Author Topic: 【IC】JTK 夜桜 NightSakura (2020-11 GB )  (Read 201449 times)
Offline Shinigamii
Re: 【IC】JTK 夜桜 NightSakura (2020-11 GB )
« Reply #250 on: Sat, 24 October 2020, 23:37:57 »
Really digging this set, is JTK a different profile from the cherry profile? I think I have heard it was slightly different, but I cant remember
Offline atlanticise
« Reply #251 on: Sun, 25 October 2020, 01:50:56 »
super hyped, can't wait!
Offline dandruff
« Reply #252 on: Sun, 25 October 2020, 04:38:28 »
I would just like an make an append to my post talking about the ISO UK keys. I think it would do us Europeans more justice if a NorDeUk kit was made instead of including ISO UK keys into the base pack with options for both hiragana sublegends and latin only legends. I'm really not happy with the idea of having inconsistent keys where i'll be missing hiragana on several keys leaving me with gaps across the board. I hope for a response from someone.
I'm sure it's just an oversight in the renderings, but that's been pointed out since day 1 and zero acknowledgement from JTK in almost 3 months. Quite disappointing.
Obviously, I can not speak on behalf of JTK, but I did work with them for a little and understand how their ICs are ran. The designer of this set is not an English speaker or is at least uncomfortable running an IC to English speakers, so JTK felt obligated to post the IC on behalf of them to the forum.
As for if JTK relayed the message to the designer regarding ISO UK/NorDeUk or if the designer never gave a response, I do not know. However, from the looks of it (and this is my opinion and is not backed up), if there was an update regarding kits, it most definitely should have been updated. I feel that it is quite unlikely that those kits will be provided; however, I could be wrong. I do know JTK is more active on discord, so maybe reach out there!
Offline elisyan
« Reply #253 on: Sun, 25 October 2020, 04:45:19 »
Echoing what has been said, would like to see black "| \" and "~" on latin alpha kit and R2/R3 PgUp/PgDn for 65/75% compatibility.
The red on pink color takes away from the relaxing nature of the keyset and I feel like white or a dark grey would work much better.
I would like to see alternate icons for caps lock and 1.5U backspace as well, or even just text legends "Caps" and "Backspace".
The darker sublegends suggested looks really good.
I hope to pick up a set regardless if these changes are implemented, but I do think the compatibility for 65/75% is most important.
Offline saintnoodle
« Reply #254 on: Sun, 25 October 2020, 13:27:09 »
I was able to get in touch with rifen through someone else at CMM.Studio and it appears that he did raise this concern already with JTK. The issue is that JTK simply does not have the moulds to carry out this process and I think JTK would expect rifen to pay for these moulds himself so unfortunately nothing can be done about it. This is how I understand the situation anyway.
« Last Edit: Sun, 25 October 2020, 13:28:46 by saintnoodle »
Offline JT Keycaps
« Reply #255 on: Sun, 25 October 2020, 20:27:18 »
I never ask designer to pay for anything sir. I just share profit with them.
Offline Kumataka
« Reply #256 on: Sun, 25 October 2020, 20:30:53 »
This set looks clean definitely want in on the group buy
Offline JT Keycaps
« Reply #257 on: Sun, 25 October 2020, 20:37:39 »
we add so many pgup and pgdn(all cover R1~R4) into this set. For the 1.5u backcpase, we add legends "backspace " too, but this set uses icon modifier, so it will still use the old key.
For the design, it depends ont the designers, not me sir.
Offline JT Keycaps
« Reply #258 on: Sun, 25 October 2020, 20:37:54 »
For the layout, we will update before GB start.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #259 on: Tue, 27 October 2020, 13:11:38 »
Per the OP (quote below), this set will be JTK's CA profile.  CA = Cherry profile, same as what GMK uses.  Small details might vary between manufacturers (surface texture, edge breaks, etc.) so they may not be exactly the same as GMK's.  JTK also makes HSA profile = "Half-height SA."  I've labeled JKT's pictures:
Hello everyone, I am coming to bring you a new set called "夜桜 NightSakura".
Designer: rifen
Manufacturer:JTK
Profile: JTK CA double/triple shot (hiragana, 2 same color)
vendor/agent:
discord: https://discord.gg/QgUgkM5
Offline paysen
« Reply #260 on: Wed, 28 October 2020, 10:07:44 »
So no NORDE planned?
Offline JT Keycaps
« Reply #261 on: Fri, 30 October 2020, 10:42:32 »
renders update now.
Offline nvh2092
« Reply #262 on: Fri, 30 October 2020, 13:58:23 »
renders update now.
Nice to see the new added keys, also the black ~` key is gonna be R1, right? Because in the render it's R2
Offline nvh2092
« Reply #263 on: Fri, 30 October 2020, 20:27:41 »
renders update now.
Also, can you add 1u R4 Fn key to the base kit, you already have 1.25 Fn key.
Offline redrobin2980
« Reply #264 on: Fri, 30 October 2020, 21:15:36 »
Looks fantastic sir im sold!
Offline miaiji
回答: [IC]JTK桜樱花 (2020-11 GB)
« Reply #265 on: Fri, 30 October 2020, 21:54:01 »
Why is there a 1U PgUp of R4, shouldn't it be a 1U Fn of R4? Is this a rendering error? It's incredible!
Also, can R2's 1.5u Backspace be modified to R1's Backspaced? It looks more coordinated!
Offline aotoki
« Reply #266 on: Sun, 01 November 2020, 03:15:05 »
the set was not supposed to be availalbe today ? :/
Offline YeeticusTexacus1
« Reply #267 on: Sun, 01 November 2020, 18:15:48 »
Any update on how soon the group buy might start?
Offline Surostu
  • switchkeys.au x keyboardfinder.com
    • keyboardfinder
« Reply #268 on: Mon, 02 November 2020, 22:17:17 »
Well im keen, getting every set!
« Reply #269 on: Mon, 02 November 2020, 22:28:50 »
i think friday? last i heard
Offline xarly06
« Reply #270 on: Tue, 03 November 2020, 13:56:34 »
Dark grey JTK trays for the set. Image from the official Discord Server.
« Last Edit: Tue, 03 November 2020, 13:58:39 by xarly06 »
Offline regionfree
« Reply #271 on: Thu, 05 November 2020, 08:24:53 »
How many years will it take JTK to ship this?
Offline xarly06
« Reply #272 on: Thu, 05 November 2020, 23:50:55 »
They said about July 2021
Offline peachie
  • keycap enthusiast, dreams of designing
« Reply #273 on: Fri, 06 November 2020, 22:48:39 »
TKC is claiming March 2021 on the official GB page, as of today.
..... so yeah, probably somewhere around July, perhaps later pfff.
Foxlab Key65       TMO50          MOJO60
Offline peachie
« Reply #274 on: Fri, 06 November 2020, 22:59:11 »
so so glad to see this made it to GB-- and so quickly, too :0!
I gladly placed my order for the base, novelty, and pink spacebar kits already on day one heheh. The free JTK key cases included are also a really great touch, looking forward to this set for sure~
Offline njrobb
« Reply #275 on: Sat, 07 November 2020, 01:24:48 »
Love the colours! That deskmat is super nice too. Hope the GB goes well for you!  :D
Offline Surostu
    • keyboardfinder
« Reply #276 on: Sat, 07 November 2020, 01:27:19 »
i know Buddha hasn't updated the front page yet, but if anyone wants to order from OCE/Australia, the link can be found below from Switchkeys
https://www.switchkeys.com.au/collections/keycap-collections/products/jtk-night-sakura
Offline DonkeyD
« Reply #277 on: Sat, 07 November 2020, 04:38:52 »
can you please share the pantone/chinese equivalent colors with us?
Offline Ustinj
« Reply #278 on: Sat, 07 November 2020, 14:47:49 »
was looking to buy on TKC this morning . is there really no HHKB control?
Offline ZongZiWang
« Reply #279 on: Sat, 07 November 2020, 15:59:56 »
Several comments previously suggested HHKB compatible legends but since JTK has no molds for them previously, there won't be HHKB control or right 1u fn key.
Offline slyr586
« Reply #280 on: Sat, 07 November 2020, 17:03:03 »
Wait, ****, for real?? I hadn’t even noticed this. I remap basically every board I have to have control instead of caps lock. I realize it would just be the wrong cap, but that is going to bother me SO much. Definitely can’t put it in my HHKB style boards then with no Fn key either. Sad....
Offline ZongZiWang
« Reply #281 on: Sat, 07 November 2020, 18:17:18 »
You can still use “end” on the same row, or 1u “alt”/“ctrl”/“super” which is basically same profile
Offline Ustinj
« Reply #282 on: Sat, 07 November 2020, 18:53:33 »
damn.
thank you for confirming. I had JTK WoB and it had HHKB compatibility, so I assumed this would as well. I love this set's  colors, but what a massive bummer - can still get around it by using novelties for ctrl / fn, but ideally I would've been able to do it with the base alone. ty!
