Author Topic: [IC] KAT Moonrise  (Read 23171 times)
Offline titoepfx
[IC] KAT Moonrise
« on: Thu, 09 January 2020, 11:37:55 »
Hello people of geekhack I am doing a interest check for my keycap set for a set I would like to call KAT Moonrise if that's not taken that is.
The three renders are all SA, I don't have a way to render KAT without paying someone for renders which im not ready to do yet neither do I have the money.
SA 104 key, these renders are to test the colors of keycap font and the keycaps, I can't change the font or anything like that.
233296-0
Leopold fc660m
233298-1
233300-2
The kits would follow something similar to KAT Lich.
Working on
Kits
TO DO
Get renders
Get feedback and adjust things if needed
Get vendors
Here's a signature I made for the set
the code is
Code: [Select]
[url=https://geekhack.org/index.php?topic=104163.0][img width=484 height=120]https://i.imgur.com/gvksP4t.png[/img][/url]Leave some feedback please and let me know if there's stuff that can be improved and stuff.
« Last Edit: Thu, 09 January 2020, 15:56:58 by titoepfx »
Offline KingOfMemes
Re: [IC] KAT Moonrise
« Reply #1 on: Thu, 09 January 2020, 12:50:05 »
Coleverak set and I'm in
Offline titoepfx
« Reply #2 on: Thu, 09 January 2020, 13:08:47 »
It'll have that, if the IC check goes through then ill use the KAT keycap system good like the other KAT keysets that have like 13 kits.
Offline nathanchere
« Reply #3 on: Thu, 09 January 2020, 13:14:31 »
It doesn't appeal to me personally but have to say you totally nailed 'moonrise' with that gradient.
Offline logo4poop
  • Talk to me on discord @logoooo
« Reply #4 on: Thu, 09 January 2020, 13:24:48 »
Needs novelties tbh, but other then that it is good.
LCK75 so lit
Offline utilitytech
« Reply #5 on: Thu, 09 January 2020, 13:33:18 »
First Let me say the colour looks great. Second, I feel MT3 profile might be perfect. If the GB is sometime late in the year probably might get in.
Offline Koniotaur
« Reply #6 on: Thu, 09 January 2020, 13:42:17 »
Great job out there, awaiting for some novelites and also kinda wish the colors would be more beige.
Offline stoffelduss
« Reply #7 on: Thu, 09 January 2020, 13:59:36 »
Meh. Really not a fan of seeing yet another gradient set. :/
I would wish for a regular, non-gradient grey/beige set in KAT profile. Your colors aren't even far off at all from what I want but I just don't think gradients look good at all, they've never impressed me on keycaps.
If you'd made something like DSA Alchemy (https://pimpmykeyboard.com/dsa-alchemy-keyset/) in KAT I'd be all over it.
Offline empty_dreams
« Reply #8 on: Thu, 09 January 2020, 14:48:07 »
I dig it
Offline vosechu
« Reply #9 on: Thu, 09 January 2020, 15:06:16 »
What do you think about a set of f keys with white text? Would raise contrast, but also it would look like stars twinkling.
Offline titoepfx
« Reply #10 on: Thu, 09 January 2020, 15:19:43 »
I'll render it and reply to you with it give me a couple of minutes
Offline titoepfx
« Reply #11 on: Thu, 09 January 2020, 15:53:44 »
Offline vosechu
« Reply #12 on: Thu, 09 January 2020, 15:58:23 »
Looks dope. I would probably only use the f keys with white background because that lighter blue looks great with the grey text to me.
Offline Darth_munkee
« Reply #13 on: Thu, 09 January 2020, 16:06:20 »
I like it. I'll probably get a set of there's ortho and/or split support.
Offline DrHigsby
  • The doctor is in.
« Reply #14 on: Thu, 09 January 2020, 17:42:32 »
The gradient is awesome. I’d like to see an ortho kit as well as icon mods for arrows (I personally dislike text mod arrows). Also, actual KAT profile renders.
Offline equalunique
« Reply #15 on: Thu, 09 January 2020, 21:21:03 »
Count me in too
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline antx1701
« Reply #16 on: Fri, 10 January 2020, 00:01:30 »
I'm not familiar with KAT sets, but I'm not a fan of these legends. I dislike text arrows and "PAGE UP" instead of "PG UP". Otherwise, very nice set, especially with the top row white legends.
Offline nathanchere
« Reply #17 on: Fri, 10 January 2020, 05:04:58 »
The biggest problem with MT3 is (mass)drop's monopoly over the profile. I would much rather KAT. Lower cost, still great quality, reverse dye-sub PBT options = way more colour options, much better kit MOQs = more kit variety and more likelihood they actually make it to production.
Offline catbus
« Reply #18 on: Fri, 10 January 2020, 05:39:43 »
I'd be in for either KAT or MT3 - as long as there is ergodox/boardwalk compatibility.
Offline nathanchere
« Reply #19 on: Fri, 10 January 2020, 06:00:34 »
Love it!
Offline Dox.h3
« Reply #20 on: Fri, 10 January 2020, 08:53:47 »
Looking good.
Is there any chance that just only gray Alphas kit?
Offline fluidin
« Reply #21 on: Fri, 10 January 2020, 08:55:43 »
love this version! really nice
Offline titoepfx
« Reply #22 on: Sat, 11 January 2020, 08:18:33 »
Would you guys prefer the white function key text, black function key text, or yellow which is this
233400-0
« Last Edit: Sat, 11 January 2020, 08:20:58 by titoepfx »
Offline Koniotaur
« Reply #23 on: Sat, 11 January 2020, 10:17:54 »
Yellow fits best IMO. After that I would say black and white as last.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #24 on: Sat, 11 January 2020, 13:29:28 »
Just curious: what's the plan to produce this color scheme?  Will all keycaps be molded in the bottom row color, completely dyed to get the base color, and then dye-sub for black legends?  Or will they be molded in six different colors with black dye-sub legends?  Or something else?
Offline titoepfx
« Reply #25 on: Sat, 11 January 2020, 13:33:16 »
Idk what keyreative has but im thinking dyesub or reverse dye sub whichever I need.
Offline sent-by-an-iPerson
« Reply #26 on: Sat, 11 January 2020, 21:06:29 »
I like the set a lot. I'm in
Offline kaisn
« Reply #27 on: Mon, 13 January 2020, 08:24:09 »
I like the idea!
Offline lush_bunny
« Reply #28 on: Mon, 13 January 2020, 12:31:48 »
I've been looking for a 'gradient stripes' set. I'll be watching this.
Offline bill.choi
« Reply #29 on: Mon, 13 January 2020, 15:51:48 »
Definitely interested!
Getting in to the custom keyboard world.
Not afraid to list my current OEM keyboards:
Apple Keyboard A1048 - DasKeyboard Pro 4 - Razer BlackWidow Tournament Edition Chroma V2
Offline catbus
« Reply #30 on: Tue, 18 February 2020, 08:30:23 »
Any updates on this? Hoping its not dead  :'(
Offline titoepfx
« Reply #31 on: Fri, 21 February 2020, 00:26:47 »
it's pretty dead i could finish the kit stuff but i dont have novelties and plus im poor so i basically cant do the usual stuff like renders and color matching etc
Offline duckadence
« Reply #32 on: Mon, 13 April 2020, 15:18:53 »
I have some ideas.
These are pretty rough sketches, and I centered by eye. I'm not sure how this all works and the limitations of making novelties. But I made an account just to do this cuz this keyset looks really cool and it'd be sad to see it die.
« Last Edit: Mon, 13 April 2020, 15:23:13 by duckadence »
Offline titoepfx
« Reply #33 on: Mon, 13 April 2020, 20:45:18 »
The limitation is normally only 2 colors which is the keycap color and the font itself I think tripleshot can do 3 colors not sure about the others but the other thing that is not letting me continue is no money.
Offline nasp
« Reply #34 on: Tue, 14 April 2020, 00:37:14 »
KAT is dye-sub so it's a bit different, but I don't know if they can do more than 2 colors. Someone chime in if you know the answer.
I think last I looked KAT Cyberspace was doing 3 colors but I don't know if the designer has asked Keyreative if that's feasible or not.
Offline Koniotaur
« Reply #35 on: Tue, 14 April 2020, 00:55:58 »
I've asked them once about it, the answer I got :
With Dye-sub, you can have as many colors as you want on the keycap :) 1, 2, 3 or even more
Offline titoepfx
« Reply #36 on: Tue, 14 April 2020, 01:31:26 »
Oh thats really good then, I thought it was just 2
Offline Koniotaur
« Reply #37 on: Tue, 14 April 2020, 02:43:34 »
About novelties i feel like mountain with moon back light would be a nice concept for deskmat.
Offline Friendship
« Reply #38 on: Sat, 26 September 2020, 18:13:08 »
looks promising! count me interested, looking to see how this shapes up!
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline titoepfx
« Reply #39 on: Sat, 26 September 2020, 19:03:28 »
i gave up on this couldn't afford doing color sample stuff and everything else
