Author Topic: [IC] SA Nightlight | GB IS LIVE  (Read 40843 times)
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« on: Mon, 20 July 2020, 10:32:49 »
    --> GB THREAD HERE <--
    US - Kono.Store
    EU - CandyKeys
    CA - DeskHero
    OC - DailyClack
    AS - ThicThock
    GB Date runs from September 22nd to October 30th!!!!!
    Official Site Here!
    Introduction
    Hello everyone, thank you for clicking on this! I would like to introduce SA Nightlight, a set inspired by me waking up in the middle of the night and looking out the window and thinking about life. The color way is what I remember seeing after I woke up. Also this project has been on and off for around the last four or five months.
    Colors
    The Colors are Signature Plastics ABS and the codes are BFM and BED, I'm also trying to make sure the colors match as close as possible!
    Kitting
    Vendors and Pricing
    US - Kono.Store
    EU - CandyKeys
    CA - DeskHero
    OC - DailyClack
    AS - ThicThock
    Collabs
    I have partnered up with thok.click and moonkeycap for 2 collabs, one is 2 metal artisans that both glow in the dark and a moon wrist rest to match your nightlight set!
    Renders
    More on the way! soon™
    rama m60
    rama u80
    More renders: More renders here!
    Change Log
    • Update #1 7/21
    • Rebranded to SA Nightlight
    • Replaced WIN with SUPER for maximum OS compatibility
    • Added 2 1.5u spacebars
    • Added a homing 5
    • Added an extra B for my special ladies in the crowd
    • Update #2 7/24
    • Added ISO Support for my friends across the pond
    • Deleted the 6u and 5.5u spacebars because SP does not have molds for that
    • Added 2.25 and 2.75 Mod colored spacebars for my Alice friends
    • Added a colored standard layout spacebar
    • Signature Plastics Chips being shipped to me so I can see some very noice colors
    • Update #3 8/06
    • Added extra " ' on ortho kit and expanded on ISO Layout
    • Added all vendors
    • Received Color Samples in the mail and they look great and what I envisioned
    • Kitting is starting to be finalized
    • Contacted Salvun about a possible Metal Keycap
    • Alpha Keyboards also contacted
    • Possible Cable Collab with Rocket Cables?
    • Update #3b 8/06
    • Moved 7u spacebar to Alt Kit and Added 1u shift
    • Switched Ortho tab esc for more planck compatibility
    • Replaced Home with Del
    • Changed R3 ortho blanks to Alpha colors
    • Added Numpad + to R3 and Numpad R2 -
    • Changed Changed R4 0 to R3
    • Update #4 8/12
    • Deskmat Added
    • Asia Vendor Finalized
    • Started Finalizing Kitting with Kono
    • Still looking for a metal artisan maker
    [liRocket cables collab[/li]
    [/list]
    • Update #5 9/1
    • Kitting Finalized
    • 4/5 Vendor Pricing Finalized
    • Working with Thok.Click on Metal Keycap
    • Rocket Cables Collab
    [/list]
    • Update #6 9/12
      • GB 10 Days Away!!!!!!
      • Thok.Click Metal Artisan
      • Moonkey wrist rest GB
    Some Questions Answered from the IC Form
    Q:Is there a mac version or only the "win" keycaps? A: I have switched win with super so you don't have to worry about it anymore
    Q:Make a key that has a whole moon. with as mch detail as possible. for the escape key :) or try and get a collab from rama to make a metal moon keycap :0 I love the moon man lets make this happen. A: Working on it and was part of my original plans, just have to contact RAMA a bit later in the process.
    Q:How much will the base set cost? A: Still working on it but may have the price between $70 and $120 for basekit, This is not whatsoever official.
    Q: Vendors? A:I may have a European and Canadian vendor on the way. Also still working on a US Vendor
    Q: ISO Support A: Since I am working on a Euro vendor, I have decided I will have a basic ISO Kit.
    Show your support by putting this in your signature!
    [/list]
    Code: [Select]
    [url=https://geekhack.org/index.php?topic=107592.0][img width=533 height=100]https://i.imgur.com/ZwqC5ij.png[/img][/url]
    Credits
    I would love to thank everyone in the Keycap designer Discord, they really helped me go through the design process, especially with my multiple identity crises that I went through while designing this. I would also like to thank the whole community mostly because all the key caps everyone inspires me to be creative and let it flow. It shows how a simple hobby can turn out to be a huge community of people helping each other with whatever they can, overall great community. Thank you
    Discord!
    Interest Check Form Here!
    Some specific people I would like to thank is
    Swishy (check out his KAM 80's after dark when that comes out)
    Pwade3 (for walking me through my idenitity crises)
    SGrumpyBunny (for a lot of help with many things)
    Bachoo (for helping with a lot of things as well, also gmkishtar.com)
    Note: Final Product may be different
    « Last Edit: Tue, 22 September 2020, 22:30:28 by thatkoaladoe »
    Offline yoot
      • none
    Re: [IC] SA Moonlight
    « Reply #1 on: Mon, 20 July 2020, 10:36:06 »
    SA Mizu r2! In all seriousness, great looking set!
    Sent from my Pixel 3 XL using Tapatalk
    Offline cijanzen
    [IC] SA Moonlight
    « Reply #2 on: Mon, 20 July 2020, 10:36:07 »
    SA Mizu?
    Love the colours but when you put them together you are basically getting Mizu. Personally I love that modifier colour but perhaps you could pair it with something else or make it a monochrome kit?
    I’d love to see where you can take this!
    Edit: additionally, your wolf novelty is almost exactly the same as the DCS Midnight wolf novelty. Not saying don’t use it but just be aware of that.
    « Last Edit: Mon, 20 July 2020, 10:50:08 by cijanzen »
    Offline mydens
    « Reply #3 on: Mon, 20 July 2020, 10:38:20 »
    SA is dead......long live MT3
    Offline violeaf
    « Reply #4 on: Mon, 20 July 2020, 10:44:18 »
    Looks nice. ISO kit at all?
    Sent from my SM-G950F using Tapatalk
    Offline harlekein
    « Reply #5 on: Mon, 20 July 2020, 10:49:27 »
    That ortho kit leaves a lot to be desired.
    Offline kajahtaa
    « Reply #6 on: Mon, 20 July 2020, 11:15:02 »
    I'd love an ortho kit that matches alphas rather than darker
    Offline break
    « Reply #7 on: Mon, 20 July 2020, 11:56:25 »
    Love to see a SA interest check!
    +1 to folks commenting on the Mizu similarity. Your keyset also shares a name with another keyset in GMK.
    Offline ycanales
      • keybordist
    [IC] SA Moonlight
    « Reply #8 on: Mon, 20 July 2020, 12:07:14 »
    Are 6u spacebars doable? I thought there weren’t molds for that. I’d be glad to be wrong of course!
    edit: btw you probably mean 6.25u instead of 6.5u
    Offline IOVERCALLHISTIOCYTES
    « Reply #9 on: Mon, 20 July 2020, 13:04:03 »
    blues are reminiscint but are different than mizu. Name needs a change because of the corresponding GMK set. Make it, I dunno, SA Waxing Gibbous or something and carry on. I'm in for these colors when you run it.
    Offline vosechu
    « Reply #10 on: Mon, 20 July 2020, 13:50:54 »
    If you throw in 2 blank 1.5u keys you’ll get support for all the atreus keyboards (and there are many). It’s a small cost for a very large increase in potential buyers.
    Offline BapoDonu
    « Reply #11 on: Mon, 20 July 2020, 15:45:48 »
    2nd B ?
    Offline xkhol
    « Reply #12 on: Mon, 20 July 2020, 17:53:52 »
    SA Mizu?
    +1 to monochrome idea. The darker blue would make for a nice accent
    Offline bobgr8
    « Reply #13 on: Mon, 20 July 2020, 18:02:59 »
    looks good! Can we get 2x 1.5u Super Keys?
    Offline Zeelobby
    « Reply #14 on: Mon, 20 July 2020, 20:15:14 »
    Yeah... Gonna need a new name.
    Offline frostykoala
    « Reply #15 on: Mon, 20 July 2020, 23:53:23 »
    Done with that, will be updating tommorrow!
    Offline fabijolo
    • I like expensive plastic.
    « Reply #16 on: Tue, 21 July 2020, 00:02:17 »
    I gotta say, I really love the novelties, but besides that, the set is (at least for me personally) way to similar in terms of colour to other sets that just ran/at coming up the next few months. Because of this I'd really appreciate to see some, at least slight, adjustments/changes to the colours.
    Offline olsen34
    « Reply #17 on: Tue, 21 July 2020, 05:11:08 »
    So now we have Mizu, Comet and Moonlight. I wonder which new sibling will appear next month.
    Offline Swishy
    « Reply #18 on: Tue, 21 July 2020, 09:26:14 »
    Interesting you say that we have a ton of bow and wob ICs, and each set you listed are very different from one another in theme and color.
    Offline frostykoala
    « Reply #19 on: Tue, 21 July 2020, 09:49:21 »
    Not planning on it but if I get enough interest, then maybe
    Offline frostykoala
    « Reply #20 on: Tue, 21 July 2020, 09:50:06 »
    Yup I meant 6u not 6.5, my mistake!
    Offline frostykoala
    « Reply #21 on: Tue, 21 July 2020, 09:50:32 »
    Done, in the spacebar kit!
    Offline frostykoala
    « Reply #22 on: Tue, 21 July 2020, 10:03:57 »
    Yeah there are similar colors. Also fixed the keycap set name!
    Offline olsen34
    « Reply #23 on: Tue, 21 July 2020, 11:42:53 »
    If the colors between those 3 keysets are very different to you, I'm interested in knowing what your perception of black and white to you. Super mega ultra delicious different or what?
    « Last Edit: Tue, 21 July 2020, 11:44:29 by olsen34 »
    Offline Swishy
    « Reply #24 on: Tue, 21 July 2020, 16:56:12 »
    I think they are very different for sure also there is another major difference out of the three one is a major copyright infringement waiting to happen and promotes stealing art while the other two are original and creative I'll let you decide what I am talking about!
    « Last Edit: Tue, 21 July 2020, 17:13:46 by Swishy »
    Offline vocal118
    Re: [IC] SA Nightlight (formerly known as SA Moonlight) (Updates 7/21)
    « Reply #25 on: Tue, 21 July 2020, 20:40:02 »
    defi in
    Offline frostykoala
    « Reply #26 on: Thu, 23 July 2020, 16:52:05 »
    Planning on it, I might've got an EU vendor so looking forwards to getting one.
    Offline Skelig
    Re: [IC] SA Nightlight (Updates #3 8/26) VENDORS WOOHOO
    « Reply #27 on: Sun, 09 August 2020, 16:01:30 »
    Late to the party but I'd defo be in for this.
    Offline vocal118
    « Reply #28 on: Sun, 09 August 2020, 21:44:49 »
    ilumkb?zf?
    Offline frostykoala
    « Reply #29 on: Tue, 11 August 2020, 10:04:20 »
    ilumkb?zf?
    For Asia I have thic thock currently.
    Offline Nudd
    « Reply #30 on: Tue, 11 August 2020, 10:42:17 »
    Watching  :thumb:
    Offline The.Ryan.Gamer
    « Reply #31 on: Tue, 11 August 2020, 10:42:27 »
    ilumkb?zf?
    Ooohhh. Thic Thock. I haven't tried to purchase from them yet. This might be the first. It's just Ilumkb is so much better to deal with, fast after sales, good shipping fee, under declare (by request) for customs tax purposes, etc.
    But i'll give it a try. This might look sick on Titan65
    Offline Stev!e
    Re: SA Nightlight (Update #5 9/1) GB DATES AND PRICING!!!!!!!!
    « Reply #32 on: Fri, 04 September 2020, 01:51:15 »
    I joined SA Mizu earlier this year, but this set also looks really nice. I think I have an addiction to blue keycap sets lol.
    Offline dandruff
    « Reply #33 on: Fri, 04 September 2020, 04:04:17 »
    Will you have a \| key that's the same colors as the rest of the mods? The `~ key has it in the alternate kit, but the \| is not there.
    Offline frostykoala
    « Reply #34 on: Fri, 11 September 2020, 07:58:52 »
    Sorry not this time, maybe next time :wink:
    Offline frostykoala
    « Reply #35 on: Fri, 11 September 2020, 07:59:18 »
    Who doesn't like some blue keycap sets :shrug:
    Offline konstantin
    • Formerly constexpr
    « Reply #36 on: Fri, 11 September 2020, 08:44:21 »
    That key in general isn't very commonly used, so it usually isn't worth including in kits.
    Offline paperassgasket
    Hey that's a pretty big update you got there.
    Where should we be keeping an eye out for links to the wrist rest / artisan?
    Do you know if those are limited?
    Offline Swishy
    I am very excited this has grown sooo much
    Offline frostykoala
    As of know and what I know the artisan will be run through vendor's site and the wrist rest will be hosted on Moonkeycaps site. That's all!
    Offline MIXO Cables
    would it be a bit too much if i ask for an accent colour XD
    Offline frostykoala
    Uh sorta late sorry!
    Offline kwhilden
    Re: [IC] SA Nightlight | GB IS LIVE
    « Reply #42 on: Tue, 22 September 2020, 10:49:21 »
    There's no spacebar kit on the Kono website.  Did that kit get dropped?
    Offline singabore
    « Reply #43 on: Fri, 02 October 2020, 09:26:42 »
    Offline boneandbee
    « Reply #44 on: Fri, 02 October 2020, 10:21:11 »
    Love the novelties and desk mat on this. It's simple yet really strong!
