Author Topic: [IC] 6key Macropad  (Read 8729 times)
Offline uqer1244
[IC] 6key Macropad
« on: Mon, 25 May 2020, 07:42:58 »
E-white
Some Silver
Just Gray
At first, I made this model to 3D print and wiring my own.
1. This model is for 3D printing.
2. I have testing model again and again by using 3D printer.
3. I want to make this to aluminum, but I think that's out of my control.
4. At first i think i just glue those parts but It's not hard enough to use....I need another way to attach those parts.
5. Using ATMega32u4 arduino (with QMK or other keymapping programs) and custom designed PCB.
« Last Edit: Mon, 01 June 2020, 08:04:22 by uqer1244 »
Offline consumer
Re: [IC] 6key Macropad
« Reply #1 on: Mon, 25 May 2020, 08:43:02 »
Count me in
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #2 on: Mon, 25 May 2020, 08:44:46 »
How about 4 screws going through the plate from the bottom so it cant be seen?
Offline uqer1244
« Reply #3 on: Mon, 25 May 2020, 08:53:02 »
4 screws start to bottom and go through plate and the upper?...Thanks! I'd try it
Offline yui_
« Reply #4 on: Mon, 25 May 2020, 11:07:02 »
any details on pcb/connector/firmware? looks interesting, glwic.
Offline Ensaum
« Reply #5 on: Mon, 25 May 2020, 11:11:11 »
Love it. I'm in.
Offline kolec94
« Reply #6 on: Mon, 25 May 2020, 11:12:16 »
What’s the controller going to be?
I’m in
kbparadise v60 blues
Offline uqer1244
« Reply #7 on: Mon, 25 May 2020, 17:40:26 »
I think about any ATMega32u4(with QMK on)controller that usually used in wiring, custom kbdlayout.
If i could, I want to design own PCBs.
Offline tavidayo
  • I see you okay?
« Reply #8 on: Mon, 25 May 2020, 21:30:58 »
This looks great! Depending on pricing I'm in.
Offline sohju
« Reply #9 on: Mon, 25 May 2020, 21:46:03 »
+1  for me. This looks rad!
Offline amarotea
« Reply #10 on: Mon, 25 May 2020, 22:55:27 »
oh you brought it to GH. Nice. I want one
Offline enjoidis
« Reply #11 on: Tue, 26 May 2020, 01:11:06 »
Looks awesome! I'd be down for this if you sort out the "keep it together without glue" issue as well as getting a PCB. Not everyone have the want to hand wire, even if it is for a 6 key macro. It does look pretty sweet though, I'll keep checking back to see the progress if you decide to take it further.  :thumb:
Offline hottrout
  • I'd Hit Dat Key
« Reply #12 on: Tue, 26 May 2020, 02:41:15 »
This is pointless, small, cute and probably expensive.  Where can I get one?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline uqer1244
« Reply #13 on: Tue, 26 May 2020, 07:46:00 »
I need to design PCB and I am studying about it
As possible, I think about Arduino controller with bluetooth module (to use it wireless)
Offline daftswanson
« Reply #14 on: Tue, 26 May 2020, 10:40:24 »
Would absolutely be interested in this!
Offline youreyesonly
« Reply #15 on: Tue, 26 May 2020, 17:00:49 »
ditto
Offline enjoidis
« Reply #16 on: Tue, 26 May 2020, 23:42:30 »
Yeah, that would be pretty awesome having a wireless macro! I don't know if anyone has tried that before, none that I've seen before anyways... You'd have to sort out a battery option then, but I'm sure there are plenty of cell phone batteries that could work in a small form factor like that. I'd most likely see what's out there and try and work the "attaching everything together" situation around that. In my head, you might be about to attach everything with just one screw on left side. PM me if you'd like me to draw up my idea, I'm a graphic designer so it shouldn't be a big deal.
Offline Dyto69
  • 420 blaze it but dont forget 69
« Reply #17 on: Wed, 27 May 2020, 07:14:37 »
Oh yes i like it. Im searching for a nice Macropad a while now but i dont wanna spend to much on this so this could be a nice opportunity!
Offline uqer1244
« Reply #18 on: Wed, 27 May 2020, 10:08:43 »
Next week, I'll receive the 3d printed sample and 'll think about that problems....
Also I need to re-design it to add the solution of attachment problem
Thanks for your advices and attentions...
Offline riterdando
« Reply #19 on: Wed, 27 May 2020, 15:21:13 »
Very interesting. Looking forward to new updates.
Offline CrlaoSvloadr
« Reply #20 on: Fri, 29 May 2020, 16:13:10 »
Wonderful idea, and an even better design- hoping for more updates on this!
