Author Topic: [IC] Trifecta, Prototype Pictures in Comments  (Read 147480 times)
Offline vurtomatic
Re: [IC] Trifecta 5/10 Update
« Reply #100 on: Thu, 14 May 2020, 18:27:41 »
Perfect. How tall are the knobs?
Offline BuddhaBen
« Reply #101 on: Sat, 16 May 2020, 00:12:38 »
Poly alice with arrow keys and possible rotary encoders? Done, I am in.
Offline 2Moons
« Reply #102 on: Sat, 16 May 2020, 07:45:42 »
Is the plan for the knobs to be made by RAMA as well?
No plans yet, but we can ask them.
It depends. The knobs here were based off of Splitkb's design.
Thanks for your support.
Also a discord was started. https://discord.gg/cM5xEte
Offline chakkii
Re: [IC] Trifecta
« Reply #103 on: Sat, 16 May 2020, 12:53:11 »
only per key rgb or also underglow for the polycarb case? :)
As of right now per key rgb without underglow
it would be so nice if you guys would manage to get underglow as well :) im looking for an "alice" style keyboard with arrow keys for so long now. that would be just perfect :) was close getting on the rukia polycarb GB but no arrow keys hold me back, glad i did, but the underglow looked amazing on that board :)
Offline YMwoo
« Reply #104 on: Sat, 16 May 2020, 21:37:09 »
Joined the discord!
What would be the layout options? Esp curious about the sizes of the bottom row
Offline Baionlenja
  • +B
    • www.baionlenja.com
« Reply #105 on: Wed, 27 May 2020, 04:07:12 »
How much space is there between the pcb and the plate?
Offline swiftrax
« Reply #106 on: Fri, 29 May 2020, 11:12:53 »
As per cherry spec the distance from the top of the plate to the top of the pcb is about 5mm
Offline OJtheTiny
« Reply #107 on: Sat, 30 May 2020, 10:46:27 »
I'm down, hope this comes soon
« Reply #108 on: Thu, 11 June 2020, 14:55:18 »
Any updates on what timeline we're looking?
Offline 2Moons
« Reply #109 on: Thu, 11 June 2020, 20:15:09 »
We're looking at potential vendors and prototype funding. Currently I'm finishing the Slice GB and then I will begin again on this project.
« Reply #110 on: Fri, 12 June 2020, 00:21:58 »
Sounds good, thanks!
Sent from my Redmi K20 Pro using Tapatalk
« Last Edit: Fri, 12 June 2020, 06:28:29 by AspiringMechKeebFan »
Offline yqliang
« Reply #111 on: Fri, 12 June 2020, 02:28:22 »
Any ballpark numbers for price?
Nightfox Zealios 65g | Input Club K-Type Halo True | CM Masterkeys Pro S MX Brown x Norbauer Case | SA Carbon | SA Hyperfuse | XDA MiTo Godspeed | DSA K Bares Miami Dolch | ePBT WoB
Want: Satisfaction 75 | Space65 | GMK Dot
Offline 2Moons
Re: [IC] Trifecta KAT Hyperfuse Renders
« Reply #112 on: Wed, 24 June 2020, 08:22:50 »
Not yet
Kat Hyperfuse Renders are here!
KAT Hyperfuse Group Buy starts June 29th
https://geekhack.org/index.php?topic=105660.0
Offline alphabirth
Re: [IC] Trifecta, KAT Hyperfuse Renders in Comments
« Reply #113 on: Wed, 24 June 2020, 14:48:16 »
Oof!  :chef_kiss:
Offline hiddensong
  • this too shall pass
Re: [IC] Trifecta
« Reply #114 on: Wed, 01 July 2020, 01:13:19 »
What are the encoders for?
     What are those letters and numbers on those square shaped things for? rofl....I had to. apologies if I offended, just a jokey-joke. On to the real....
     Knobs just beg to be touched and turned. Someone needs to design a rotary that has the same low weight pressure needed to engage the push button mechanic as a normal tactile/linear switch does so that we can have a keyswitch that does both....allow for easy typing AND acts as a knob. Hell, lets add RGB while we're at it. Oh why not, lets make the tip an OLED screen that can be customized to any image! Now we're cooking with week old pork fat....
     A hex shaped rotary switch that mimics exactly the push characteristics of a linear or tactile switch (or a linear/tactile switch that mimics exactly a rotary encoder's functions) along with addressable RGB strip/ring at bottom edge and an OLED screen on the switch face that is image/color addressable.
     If only I were a billionaire and could play with R&D....if only for most of us!!
Offline maximize
« Reply #115 on: Tue, 28 July 2020, 09:02:07 »
  • Encoders Spread out.
  • Hot Swap or Soldered Option.
  • Sides cut to easily pick up.
  • Knobs or Switches on the right, you choose.
  • Knobs to come in 3 colors.
  • Most popular interest check colors rendered.
New renders looking great! Just another suggestion from myself, the chin on the front of the board feels slightly out of place because of the relative sharpness compared to the rounded aesthetic the corners, encoder and side cutouts. Maybe you could try :
1. rounding out the chin at these 3 points to match how the rest of the board looks (the quasi alice by qlavier is an example)
2. Making the corners and side cutouts sharper and less rounded to match the chin, thereby making the encoders stand out more!
Sorry if I seem overbearing haha just really excited for this board!
Those 3 points are rounded but less aggressively
Is there any chance those corners might be rounded more aggressively? I realize it's pretty far into IC, but I agree with gummybur on this; the design language is not super consistent as-is. It's still a very, very nice board! :D And I like the option to have so many encoders. That's what makes this unique.
Offline 2Moons
« Reply #116 on: Tue, 28 July 2020, 16:29:12 »
Thanks. I haven't updated in awhile but prototypes will be coming soon. I respected Swiftrax initial design with a slightly more blocky look. Let's see how the prototypes turn out. Personally I really like this as it differentiates itself between other similar keyboards. As soon as I have the cases in hand, I'll post some pics then. Cheers.
Offline tonyz723
« Reply #117 on: Sun, 02 August 2020, 23:43:41 »
Filled out the IC form, honestly really excited for this keyboard.
The triple encoder setup makes it really stand out from a lot of the designs I've looked at. From a practicality standpoint maybe a bit excessive, but if I can get them to work with Lightroom I certainly wouldn't complain.
Really looking forward to whatever this project turns into, the back and forth on feedback is cool to watch happen.
I haven't personally owned an Alice style keyboard before, what special caps are needed compared to what you'd get in like a base GMK set? Right off the bat I see short spacebars for sure
Offline 2Moons
« Reply #118 on: Mon, 03 August 2020, 08:07:34 »
Thanks, I really appreciate the comment. Yep, spacebars kit, usually that's where the second b ends up as well. I'm currently adding underglow to the pcb so the polycarb version should be fun. I've always taken feedback from Geekhack especially. Closely listening to the people who will end up owning the keyboard is so important. After all, if you make recommendations, then buy the board, part of you ends up in the final result. Then in some small way you were the designer too. Even if an idea was rejected, it was at least thought about and I think that's really important as well. As soon as prototypes come in, I'll be making a big update. Meanwhile, enjoy this picture.  ;D
« Reply #119 on: Wed, 16 September 2020, 02:02:02 »
Any updates on when prototypes come?
Offline 2Moons
« Reply #120 on: Wed, 16 September 2020, 02:05:56 »
The prototypes have been made and went in for anodizing. I'm waiting for a message from the manufacturer for an update. The pcb is done and will be VIA compatible with VIA RGB control.
« Last Edit: Wed, 16 September 2020, 02:08:58 by 2Moons »
« Reply #121 on: Wed, 16 September 2020, 02:39:46 »
Glad to hear it! Looking forward to it.
Offline 2Moons
« Reply #122 on: Fri, 18 September 2020, 06:17:52 »
Here you are:
These pictures came today and I couldn't be happier with the results.
Re: [IC] Trifecta, Prototype pictures are here
« Reply #123 on: Fri, 18 September 2020, 06:22:56 »
Noice! I like the looks of darkish PC case. Waiting for the GB!
Offline tonyz723
« Reply #124 on: Sat, 10 October 2020, 19:02:11 »
What's the next step for these? Any timeline yet?
Offline 2Moons
« Reply #125 on: Sun, 11 October 2020, 07:10:33 »
  • One prototype has already been built but is waiting for encoder parts. The rest of the prototypes are to follow.
  • We're sending the prototypes out to streamers this week.
  • Finalizing price and date
  • Start Group Buy
Here is a picture of a built prototype without encoders.
Offline 2Moons
Re: [IC] Trifecta, Prototype Pictures in Comments
« Reply #126 on: Thu, 15 October 2020, 22:09:43 »
Trifecta Stream Build.
Tuesday 20/10 20:00 CEST
https://www.twitch.tv/p0esjuh
« Reply #127 on: Fri, 16 October 2020, 11:17:07 »
Have you finalized list of available colors?
Offline 2Moons
« Reply #128 on: Fri, 16 October 2020, 19:46:38 »
Yes. Black, White, Blue, Red, Polycarb, Smoke Polycarb, Combinations.
You can have an aluminum top with a polycarb bottom, for example. We're working out final design details. I'd like to see the weight smaller and more centered as to not interfere with the underglow, for example.
Offline RedBananaBread
« Reply #129 on: Sat, 17 October 2020, 05:28:43 »
The prototypes look so good! When you say combinations, does this mean we can mix and match an alu top with a polycarb bottom?
« Reply #130 on: Sat, 17 October 2020, 06:07:30 »
Offline Poesjuh
« Reply #131 on: Sat, 17 October 2020, 09:21:07 »
Like this ;)
(Neither board is build btw, that I’ll do on Tuesday. This is me trying switches to know what sounds the best to me :P)
« Last Edit: Sat, 17 October 2020, 09:41:09 by Poesjuh »
Offline Poesjuh
« Reply #132 on: Wed, 21 October 2020, 04:12:35 »
Build stream can be found here;
https://www.twitch.tv/videos/776359750
« Reply #133 on: Wed, 21 October 2020, 11:11:59 »
Oh God. They look sooooo good :p
« Reply #134 on: Mon, 15 February 2021, 09:27:06 »
Any news on this?
Offline 2Moons
« Reply #135 on: Tue, 16 February 2021, 07:48:56 »
Any news on this?
I was unsatisfied with the original prototype. Mainly the 10 degree layout and the space between some keys. The weight was also overly large, so it was made smaller so that the underglow will show through the polycarb all the way around. New prototypes were ordered from the main vendor and I'm waiting on them to be done from the manufacturer. As soon as they're done I'll do a polycarb build stream. I'm also probably going to do an STM32 pcb build for this as it can benefit from having more memory and a better MCU if you ever want to turn on RGB Matrix for amazing effects in QMK. Even if there is no finished STM32, once the prototypes are built and I'm satisfied with this prototype round, it will go straight to GB. Cheers.
Offline Xury46
« Reply #136 on: Wed, 31 March 2021, 21:35:57 »
Wow that blue prototype is really stunning. The three knob design is neat, but wouldn't it be hard to use them with them all so close together?
Offline UGunaLOSE
« Reply #137 on: Sun, 25 April 2021, 14:02:35 »
Oh my knob.. So cool, looking forward to more updates.
Offline Jefff
    • jlabs.co
« Reply #138 on: Mon, 26 April 2021, 15:03:32 »
Those engravings have some awfully sharp internal corners which aren't machinable. You should probably change those to filets.
