Author Topic: What Antivirus do you use?  (Read 74257 times)
Offline yui
Re: What Antivirus do you use?
« Reply #50 on: Tue, 22 December 2020, 08:02:36 »
against targeted attacks, nothing does anything, against automated attacks it does at least blocks what it knows to be malware, it is why i do consider it as above nothing, with nothing you can get infected by even the oldest and simplest viruses, so yes i do agree that it is not enough to be safe, but then nothing is so where do you draw the line?
Offline Leslieann
« Reply #51 on: Tue, 22 December 2020, 08:31:06 »
Blocks malware?
What kind of an idiot malware maker ignores the basic default OS protection? Who's it going to infect?
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline yui
« Reply #52 on: Tue, 22 December 2020, 08:34:29 »
Blocks malware?
well every older malware that existed before it, and peoples aiming for older machines, that have not been updated because too important to have downtime for update, or idiots that disable it outright because it make the pc slower, the number of potential infection is smaller but not 0 and some can be rather juicy.
Offline yqqdrasil
« Reply #53 on: Tue, 22 December 2020, 14:03:23 »
When I was younger I remember trying a few AVs like Norton and McAfee but got super annoyed with the updates and notifications to purchase ****.
I don't think I've used a single AV, not even MWB or CCleaner in over a decade. I just don't download sketchy stuff/click on random links.
Offline yui
« Reply #54 on: Wed, 23 December 2020, 02:04:34 »
CCleaner will do absolutely nothing against any malware, not its job, and well your computer will, without you asking it, download stuff from sites you never heard off, those things are called adverts, and can be compromised to contain a payload, so you will browse a completely normal and safe site (ex. The Guardian or any site with ads) and randomly can get infected with no fault from the site or you, well some fault from you for running no AV but not the point, only because the advertisement agency did not properly check the ads (and it does somewhat happen often, even did to google not too long ago).
there exist some free AV that are less intrusive with asking you to buy, from my experience Comodo is pretty good with not being too annoying(although have not used it in years so maybe has changed) and ClamAV is an opensource AV engine that does not have any paid version, but it is kinda meh, it was built to check emails not run continuous on a pc, but still better than having nothing at all.
Offline yqqdrasil
« Reply #55 on: Wed, 23 December 2020, 11:32:16 »
Yes I'm aware CCleaner isn't that type of program, I was just making the point that I don't use programs like that to 'Protect against x' or 'Increase performance' etc.
I'm also aware you can get infected from no fault of your own, but I still don't see any free AVs protecting you from something like that. I might be wrong, maybe you've been saved numerous times by adding that extra layer of protection.
Offline Leslieann
« Reply #56 on: Wed, 23 December 2020, 21:00:40 »
Web pages can link to hundreds of sites in the background.
How modern AV's protect you against a lot of that stuff is not with a patch, it's with proxies, firewalls and DNS, they simply block your system from contacting it in the first place. This is why Norton and others started implementing firewalls into their products and became more invasive. Your browser also more than likely also does some of this and it's probably saved you far more times than you will ever know. You can also use these systems to act as a privacy system to hide from your ISP as well as get access to these dns systems without using the AV, adguard is a popular one.
AVs do however block certain code from running and it's not just that they block code, they they can block different code. While many AV makers share a database of exploits, most also run their own independent labs analyzing and finding ways to block this stuff so not all are created equal. Some gain protection for exploits earlier than others, some do not block as much older stuff... They all have their pros and cons.
Fire up something like Ublock Origin and Privacy Badger and then hit up a few random websites, better yet, hit up popular news sites and take a look and see just how many different domains your browser is accessing without you knowing, not to mention how many companies are tracking you.  I've seen websites have 250 blocked items on a singe page, I've also had a website hit me with 700 cookies for tracking purposes.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline yqqdrasil
« Reply #57 on: Thu, 24 December 2020, 00:56:37 »
Never heard of Privacy Badger before so I'll check that out, but I've definitely seen uBlock with a few hundred blocked items on some webpages - not really something I've paid a ton of attention to however.
I've had piHole running for almost a year though.. I haven't logged into the admin interface since I installed it so I don't know if theres any interesting analystics to see there, but it does a pretty good job, especially on mobile devices where there aren't much options for adblockers (especially iOS devices).
Offline yui
« Reply #58 on: Thu, 24 December 2020, 04:57:24 »
i have a few times ran into bad adverts on good site that had gotten blocked by one of my AV, it is somewhat rare though, and well it was blocked so i do not know what it would have done
and i tried to run privacy badger but it never seemed to do much, although it may be because noscript was also running, i have seen sites with about 250 blocked domains in noscripts, only once mind you and i do not remember what it was... and my noscript is set up so that it blocks everything by default, and i add exceptions as i go, so even some of googles domains are still blocked
and yeah pihole will help, but it only is a blacklist, if something is not in it it becomes useless (like windows defender)
Offline andy55
« Reply #59 on: Wed, 06 January 2021, 12:22:40 »
I use free antivitrus Avast for a few months already, works well
Offline Leslieann
« Reply #60 on: Wed, 06 January 2021, 21:46:01 »
Privacy Badger doesn't work like any of the others, it notices extraneous sites that track you and after it sees it a third time it then blocks it but it only works after Ublock, Noscript and Pihole have been used.
If you already use a whitelist then PB will not do anything for you. Ublock also should also be almost useless.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline yui
« Reply #61 on: Thu, 07 January 2021, 00:45:13 »
well then yeah it is why it was doing a whole lot of nothing :) i thought it would run before noscript as i installed it before it but seems like it does not. although even with noscript ublock still does some work, especially on youtube where is sometimes blocks 2k+ ads, my pc is too old for all those ads...
Offline shortdog6
    • Casper Keys
« Reply #62 on: Wed, 20 January 2021, 22:33:01 »
Kaspersky
Offline DELLA KEY
  • Formerly 'AFA STUDIO'
    • https://en.dellakey.com/
« Reply #63 on: Wed, 14 April 2021, 19:08:42 »
I use AVAST as a recommendation from people. Okay and good.  :thumb:
Offline BlueberryIsHere
  • Formerly KaptainKitsune
  • Just a normal guy
« Reply #64 on: Fri, 04 June 2021, 07:41:01 »
If you really need an AV I recommend MalwareBytes and ByteDefender. You can go without an AV (what I do) assuming you aren't stupid and don't download everything you see. Assuming you are on Windows, they have a built in AV (Windows Defender) that does a serviceable job.
I was told to put something here.
So I did
Offline kizuna
« Reply #65 on: Sun, 13 June 2021, 07:51:29 »
When I used to run windows, I used Spybot Search & Destroy and malwarebytes. I never ran antivirus and it seemed to me it was a lot more likely to get malware then a virus. I have gotten malware but never a virus on a windows pc.
Offline sapisoi
« Reply #66 on: Thu, 15 July 2021, 12:42:14 »
windows defender all the way   ;D
Offline foxieze
  • i like code.
« Reply #67 on: Fri, 23 July 2021, 16:35:29 »
Not really using any AV at the moment as switched to Arch Linux a little while back, and just relying on the fact there is a very minimal amount of virus targeting Linux systems.
« Reply #68 on: Fri, 23 July 2021, 18:37:45 »
Just as long as you install security updates regularly ...
Offline Leslieann
« Reply #69 on: Fri, 23 July 2021, 23:02:14 »
I'd argue even an out of date Linux install is far more safe than Windows, especially if behind a hardware firewall like you have in your router/modem.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline geauxflying
« Reply #70 on: Wed, 04 August 2021, 20:22:22 »
I like Sophos. It’s fairly unobtrusive and stays out of the way, and if you have a lot of computers the licensing is great. I can cover 10 computers with my subscription. I think I’m using 7 of the licenses.
Offline ollir_
« Reply #71 on: Thu, 19 August 2021, 06:44:19 »
Moderna
« Reply #72 on: Sat, 21 August 2021, 03:39:24 »
Offline SBJ
  • Tactile pls
« Reply #73 on: Sat, 21 August 2021, 03:49:58 »
Well since switching to Linux I have been using ClamAV to scan some directories every month or so.
So far no problems. :)
Offline yui
« Reply #74 on: Mon, 23 August 2021, 06:22:37 »
from my experience it seems like most big linux distros have some kind of virus/malware detecting and mitigation out of the box anyhow, with strong firewalls, LXC, apparmor etc. and with most virus squarely targeted at windows it makes it safer, still JS malware is completely portable often across all OS and architectures, so still not foolproof (JS or other web based vectors are somewhat popular because they can attack anything, from phones to cars to desktop to fridges with no discrimination)
oh and i came across qubesOS, a security through virtualization oriented distro, can be interesting.
Offline Burgo
  • Burgo's Computing Solutions
« Reply #75 on: Tue, 31 August 2021, 20:45:21 »
Bitdefender Total security
Computer Repair | Northern Tasmania: https://burgoscomputingsolutions.com.au
Offline Leslieann
« Reply #76 on: Tue, 31 August 2021, 23:48:39 »
Stuff like that has faaaaar less ability on Linux and even Mac compared to what it does with Windows or phones.
The trouble with Windows and phones is app control is minimal and it can ride that app's permissions, and since few actually close programs or reboots (and Chrome likes to restore your session, once it's in it will be there a looong time just hoovering info. The worst for this is probably Chrome because if the malware can set itself as an extension it can also propagate across all of your logged in Chrome installs on all devices. This was a big deal not long ago when an ad vendor starting buying long trusted extensions and injecting ads into them. Suddenly people were getting ads allover, removing the extension command didn't propagate, so you removed it on desktop then you'd use your phone and it would reinfect the desktop because you still had it installed on your phone, just a repeating loop. I believe they fixed the delete propagation but installing will still spread across devices.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline maybejari
    • Honkertown Studio
« Reply #77 on: Sun, 12 December 2021, 15:24:04 »
I personally use Malwarebytes.
Offline germpy
  • and most importantly, home depot tools.
« Reply #78 on: Sat, 18 December 2021, 11:19:06 »
malwarebytes has always done the job for me, and i use it with fairly good results in cybersecurity competition. i heard tronscript is good for assisting seriously screwed up computers though.
« Reply #79 on: Sun, 19 December 2021, 02:14:31 »
MS Defender forced another update that broke my system overnight. It's super cool how Win 10 tracks my least used times and updates then, also cool how turning off updates does nothing, and very cool how it's baked into Win 10 and you cannot remove or replace Defender. And what I really love is when it does take an update without your permission even though you told it not to, Win 10 holds your internet hostage until you reboot and install the unwanted update.
Offline Leslieann
« Reply #80 on: Sun, 19 December 2021, 09:51:22 »
If you use an alternate (such as Avast) it disables/replaces Defender.
It won't completely disable it, it still gets updates but for the most part it's non-functional, it's certainly not scanning anything.
It's frustrating when the software I dropped (Avast) because it was disobedient (scanning files even when "disabled") is actually more obedient than Defender, but that's the current state of Windows.
BTW,
If you think Win10 nannies you just wait for Win11, it's much worse and I'm willing to bet Win12 will be worse still.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline vkeycaps
  • Artisan keycaps maker
    • Website/Store
« Reply #81 on: Sat, 12 February 2022, 05:13:48 »
Is this even a common occurrence to find virus on Linux?
Offline Leslieann
« Reply #82 on: Sat, 12 February 2022, 10:05:27 »
Extremely rare to non-existent due to how Linux handles vulnerabilities, so long as you don't give something root/admin and keep up to date, odds of an antivirus ever doing anything for YOU is extremely rare.
The biggest reason for running an antivirus on Linux is if you run W.I.N.E. and/or to protect other systems (Windows) on your network, it may be idle and you may be immune but all it takes is some Windows user to see it and get a bit curious and now you have a virus running through your Windows machines (or W.I.N.E.).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline vkeycaps
    • Website/Store
« Reply #83 on: Sat, 12 February 2022, 22:39:12 »
Never thought about W.I.N.E from that perspective. I am not an expert tho
Offline dankthropod
  • Formerly wariomale
« Reply #84 on: Wed, 16 February 2022, 02:02:39 »
Linux is my antivirus
KEEBS: Niz atom TKL, KBD67 Lite V2 R3 with gateron black inks
AUDIO: beyers dt 880 pros with a k3 DAC. Really want to get my hands on some sennies hurr durr six hungos
Offline Tastenplatte
« Reply #85 on: Fri, 25 February 2022, 05:06:03 »
Do you still use windows for stuff?
Offline Leslieann
« Reply #86 on: Fri, 25 February 2022, 09:14:15 »
That's where it gets tricky and it varies greatly but getting better every day.
Very few with anti-cheat work on W.I.N.E. but most others can (Valve is making progress here).
Sometimes it's easier than Windows to install and backup games and sometimes the performance, especially older games, can be better than in Windows, other times it is an absolute nightmare to get working, might run slower and whether it works at all can depend on multiple variables; what version of W.I.N.E., what GPU driver is in your repo, and even more sketch, what compositor you're running. Wayland is still not well supported by W.I.N.E. and even when it works a simple update can break it.
Some Steam games are quite easy, like the Borderlands series, I think it's like one minor change to the start command to get running, takes all of 30 seconds once you know what to do and it runs great after that. Some games are even native, like Left 4 Dead which runs great (of course).
I have one old Windows game (Command and Conquer series) that while it took a bit to get it working, now runs better and more stable than Windows and I've been using the same install for years on multiple installs by just backing up and copying over a single folder (no re-install needed), try that with Windows. GTA San Andreas is similar. The same happens with my my graphics editor (I haaaaaaate GIMP) and 3d rendering program, it's a simple copy paste to put them on any Linux system.
Compare that to Fallout New Vegas and 4, while I have gotten them to work, the first time was tough, second was easy (I took notes) and the third time I gave up after a few hours. The exact same install method that worked before no longer does and this is not uncommon. Performance was almost on par with Windows the first time but not quite there the second. GTA 5 and GTA online, Bioshock 1 & 2 were all minimal hassle and ran just fine, not sure how they compared to Windows but ran fine however Bioshock Infinite was a non starter.
I attribute most of these issues with my use of Wayland and since I have a spare drive, sometimes it's just easier to drop into Windows. If it's a new (to me) game, I try and get it to run in Linux as I'm probably going to be playing for a while and it's worth doing it to not dual boot all the time. If it's an older game I've beaten and just have an urge to play I will usually give it a shot but I won't spend hours on it because sometimes I only have a few hours to play in the first place so I just drop to Windows.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Versaknight
« Reply #87 on: Tue, 12 April 2022, 09:16:20 »
windows defender is fine imo.
Offline cherriehirzel
« Reply #88 on: Thu, 14 April 2022, 03:08:58 »
I use AVAST premium
Offline jacobalbertus1
« Reply #89 on: Tue, 19 April 2022, 13:42:59 »
i use standard windows defened most antivirus ends up pissing me off in the end
Model f 122 USB industrial paint (daily), model f xt inbox almost nos Ellipse approved, NOS model m ssk , Model F 77 for class (special needs I was told I had to use a mech or a key beeper by the school) model m 1391401 silver label ( this was a factory messup where they stuck a 139101 sticker on it and sent it with a ps/2) model m 1390131 model m unicomp industrial case modded  and a model f at
Offline granola bar enthusiast
« Reply #90 on: Wed, 20 April 2022, 12:33:33 »
i currently use Norton just for the reason that i have been using it since i got too active with computers, if I'm being fully honest it's a pretty bad antivirus and is constantly giving me ad's and saying "You have 2.38 GB of wasted space on your computer! Lets fix that up for only 15 USD a month!" or stuff like that trying to get me to buy more of their products.
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #91 on: Fri, 30 September 2022, 08:14:30 »
Just Windows Defender, personally.
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline ArchDill
« Reply #92 on: Fri, 30 September 2022, 10:24:14 »
When I got my first windows computer, a friend gave me the best advice... just don't click on links that you don't know what they are. I have lived by that rule and have never had a virus.
Offline Leslieann
« Reply #93 on: Fri, 30 September 2022, 12:03:21 »
That you know of.
The advice you got was true way back when, for viruses, it's not true today and hasn't been for a looong time due to other forms of malware which is far more common.
Today's bare minimum is to stay away from shady sites, use Defender, do a scan with something like Malware Bytes on occasion and run an ad blocker, Ublock preferred. Better still, get rid of Chrome and not use Edge, preferably while also using a tool to knock out Windows telemetry.
I would recommend you read through the rest of this thread.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
