Author Topic: [IC] CU40 / CU7 / CU21 - Need Feedback!  (Read 7069 times)
Offline CAPS UNLOCKED
    • capsunlocked
« on: Mon, 09 December 2019, 08:38:19 »
Hi All!
After the success of the CU65 and CU80 we have been thinking about the next kits to produce.
At the moment we have three layouts:
CU40
231428-0
A 40% mechanical keyboard kit that offers support for ANSI/ISO, Hot-swap sockets, QMK compatability and a high-profile Aluminium case.
CU7
A macro pad with rotary encoder. The macro pad will have hot-swap sockets, QMK compatability, a high-profile case and USB ports to allow for USB passthrough.
CU21
A numpad that will also feature hot-swap sockets, QMK compatability and a high-profile case. The CU21 will match the gradient and height of the CU80.
We have made a quick feedback form to get your thoughts on what we should produce next.
https://docs.google.com/forms/d/e/1FAIpQLScEW202Zu9j0kbXOfZMOlPRi363O82pO2dtO8Y6NeVne5pD6w/viewform?usp=sf_link
We know that the CU65 and CU80 are still due to be completed and we will not be announcing anything while both of those GB's are still open and active.
Offline Macmutant
Re: [IC] CU40 / CU7 / CU21 - Need Feedback!
« Reply #1 on: Mon, 09 December 2019, 08:57:41 »
I'm interested to see how the macro pad and numpad develop. If both are premium and available in neutral colors, I would want them to go with smaller boards.
Offline SolidCactus
« Reply #2 on: Mon, 09 December 2019, 08:59:41 »
If the macropad pairs nicely with the CU65 then I would def grab one.
Offline uood5
« Reply #3 on: Mon, 09 December 2019, 09:44:44 »
Filled out the form, might want to make the question about other layouts not required though
Sent from my SM-G970F using Tapatalk
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #4 on: Mon, 09 December 2019, 10:56:24 »
Great layouts all 3. Just please no more tray mount!
Offline KingOfMemes
« Reply #5 on: Mon, 09 December 2019, 11:01:16 »
+1337
Offline worldspawn
« Reply #6 on: Mon, 09 December 2019, 13:26:28 »
2u right shift and 2.5u enter? gonna have compatibility issues with a lot of keysets if people don't want ISO...  Also the other layout needing 2x 1.75u r4 caps...
« Last Edit: Mon, 09 December 2019, 13:28:58 by worldspawn »
I can make acrylic laser cut cases/plates PM for info
Offline mutthunt
« Reply #7 on: Mon, 09 December 2019, 15:11:27 »
CU40 looks really fun! About time we had some more ISO to have fun with. CU21 would be genuinely nice, very interested in both.
« Reply #8 on: Mon, 09 December 2019, 22:37:47 »
I didn't realize that was 2.5u. Does that even exist? Let's definitely stick to more commonly available key sizes.
Offline Cedific
« Reply #9 on: Mon, 13 January 2020, 04:52:33 »
If the numpad pairs well with the CU65, I am definitely getting it
Offline raptorzoz
« Reply #10 on: Mon, 13 January 2020, 05:53:53 »
I'd be more interested in a numpad matching the cu65, than the cu80.
Offline Fredington
    • Instagram
« Reply #11 on: Mon, 13 January 2020, 06:17:45 »
Nice layout on the CU40. Can you have ISO support while having hotswap? Not sure how that would work.
Offline YMwoo
« Reply #12 on: Mon, 13 January 2020, 06:42:53 »
really interested in CU21!
hotswap, qmk and high profile is just perfect for me.
it'll be USB Type C, right?
Edit: any ETA when it'll run?
« Last Edit: Mon, 13 January 2020, 20:09:25 by YMwoo »
