Author Topic: [IC] Prime_Elise  (Read 27052 times)
Offline mujimanic
[IC] Prime_Elise
« on: Sun, 12 January 2020, 20:15:12 »
GROUP BUY HERE https://geekhack.org/index.php?topic=104493.0
IC PAGE IS LOCKED AND CLOSED
Prime_Elise Aluminum Case
Group Buy planned for February 2020
IC FORM HERE https://forms.gle/iNTBR24MDC5qbmWZA
Link to my Discord server https://discord.gg/77d4hDq
233474-0
Hello again, mujimanic here. Yes, I'm that ButterKnife guy (https://www.gboards.ca/product/butterknife)
The Elise enclosure for Holtenc's Prime_E PCB is my next project. It's a 2-part aluminum shell with separate switchplate layer which restores Alice case curves to the Prime_E. There are some things you should know, so let's get talking.
How did I end up at this point?
   Like many others in the community, after snagging a PCB, I felt that the chiseled Alice nose had to come to Prime_E. After a reddit post (https://www.reddit.com/r/MechanicalKeyboards/comments/e19r0m/prime_elise/), Holtenc mentioned he was open to working with designers to make third party cases for Prime_E! I came up with a revised prototype as proof of principle of some of my case designs: (https://www.reddit.com/r/MechanicalKeyboards/comments/eaqr46/elise_a_case_for_prime_e/) and things took off from there. Up to now, I've been coordinating with Holtenc to sell my aluminum case along with his PCBs as a bundled kit.
Three design goals I wanted to achieve with this project:
- Create a "fitted lid" that slides over and around part of the base, like a shoebox.
- Bring a bottom-mounted switchplate design, as there hasn't been many.
- Make this PCB and case more accessible to the community.
233476-1
Design Features
- T6 solid block aluminum CNC-machined enclosure
- Switchplate is BOTTOM MOUNTED. Instead of anchoring the switchplate to the top shell like a standard CNC'ed Alice case, it's perched atop pedestals on the bottom shell. This is *not* a tray mount. Interestingly this allows for an air gap between the switchplate and top shell that seems to transmit more sound from the resonant chamber out the top.
- Case follows the contours of the Prime_E key layout, which it itself fashioned after the Alice layout.
- Fits both Rev 1 (blocky) and Rev 2 (angled) Prime_E PCBs.
- Bead-blasted and anodized in 3 colors: RAL 7021 (Black Grey), Clear coat (Natural Aluminum), and Rose Gold (specific color still to be confirmed)
- The four case corners are "squircles" (variable tangent corners) rather than the conventional filet edge shape (fixed tangent). It's a subtle addition, but I think it gives the case a nicer "soft" profile.
- Milled depressions to accommodate rubber feet (will be provided with the kit) to keep the case close to the table surface.
- Accomodates up to 2mm switchplates.
- I will provide the switchplate DXF at completion of group buy.
- "elise" logo and my studio emblem milled into the bottom surface
- I would consider offering up to 75-100 of these cases depending on interest.
- UPDATE: Unlimited units will be offered for sale.
Render Gallery
233478-2233480-3
233482-4233484-5
233486-6233488-7
Proto is forthcoming.
Timeline
- [01/12/2020] Geekhack IC page created. Awaiting final protos and color selection. Awaiting manufacturer pricing. Chinese New Year will delay productions until March, so won't even plan to start manufacturing until then!
- [Mid February] Planned Opening of the Prime_Elise Group Buy
Credit:
- Keycaps from Haxoroo's Thingiverse models. (https://www.thingiverse.com/thing:2398873) I had to fashion my own 2.25u keycaps so yes they're janky.
« Last Edit: Sun, 02 February 2020, 19:58:20 by mujimanic »
Offline Abec13
Re: [IC] Prime_Elise
« Reply #1 on: Sun, 12 January 2020, 20:29:59 »
YEEEEEEEEEEEEEEAAAAAAAAAAAAAHHHHHHHHHHHHHH
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline Macmutant
« Reply #2 on: Sun, 12 January 2020, 20:37:54 »
Looks great. Not sure I need another Ptime_E, but may pick one up anyway. Will this GB run through PrimeKB.
Offline Crack85
« Reply #3 on: Sun, 12 January 2020, 20:41:53 »
Clean!!!!
Sent from my Pixel 3 XL using Tapatalk
Offline mujimanic
« Reply #4 on: Sun, 12 January 2020, 20:48:38 »
So the arrangement will be that I will purchase the PCBs from holtenc, and I will then sell them as kit including whatever extra you folks want to add on (extra PCBs, etc). Holtenc feels that if people want extra PCBs then they can buy extra PCBs. I agree with him.
Offline holtenc
« Reply #5 on: Sun, 12 January 2020, 20:50:11 »
looks good man
Offline octix
« Reply #6 on: Sun, 12 January 2020, 20:51:45 »
Wooooo!
Discord: octix#0478
Offline Agilr
  • Never stop achieving
    • Discord Server
« Reply #7 on: Sun, 12 January 2020, 20:53:30 »
This is it
Offline kennardsmith
« Reply #8 on: Sun, 12 January 2020, 20:57:23 »
i’m in
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
Offline joshuarubin
« Reply #9 on: Sun, 12 January 2020, 21:00:17 »
Very interested
Offline Andrago
  • Hobbyist from Singapore!
    • Github
« Reply #10 on: Sun, 12 January 2020, 21:38:31 »
I'm in too!!
Offline MikeTheTiger
« Reply #11 on: Sun, 12 January 2020, 21:38:53 »
Woah!!
"all the numbers or none of them cmon man" -Kokaloo
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #12 on: Sun, 12 January 2020, 22:33:43 »
Any chance of a non-metal plate, considering how rigid bottom mount is? E.g. polycarbonate, POM, carbon fiber, et al.
Offline r4wromg
« Reply #13 on: Sun, 12 January 2020, 22:44:46 »
Been waiting for this one, my Prime_E PCB desperately needs a home
Offline modeseven
« Reply #14 on: Sun, 12 January 2020, 22:46:16 »
Oh boy, this looks nice.
Offline prettydouchebag
« Reply #15 on: Sun, 12 January 2020, 22:53:09 »
This is NAIS
Offline Myteethfeelweird
« Reply #16 on: Sun, 12 January 2020, 22:55:16 »
can you put a plate foam/case foam option?
Offline mujimanic
« Reply #17 on: Sun, 12 January 2020, 22:57:10 »
I'll look into it. It may be better and simpler as an aftermarket option. Some people are very selective about their foams.
Offline mujimanic
« Reply #18 on: Sun, 12 January 2020, 22:58:59 »
At this point I'm not planning to offer alternative plates, but I will definitely provide the DXF for custom plate cutting. Anything 2mm thick or less should be good with this case.
« Reply #19 on: Sun, 12 January 2020, 23:02:28 »
Ah I see. Do you think you could provide a pattern file so we can get these cut on our own?
Offline mujimanic
« Reply #20 on: Sun, 12 January 2020, 23:04:17 »
Yeah I can do that. I don't know a whole lot about it, but aren't some foams toxic when laser cut??
« Reply #21 on: Mon, 13 January 2020, 00:25:21 »
Thanks. The stock plate is aluminum, right?
Interestingly the extra clearance inside the case should make it easy to "gasket mount" this, by sticking rubber strips between the bottom of the plate and the mounting surface inside the case.
Offline equalunique
« Reply #22 on: Mon, 13 January 2020, 00:38:01 »
This past week I was just thinking how the Prime_E seems to be the best Alice-style keeb IMO because it's thumb keys are more or less symmetrical. Frankly am amazed to see this IC open up here. Am def in.
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline iWalkingCorpse
« Reply #23 on: Mon, 13 January 2020, 07:36:54 »
OH herrow nurse, I think I might need to pick up a couple prime_e pcbs when available in anticipation...
Offline kaisn
« Reply #24 on: Mon, 13 January 2020, 09:01:46 »
Ohhh yeaaaaah I want it
Offline Fabi
« Reply #25 on: Mon, 13 January 2020, 11:03:18 »
Just when I thought I was out, they pull me back in!
Offline vegs
« Reply #26 on: Mon, 13 January 2020, 12:57:40 »
FYI there's already a Alice clone called Elise. It's currently in IC stage.
hhkb 4 life
buy less
Offline Macmutant
« Reply #27 on: Mon, 13 January 2020, 18:58:42 »
Sounds great. Thank you for responding.
« Reply #28 on: Tue, 14 January 2020, 17:09:39 »
Love this!!! And I want there to be foam included, but I understand if this is an additional purchase. Just appreciate the option:)
Offline modeseven
« Reply #29 on: Fri, 17 January 2020, 03:20:47 »
Will the group buy operate as FCFS, raffle, or both?
Offline BlueViola
« Reply #30 on: Fri, 17 January 2020, 10:09:07 »
I was assuming the PCB would be hotswap, since the original Prime_E PCB was hotswap, but I read that the new PCB would not be hotswap.  Is this correct?
Offline 0ff1c1al
« Reply #31 on: Wed, 22 January 2020, 15:10:28 »
Has a date been picked yet, or is that still up in the air?
Offline mujimanic
« Reply #32 on: Thu, 23 January 2020, 07:01:40 »
GB Feb 15. I will get the GB page up Feb 1
Offline KingOfMemes
« Reply #33 on: Thu, 23 January 2020, 08:16:28 »
Bless up, any ballpark on the price
Offline mujimanic
« Reply #34 on: Thu, 23 January 2020, 08:18:37 »
Yes. Case + T5 aluminum plate + pcb will be $250. Add $10 for brass plate instead of aluminum
Offline mujimanic
« Reply #35 on: Thu, 23 January 2020, 08:19:43 »
Case option without plate ($ 230)
Offline KingOfMemes
« Reply #36 on: Thu, 23 January 2020, 08:25:32 »
Does that include PCB?
Offline mujimanic
« Reply #37 on: Thu, 23 January 2020, 08:26:46 »
Yeah. $230 would be for case plus pcb without plate
Offline KingOfMemes
« Reply #38 on: Thu, 23 January 2020, 08:38:04 »
Sweet, count me in daddy
Offline mujimanic
« Reply #39 on: Thu, 23 January 2020, 08:43:06 »
Correct. The Rev2 pcb is NOT hotswap. You're going to have to solder your switches to the board or use MilMax or holtite sockets
Offline mujimanic
« Reply #40 on: Thu, 23 January 2020, 08:46:23 »
Due to overwhelming demand, purchase opportunity will be unlimited to the group buy end date!
Offline KingOfMemes
« Reply #41 on: Thu, 23 January 2020, 09:02:36 »
Unlimited, $230, Alice layout, 40%. The future is now
Offline equalunique
« Reply #42 on: Thu, 23 January 2020, 12:51:11 »
If the PCB isn't hotswap, can the plate at least have cutouts to support switch top opening?
Offline modeseven
« Reply #43 on: Thu, 23 January 2020, 15:21:34 »
Offline KingOfMemes
« Reply #44 on: Fri, 24 January 2020, 10:25:38 »
Will we be able to mix and match color options between top and bottom pieces?
Offline mujimanic
« Reply #45 on: Fri, 24 January 2020, 17:32:43 »
In the next week before I start the GB page I'm working to secure this as an option but currently it is a "no". I really want this too!
Offline briano1905
« Reply #46 on: Tue, 28 January 2020, 12:33:57 »
Looks great! Whats the typing angle on this? :)
Offline KingOfMemes
« Reply #47 on: Tue, 28 January 2020, 13:20:24 »
Probs going black, but colorway might be a game time decision
Offline Dafraz117
« Reply #48 on: Tue, 28 January 2020, 19:58:21 »
Interested
Offline mujimanic
« Reply #49 on: Tue, 28 January 2020, 22:50:09 »
6 degrees
