Author Topic: [IC] GMK HALLYU 한류  (Read 293435 times)
Offline punchaslime
Re: [IC] GMK HALLYU 한류
« Reply #150 on: Tue, 09 June 2020, 03:48:21 »
Any possibility of a kit without the row by row color? Like just the blue on navy.
Offline DrRazzmaTaz
« Reply #151 on: Wed, 10 June 2020, 18:33:56 »
a thousand percent yes, I want these yesterday
Offline DrRazzmaTaz
« Reply #152 on: Sat, 13 June 2020, 09:15:52 »
Would it be possible to include a 1u shift key? :)
Offline itsslim
« Reply #153 on: Mon, 15 June 2020, 13:46:36 »
I can't wait for this set.
Offline Schmack
« Reply #154 on: Sat, 20 June 2020, 22:31:38 »
Definitely going to set a reminder in November for this!
Offline NGI
« Reply #155 on: Sat, 20 June 2020, 22:38:06 »
Extremely Interested 😍
Offline bl1ndguy0
« Reply #156 on: Mon, 22 June 2020, 14:08:31 »
Offline bl1ndguy0
« Reply #157 on: Mon, 22 June 2020, 14:10:01 »
still wishing there will be more mono hangul alphas for kits.
(or not since it will make me interested in getting more keycaps)
I too am also interested in this. Even it's not mono, it's fine!
Offline JinJuu
« Reply #158 on: Tue, 23 June 2020, 08:34:02 »
oh damn this is really nice
yeah im in
Offline bow3i
« Reply #159 on: Tue, 23 June 2020, 14:14:35 »
Can I make a request to include an extra 'B' key for the spacebar set? I would love to have one for an alice layout keyboard
Offline konstantin
  • Formerly constexpr
« Reply #160 on: Tue, 23 June 2020, 14:44:57 »
I would like to add that since this set doesn't have any 40% compatibility, including a 1.75u space key is not useful at all, as that key is only used on the following 40% boards: Vortex Core, JD40/45, and nowhere else. Including a second B instead of a 1.75u space makes more sense.
On that note, a 1u space key is also useful to some users of Alice and other layouts. So, all in all, I would suggest making the following changes to the spacebars kit:
– remove 1.75u space
– add 1u space
– add second B
« Last Edit: Fri, 21 August 2020, 15:49:53 by konstantin »
Offline JinJuu
« Reply #161 on: Tue, 23 June 2020, 19:46:51 »
What color are the keys? They look like a really pretty deep purple, like GMK Rouge, but renders are sometimes different. I'm a sucker for purple sets, and this one is Korean so that's a huge plus
Offline stokedd_d
« Reply #162 on: Wed, 24 June 2020, 09:05:40 »
can't wait for this!!  :)
Offline Bidulomachin
« Reply #163 on: Thu, 25 June 2020, 06:51:54 »
Do you have the exact codes of the colours you used ? Would be nice to get an idea of what it (especially the base colour) looks like IRL
Here are the RAL colors I've chosen based on my RAL color swatch :
base kit : 290 30 20 / it's pretty similar to gmk rouge indeed  :) careful because on screen it looks wayyy lighter than it looks irl on the printed RAL color swatch, I'll try to post a picture of it ! What I want looks more like 290 20 15 on screen, so I'll make sure that the final color looks like the render when i'll get samples from gmk !
R1/ R4 (blue) legends : 270 70 25 knabenblau
R2 legends : 040 60 60 korallenorange
R3 legends : 050 80 30 fahlorange
R4 (yellow) legends : 080 80 60 vollgelb
I will add this in the first post !
I would like to add that since this set doesn't have any 40% compatibility, including a 1.75u space key is not useful at all, as that key is only used on the following 40% boards: Vortex Core, Daisy, JD40/45, and nowhere else. Including a second B instead of a 1.75u space makes more sense.
– add 1u space
– add second B
I'll add an extra B and two 1u spacebars to the spacebars kit !
Thanks again everybody for all the support  :D
I'm working on the deskmat too !
Offline bow3i
« Reply #164 on: Thu, 25 June 2020, 15:47:41 »
That's awesome, thank you for your work! Can't wait to get one, November seems too far away
Offline konstantin
« Reply #165 on: Thu, 25 June 2020, 19:05:14 »
That's good to hear. You can reduce it down to one 1u if you aren't planning on support ortho boards. But combining the novelty kit with the second 1u technically allows you to cover ortho grid layouts as well.
Edit: Thanks to Dvorcol for pointing the above out.
« Last Edit: Fri, 26 June 2020, 15:00:40 by konstantin »
Offline bobfrink
« Reply #166 on: Sun, 28 June 2020, 14:31:40 »
It it possible to send enough alt modifers to base, like extra shift, tab, enter to allow us to build a second set with buying alphas?
Offline productkun
« Reply #167 on: Sun, 28 June 2020, 15:41:31 »
I love the colours of the set! Will pick up a set for sure :D
Not sure how I feel about Rama keys tho :/
Offline JinJuu
« Reply #168 on: Mon, 29 June 2020, 09:41:28 »
Is a matching cable being considered as well? Would totally jump for that also
« Reply #169 on: Thu, 02 July 2020, 07:22:46 »
UPDATE !
The extra B + 2 blank 1u have been added !
I'll figure that out, I'd like to :)
What bothers you about the rama caps ? Trying to improve that but since some people like it others don't I'm kinda confused about them :)
Offline konstantin
« Reply #170 on: Thu, 02 July 2020, 07:26:15 »
Is there a Discord server for this set?
Offline prizeS
    • TastyKeys
« Reply #171 on: Thu, 02 July 2020, 15:13:21 »
i love the rama caps, especially the heart one. <3
i lub 65% and wkl tkl.
Offline Aspherical90
« Reply #172 on: Fri, 03 July 2020, 08:29:39 »
Does the base kit (e.g spacebar/shift keys) fits most 65% layout?
Looking forward to this set!
Offline itsbeard
« Reply #173 on: Wed, 08 July 2020, 17:04:24 »
100% in for finger heart and probably the set too.
Offline konstantin
« Reply #174 on: Wed, 08 July 2020, 17:22:06 »
Yes!
Offline Minam
« Reply #175 on: Wed, 08 July 2020, 18:06:13 »
Set + heart rama lets go baby
Offline bobfrink
« Reply #176 on: Sun, 12 July 2020, 21:48:13 »
dont listen to him, the finger heart rama is awesome. Definitely getting that and adds to korean theme
Offline Sanctified
« Reply #177 on: Mon, 13 July 2020, 14:29:09 »
Personally I like the design of the engravings (especially the finger heart) but I'd love to see the RAMA caps with an enamel filling, like the dark blue base color on the gold would contrast incredibly well imo.
Another option would be to have the entire heart recessed instead of just being a line art and having it enamel filled while leaving the hand as is
I feel like it would make the cap more interesting to look at :D
I'll for sure get the base kit and the novelties anyway !
« Last Edit: Mon, 13 July 2020, 14:34:17 by Sanctified »
Offline Arithmetics
« Reply #178 on: Mon, 13 July 2020, 18:35:57 »
dont touch those ramas! i git
Offline xkhol
« Reply #179 on: Tue, 14 July 2020, 09:45:18 »
+1 leave as is. Love the finger hearts!
Offline aadk5
  • AKA: feeebleminded
« Reply #180 on: Tue, 14 July 2020, 11:21:19 »
Oh, I LOVE this! Will be watching this, and yes, please keep the finger hearts lol
Offline JinJuu
« Reply #181 on: Thu, 16 July 2020, 00:49:21 »
Have you gotten pictures of the keycaps yet? Also, do you have any plans on working to make a matching cable, kind of like the ones for GMK Sumi? Cause I would totally go for one even if the design was only half good
Offline SenseiJia
  • Hey you.
« Reply #182 on: Sun, 19 July 2020, 14:07:14 »
Massively cute. In for this!
Offline bobfrink
« Reply #183 on: Fri, 24 July 2020, 19:08:58 »
Would love to see an extra tab and escape key added. Really wish this could cover 2 65% if you buy a separate alphas set.
Offline Hyphen
« Reply #184 on: Sun, 26 July 2020, 05:14:29 »
Now to just wait patiently for November.
Offline hkhawk
« Reply #185 on: Sun, 26 July 2020, 14:36:24 »
... and then wait another nine months!
Offline Hyphen
« Reply #186 on: Sun, 26 July 2020, 16:39:30 »
True! :'( But at least there's a certain satisfaction to paying for something.
Offline hkhawk
« Reply #187 on: Sun, 26 July 2020, 20:14:58 »
Haha, I know. I have a particular keyboard that I think this will look amazing on so I'm excited
Offline seanpandas
« Reply #188 on: Sun, 02 August 2020, 21:01:41 »
Love it, super basic 40s compat would be appreciated :)
Thanks ! Unfortunately, I think it would struggle to reach 250 MOQ  :(
250 MOQ is for the base kit, 100 would be for child kits. For super basic 40s reference something like GMK Deep Navy
https://cannonkeys.com/products/gb-gmk-deep-navy?variant=31505722474607
or simply adding a single 1.25 R3 "Tab" to the base kit would give all the necessary row profiling, then with the addition of the bars kit it would be fill in the rest.
Would second this suggestion, would highly appreciate that 1.25u r3 tab. I know it's hard to reach that 150 MOC for a 40s kit, but this would be a good middle-ground
I would like to third this, a 1.25u r3 tab seems like a good compromise and would make me very happy :)
Please add a 1.25u r3 tab <3
Offline glazeds0n
« Reply #189 on: Mon, 03 August 2020, 20:57:50 »
Agreed would love this thank you, this is only key missing for the basic 40s compatibility
« Reply #190 on: Tue, 04 August 2020, 07:03:13 »
UPDATE !
I don't have any samples yet, they'll come later! I'd love to have a matching cable for sure, work in progress ;)
I'm considering an Instagram account  :)
Since a lot of you guys asked for it, the 1.25u r3 tab has been added for 40s compatibility  :thumb:
Offline Steve Laroo
« Reply #191 on: Tue, 04 August 2020, 07:11:43 »
This is legitimately an awesome addition, great move in doing this! You'd be surprised how much of a difference one key can make.
Offline youngano
« Reply #192 on: Tue, 04 August 2020, 19:39:03 »
Desk mats or nah
Offline seanpandas
« Reply #193 on: Tue, 04 August 2020, 23:19:53 »
Thanks for adding the tab key, count me in! I'm so excited
Offline glazeds0n
« Reply #194 on: Wed, 05 August 2020, 00:11:09 »
The tab addition made my day! Going to get this set for sure
Offline jokbal64
« Reply #195 on: Wed, 05 August 2020, 01:27:02 »
Desk mats or nah
I would love to see a matching deskmat for this set  :)
Offline mattv
« Reply #196 on: Wed, 05 August 2020, 16:21:19 »
Love the kit and rama heart. Want them right now!  Gotta wait so long to preorder and then wait more  :'(
Offline SnowyMinion
« Reply #197 on: Wed, 05 August 2020, 18:08:33 »
Loving the colors  :D
Offline PanCP
« Reply #198 on: Thu, 06 August 2020, 08:23:03 »
Would it be possible to have a base kit version without the hangul sublegends? The design is really nice but I'm not a hangul user so it's a bit awkward to have those on the keycaps.
Offline Pach
« Reply #199 on: Thu, 06 August 2020, 08:56:51 »
hmm, a latin alphas kit would probably do well
