Author Topic: [IC]Theo 60% custome keyboard(GB LIVE )  (Read 14673 times)
Offline wylie
« on: Sun, 30 June 2019, 10:14:54 »
Hi geekhack,
Today I am here with an Interest Check for my  project: Theo60.
 This is the first time that I am sharing my personal design.I thought about what would make MY perfect keyboard? With a few ideas in
mind, below is some pictures,please let me know what do you think of this keyboard.
Some details about this keyboard :
        Top case : Five kinds of top case https://i.imgur.com/5E0bBsO.jpg
        Layout    :
        Color      : we have intend to have PC material case and four Anodizing color
        Brass     : Silver & Gold for plate and brass weight
GB Pricing                                               Start at $280,final price depens on you options
Mounting. :
The plate is mounted to the top case with the 'O- rubber '
Do not like "Gasket" mount, we have the 'O-rubber' Cutout,when the 'O-rubber' put  on the top & bottom of the case.  the plate will
experience a stronger or lighter clamping force.When you type through the plate will get fedback from bottom due to the 'O
-rubber get press
Please let me know you options,We will refer to the form you filled out.
https://docs.google.com/forms/d/e/1FAIpQLSfOu2yiHzwVthLNwywj0itmb2Qm_OOEFcV7IOTGzLS73zmR3A/viewform?usp=pp_url
My discord :wylie#4171
« Last Edit: Tue, 10 December 2019, 23:31:27 by wylie »
Offline mrpetrov
Re: [IC]Theo 60% custome keyboard
« Reply #1 on: Sun, 30 June 2019, 10:21:09 »
Hi! Thanks for launching this IC to get feedback. May I ask what your experience is in running GBs?
Offline victorpre
« Reply #2 on: Sun, 30 June 2019, 10:23:07 »
Interesting design
Offline wylie
« Reply #3 on: Sun, 30 June 2019, 10:30:22 »
I think yes ,been take part in some keyboards groupbuy.and then familliar with some author that  i can ask them for help
Offline MdotMaxson
« Reply #4 on: Wed, 03 July 2019, 13:03:39 »
Is this not getting popular? I kinda really like this case
Offline wylie
« Reply #5 on: Wed, 03 July 2019, 13:53:40 »
Thank you guys for filling out the form and the suggestion.i will do prototype later and i want to make sure everything is ok,so is maybe need some time.will continue to update.thank you all. :thumb:
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #6 on: Wed, 03 July 2019, 14:30:06 »
  • Is there a gap between the bottom of the keyboard and the table?
  • Is it a custom PCB? Or does it use generic 60% PCB like DZ60?
  • The IC form mentions underglow. Where will the underglow be located?
« Last Edit: Wed, 03 July 2019, 14:35:27 by tex_live_utility »
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #7 on: Thu, 04 July 2019, 06:15:23 »
Happy to see ISO support!
Offline victorpre
« Reply #8 on: Thu, 04 July 2019, 06:18:37 »
I like
Offline pheonix991
« Reply #9 on: Fri, 05 July 2019, 15:01:35 »
Gimme a Rose gold, and I'll probably buy that and the purple
Offline freespam
« Reply #10 on: Sat, 06 July 2019, 12:00:14 »
Will there be split space bar?
Offline wylie
« Reply #11 on: Mon, 08 July 2019, 07:48:02 »
1.it will have gap
2custom pcb /middle port /typec
3case two sides will have underglow
Offline wylie
« Reply #12 on: Mon, 08 July 2019, 07:49:05 »
No split space bar
Offline wylie
Re: [IC]Theo 60% custome keyboard(prototypes comes )
« Reply #13 on: Tue, 03 December 2019, 09:16:12 »
prototypes comes :thumb: :thumb:  will Update typing video later.
Offline kw88
« Reply #14 on: Tue, 03 December 2019, 09:56:46 »
how's that happened to the blockers :(
Offline jonowarren94
« Reply #15 on: Tue, 03 December 2019, 13:37:51 »
I really like this. I'm a big 60% fan and brutal60 owner (fairly similar design). A few comments:
  • I am not a fan of universal plates, imo best option would be to release plate files and then have a few options in terms of plates that will suit most people eg standard ANSI, tsangan ANSI and tsangan ISO ?
  • I like that the outer most plate tabs are nearer the ends, on the brutal60 they are more central and with more flexible plate materials like POM it flexes very inconsistently
  • I also really like the half backspace, its something different but wont require kits to have special keys to support this board
Expanding on my plate point: even if you go 1 or 2 materials for the plate to simplify your options, but with a fixed layout it'll make a much more premium board.
Offline wylie
« Reply #16 on: Wed, 04 December 2019, 09:53:56 »
it will have .
Offline wylie
« Reply #17 on: Wed, 04 December 2019, 10:00:54 »
1plate files will open you can take it
2cant understand it well about you quesiton.
3split backspace already support.
Offline holocene
« Reply #18 on: Sun, 08 December 2019, 05:00:57 »
In for an HKKB layout!
Sent from my SM-G973F using Tapatalk
Offline iMav
  • geekhack creator/founder
« Reply #19 on: Sun, 08 December 2019, 05:38:55 »
I approve of the name.  :)
Offline wylie
« Reply #20 on: Tue, 10 December 2019, 22:51:07 »
