Author Topic: [IC] GMK Shoko 2nd Style「Group Buy Live Now」  (Read 261122 times)
Offline nu_types
  • Formerly Iredeus
Re: [IC] GMK Shoko 2nd Style
« Reply #150 on: Thu, 16 April 2020, 19:23:09 »
This reminds me of a thing that happened a few years ago between a team of "mostly" engineers and another company who financed some stuff...
Oh, how the turn tables.
Offline JME
« Reply #151 on: Thu, 16 April 2020, 20:45:08 »
Kono going off the rails and not even including the highlight accent ESC...Not paying for a add-on set just for one key.
Hope RaySasQuach gets creative control of this GB, otherwise i'll pass.
Offline belerian
« Reply #152 on: Thu, 16 April 2020, 21:32:45 »
What is your opinion on splitting the numpad portion of the full kit into its own separate kit?
Offline Daellin
« Reply #153 on: Thu, 16 April 2020, 21:46:22 »
I'd rather buy it overpriced from aftermarket than pay Kono a dollar if they wrest control of the GB from Ray.
Offline oldcat
  • 65% is Life
« Reply #154 on: Thu, 16 April 2020, 22:20:21 »
This has been debated for a while I believe.
I would really like to have that kind of base as well (as I only use 65%), not sure if it will happen.
Offline byoliven
« Reply #155 on: Thu, 16 April 2020, 22:29:45 »
I prefer splitting those numpad portion into separate kit too.
Offline DJ Shoko
« Reply #156 on: Fri, 17 April 2020, 01:25:57 »
I am strongly considering this right now actually after talking to a few people about it actually. It is a nice way to bring the price down and the amount of numpad users are kinda low in this hobby I'd imagine.
Offline iammeuru
« Reply #157 on: Fri, 17 April 2020, 03:55:12 »
I strongly hope you don't do this... I am buying up support for basically all kits, and splitting off numpad never seems to reduce the cost more than a few bucks on each kit, but rather increases the cost for me by $30 or so. I was planning to buy two sets of Shoko (one for display only, and another for use), and this will significantly increase the cost... Also, there are a lot of 1800 boards out there, and plenty of full-size users (though I suspect most of those don't participate on GH, or /r/mk much)
Offline IOVERCALLHISTIOCYTES
« Reply #158 on: Fri, 17 April 2020, 10:33:00 »
If MOQ is 500, base kit split off isn't so bad, as you can get 99 base and 40 numpad. At 250, you're often near 120 base and 40 numpad, and base could have been 125 or 130 with numpad in it.
Offline daniwa
« Reply #159 on: Fri, 17 April 2020, 10:40:31 »
From a sustainability point of view, I would very much like to not buy things that I'm not going to use.
Offline konstantin
  • Formerly constexpr
« Reply #160 on: Fri, 17 April 2020, 10:41:01 »
The base kit is still going to be large without the numpad, it's not going to reach $99 @ 500 MOQ.
Offline Mcnos
    • GMK Fuyu
« Reply #161 on: Fri, 17 April 2020, 11:16:27 »
Just depending on how the base kit would be changed to suit the 500 MOQ price point. It's about the kit components and what's added/removed for the sake of utilization.
There's always two sides to a coin.
The majority who buys a base kit for 140 but has 20+ keys they'll possibly never use
The minority who utilizes all keys and pays 140
Say they manage a 500 MOQ theory.
Majority buys a set at 110 (for the lack of real examples) buys all the keys that they need and will ever use
Minority who pays 110+40 who gets everything they need at the cost of an extra 40.
I would lean towards a numpad-less base if a set can manage the MOQ numbers as I side with the majority.
Keep note that kit compositions would be different for both situations.
« Last Edit: Fri, 17 April 2020, 11:25:11 by Mcnos »
Offline tominabox1
« Reply #162 on: Fri, 17 April 2020, 11:22:51 »
As a 40s user, a numpad-less base kit is far better for me. It would help me afford the set by quite a bit.
Offline SlurmsMacKenzie
« Reply #163 on: Fri, 17 April 2020, 12:52:37 »
The Obscure kit doesn't even have the keycap that you would want. I would assume the Obscure has R2 and R3 Esc, so there is literally no R1 Blue Esc available.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #164 on: Fri, 17 April 2020, 18:45:13 »
EDIT: See the bar graph in a later post which uses (Numpad kits) / (TKL Mod kits) so is more representative.
Here are Numpad take rates for some previous (Mass)Drop GBs.
<-- this graph's take rates are artificially low because it's using (Numpad kits) / (Alpha kits).  Alphas are also used on ortho and ergo boards, but Numpads aren't.
« Last Edit: Tue, 21 April 2020, 21:42:03 by dvorcol »
Offline nasp
« Reply #165 on: Fri, 17 April 2020, 18:59:41 »
Do you have more GMK set data besides Jamon?
Another important thing to note about this is time. I think the trend over time is to favor smaller boards. Just look at the number of 60/65% boards going to GB compared to those there have numpads.
Offline oldcat
  • 65% is Life
« Reply #166 on: Fri, 17 April 2020, 20:01:34 »
always amazing graphics
Offline whitty
  • Formerly dsw_408
« Reply #167 on: Sat, 18 April 2020, 03:51:45 »
+1 for splitting numpad
Offline Mcnos
    • GMK Fuyu
« Reply #168 on: Sat, 18 April 2020, 04:19:19 »
I think a GMK graph would be in order here to be more relevant to the certain situation
Here's more than a few sets to use for referencing
GMK Minimal
GMK Apollo
GMK Dark
GMK Nautilus Nightmares
GMK Peach Blossom
GMK Yugo
GMK Analog Dreams
GMK Cafe
GMK 9009 R3
And don't forget about Bleached.
Just by looking at the numbers at a glance of final numbers, num-pad consists of 1/4 - 1/6 of the base kit estimated.
« Last Edit: Sat, 18 April 2020, 04:27:18 by Mcnos »
Offline huey
« Reply #169 on: Sat, 18 April 2020, 04:29:43 »
Warning! Opinions that some may not like. Proceed with caution.
I dislike splitting the numpad unless you are going for a very low price/high MOQ.
This set is a community favourite and I personally contribute it's very "all inclusive" base kit as one of its strong points. If this 2nd round can be achieved at a price similar price to what Kono is running at right now (lmao btw), then it'll sell like hotcakes.
If we follow the mentality of "I don't need it, therefore it should go", then we'd all be running around buying slightly fleshed-out ANSI 60% kits. The kitting would be insane making it so damn expensive for anyone that dares not to use Standard ANSI/Tsangan. Also, if numpad goes then UK-ISO is on the chopping block.  :(
Offline dvorcol
« Reply #170 on: Sat, 18 April 2020, 11:21:54 »
GMK Minimal
GMK Apollo
GMK Dark
GMK Peach Blossom
GMK Yugo
GMK Analog Dreams
GMK Cafe
GMK 9009 R3
I have a ton of numbers to gather, but I'll try to have a graph in the next few days.
Sets that split everything into a larger number of smaller kits by default (Alphas, Mods, Numpad, etc. for SA, DSA, XDA, KAT/KAM) might better-reflect the market, since cost up/down is not a factor.  Here's something to ponder:
Edit: corrected bad math. Changed to TKL mod ratio rather than Alpha ratio.
« Last Edit: Fri, 24 April 2020, 15:53:29 by dvorcol »
Offline tankskun
« Reply #171 on: Sat, 18 April 2020, 11:35:33 »
Love the Shoko, such an elegant colourway. Please don't split the numpad. Also waiting for raysasquach official vendor. Not buying from Kono
« Last Edit: Sat, 18 April 2020, 11:38:09 by tankskun »
Offline oldcat
  • 65% is Life
« Reply #172 on: Sat, 18 April 2020, 17:27:55 »
This is probably THE keycap groupbuy I have to join this year. Will be holding out buying from Kono (as the deadline for joining is June 12 anyway). And eagerly awaiting author's plans to move the GB forward.
Offline DERBS
  • N E 3u bars avail?
« Reply #173 on: Sat, 18 April 2020, 17:58:53 »
+1 for keeping numpad in the base
Offline Waffle0508
« Reply #174 on: Sat, 18 April 2020, 18:41:43 »
Another +1 for keeping the Numpad in the base kit!
Offline oldcat
  • 65% is Life
« Reply #175 on: Sat, 18 April 2020, 22:54:40 »
If Ray can consider adding R3 PgUp and R4 PgDn it will be greatly appreciated.
Offline ggmoss
« Reply #176 on: Sat, 18 April 2020, 23:36:42 »
+1 for slplitted kits.
Offline sirieous
  • help
Re: [IC] GMK Shoko 2nd Style「To split or not to split numpad and ISO」
« Reply #177 on: Sun, 19 April 2020, 00:01:30 »
+1 for splitting kits
Offline 2QT2BSTR8
« Reply #178 on: Sun, 19 April 2020, 00:18:03 »
Happy to pay for numpad, despite not needing it.
Offline belerian
« Reply #179 on: Sun, 19 April 2020, 00:59:30 »
1 vote for splitting.
Offline calveeen
« Reply #180 on: Sun, 19 April 2020, 03:05:15 »
+ 1 for splitting
Offline flying1911
    • Mechlovin' Studio
« Reply #181 on: Sun, 19 April 2020, 04:31:39 »
+1 for splitting
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline Mcnos
    • GMK Fuyu
« Reply #182 on: Sun, 19 April 2020, 05:30:28 »
+ 1 Splitting
Offline heliar_mk
« Reply #183 on: Sun, 19 April 2020, 05:38:44 »
+1 for splitting
Offline SolidCactus
« Reply #184 on: Sun, 19 April 2020, 07:04:37 »
This please!
Offline terrad
« Reply #185 on: Sun, 19 April 2020, 07:31:16 »
+1 for splitting, and a text + icon mod kit.
Sent from my SM-G955F using Tapatalk
Offline dallman5
« Reply #186 on: Sun, 19 April 2020, 09:19:16 »
Plz don’t split
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline neutralstate
« Reply #187 on: Sun, 19 April 2020, 10:21:37 »
would prefer splitting.
Offline pcire
« Reply #188 on: Sun, 19 April 2020, 10:22:50 »
Split it!
But more importantly, don’t run it on kono
Offline Mcnos
    • GMK Fuyu
« Reply #189 on: Sun, 19 April 2020, 10:25:09 »
Instead of flooding this IC
How about just input your votes on this strawpoll until a better means is presented.
https://www.strawpoll.me/19814989
Edit:
This does not mean a decision will be made off of this, but a better means to obtain data.
Offline oldcat
  • 65% is Life
« Reply #190 on: Sun, 19 April 2020, 13:10:54 »
Edit:
Great. Voted, thanks!
Offline greentea
« Reply #191 on: Sun, 19 April 2020, 19:06:02 »
I'll just call it GMK Shoko Substream to fit the naming scheme...
Can't wait for Shoko Red, Shoko Happy Sky, Shoko Distorted, and Shoko Gold
Offline Karni
« Reply #192 on: Sun, 19 April 2020, 19:15:29 »
im for splitting
Offline Fidelias
« Reply #193 on: Mon, 20 April 2020, 16:48:30 »
This is what I got from Kono when I canceled my order:
Apologies, the designer for Shoko has been inconsistent — when he disappeared during the original GB we had to finish it without him.
He gave us the go-ahead for Round 2 and agreed to a rough timeline, but ghosted us again and stopped updating the set.
We kept the GB moving by using the files he submitted before the lapse in communications. The kits on the page are what was quoted with GMK for this run.
Hitting stop on the current set would result in delays and losses for everyone, especially during the pandemic.
I've cancelled your Order and issued a refund.
Please let me know if you need anything else,
It sounds like they're trying to blame OP for running this without his knowledge (even if there were communication issues, still don't see how it makes it OK to take OP's designs and do a GB on their own). Also not sure what "delays and losses for everyone" means since I wouldn't expect them to have paid for an order from GMK since GB didn't close yet.
Offline oldcat
  • 65% is Life
« Reply #194 on: Mon, 20 April 2020, 16:59:06 »
To be fair to Kono what was described here about R1 by Kono was what I observed as well. That was the reason many people did not join R1 afaik. You can still find those comments in the R1 IC page.
Hopefully, OP can come here more often and provide more communication for R2, and I will certainly join now the real pictures came out great.
« Last Edit: Mon, 20 April 2020, 17:03:22 by oldcat »
« Reply #195 on: Mon, 20 April 2020, 17:09:19 »
Loss is with refunds with PayPal or the other pay apps? So someone (buyers, it seems) would be out the ~4% or so for fees?
Offline Slayer77
« Reply #196 on: Mon, 20 April 2020, 17:10:09 »
To play devil's advocate, Kono probably invested in the renders (those renders look pretty nice) and probably couldn't wait any longer for design changes. There was probably an agreed upon timeline of some sorts.
Sent from my GM1911 using Tapatalk
Offline pcire
« Reply #197 on: Mon, 20 April 2020, 17:12:09 »
We’re all just speculating here. Hope OP can clarify soon
I have a build planned around Shoko. Can’t wait!
Offline oldcat
  • 65% is Life
« Reply #198 on: Mon, 20 April 2020, 18:18:25 »
Really liked Shoko and hope it will happen one way or another. Certainly, I would like to support OP as a designer and creator and refrain from buying from Kono at this moment, but hopefully, more clarity can be provided and it may not be too late to bring Kono on board again by communicating with them about possible new kits.
I even want to do work on some custom case colors for Shoko for Think2020...
Still hoping for that R3 PgUp and R4 PgDn to happen....
Offline Tennstrong
« Reply #199 on: Mon, 20 April 2020, 19:07:13 »
If numpad gets split might be more affordable to go all-in (buy all kits) with the **** kitting on kono than buy base + numpad + spacebars all separate; one of the few things that could get me to buy the kono run.
