Author Topic: [IC] GMK βeta - Launching August 28  (Read 56245 times)
Offline Vadurr
  • Valar Morghulis
Re: [IC] GMK βeta
« Reply #50 on: Mon, 20 July 2020, 23:27:58 »
color me interested in weebkit
Offline fabijolo
  • I like expensive plastic.
Re: [IC] GMK βeta
« Reply #51 on: Mon, 20 July 2020, 23:55:22 »
For me to consider this set, it'd definitely need Alice support.
But besides that, it is already banging, great job Hiney :thumb:
Offline hineybush
  • student of error
    • hineybush keyboards
Re: [IC] GMK βeta
« Reply #52 on: Mon, 20 July 2020, 23:58:10 »
To whoever begged for split spacebars in the form replies...
Regarding split/extra spacebars, OG Spacekeys will be running in a few weeks on my site, so you can get L9 spacebars from that.
https://geekhack.org/index.php?topic=100618.0
Offline fabijolo
Re: [IC] GMK βeta
« Reply #53 on: Tue, 21 July 2020, 00:03:54 »
Thank you sir, didn't catch the message previously.
Sorry for being a little dumb dumb :)
Offline kema
  • Designer
    • kevinmadesign
Re: [IC] GMK βeta
« Reply #54 on: Tue, 21 July 2020, 00:22:07 »
Super in for the regular alphas with red accents, GB soon pls 😤
Also would love a R4 1.25u Caps Lock if possible (for those that like to swap caps and control)
« Last Edit: Tue, 21 July 2020, 00:54:37 by kema »
Offline Mr_BeastQuake
    • Reddit
Re: [IC] GMK βeta
« Reply #55 on: Tue, 21 July 2020, 01:07:12 »
Both sets are good looking, I like the JS Hi-pro colorway a lot.
I’ll publicly request a couple windowed keys for caps and some 1u.
Offline MyManMart
Re: [IC] GMK βeta
« Reply #56 on: Tue, 21 July 2020, 01:13:47 »
Hiney only drops bangers. Looks very good as always!
Offline lakeboredom
Re: [IC] GMK βeta
« Reply #57 on: Tue, 21 July 2020, 02:10:58 »
Why you gotta go and make a classic looking set like that man!!! I can't be buying so many god damn keycaps  :D
Offline hottrout
  • I'd Hit Dat Key
Re: [IC] GMK βeta
« Reply #58 on: Tue, 21 July 2020, 03:06:41 »
So much love for the UK ISO included in the base kit.  For that reason alone I will be buying.  An alternative MOD set might be a nice addition.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Shikada
Re: [IC] GMK βeta
« Reply #59 on: Tue, 21 July 2020, 03:11:21 »
So it's just a very classic colorway with orange accents?
The JS one looks nice and clean if you're into that. I like the choices made in the base kits.
Am I missing something? Is the hype just because it's hiney?
Offline befbef
Re: [IC] GMK βeta
« Reply #60 on: Tue, 21 July 2020, 07:10:03 »
In for JS Base.
What I would like even more:
- R5
- CP instead of L9
- P3 instead of RO2
Offline kolyz
Re: [IC] GMK βeta
« Reply #61 on: Tue, 21 July 2020, 07:37:13 »
Love the JS Base!  :eek:
Offline tommyhongg
Re: [IC] GMK βeta
« Reply #62 on: Tue, 21 July 2020, 08:03:33 »
Both base kits are very nice. Great job :thumb:
Matrix Magic3 | Frog TKL
Offline kidviddy
    • 駄日記
Re: [IC] GMK βeta
« Reply #63 on: Tue, 21 July 2020, 09:50:06 »
In summary, these are the suggested changes for the JS kits:
  • Add R1 `~ー
  • Add R3 #~む
  • Change R4 \|む to \|ろ
  • Change R1 -_ほ to -_ほー
  • Change R1 0(わを to have a large を sublegend
I agree with these recommendations.  The last two are required to make even the ANSI layout correct, which should probably be a minimum bar, and as for the first three -- while they wouldn't go so far as to offer full support for JIS keyboards (which I would love, but unfortunately would require a much more extensive kit) -- they would at least allow for correct placement of alphanumeric and kana characters on JIS keyboards, meaning that only the punctuation is off. I believe the same is true of ISO boards, although I will defer to konstantin there as he has done more research on the state of kana input on non-JIS boards than I have.
Offline jerrolds
  • Discord "jerrolds | deskhero.ca#0379"
    • Deskhero.ca
Re: [IC] GMK βeta
« Reply #64 on: Tue, 21 July 2020, 10:25:50 »
Oh no - i need this now. BETA was life as a kid, too poor to buy VHS when my family bet on the wrong horse.  Movie selection was so bad.
Offline _rubik
Re: [IC] GMK βeta
« Reply #65 on: Tue, 21 July 2020, 10:47:15 »
  • Add R1 `~ー
  • Add R3 #~む
I remember folks waging this war for GMK Laser as well. I completely agree that full JIS support would be amazing, I think it's in less demand that NordDe etc...
Offline nu_types
  • Formerly Iredeus
Re: [IC] GMK βeta
« Reply #66 on: Tue, 21 July 2020, 10:50:31 »
Any chance you could add a 2u shift?
Offline OtherAndrew
Re: [IC] GMK βeta
« Reply #67 on: Tue, 21 July 2020, 14:02:55 »
  • Add R1 `~ー
  • Add R3 #~む
I agree with the last two suggestions as well, along with adding ¥ to \|む
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK βeta
« Reply #68 on: Tue, 21 July 2020, 14:06:32 »
We used to pile in a car and drive 15 miles to rent movies for a weekend as that was where the beta selection was. Still have beta transformers tapes...
Offline roostrc0gburn
  • its just plastic
Re: [IC] GMK βeta
« Reply #69 on: Tue, 21 July 2020, 19:15:55 »
  • Add R1 `~ー
  • Add R3 #~む
less demand than NordDe is very close to zero
Offline kmba
  • Formerly tameone
Re: [IC] GMK βeta
« Reply #70 on: Tue, 21 July 2020, 20:29:21 »
I am an alpha dog.  I do not support this.
keyboards.
Offline mcmaxmcmc
Re: [IC] GMK βeta
« Reply #71 on: Tue, 21 July 2020, 21:12:35 »
Base kit compat is great. Mod-colored tilde and pipe would be nice to have, but I guess you omitted them on purpose, which is fine.
The proposed JS base, if that is preferred to the smaller JS add-on:
The JS add-on and JS base kits are missing the R1 `~ー, R3 #~む and R4 \|ろ keys needed for JIS and ISO. The JIS-only 半角/全角 key is present, so it would make sense to include these as well.
The R1 -_ほー key is missing the ー quaternary (top-right) sublegend used on ANSI JP layouts, which these kits are based on.
The R1 0(わを key has a small を quaternary sublegend when, in fact, it should be regular size (like the わ below it) since a small を character doesn't exist in hiragana. (This has been a common mistake in hiragana kits ever since GMK Serika.)
  • Add R1 `~ー
  • Add R3 #~む
All molds exist / will exist by the time this gets quoted. References:
Kana sublegends reference
Standard ANSI JP layout
GMK Bentō R2 base kit
GMK Mecha-01 base kit
Hope this helps.
Edit: added missing links
Edit2: updated Mecha-01 link
I agree with you completely.  I'm tired of JP sets not properly supporting JIS like it should be.
In therms of the set... Great colorway, probably going to be a buy. :)  Can we also have some smaller spacebars?  I think JIS should come with smaller spacebar for all the mods the layout has.  That'd be a nice addition.
I'm still a bit weary of the ETD of the set and the terrible QC though...  but this looks great.  Hopefully it'll look great out of production too!
Offline hineybush
  • student of error
Re: [IC] GMK βeta
« Reply #72 on: Tue, 21 July 2020, 21:13:19 »
  • Add R1 `~ー
  • Add R3 #~む
Hope this helps.
OG Spacekeys (running in August) is the answer to smaller spacebars
Offline hineybush
  • student of error
Re: [IC] GMK βeta
« Reply #73 on: Wed, 22 July 2020, 12:53:47 »
Updated the vendors listing!
US - Switchmod.net
EU - Oblotzky Industries
Canada - Deskhero.ca
SEA - iLumKB
Oceania - Daily Clack
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
Re: [IC] GMK βeta
« Reply #74 on: Wed, 22 July 2020, 17:35:02 »
They call him... Betamax!
It's a lovely colourway, I love that retro style.
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline kimchijody
Re: [IC] GMK βeta
« Reply #75 on: Thu, 23 July 2020, 01:42:36 »
YO HINEY THIS IS FIRE
All hail 90s weeb base.
Offline funderburker
Re: [IC] GMK βeta
« Reply #76 on: Thu, 23 July 2020, 07:39:10 »
Ok, i need this.  :eek:
Keyboard design by Skepur
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: [IC] GMK βeta
« Reply #77 on: Thu, 23 July 2020, 07:45:36 »
Offline udller
Re: [IC] GMK βeta
« Reply #78 on: Thu, 23 July 2020, 11:39:05 »
i like this. most likely will buy :)
Offline snelltrail
Re: [IC] GMK βeta
« Reply #79 on: Fri, 24 July 2020, 02:14:05 »
JS base pls.
Also pls consider adding the beta key to the JS base coz all weebs are betas.
Offline ttom
  • Formerly tvaro
Re: [IC] GMK βeta
« Reply #80 on: Fri, 24 July 2020, 12:01:13 »
normally I'm not into weeb sets but that js base got me feeling some kinda way
Hoarder Collector and designer
Classifieds
Offline maximize
Re: [IC] GMK βeta
« Reply #81 on: Fri, 24 July 2020, 16:28:41 »
The set looks great, but, uh... Pardon me... You have a favorite cassette tape sleeve?
Offline hineybush
  • student of error
Re: [IC] GMK βeta
« Reply #82 on: Fri, 24 July 2020, 16:36:35 »
you don't?
Offline Hyphen
Re: [IC] GMK βeta
« Reply #83 on: Fri, 24 July 2020, 16:54:01 »
I'm definitely interested in the JS Base option. That set takes my vote.
Offline surfmurder
  • MILK
Re: [IC] GMK βeta
« Reply #84 on: Sat, 25 July 2020, 12:03:26 »
βeta so nut
Matrix 1.2og - IDB - Ogre
Offline Sshimosawa
Re: [IC] GMK βeta
« Reply #85 on: Sat, 25 July 2020, 14:24:42 »
Wow. This is great.
Offline desipalen
Re: [IC] GMK βeta
« Reply #86 on: Sun, 26 July 2020, 09:06:16 »
That's a neat idea. I always enjoy seeing what inspired the colorway.
Offline ThePanduuh
  • Discord @thepanduuh
Re: [IC] GMK βeta
« Reply #87 on: Sun, 26 July 2020, 10:13:01 »
hiney beta?
I have some keyboards, mostly resin.
I like CAD. Making things is fun. [W] Projects
Offline koenoe
    • My YouTube channel
Re: [IC] GMK βeta
« Reply #88 on: Sun, 26 July 2020, 17:26:53 »
I need this
Re: [IC] GMK βeta
« Reply #89 on: Sun, 26 July 2020, 20:15:51 »
this is a keyboard hobby we're all weird bro
Offline Rayndalf
Re: [IC] GMK βeta
« Reply #90 on: Sun, 26 July 2020, 22:02:56 »
Here's a similar photo in worse lighting with L9, U9, N9, CR, and V2
Offline noodleman
Re: [IC] GMK βeta
« Reply #91 on: Mon, 27 July 2020, 08:44:46 »
Just noticed the JS kit is missing the red R4 1u Fn key.  Will that be added to the kit?
Re: [IC] GMK βeta
« Reply #92 on: Mon, 27 July 2020, 09:23:21 »
Any more renders planned? Would like to see what it looks like on a more realistic render of silver or grey.
Offline Oblotzky
  • Backspace is for people that make mistakes.
Re: [IC] GMK βeta
« Reply #93 on: Mon, 27 July 2020, 09:32:56 »
Working on more renders
Offline mimalik
Re: [IC] GMK βeta
« Reply #94 on: Mon, 27 July 2020, 09:46:24 »
That JS is giving me tingles in all the right places.
Offline MdotMaxson
Re: [IC] GMK βeta
« Reply #95 on: Mon, 27 July 2020, 10:11:40 »
Damn. Those stock colors are a carbon copy of the beta tape.
Offline djmantis
Re: [IC] GMK βeta
« Reply #96 on: Mon, 27 July 2020, 16:28:10 »
Does the fact that this is stock colors mean that this can "jump" the current GMK wait time?
Re: [IC] GMK βeta
« Reply #97 on: Mon, 27 July 2020, 16:35:41 »
Just 8 months and two pushbacks instead of 11 and being Dracula’d.
Offline hineybush
  • student of error
Re: [IC] GMK βeta
« Reply #98 on: Mon, 27 July 2020, 16:49:43 »
good one lol
yes, there should not be a color matching phase as the colors are all stock GMK colors. I do not think it will "jump" anything in the queue as those orders were placed before this one will be.
  • its just plastic
Re: [IC] GMK βeta
« Reply #99 on: Tue, 28 July 2020, 11:32:45 »
good one lol
GMK won't actually put you into the production queue until all the vendors have submitted their purchase orders - after the gb period
