/9dJJL3cx34cppmsu7
Prototype Pictures
Buy Details
To make the buy more manageable for me, there will be 50 units. Limit one per person. FCFS
Features
  • Top Mount
  • Anodized 5052 Aluminum for the Top and Bottom Case
  • Sandblasted Brass Weight
  • 6.5 Degree Typing Angle
  • 16.5mm Front Typing Height
  • USB Mini port
  • PCB Compatible With QMK
  • PCB features flex cuts
  • Brass weight spans the entirety of the alpha cluster
  • Side cutouts for grip
I chose to go with a relatively low typing angle at 6.5 degrees and front lip height of 16.5mm for my own comfort. I have found that my preferred range for typing angles is between 5 degrees and 7.5 degrees.
Any lower feels awkward. Any higher results in strain on my wrists. Similarly, a typing height of over 20mm results in my wrists losing contact with my desk, forcing me to keep my hands floating. I find this tiring so I made the typing height as low as possible.
Supported Layouts
Will have standard Alice supported layouts
  • Split/normal backspace
  • Split/normal right shift
  • Stepped/normal capslock
Plate
The plate will be the standard 1.5mm thickness. It will be compatible with the standard Alice plate.
There will be a few choices for plate material:
  • Aluminum
  • Brass
  • POM Plastic
PCB
  • QMK Compatible
  • USB Mini port
  • Flex Cuts
Designed by Trifelife
The board is also able to accept standard Alice PCBs if you already have those on hand.
Weight
  • "Fallacy" engraving
  • Sandblasted
  • Internally secured by screws
  • Alpha cluster has brass under it for acoustics
GIF of weight:https://i.imgur.com/yXv2Cm0.mp4
I enjoy patina so there will be no coating added. End users can apply a layer of wax or something if they would like to prevent patina from forming.
Colors
  • Black
  • Silver
  • Navy
  • Pink
Price (not inclusive of any shipping or fees):
$420 for top + bottom + weight + PCB + POM/Alu plate (+$15 for brass)
$50 for additional PCB
$30 for additional POM or Aluminum plate
$45 for additional Brass plate
FAQ
Q: Polycarbonate?
A: No.
More Pictures
More Information and Updates
Discord Server Invite: https://discord.gg/pYVsseU
Please join the Discord server and subscribe to the !fallacy role if you would like to get updates on the project as soon as possible.
Special Thanks
Choobies, Trifelife, Exfinite (Vov), and Warren for helping me prototype and giving me feedback.
Trifelife for designing the PCB.
Yuktsi for open sourcing his Alice files and giving me the okay to manufacture this keyboard.
« Last Edit: Mon, 20 January 2020, 19:00:58 by Sinapanis »
Ojou
Offline isaackang7
Re: Fallacy - An Aluminum Alice Layout Board
« Reply #1 on: Sun, 08 December 2019, 00:57:38 »
Youtube video is set to private cannot see it
Offline XtReeM1337n355
« Reply #2 on: Sun, 08 December 2019, 00:58:22 »
I think you might need to check your discord link again. Also, would you consider a USB C port instead of mini?
Offline Esheu2
« Reply #3 on: Sun, 08 December 2019, 01:01:31 »
Fixed I think. Thanks!
Oops! Public now.
Ojou
Offline octix
« Reply #4 on: Sun, 08 December 2019, 01:06:53 »
Definitely interested!
Discord: octix#0478
Offline LXVRGS
« Reply #5 on: Sun, 08 December 2019, 01:10:23 »
id lose the weight engraving personally
Offline Popopro
« Reply #6 on: Sun, 08 December 2019, 01:16:32 »
Same, not a fan of the text.
Offline FinalEleven
« Reply #7 on: Sun, 08 December 2019, 01:23:33 »
I am totally in.
Not too fond of the font for the weight engraving though.
Offline Pwner
  • soon™
« Reply #8 on: Sun, 08 December 2019, 01:37:34 »
Great to finally see something fresh, new and exciting.
Offline dantambok
« Reply #9 on: Sun, 08 December 2019, 04:59:28 »
oh wow
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline roguesystem087
« Reply #10 on: Sun, 08 December 2019, 06:32:37 »
Forget the IC!!!! Lets goooooooooooooo XD omgarddddddddd X3
Offline CrazyNun
« Reply #11 on: Sun, 08 December 2019, 07:08:24 »
Would love to see this in white
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #12 on: Sun, 08 December 2019, 07:15:31 »
Can one use the PCB this has for a regular Alice?
Offline Solotov
« Reply #13 on: Sun, 08 December 2019, 07:32:25 »
+1 for the new design of the weight if possible  :thumb:
Flex is love, flex is life.
Offline cdhoffmann
« Reply #14 on: Sun, 08 December 2019, 07:44:05 »
Oooo yeeeees
Offline adxlk
« Reply #15 on: Sun, 08 December 2019, 07:58:21 »
Yeah,
Offline Vigrith
« Reply #16 on: Sun, 08 December 2019, 08:42:16 »
LOL
Offline lolafineday
« Reply #17 on: Sun, 08 December 2019, 08:55:17 »
LOL
LOL
Sent from my SM-G975F using Tapatalk
Offline Mcnos
    • GMK Fuyu
« Reply #18 on: Sun, 08 December 2019, 09:05:17 »
You got me at Blue Gray
Offline DukeEsquire
« Reply #19 on: Sun, 08 December 2019, 09:32:29 »
Would love to see people do at least something different with these Alice clones.
I guess it’s easier to just use the files without changing anything.
Offline Mcnos
    • GMK Fuyu
« Reply #20 on: Sun, 08 December 2019, 10:10:06 »
Check out the Majaphit or the EM7 in that case. People like the original look of the Alice, I see TKLs looking the same everyday but there's not an outcry about that.
Offline victorpre
« Reply #21 on: Sun, 08 December 2019, 10:12:42 »
Question now;
Unlimited GB?
Offline eniigma
    • Storefront:
« Reply #22 on: Sun, 08 December 2019, 10:19:30 »
this looks nice, but I do hope you got permission from Yuktsi to run this. good luck!
edit: nvm, saw the last line.
Offline nickaster1
« Reply #23 on: Sun, 08 December 2019, 10:27:52 »
That weight is super nice!
Offline Aevyn
« Reply #24 on: Sun, 08 December 2019, 11:02:12 »
"Similarly, a typing height of over 20mm results in my wrists losing contact with my desk, forcing me to keep my hands floating."
SMH. Proper typing means your wrists should be floating. And for that reason, I'm out.
Sent from my GM1915 using Tapatalk
« Last Edit: Sun, 08 December 2019, 11:13:09 by Aevyn »
Offline Aevyn
« Reply #25 on: Sun, 08 December 2019, 11:06:47 »
There should be outcry about TKLs being boring af. Same ol' boring Alice. I appreciate the idea with the flex cuts. Not sure how helpful it is on only two rows. Also like the idea of the weight expanding whole alpha cluster.
Offline DukeEsquire
« Reply #26 on: Sun, 08 December 2019, 11:29:31 »
1. There should be. I’ve certainly brought it up.
2. There is a difference between similar TKLs and literally using the same files.
Offline FunTyme
  • Formerly known as Edrylle
« Reply #27 on: Sun, 08 December 2019, 11:32:37 »
Interested 100%
hbcp
Offline ullr
« Reply #28 on: Sun, 08 December 2019, 12:04:10 »
Looks pretty damn good. If I were in the market for another Alice riff, I'd be looking at this one.
Offline AlcoholEnthusiast
« Reply #29 on: Sun, 08 December 2019, 13:27:19 »
Don't love the font engraving. Also don't love not offering coating for the brass weight. You might like patina, which is fine. But many others don't. Having a clear coat option or something similar shouldn't be too hard to add for people who want it.
Offline lolafineday
« Reply #30 on: Sun, 08 December 2019, 13:50:59 »
How many units will be avail?
Offline beekey
« Reply #31 on: Sun, 08 December 2019, 14:40:14 »
+1
Offline Esheu2
« Reply #32 on: Sun, 08 December 2019, 16:02:44 »
It is compatible with standard Alice PCB's as well.
Unfortunately, it is not possible to anodize aluminum white. And, at least for now, I will not be looking into e-coating. So, no white for now. Sorry!
There are design differences from the Fallacy and the Alice. It sounds more like you want a completely different board/layout. And if that is the case, then I understand that this is not something that is for you.
+1
No USB C for this. I want to retain compatibility for what is now the "standard" for Alice PCBs. I might have added USB C compatibility if the Project Keyboard Alice PCB USB C variant had a top mounted port instead of a bottom mounted port. Unfortunately, that is not the case.
~50
I never claimed to have "proper" typing. If you have any feedback for the design rather than my typing, you can feel free to voice that instead. And no, "ree another alice" is not feedback. An Alice layout is fundamentally what this board is. If you do not like or want that, you do not have to give this IC anymore of your attention.
Ojou
Offline Mcnos
    • GMK Fuyu
« Reply #33 on: Sun, 08 December 2019, 16:05:00 »
I agree there should be more differences with the TKL but there isn't quite a lot you can with with 84-87 keys with a classic top face without it looking like a monster overall exception of F13  ^-^ I don't design boards but I do appreciate a classic style
and to be fair, the top piece may be the same but the original Alice case doesn't have a wedge cutout, and if Yuktsi gave him the OK I don't see an issue with him wanting to run something like this for people who want it. We see it with key sets all the time that look stupid similar but doesn't seem to bother people.
Offline DJ Shoko
« Reply #34 on: Sun, 08 December 2019, 16:31:18 »
That pink looks amazing, I really want a pink Alice like board after seeing it in the LA meetup yesterday.
Offline lolafineday
« Reply #35 on: Sun, 08 December 2019, 17:58:24 »
Please include compatibility for top mount usb c for future proof and for me as I have some usb c pcbs
Offline Esheu2
« Reply #36 on: Sun, 08 December 2019, 18:09:58 »
Wait are there top mount USB C Alice PCBs being publicly made?
Ojou
Offline johnnysstash
« Reply #37 on: Sun, 08 December 2019, 21:41:46 »
def in for one. hoping for optional name on the weight as i am not a fan of the font either. i am sure with as many people have said that, there will be a resolution. with that said i am forsure in for atleast one!
Offline Loveyuri
« Reply #38 on: Sun, 08 December 2019, 22:43:08 »
100% in. Hopefully I'll get in.
Offline yuppie
« Reply #39 on: Sun, 08 December 2019, 23:36:32 »
Can you add an arrow cluster?
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline packman86
  • Morning Coffee
« Reply #40 on: Sun, 08 December 2019, 23:48:45 »
Very neat Alice adaptation.
I think the weight corner radius looks a bit "fat" compared to the tight corner of the case.
231416-0
EDIT: agree with above statements. The weight engraving doesn't do this board any favors.
Keyboard Collection:
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
Offline r4wromg
« Reply #41 on: Mon, 09 December 2019, 00:05:33 »
HomerowCo's Lubrigante uses a top mount USB C PCB, but unsure of the availability of those going forward.
Offline Esheu2
« Reply #42 on: Mon, 09 December 2019, 00:58:23 »
Ojou
Offline lolafineday
« Reply #43 on: Mon, 09 December 2019, 01:16:37 »
No but I joined a private gb for some
Offline regionfree
« Reply #44 on: Mon, 09 December 2019, 08:40:45 »
Let the haters hate, and the thread crappers spread their crap. Even with that, your ~50 units will be sold out in no time.
In for one, hoping to get 2.
Also, suggestion for the script for the bottom weight logo is attached.
231433-0
« Last Edit: Mon, 09 December 2019, 08:46:49 by regionfree »
Offline thnick
« Reply #45 on: Mon, 09 December 2019, 09:26:46 »
I just pre-ordered 2 of the "ALICE PCB REV2" (USB-C) and 1 POM plate and 1 fiberglass plate. Will your case fit any of those?
Offline mrkantz
« Reply #46 on: Mon, 09 December 2019, 09:49:59 »
No, the PCB you ordered has the USB port on the component side (bottom) of the PCB while this case supports the original Alice PCB with it on the top.
Offline thnick
« Reply #47 on: Mon, 09 December 2019, 09:54:05 »
Offline Mcnos
    • GMK Fuyu
« Reply #48 on: Mon, 09 December 2019, 12:03:30 »
Bruh, just keep it to one
Offline djmantis
« Reply #49 on: Mon, 09 December 2019, 12:18:49 »
Hope to see the price for this go down, especially if we have to provide our own PCB. Here is what the original Alice went for: "$463 for case + plate + weight + PCB (Pre-soldered with controller parts, LED's resistors, and diodess)". Cheers!
