Author Topic: [IC] GMK Rainy Day | Update: GB Date Oct 6th. Pricing Announced! [10/1/20]  (Read 255155 times)
Offline alanskiii
Re: [IC] GMK Rainy Day | Desk Mats and Kit Changes [Update: 2/8/20]
« Reply #50 on: Wed, 19 February 2020, 02:56:52 »
Those desk mats! You got me.
Offline Scriba
« Reply #51 on: Wed, 19 February 2020, 03:17:13 »
The render on the accent keycaps is pretty bad. But I like the accent colour in general.
Norde/Int kit would be nice.
Offline yuuS0cut3
  • Stay young
« Reply #52 on: Sat, 22 February 2020, 09:47:04 »
Please consider adding a 1,75u R3 Control. Also I think 1,5u Delete is better than 1,5u Backspace  :)
Offline aodaliya1234
« Reply #53 on: Sun, 23 February 2020, 21:36:55 »
im loving the vibe man!! so in
Offline ghillan
« Reply #54 on: Mon, 24 February 2020, 02:51:55 »
Your renders shows 2 pairs of F-J keys, but none of then have bumps. It's that intended? ( usually, one pair is with and the other without bumps )
Offline Owl
« Reply #55 on: Mon, 24 February 2020, 03:48:50 »
This is not intentional. One of the pairs should have bumps. There have been a few hiccups/inconsistencies with the render service I am using. It's an awesome service and I highly recommend it but I will still be looking to a render specialist for more finalized renders.
To address everyone else. Thank you so much for the support and enthusiasm towards the set. I am still working on finalizing the polished versions of the novelties and getting them and the rest rendered by an artist so that it is all consistent and a little more polished looking.
The google forms help out a lot so and I have gotten some great feedback and insight from them which helps me keep the focus of the set. Thank you for filling those out.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #56 on: Fri, 28 February 2020, 23:25:40 »
The entire Sidewalks kit and all blanks in 40's|Ortho kit will be convex, right?  GMK has convex tooling for all those sizes.
Offline Owl
« Reply #57 on: Sun, 01 March 2020, 17:03:59 »
That is correct they will be properly convex just like any other GMK set. That representation is another limitation of the render service that I used. I am still looking for someone to do all of my renders so that they are more polished and hope to have those added ASAP to relieve some of the confusion that my current renders are causing. Right now most of the people I want to hire are booked or are on vacation so I don't have an estimated ETA on arrival for those renders.
Offline despairsray
« Reply #58 on: Sun, 01 March 2020, 19:53:10 »
This is probably my favorite upcoming GMK in IC. I especially love the deskmats, definitely in.
Offline Jaltr
« Reply #59 on: Mon, 02 March 2020, 03:46:24 »
Very interested. Thank you for the 한글 kit!
Sent from my SM-J415G using Tapatalk
Offline BrendanB02
« Reply #60 on: Sat, 11 April 2020, 23:23:37 »
I really like this!!
Offline amarotea
« Reply #61 on: Sun, 12 April 2020, 00:04:50 »
Wow the streetlight desk mat is really lovely.
Offline Hanabi
  • Falling into a black hole.
« Reply #62 on: Sun, 12 April 2020, 00:16:49 »
Really like the "feel" from the keycaps.
Offline Dumble_Hub
  • Lets Go Bills!!!
« Reply #63 on: Sun, 12 April 2020, 01:16:36 »
Love the mood of this set, reminds me of a midnight walk home.
Consider me interested.
Offline huey
« Reply #64 on: Sun, 12 April 2020, 04:38:25 »
Hey man, I'm glad to see that this set is coming together. The updates you have put into it are looking promising, and thank you for putting UK ISO in the base kit. But I do have some more nitpicks to throw your way.
- The colours selected are all hex codes. It's probably in your best interest to take a look at GMKs' stock colours, RAL colours or at least Pantones and see how these colours translate. I'm pretty sure that GMK will turn away hex codes.
- The deskmat ideas aren't bad so far. But I do think a more minimal design is not only better suited to this set, but it would be more popular design language over something a bit more complex (I might be bias to this ;D).
« Last Edit: Sun, 12 April 2020, 04:40:29 by huey »
Offline Owl
« Reply #65 on: Sun, 12 April 2020, 06:36:34 »
Thank you for following the set through its changes. Don't worry, there is a big update coming very soon to you guys with the final colors in Pantone form, new professional and accurate renders from a well respected and talented artist, polished novelties, the whole kit and kaboodle. I can't give an ETA just yet as I have a few loose ends to wrap up but it is absolutely coming. Thank you all again.
Offline Jaltr
« Reply #66 on: Sun, 12 April 2020, 12:50:42 »
I completely forgot about this!
Will be waiting on the updates and will be getting a couple of sets at least.
Offline DERBS
  • N E 3u bars avail?
« Reply #67 on: Sun, 26 April 2020, 00:01:28 »
Loving what I see so far!
Offline konstantin
  • Formerly constexpr
« Reply #68 on: Sun, 26 April 2020, 05:05:40 »
Hey there, not sure if this has been mentioned before, but consider dropping the R1 1u mod-colored \|, it isn't really necessary (the alpha-colored one is sufficient). Furthermore, you could also drop the numpad 00 key, since you don't see it used very often nowadays (except as an Alice B replacement, but you already have that covered).
Also, please consider adding R3 PgUp, R4 PgDn for us 65% and 75% users. I think HHKB users would also appreciate the addition of a R3 1.75u Control key.
Some legend suggestions: use Control instead of Ctrl, System/Sys or Super instead of Win, and Fn instead of Menu. You can change Num↲Lock to Num, Scroll↲Lock to Scroll, and Caps↲Lock (stepped) to Caps if you want all of the legends in the set to be single-line; it might look cleaner this way.
Offline Owl
« Reply #69 on: Sun, 26 April 2020, 11:38:14 »
Thank you for the feedback. These are some good ideas. I am going to keep the \| mod color as I personally love having that in mod color for that cradled alpha look. But I think you're right in that I could get away with dropping the 00 key.
I will absolutely take a look at adding R3 PgUp and R4 PgDn as I am a 75% lover myself. Not sure how I missed that.
as for the legends, the final renders are in queue with an artist right now and they will be cleaned up to have control, super, ect.
I apologize for the confusion that the current renders are causing everyone right now. The polished versions are in the works and there will be a big overhaul to this thread once they are done that I feel very proud about and think you guys will like a lot. Thank you for continuing to check in while we wait for that update. It means quite a bit to me.
Offline equalunique
« Reply #70 on: Sun, 26 April 2020, 11:40:41 »
I really like this color scheme. Been rainy here for weeks, and I can confirm it's a perfect match.
Offline Jaltr
« Reply #71 on: Sun, 26 April 2020, 12:18:40 »
Will you add the | ₩ key in the Hangul kit?
Offline konstantin
« Reply #72 on: Sun, 26 April 2020, 14:58:34 »
Alright, great. Just to make sure we're on the same page, I was talking talking about the mod-colored R1 1u \|, not the R2 1.5u one. The latter should stay in the kit of course, but the R1 1u isn't needed because if you're using split Backspace and want a mod-colored cap in the top-right corner, you're going to use `~ (at least that's what most people do).
Is R3 1.75u Control also something you're going to add (Caps replacement for HHKB users)?
Offline Owl
« Reply #73 on: Sun, 26 April 2020, 16:39:22 »
Ah I see. Yeah you make a good point. I will probably take that out then unless a majority want that in (sounds like most people wont). I would like to keep the kits as condensed as possible to make the price accessible while still offering as much support as possible. As heads up, this goes for the novelties as well. I have taken out a few of the ones that felt "redundant" and left just a few to make it easier for people to get that one or 2 novelties that they want without paying a small fortune for just a few keys. I think most people would like to just accent their keyboard with novelties instead of having one for every slot. I will be working with my render artist as well to discuss further possible changes to the base kit as they have a lot of experience with kitting.  Thank you for your valuable feedback.
And yes I will add that control key for the HHKB users out there. Shouldn't be a problem. I may end up putting a KLE up with the To-Date changes until those final renders come
Also the Won key will also be in the Hangul kit. I will go ahead and update the IC with a KLE that represents that I think
« Last Edit: Sun, 26 April 2020, 16:42:10 by Owl »
Offline vurtomatic
« Reply #74 on: Sun, 26 April 2020, 16:53:39 »
Suggestion for desk mat: A minimal black background with some concentric circles of different thickness in your color palette to indicate ripples from raindrops.
Offline Jaltr
« Reply #75 on: Sun, 26 April 2020, 17:01:31 »
Thank you OP! Yeah, the KLE not showing that key threw me off a lot Haha.
Offline Owl
« Reply #76 on: Sun, 26 April 2020, 17:28:02 »
I think you are right on that. The streetlight and concrete ones, based on the google form, were very popular. Not sure if I will be able to run a third but if I can I will certainly mock up this idea and run it as I had thought about it before. I think I will just use the bridges for the box art as they weren't super popular at all as desk mats.
I updated the KLE on the page. That is what I intend to add. Thank you.
« Last Edit: Sun, 26 April 2020, 17:34:15 by Owl »
Offline despairsray
If we are on the topic of deskmats, I really hope you keep streetlights. Digging that along with the entire set. I am glad that this is moving along, definitely in on day 1.
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
I really really like this set.
But those colors are going to be extremely hard to match in plastic. Especially in Pantone since GMK only does RAL (european standard).
Also as much as I love those novelties, it won't be possible to make them the way they look now.
GMK has a limit on how fine lines are allowed to be and those are definitely too detailed.
You have to keep in mind that the legend has to be CNC machined into a metal mold.
« Last Edit: Mon, 27 April 2020, 05:34:58 by elmo »
Offline KoyBoi
Keep coming back to check up and look at this set... My gf is especially looking forward to it!!
« Last Edit: Thu, 30 April 2020, 11:06:36 by KoyBoi »
Offline KRY2SOON
  • Divine Studios
Literally my favorite color!
Sent from my KitchenSmith by BELLA 2 Slice Toaster
Offline Owl
Re: [IC] GMK Rainy Day | UPDATE: Vendors, Renders and Kits [5/25/20]
« Reply #81 on: Mon, 25 May 2020, 17:15:49 »
Thank you all for the continued support. I have just launched a large update on the thread that I hope you will all enjoy. I will continue working on this and get you guys info on collaborations as soon as they are finalized. Thank you.
Offline despairsray
« Reply #82 on: Mon, 25 May 2020, 17:38:35 »
glad to see this is happening. ETA on the GB? July - Sept?
Offline RIPTunaMan
« Reply #83 on: Mon, 25 May 2020, 18:52:19 »
Double checking to make sure I'm not just blind but this kit doesn't have a 1U shift in any of it's kits correct? Not a big deal since I can just use a novelty key in place of it either way. Excited for the GB and US vendor announcement.
« Last Edit: Mon, 25 May 2020, 18:54:49 by RIPTunaMan »
Offline Owl
« Reply #84 on: Mon, 25 May 2020, 18:56:01 »
Double checking to make sure I'm not just blind but this kit doesn't have a 1U spacebar in any of it's kits correct? Not a big deal since I can just use a novelty key in place of it either way. Excited for the GB and US vendor announcement.
that's correct. There is no 1U spacebar.
Offline RIPTunaMan
« Reply #85 on: Mon, 25 May 2020, 18:58:07 »
Sorry, I spaced out and typed "spacebar" instead of "shift", didn't edit my comment on time :/ Assuming the same goes for that. Probably going to be the first keycap set I buy besides the one I got with my board in the first place though, great work on this.
Offline Owl
« Reply #86 on: Mon, 25 May 2020, 19:01:10 »
Oh no worries lol. Yeah no 1U shift either but you could use the 1U Fn key from the base kit or the 1U umbrella from the novelties.
Offline Alpacacino
« Reply #87 on: Mon, 25 May 2020, 19:52:11 »
Definitely into this!  Would be nice to have a Canadian vendor like Deskhero as well!
Offline dydy124
« Reply #88 on: Mon, 25 May 2020, 20:01:28 »
Very interested. Looks real good.
Offline Hugs94
« Reply #89 on: Mon, 25 May 2020, 20:30:13 »
Very cool. glad theres no excessive kits.
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #90 on: Mon, 25 May 2020, 20:43:01 »
Gonna be tracking this one!
Offline KoyBoi
« Reply #91 on: Wed, 27 May 2020, 18:02:06 »
Is it just me or did the colors completely change from the previous renders?
« Last Edit: Wed, 27 May 2020, 18:05:56 by KoyBoi »
Offline Owl
« Reply #92 on: Wed, 27 May 2020, 18:33:09 »
Same exact Pantones were used in both render versions. Admittedly, the first service was very "budget" and lacked more robust lighting. They also had a darker background which can make a big difference but comparing them side by side and taking into account lighting, they are pretty much the same.
Offline Owl
« Reply #93 on: Wed, 27 May 2020, 18:48:03 »
I have uploaded the Pantone chips that I have to the thread as well to compare to the renders. Note that the picture was taken with a phone in direct natural lighting. The colors in the palette are using the Pantone-provided HEX codes from their website.
Offline wil
« Reply #94 on: Wed, 27 May 2020, 19:33:17 »
as someone who did not like this when the IC launched, revisiting it now today i think it's a fantastic set!
Offline maximize
« Reply #95 on: Fri, 29 May 2020, 08:26:55 »
The colors are great  :thumb:, but the novelties really need some work.
Offline Agilr
  • Never stop achieving
    • Discord Server
« Reply #96 on: Fri, 29 May 2020, 09:48:36 »
Oh my god I want this
Offline Quinella
« Reply #97 on: Fri, 29 May 2020, 09:49:28 »
DC for Oceania vendor pls!
Offline alexkunnen
« Reply #98 on: Mon, 01 June 2020, 18:46:53 »
love it
Offline LemonyA
« Reply #99 on: Wed, 03 June 2020, 19:44:39 »
Love it! Well we get Canada vendor?
