Author Topic: [GB]Theo 60% custome keyboard (invoice check)  (Read 67832 times)
Offline wylie
« on: Tue, 10 December 2019, 09:00:34 »
Hi geekhack,
Groupbuy for - Theo60.
This is the first time that I am sharing my personal design.I thought about what would make my perfect keyboard? With a few ideas in
mind, below is some pictures
Some details about this keyboard :     (IC:https://geekhack.org/index.php?topic=101403.0)
        Top case : Four kinds of top case https://i.imgur.com/r9OAxPs.png .
                                                             (alu/ pc/brass pvd /brass sand finish.You can mix choices,we have brass top and bottom to
        choose.)
                                                 Default kit:
        Aluminum/PC/ top and bottom cases
        Aluminum/PC/ plate
        QMK PCB with type-C
        Aluminum/PC/ bottom
        O- rubber (two types), screws, custom box
        Price for default kit: $280 excluding PayPal fee and shipping
Solder PCB: add HHKB layout
Hotswap pcb :
Alps :
layout 3:
Mounting. :
The plate is mounted to the top case with the 'O- rubber '
Do not like "Gasket" mount, we have the 'O-rubber' Cutout,when the 'O-rubber' put  on the top & bottom of the case.  the plate will
experience a stronger or lighter clamping force.When you type through the plate will get fedback from bottom due to the 'O
-rubber get press .we will provide two types O-rubber for free.
Typing test :
                                              Groupbuy open :10th Dec - 15th Dec (30units)
                                              Groupbuy payment :deadline 20th Dec
                                              ETA         :early April 2020  shipping cost $45-$50(invoice  will send when start shpping)
« Last Edit: Sun, 22 December 2019, 02:02:58 by wylie »
Offline Mcnos
    • GMK Fuyu
Re: [GB]Theo 60% custome keyboard (30units FCFS)
« Reply #1 on: Tue, 10 December 2019, 22:31:15 »
What kind of angle and front height does this board have? I didn't see it in the IC
I would appreciate a side shot to see how it sits on the desk
« Last Edit: Tue, 10 December 2019, 22:33:28 by Mcnos »
Offline Warrenified
« Reply #2 on: Tue, 10 December 2019, 22:39:38 »
Submitted my order!
Thanks! I added you on discord in case I need to change my form if I was in the first 30!
« Last Edit: Tue, 10 December 2019, 22:49:08 by Warrenified »
Offline aslanxdeft
« Reply #3 on: Wed, 11 December 2019, 03:11:11 »
Are there any examples of the other colors?
Offline modeseven
« Reply #4 on: Wed, 11 December 2019, 05:54:51 »
He mentioned 6 degrees in the past. Also interested in seeing side profile and front height.
Offline wylie
« Reply #5 on: Wed, 11 December 2019, 08:48:29 »
Offline aslanxdeft
« Reply #6 on: Wed, 11 December 2019, 10:50:44 »
Thanks! Is the top color "e pink"?
Offline gnhuy91
« Reply #7 on: Wed, 11 December 2019, 12:07:43 »
In for an Alps version, I hope Alps switch legs would not touch the bottom of the case like Leaf60
Offline kaz_kitty
« Reply #8 on: Wed, 11 December 2019, 15:21:16 »
Submitted for a full PC, most likely won't get it though...Is it even a GB when there is only 30 units?
Offline DukeEsquire
« Reply #9 on: Wed, 11 December 2019, 17:00:57 »
You want caps for first time GB runners.
You don't want someone whose in over their heads.
Offline nasp
« Reply #10 on: Wed, 11 December 2019, 17:07:43 »
Agreed. And 30 is a good number.
Offline sumbody
« Reply #11 on: Wed, 11 December 2019, 17:51:35 »
Submitted for a full PC board. Good luck to the rest in the GB.
Offline Felt
« Reply #12 on: Wed, 11 December 2019, 18:39:13 »
Just submitted. Has the 30 units already been reached?
Offline Skeezy
« Reply #13 on: Wed, 11 December 2019, 20:12:46 »
Just filled out the form.
When will we be notified if we got in or not?
« Last Edit: Wed, 11 December 2019, 20:15:59 by Skeezy »
Offline Little4Real
« Reply #14 on: Wed, 11 December 2019, 23:57:40 »
Will a standard 60% PCB fit?
Offline aslanxdeft
« Reply #15 on: Thu, 12 December 2019, 06:58:35 »
It's fcfs so I guess if you filled out the form you got it.
Offline wylie
« Reply #16 on: Thu, 12 December 2019, 08:43:56 »
  we will send invioce when the gb form closed by the time,and if you have received and paid, you are in .if not,we will move to next members.thank you.
Offline wylie
« Reply #17 on: Thu, 12 December 2019, 08:44:20 »
   not fit.
Offline wylie
« Reply #18 on: Thu, 12 December 2019, 08:46:08 »
    side view:
Offline gnhuy91
« Reply #19 on: Thu, 12 December 2019, 11:27:14 »
    side view:
Have you tried Alps on this prototype? I asked because the switch legs is longer than mx and may touch the bottom case, happened to Leaf60
Offline wylie
« Reply #20 on: Fri, 13 December 2019, 06:42:39 »
    side view:
   yes,I will try again
Offline wylie
« Reply #21 on: Fri, 13 December 2019, 06:44:20 »
I will start  sending invoice. If you have any questions, please pm me (or discord).
Offline kaz_kitty
« Reply #22 on: Fri, 13 December 2019, 09:08:41 »
Paid and hyped, can't wait to receive it :)
Offline sumbody
« Reply #23 on: Fri, 13 December 2019, 09:54:32 »
All paid up and sent you a PM :)
Can't wait!
Offline gnhuy91
« Reply #24 on: Fri, 13 December 2019, 10:55:29 »
Paid for mine too, Alps build with extra PCB + mx PC plate so I can swap between alps and mx :D
Offline Felt
« Reply #25 on: Fri, 13 December 2019, 12:24:06 »
Just paid! Love the simplicity of this board and different mounting style, cant wait!
Offline Mcnos
    • GMK Fuyu
« Reply #26 on: Fri, 13 December 2019, 12:32:55 »
Sent a PM about my order
Offline modeseven
« Reply #27 on: Fri, 13 December 2019, 14:19:24 »
In the pictures there seems to be a pretty large gap between the WKL blockers and the ALT keys. Do you know if this will be changed or is this the final design?
Offline Warrenified
« Reply #28 on: Fri, 13 December 2019, 18:20:09 »
Hi! I wanted to add a PC plate to my invoice. I’ve PM’d you on discord and Geekhack just in case. Thank you!
Offline sumbody
« Reply #29 on: Fri, 13 December 2019, 18:23:19 »
Anyone has an idea how heavy will a full PC build be?
Which one is the weight in the keyboard? Can't seem to make out the component from the images.
Offline nasp
« Reply #30 on: Fri, 13 December 2019, 20:51:20 »
Check out the fourth image. It's the one with the white Theo on its back. That red piece is the "weight". It's more of an accent really.
Offline sumbody
« Reply #31 on: Fri, 13 December 2019, 21:59:32 »
I expect the full PC to be really light I guess, perfect for a travel board
Offline wylie
« Reply #32 on: Sat, 14 December 2019, 01:10:10 »
it will change,this is just prototype
Offline wylie
« Reply #33 on: Sat, 14 December 2019, 01:10:59 »
3 requests cancelled the order.
Offline wylie
« Reply #34 on: Sat, 14 December 2019, 01:11:46 »
  check. :thumb:
Offline wylie
« Reply #35 on: Sun, 15 December 2019, 21:46:36 »
Hi geekhack,
        choose.)
                                                 Default kit:
        Aluminum/PC/ plate
        QMK PCB with type-C
        Aluminum/PC/ bottom
Hotswap pcb :
Alps :
layout 3:
Mounting. :
Typing test :
Offline Tamkarm
« Reply #36 on: Mon, 16 December 2019, 13:39:03 »
Sent a PM
Offline jacky
« Reply #37 on: Tue, 17 December 2019, 10:19:58 »
 :thumb:
Offline regionfree
« Reply #38 on: Wed, 18 December 2019, 17:54:48 »
finally settled my invoice!
Offline wylie
« Reply #39 on: Thu, 19 December 2019, 04:25:50 »
All invoices have been sent for a few days,please check it,if have any question pm me.(deadline is on 20th Dec.)
Offline nasp
Re: [GB]Theo 60% custome keyboard (invoice check)
« Reply #40 on: Fri, 27 December 2019, 21:31:00 »
Hello sir,
Can you please send the plate file? I'd like to use this board with a custom layout.
Thanks
Offline aslanxdeft
« Reply #41 on: Wed, 08 January 2020, 07:08:01 »
Any updates ?  :)
Offline wylie
« Reply #42 on: Wed, 08 January 2020, 21:25:12 »
Any updates ?  :)
waiting for new prototype make confirmed.
Offline sumbody
« Reply #43 on: Tue, 21 January 2020, 08:47:49 »
Are we on track for April 2020 release still?
Offline aslanxdeft
« Reply #44 on: Sun, 02 February 2020, 06:29:00 »
Any news on the prototype?
Offline Vireca
« Reply #45 on: Sun, 02 February 2020, 10:30:27 »
GB before prototype? wew
Offline nasp
« Reply #46 on: Mon, 03 February 2020, 21:32:07 »
No, he has a typing test video in the OP
Offline regionfree
« Reply #47 on: Mon, 24 February 2020, 09:59:29 »
Any update on this?
Offline aslanxdeft
« Reply #48 on: Mon, 24 February 2020, 12:16:03 »
Any update on this?
He replied to my Pm on the 15th. He said that he is still waiting on a government annoucement but would keep everyone updated.
Offline regionfree
« Reply #49 on: Mon, 24 February 2020, 18:23:23 »
thanks for sharing. does he have a discord server for updates? or it might be nice to have updates posted in the thread. worried about this GB, and my 6-month paypal protection limit is closing in.
