Author Topic: [IC] Trifecta, Prototype Pictures in Comments  (Read 147482 times)
Offline ilemondrop
Re: [IC] Trifecta
« Reply #50 on: Wed, 06 May 2020, 23:22:29 »
I was just thinking that more than one encoder would be a cool idea, great to see it in action!
Offline YMwoo
Re: [IC] Trifecta
« Reply #51 on: Thu, 07 May 2020, 00:30:21 »
I'm working on allowing it to be keyswitches and encoders so one has the choice for one or the either and we are moving the encoders so there is more space for fingers to turn them.
awesome! it looks great so far!
just few other questions:
  • Asked this previously, but just in case, is it possible to include foam?
  • I know you wrote that GB and Price are still undecided but is there any estimation you able to share? just want to plan out but will understand if you still can't say anything just yet
Offline swiftrax
Re: [IC] Trifecta
« Reply #52 on: Thu, 07 May 2020, 00:55:36 »
Foam between pcb and plate? or foam between the bottom of the pcb and the bottom of the case?
Offline yqliang
Re: [IC] Trifecta
« Reply #53 on: Thu, 07 May 2020, 01:05:10 »
Love it! will definitely get one if priced well!
Nightfox Zealios 65g | Input Club K-Type Halo True | CM Masterkeys Pro S MX Brown x Norbauer Case | SA Carbon | SA Hyperfuse | XDA MiTo Godspeed | DSA K Bares Miami Dolch | ePBT WoB
Want: Satisfaction 75 | Space65 | GMK Dot
Offline vsrnth
Re: [IC] Trifecta
« Reply #54 on: Thu, 07 May 2020, 01:17:33 »
Loving the design, an option for switches in place of the encoders is a welcome change.
You've mentioned in the OP that you plan on open sourcing this from the get go. I'm just curious how that will work?
You'll open source the case  and pcb once the gb is done? Or do you plan on doing that before the gb?
I'm joining the gb either way :)
Sent from my SM-G975F using Tapatalk
Offline swiftrax
Re: [IC] Trifecta
« Reply #55 on: Thu, 07 May 2020, 01:19:34 »
Design is currently being revised based on community feedback. Things are being changed and old versions can be found on github
Offline YMwoo
Re: [IC] Trifecta
« Reply #56 on: Thu, 07 May 2020, 01:44:07 »
Ideally both, unless it really affects the cost too much ofc. Tbh, I'm not sure myself but I think foam between pcb and case should affect the acoustic more?
Offline 2Moons
Re: [IC] Trifecta
« Reply #57 on: Thu, 07 May 2020, 04:21:56 »
That's a good question. As far as foam is concerned. Between the pcb and the bottom of the case will be an absolute must. Especially since this is top mount and hot swap. I'm going to include this foam with each Trifecta. Also, if you have suggestions on the type of foam, I would welcome any suggestions you might have.
Offline KRY2SOON
  • Divine Studios
Re: [IC] Trifecta
« Reply #58 on: Thu, 07 May 2020, 04:58:37 »
Blu :eek:
Offline 2003987
Re: [IC] Trifecta
« Reply #59 on: Thu, 07 May 2020, 05:04:58 »
I am digging the blue, it would be perfect if its one shade darker, probably samurai blue? Maybe a polished finish?
Offline 2Moons
Re: [IC] Trifecta
« Reply #60 on: Thu, 07 May 2020, 05:32:35 »
Blu :eek:
I'll take any pantone color suggestions you might have.  :thumb:
Offline YMwoo
Re: [IC] Trifecta
« Reply #61 on: Thu, 07 May 2020, 06:40:26 »
Awesome! Thank you so much for that. Totally excited for this.
Unfortunately for the type of foam, I'm not too familiar with that either. Hopefully someone else can chip in with the suggestions.
Offline Agilr
  • Never stop achieving
    • Discord Server
Re: [IC] Trifecta
« Reply #62 on: Thu, 07 May 2020, 06:48:14 »
Looks great 2Moons! Can't wait to hear more updates on this
Offline 2003987
Re: [IC] Trifecta
« Reply #63 on: Thu, 07 May 2020, 08:36:34 »
Blu :eek:
Not sure how others think, but personally I feel a little tired of the traditional (safe?) color offered by other Alice Layout?
Not saying I won't buy it even its traditional color but would love to see some other color variations, given your unconventional design.  ;) ;)
Just some random thoughts:
1. Prussian blue/ Samurai blue?
2. A bit unconventional, but maybe Vine Grape?
3. What about this tree peony?
4. What about Japanese red plum blossom?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: [IC] Trifecta
« Reply #64 on: Thu, 07 May 2020, 09:50:09 »
The new design looks great!
Much prefer this over the 3 encoders.
I'm curious how others feel but regarding the per-key lighting, I think even when splitting backspace, it's easy to solve the light bleed issue by putting tape or something over the middle LED. I know some might think of it as a low quality fix but it's easy and doesn't affect production methods so just one PCB can be made.
GON NerD TKL DTA Edition
Offline Jaltr
Re: [IC] Trifecta
« Reply #65 on: Thu, 07 May 2020, 09:55:04 »
Blu :eek:
I +1 the cherry blossom color! There's another Alice layout board with e-wine color (certainly not the same, but already "taken" so to speak)
Sent from my SM-J415G using Tapatalk
Offline 2Moons
Re: [IC] Trifecta
« Reply #66 on: Thu, 07 May 2020, 09:56:48 »
Blu :eek:
Blu :eek:
I'm loving this blue. I think pinks and purples are out though, unless many people ask for them. I would to stick with red, blue, black, E white, and Poly. It's really to keep the cost down more than anything.
Offline ACF101015
Re: [IC] Trifecta
« Reply #67 on: Thu, 07 May 2020, 09:57:35 »
Any chance of a soldered PCB?
Offline Jaltr
Re: [IC] Trifecta
« Reply #68 on: Thu, 07 May 2020, 10:02:09 »
Blu :eek:
Blu :eek:
Maybe you should do a poll with the colors above?
Offline swiftrax
Re: [IC] Trifecta
« Reply #69 on: Thu, 07 May 2020, 11:14:27 »
Blu :eek:
Same order as above rendered onto the case as best I could
Offline TopreMoon
Re: [IC] Trifecta
« Reply #70 on: Thu, 07 May 2020, 13:35:17 »
This is really cool! Unfortunately, I'm too vested into the HHKB layout / split backspace.
Offline airyimbin
Re: [IC] Trifecta
« Reply #71 on: Thu, 07 May 2020, 13:39:56 »
I love the design. In terms of the layout, I think traditionally the split spacebar has the right side with a longer key and the left a shorter one.
Also I would prefer having an FN key to the right of the left side spacebar. This would be possible if the split spacebar setup was flipped like I mentioned above.
Sent from my SM-N960U using Tapatalk
Offline swiftrax
Re: [IC] Trifecta
« Reply #72 on: Thu, 07 May 2020, 14:01:13 »
There is split backspace so you can have that little one
Offline Luciqueii
  • 【Luciquell & Co.】
Re: [IC] Trifecta
« Reply #73 on: Thu, 07 May 2020, 15:57:46 »
Wow interesting concept, good luck bro.
Offline logo4poop
  • Talk to me on discord @logoooo
Re: [IC] Trifecta
« Reply #74 on: Thu, 07 May 2020, 23:37:13 »
rgb bad, love u swiftrax
LCK75 so lit
Offline 2Moons
Re: [IC] Trifecta
« Reply #75 on: Fri, 08 May 2020, 09:58:24 »
  • Encoders Spread out.
  • Hot Swap or Soldered Option.
  • Sides cut to easily pick up.
  • Knobs or Switches on the right, you choose.
  • Knobs to come in 3 colors.
  • Most popular interest check colors rendered.
Offline Jaltr
Re: [IC] Trifecta
« Reply #76 on: Fri, 08 May 2020, 10:02:18 »
Awesome to see the options! Will there be knobs as an extra option to purchase separately? And will the knobs be special in any way (engraving, materials, or even a collab)?
Offline 2Moons
Re: [IC] Trifecta
« Reply #77 on: Fri, 08 May 2020, 10:05:38 »
There will be 3 different colors to choose from. You'll get 3 knobs of your color choice and it's up to you if you want to use them. That way you could always solder them on later instead of switches if you like. The encoder switches will not be hot swap.
I would like to Rama collab for special encoders, I will contact them.
Offline Jaltr
Re: [IC] Trifecta
« Reply #78 on: Fri, 08 May 2020, 10:08:17 »
Oh gotcha, maybe I'll get all 3, just for keepsakes.
Rama collab would be fire ;)
Offline Jaltr
Re: [IC] Trifecta
« Reply #79 on: Fri, 08 May 2020, 13:04:14 »
Hey 2Moons, do you have an idea of a vendor?
Offline xef
Re: [IC] Trifecta
« Reply #80 on: Fri, 08 May 2020, 13:40:00 »
« Last Edit: Fri, 12 February 2021, 21:39:44 by xef »
Offline swiftrax
Re: [IC] Trifecta
« Reply #81 on: Fri, 08 May 2020, 13:52:34 »
Vendor is BaseKeys which would be him
Offline YMwoo
Re: [IC] Trifecta
« Reply #82 on: Sat, 09 May 2020, 01:37:09 »
forgot to ask this previously but any plan for VIA support?
Offline FinalEleven
Re: [IC] Trifecta
« Reply #83 on: Sat, 09 May 2020, 02:30:05 »
That dark purple just tugged at my heart...I would be all in for that.
Offline 2Moons
Re: [IC] Trifecta
« Reply #84 on: Sat, 09 May 2020, 05:33:18 »
I would love to do VIA support. I will try my best to make it happen.
I would love to do Purple, Pink, and some other colors but I feel that for the first round, we should keep it simple. Although I'll be able to do one-off pantone colors for anyone who wants one eventually. The other nice thing about this project is that you can always take the files to a company to have it made for you because the files are open source. I think that's a great thing.
Offline gummybur
  • Keep calm and curry on
Re: [IC] Trifecta
« Reply #85 on: Sat, 09 May 2020, 11:34:50 »
New renders looking great! Just another suggestion from myself, the chin on the front of the board feels slightly out of place because of the relative sharpness compared to the rounded aesthetic the corners, encoder and side cutouts. Maybe you could try :
1. rounding out the chin at these 3 points to match how the rest of the board looks (the quasi alice by qlavier is an example)
2. Making the corners and side cutouts sharper and less rounded to match the chin, thereby making the encoders stand out more!
Sorry if I seem overbearing haha just really excited for this board!
« Last Edit: Sat, 09 May 2020, 11:37:05 by gummybur »
Offline BruceDinh
  • Explorer | Artist | Petrolhead
    • ORI CLUB
Re: [IC] Trifecta
« Reply #86 on: Sat, 09 May 2020, 11:36:52 »
wowwwwwww
Offline swiftrax
Re: [IC] Trifecta
« Reply #87 on: Sat, 09 May 2020, 12:41:52 »
Those 3 points are rounded but less aggressively
Offline chakkii
Re: [IC] Trifecta
« Reply #88 on: Sat, 09 May 2020, 13:49:19 »
only per key rgb or also underglow for the polycarb case? :)
Offline swiftrax
Re: [IC] Trifecta
« Reply #89 on: Sat, 09 May 2020, 14:22:11 »
As of right now per key rgb without underglow
Offline jollyeskimo
Re: [IC] Trifecta
« Reply #90 on: Sat, 09 May 2020, 21:01:13 »
USB-C?
Offline swiftrax
Re: [IC] Trifecta
« Reply #91 on: Sat, 09 May 2020, 21:20:34 »
Offline YMwoo
Re: [IC] Trifecta
« Reply #92 on: Sat, 09 May 2020, 21:40:59 »
Nice, this looking better and better each day.
You mentioned "for the first round", does that mean you are planning to have this as several round or even in-stock kind of thing?
Offline 2Moons
Re: [IC] Trifecta
« Reply #93 on: Sat, 09 May 2020, 22:54:26 »
Yep, I definitely think multiple rounds would be a great idea. First with regular colors, then with different pantones. Also after the group buy, my goal is to do custom orders for anyone who wants a custom pantone color.
Offline sangeth
Re: [IC] Trifecta
« Reply #94 on: Sat, 09 May 2020, 23:11:37 »
Really pumped to see this happen.  Huge fan of the Gothic70 and would love a high end with the same layout.
Offline mathewC
Re: [IC] Trifecta 5/10 Update
« Reply #95 on: Wed, 13 May 2020, 05:08:07 »
Probably has been asked already but what price range are we looking at?
Verzonden vanaf mijn iPhone met Tapatalk
Offline sumbody
« Reply #96 on: Wed, 13 May 2020, 08:15:03 »
Is there room for a design modification?
I feel the symmetry is quite off with the current layout, partially due to right side mod blockers being thinner.
The Arisu seems to have a better balance with the thicker right blocker.
https://github.com/FateNozomi/arisu-case
Maybe a top down render with keycaps so we can judge better?
Keep up the good work and can't wait to see this enter GB.
EDIT: After looking at it more, maybe its the chin? The chin is relatively smaller compared to even the traditional TGR Alice. The angled corner usually starts from the left/right blocker rather than the current design. Someone above pointed this flaw with the circled parts for reference
« Last Edit: Wed, 13 May 2020, 23:59:35 by sumbody »
Offline SMOKEY
« Reply #97 on: Thu, 14 May 2020, 05:21:30 »
Love it! I'm in for a PC variant, if priced "ok-ish" ;)
Offline swiftrax
« Reply #98 on: Thu, 14 May 2020, 11:56:36 »
I didn't try to make it symmetric
Offline bukowski
« Reply #99 on: Thu, 14 May 2020, 13:30:01 »
Is the plan for the knobs to be made by RAMA as well?
