Author Topic: [IC] Evolv | A four year journey complete  (Read 522321 times)
Offline DonaldPShimoda
Re: [IC] Evolv 75% | R2 Protos on the way, Page 11 for teaser pic!
« Reply #550 on: Mon, 29 June 2020, 22:44:25 »
What are the keycaps in the render in the 1st post? The matte finish makes them look similar to the GMK Modern Dolch 2
I believe that's Infinikey Amalfi, by the same designer. IC thread here.
Offline NathanAlphaMan
« Reply #551 on: Mon, 29 June 2020, 23:00:09 »
This is the correct answer  :thumb:
Offline sagarsiddhpura
« Reply #552 on: Thu, 02 July 2020, 14:08:50 »
Any updates on this?
« Reply #553 on: Thu, 02 July 2020, 14:59:58 »
The PC protos should be arriving to me very soon. A real update will follow once I build the board and test it out.
Offline willphillipsjr
« Reply #554 on: Thu, 02 July 2020, 15:58:22 »
even I don't get in on the raffle I'm excited to see the progress!  ;D
(don't worry, I'm still hoping to get one. Just staying realistic. lol)
Offline MechanicalNerd
« Reply #555 on: Wed, 08 July 2020, 23:37:40 »
Could someone be kind enough to explain to me why not run a GB instead of a raffle? Seems like demand is pretty high for this...  :eek:
« Reply #556 on: Thu, 09 July 2020, 01:00:14 »
The raffle is a GB, if you win the raffle, you get a spot in the group buy. The reasoning for this is because I'm just a one-person team, I can't feasibly QC 1000+ boards if I run something unlimited. As such, I'm artificially limiting the number of boards that will be produced to a much more manageable number for myself, and because I don't like FCFS, a raffle is the best way to allocate spots. This is no different from what Keycult do.
Offline Nirelko
« Reply #557 on: Thu, 09 July 2020, 15:08:34 »
Is there a date for when the raffle will go?
BTW amazing board, big big fan.
Offline ManiacMarc
    • Twitch
« Reply #558 on: Thu, 09 July 2020, 18:55:48 »
Super nice, I'd love to see this come to fruition.
Offline noorejji
« Reply #559 on: Thu, 09 July 2020, 21:57:31 »
I probably won't be affording myself this board, but I must say I highly respect your user involvement, and your decision to revamp the design following the 1st prototype.
Offline fruitofconfusion
« Reply #560 on: Tue, 21 July 2020, 10:20:57 »
Has the PC proto arrived yet? I'm really excited to see what you've been working on.
Offline Leche
« Reply #561 on: Tue, 21 July 2020, 10:25:48 »
Yes, the best way to get updates is to join his Discord (Linked in the OP)
It looks stunning!
« Reply #562 on: Tue, 21 July 2020, 11:45:28 »
It looks stunning!
Ah, thank you!
Offline Madrai
« Reply #563 on: Mon, 27 July 2020, 10:51:04 »
Due to the popularity and light this seems to be getting, have you thought of possible working with other people in the community or forming a team to run this GB? Might assist with how many boards you will feel comfortable making available (I'm sure it's been talked or thought about, but just giving my 2 cents in case not.) Not sure if it's feasible in your area or where you are manufacturing.
Offline cloudtastrophe
« Reply #564 on: Sun, 02 August 2020, 03:13:27 »
is there a new discord link? the one in the title is invalid
Offline paperassgasket
« Reply #565 on: Wed, 05 August 2020, 16:19:37 »
It seemed to work fine for me just now?
Offline mozaic
    • [IG] Mozaic
« Reply #566 on: Wed, 05 August 2020, 18:45:37 »
This has gotta be one of the most unique looking keyboards I have ever seen, the bottom of the board is very elegant. Also you couldn't have chosen a better name for this board, it definitely has evolved into something beautiful
I'm very pleased to see that you are taking your time with the prototypes to get every last detail right, rather than rushing to GB stage.
Excited to see more updates in the future :thumb:
Offline Bobatype
  • formerly bobasweatandtears
    • discord: bobatype
« Reply #567 on: Sat, 08 August 2020, 02:17:22 »
I really like the decisions made about the layout. I wish more keycap sets will start to include a 1.5u right shift key though in the base kit!
On that point, I was looking at your keycap set PBT Amalfi, and was wondering if 1.5u right shift key is included in the base kit too?
« Reply #568 on: Sat, 08 August 2020, 02:35:54 »
The 1.5u shift for Amalfi is in the extension kit, not the base, but it is there!
Offline cam
« Reply #569 on: Sat, 08 August 2020, 02:47:11 »
Insane looking design, I love the 75% with bit of space as in the satisfying.  :thumb:
Offline dibstern
« Reply #570 on: Sun, 09 August 2020, 21:56:43 »
This looks unbelievable, I'm devastated that the shift on the right is small, otherwise I would have been all in.
Offline mellowtempo
« Reply #571 on: Mon, 10 August 2020, 16:04:33 »
What's the reasoning behind using 7075 for the case? Seems a little overboard since 2024 for all intents and purposes is just as good and generally cheaper to machine. I saw that you mentioned 7075 was best for 'typing consistency and strength.' How did you test this and what traits make for good typing consistency and strength? I'm planning on designing my own board so it'd be helpful to understand the thought process.
« Reply #572 on: Mon, 10 August 2020, 16:24:12 »
I'm not sure which is more impressive... the fact that you have that specific knowledge of metallurgy or the fact that you came out of lurking just to make this your one and only post.
e: I don't think 2024 was ever even mentioned so maybe it just wasn't considered?
« Last Edit: Mon, 10 August 2020, 16:26:30 by paperassgasket »
« Reply #573 on: Mon, 10 August 2020, 18:45:24 »
Oof, that quote about 7075 is no longer valid as the plate is no longer integrated. However, to more directly answer your question, 2024 was never considered. Of the alloys I did test, 7075 proved to have the most consistent generation results, which is why I opted to use it over something like 6061. Now that the plate is no longer integrated, I will likely no longer use 7075 for the case to both help lower cost, and to make anodization possible. However, the metal version is currently on hold while I focus on getting the PC version out the door, so TBD on my final decision there.
Re: [IC] Evolv 75%
« Reply #574 on: Sun, 23 August 2020, 23:33:20 »
FWIW I wouldn't be upset with a Polycarb only GB.
Offline mellowtempo
« Reply #575 on: Sat, 05 September 2020, 01:16:30 »
Haha I'm not much of a geekhack guy, really only stay on the mechreddits, but the evolv just has me too interested. And I have some experience with chemical engineering and thought the 7075 was an unnecessarily expensive choice when there are much more mainstream affordable aluminum alloys. Glad to see the creator is really dedicated to making his board affordable but also high quality though.
Offline Buburoo
Re: [IC] Evolv 75%
« Reply #576 on: Sat, 05 September 2020, 16:37:32 »
Love, Love, Love it. Gib now plz.
Offline KeebOnMe
Re: [IC] Evolv 75%
« Reply #577 on: Sun, 06 September 2020, 23:42:43 »
Love the design of the evolv! Hope to snag a spot for the raffle!
Offline antcrm
Re: [IC] Evolv 75%
« Reply #578 on: Mon, 07 September 2020, 00:19:23 »
i like it
Offline OnNitrous
Re: [IC] Evolv 75%
« Reply #579 on: Wed, 23 September 2020, 05:38:40 »
Please tell me this is still going ahead?
if so can I Join this please?
forgive me if I missed something though the 12 pages of post.
but this is Beautiful.
Offline gilbert
Re: [IC] Evolv 75%
« Reply #580 on: Wed, 23 September 2020, 07:47:47 »
interesting bottom design
Offline spedywin
  • Formerly spedywin
Re: [IC] Evolv 75%
« Reply #581 on: Thu, 01 October 2020, 13:37:00 »
been waiting for a staggered 75 with rotary encoder and it looks like it's finally here
Offline Alga
Re: [IC] Evolv 75%
« Reply #582 on: Wed, 28 October 2020, 04:58:18 »
Very gaudinian I would say.
One question, in the renders of the PBT Amalfi is what looks like a polycarb version of this keyboard. It looks awesome.
Will that be an option? Pease say yes....
please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please
Offline sublyme
  • sublyme_keys
Re: [IC] Evolv 75%
« Reply #583 on: Thu, 12 November 2020, 12:11:26 »
This looks really cool. I hope it works out!
Offline x_mister
Re: [IC] Evolv 75%
« Reply #584 on: Fri, 25 December 2020, 04:09:22 »
such an unique design, really loving it
Offline FoxFire007
Re: [IC] Evolv 75%
« Reply #585 on: Mon, 28 December 2020, 02:59:41 »
Did I miss this GB?
Sent from my SM-G988U using Tapatalk
Offline Poesjuh
Re: [IC] Evolv 75%
« Reply #586 on: Mon, 28 December 2020, 12:04:03 »
Hasn’t been any yet, so you didn’t miss it :)
Offline FoxFire007
Re: [IC] Evolv 75%
« Reply #587 on: Tue, 29 December 2020, 02:51:41 »
That is hella good news lol. If this stays a raffle system I hope I get a spot.
Offline dudewth
Re: [IC] Evolv 75%
« Reply #588 on: Mon, 04 January 2021, 11:51:29 »
Love the design - interested!
Offline stowz
Re: [IC] Evolv 75%
« Reply #589 on: Mon, 04 January 2021, 14:30:56 »
Has anyone seen any updates on this? Thanks!
Re: [IC] Evolv 75%
« Reply #590 on: Mon, 04 January 2021, 15:26:58 »
Movement on this coming super soon with the FnF protos currently shipping!
Offline prizeS
    • TastyKeys
Re: [IC] Evolv 75%
« Reply #591 on: Sun, 10 January 2021, 21:22:02 »
ooh
i lub 65% and wkl tkl.
Offline FoxFire007
Re: [IC] Evolv 75%
« Reply #592 on: Wed, 13 January 2021, 21:20:04 »
Waiting with, school girl at a Bieber concert, level of excitement.
« Last Edit: Wed, 13 January 2021, 21:28:45 by FoxFire007 »
Offline pom
Re: [IC] Evolv 75%
« Reply #593 on: Sat, 23 January 2021, 07:45:36 »
Obligatory "Never bought a KB before, total noob" comment:
How do you buy this keyboard? Is it going on a drop website?
What kinds of timelines is common with these buys? Is it 1 year from order to arrival?
Thanks for any help!
Offline holer
Re: [IC] Evolv 75%
« Reply #594 on: Mon, 25 January 2021, 03:24:07 »
Welcome :)
While I can't answer for this specific project, but in general:
  • Boards are most sold in a group buy on a website by the developer and/or a selection of regional vendors
  • Most boards are manifactured in east asia, and the estimated lead time seems to be around 6-12 month at the moment
Again, I do have any information about this board in particular :)
Offline jadhvank
Re: [IC] Evolv 75%
« Reply #595 on: Tue, 26 January 2021, 17:29:53 »
How can I buy this keyboard?
Offline Gondolindrim
    • My GitHub
Re: [IC] Evolv 75%
« Reply #596 on: Wed, 27 January 2021, 08:19:06 »
The board is still under final developmental stages and will enter group buy. There isn't an ETA on that yet.
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline lycantivis
Re: [IC] Evolv 75%
« Reply #597 on: Wed, 27 January 2021, 10:13:15 »
oh man this might be my first GB I have entered excited to see something in time lol.
Offline MQLYU
Re: [IC] Evolv 75%
« Reply #598 on: Tue, 09 March 2021, 06:53:20 »
Reserved!
Offline Alejo1707
  • Gimme some more caps!
Re: [IC] Evolv 75%
« Reply #599 on: Tue, 09 March 2021, 07:57:34 »
Oooofff thanks god!
I've seen so many renders on this board and was fervently hoping to get my hands on one. Will keep an eye on the post and thanks for the info! :D
