Author Topic: What Antivirus do you use?  (Read 74247 times)
« on: Thu, 06 August 2020, 17:39:15 »
Tried a lot of free antivirus software and have never been pleased with any of them really.
What do you use and what other antivirus/security software have you used that you loved or hated?
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
Re: What Antivirus do you use?
« Reply #1 on: Thu, 06 August 2020, 18:07:03 »
I just leave Windows Defender on and it does the job just fine, at least as far as I can tell from the stuff it picks up, a few scans with tools every now and then and my knowledge of where to look in the registry for persistent stuff. Then again, I’ve also got an IPS running, so that helps too.
We ran Sophos across the estate at work, but found that Defender preformed equally well, for less money and at a lower performance penalty.
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline captain
« Reply #2 on: Thu, 06 August 2020, 18:08:36 »
There is nothing that will prevent COVID-19 other than staying away from other people and wearing your mask.
Tapatalk steals money then adds ads back in and demands more money!
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
« Reply #3 on: Thu, 06 August 2020, 18:27:13 »
Malwarebytes has been my main thing, and Windows built-in anti-virus has seemed to work pretty well. That said, I don't visit a lot of dangerous hot spots.
- D Trump 2026-10-24
« Reply #4 on: Thu, 06 August 2020, 18:48:32 »
I had a bad experience with them where I was unable to uninstall or get MWB to stop running actively in the background. It was preventing me from being able to reboot because it wouldn't shutdown and it would not allow an uninstall. I forgot what the solution was, but I swore I'd never use it again.
« Reply #5 on: Thu, 06 August 2020, 19:10:34 »
I use Revo Uninstaller and uninstall Malwarebytes perhaps once a year when and if it gives me trouble. Then I do what I want and then clean reinstall the newest version.
Offline 1391401
  • MX CLEAR
« Reply #6 on: Thu, 06 August 2020, 21:21:20 »
For all the new machines I buy I've basically made the switch over to ChromeOS (Pixelbook in 2018 and Galaxy Chromebook in 2020) and I don't really install antivirus (they advertise that it's not needed).
I use Chrome Browser or some form of Chromium Browser on all machines and install the typical privacy / adblocking extensions day one.
I use pihole and whatever the anti-malware cloudflare dns is.
For windows (gaming) I just use windows defender.  I do little browsing and almost no downloading of non-games in windows.
For linux I think I played around with clamav a few times mostly just so I knew how it worked incase I encountered it in the wild.
A lot of what I do is to minimize ads / bloat on the net but I think that combined with smart browsing patterns (no I didn't win that ipad) probably keep me pretty safe.
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline Leslieann
« Reply #7 on: Thu, 06 August 2020, 22:15:54 »
That's a false equivalency.
"I left my doors open and no one broke in so clearly I don't need to lock my doors." Just because it didn't happen at that time or you had no idea it happened doesn't mean it's just as good.
I've also mentioned this before...  All your eggs are in one basket.
If you crack Defender you crack Windows and since every Widows has Defender how large a target is it for hackers? Massive. This was an issue when Norton was on everything, if you broke Norton you had access to millions of systems, and it did happen, multiple times. It's only a matter of time before it happens again. And then there is the fact that it's Microsoft, who is know for shelving exploits unless it's a problem. Why? Because fixing them costs money.
Want more proof it's a screwed up system?
Why do you even need Defender? If MS knows of an exploit why not fix it instead of using Defender? Why do you need protection for a system they themselves make, does that make any sense at all? Defender wouldn't exist if MS did their job right so why are you trusting those same people to do this right?
Don't rely on Defender,
I'm not saying AVs are good, they pretty much all suck to be honest, but relying on Defender is basically just saying f'it.
Sorry, Jerry, I didn't mean to pick on you specifically, your post was just the one that prompted this.
« Last Edit: Thu, 06 August 2020, 22:17:42 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #8 on: Thu, 06 August 2020, 22:21:19 »
Certainly having WinDef and a 3rd party antivirus is the best bet
You'd think by now there would be some incredible open source independently developed option
Offline Leslieann
« Reply #9 on: Thu, 06 August 2020, 23:33:41 »
Almost all AV definitions come from one company and without the money to get access to that data you won't be as effective.
This also happens to be why one tends to not be much better than any other, the variances depend on how fast they get out new definitions. It's also why they all want to sell you a suite of security instead of just an AV, it's the only way to set themselves apart.
I'm sure some wonder why if they all use the same samples and definitions why isn't Defender a good choice? It goes back to targeting and all your eggs in one basket. Every Win10 install has it so if you target Win10 you have to target Defender, once you defeat that the rest of Windows doesn't have a chance.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #10 on: Fri, 07 August 2020, 01:47:36 »
I thought of it more as a ‘if work think it’s good enough, it probably is’ along with tests showing it had equal coverage. More recent tests appear to suggest that’s no longer the case, now that I do some research, and your point about the fragility of a wide base is valid so I will therefore adjust my solution. Thank you ^-^
Better a sacrificial goat than a schmuck ;)
Offline Leslieann
« Reply #11 on: Fri, 07 August 2020, 22:24:28 »
{cut}
Your work also may have a network wide anti-virus.
And thanks for understanding.  :)
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #12 on: Sat, 08 August 2020, 01:08:48 »
I mostly only get endpoint reports and it’s usually undergrads being injudicious with where they stick their USB sticks, so only see stuff from Defender via Security Centre. We have all the appliances you’d expect of a large network though, without going into specifics, so yes, there is that as well.
« Reply #13 on: Sat, 08 August 2020, 15:07:57 »
Tp4 just use dat Avast, cuz it's free.. and Tp4 needs all the money for gambling.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #14 on: Sun, 09 August 2020, 21:26:10 »
Spyhunter 4 for cleaning up
Just my thoughts
Offline captain
« Reply #15 on: Sun, 09 August 2020, 22:05:54 »
Ah, COMPUTER viruses!  I just stay off the dark’net and don’t run much pirated software. I agree that it’s pretty ridiculous that Microsoft makes an antivirus program instead of just patching their broken operating system. Which reminds me that I need to install Linux over the OS that came with my ThinkPad.
Offline Leslieann
« Reply #16 on: Mon, 10 August 2020, 00:10:17 »
That's not how it works.
One reason anti-virus became sort of a meh software was not because of Defender or Microsoft Security Essentials, it became largely irrelevant due to drive-by infections and side loaded malware.
Viruses in general are less popular today due to the cloud and email being used less (one of the larger infection points in the past), traditional viruses only account for about 3% of malware today. Drive-bys are done with ads, you don't have to click, all you have to do is see some of these and you get hit*. Most of these are purged when the browser is closed (Chrome never really closes), but a few can get their hooks into you and hang on.
Anti-virus has had to change, the problem is they often argue over who's responsibility it is, sure an AV scans files and email, but who should be blocking malicious ads and who decides what's malicious? Do you also scan for malicious browser extensions and side loaded apps, companies have been sued over this.  Funny how they can argue over who should protect against what but they all sure as heck scan for pirated software, with some not allowing you add an exemption or even disable the scanner. False positive? Aww too bad. Testing software, Oh well. I stopped recommending two major AV vendors over this behaviour, I refuse to let my computer or my customers computers be held hostage to them.
*Ad companies complain about adblockers (the most effectively way to stop drive-by infections), some claiming they are immoral and one even pushing for legislation to ban them. Google almost did but I think they realized how many would head to Firefox if they did, which would have been an even bigger disaster. Keep in mind, not once have IO heard of them paying to clean up an infection they caused so until they clean up their own act and are willing to pay to clean up my computer due to something they allowed onto their network they can take a long walk off a short pier, preferably into shark infested waters.
« Last Edit: Mon, 10 August 2020, 00:12:08 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #17 on: Mon, 10 August 2020, 04:54:15 »
Are any of these capable of busting through VM ?
Offline Maledicted
« Reply #18 on: Mon, 10 August 2020, 10:01:57 »
That's what I have used on every one of my personal computers, for years and years. The real-time protection is great. I have never needed it on my own systems, but the boot time scanner has come in handy as well.
I discounted Malwarebytes entirely for many years, but it appears that it has a real-time scanner now ... if you pay for it? If there's no real-time scanner, there's no reason to even have it besides for removal once you're already infected, if you ask me. I prefer to never get to that point to begin with.
Offline Leslieann
« Reply #19 on: Mon, 10 August 2020, 21:34:01 »
Avast is one of the ones I talked about above who held the system hostage by not actually turning off.
AVG refused to shut down background protection when I demanded it, Avast later bought AVG and then pulled the same stunt.
I needed to copy an infected file and they absolutely refused to allow that to happen even when I turned it "off", I had to uninstall both to make it happen.
Unacceptable.
I get it, the average user doesn't know how to deal with this stuff, but when you turn it off, it should turn off.
« Last Edit: Mon, 10 August 2020, 21:55:25 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leslieann
« Reply #20 on: Mon, 10 August 2020, 21:54:50 »
Drive-bys?
Probably not, if you have VT enabled and use the same OS as the guest (giving it the best chance) it may be theoretically possible, but most are pretty limited in capabilities. It's more likely to jump shared folders, however in this case it would still need execution.
Most virtualization happens on the server and if you're out cruising around online using the company hosting server you need to find a new line of work, might I suggest corporate sabotage. Making a drive-by to take advantage of it would be pretty pointless.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline JayZz
« Reply #21 on: Tue, 11 August 2020, 11:48:05 »
I use windows defender and malwarebytes.
Offline Darthbaggins
  • PC Cannibal
« Reply #22 on: Tue, 11 August 2020, 14:10:00 »
The one I use for all of my family members is ESET Internet Security (covers machine and home network)
Offline sharktastica
    • Admiral Shark's Keyboards
« Reply #23 on: Tue, 11 August 2020, 16:15:05 »
On Windows, I use Windows Defender, Malwarebytes and trusted browser security add-ons along with my attentive awareness and good judgement. On Linux, I just use trusted browser security add-ons along with my attentive awareness and good judgement.
Speaking more broadly than just viruses, I find that the best way to get away from relying on victory in the arms race between malicious programs and defences against them is to not occur such malicious programs in the first place. Sounds precarious, and of course, not everyone is 'streetwise' with using the internet... But I would say that in this day and age (and related to Leslieann's very valid point), having a modern web browser (ie, not IE) with sandboxing, good adblocker (I use uBlock Origin) and aggressive JavaScript policy will in fact grant a lot of protection by hiding things that you might unwittingly click or code that might steer you towards downloading a Pandora's Box of craptastical computer corruption. And if that doesn't work and you've been vectored by a 'classical' style of virus, then the two software I listed for Windows are good enough in my experience. I know that paid suites may have useful features for non tech-savvy people and I believe most get more frequent definitions updates, but I am not of that group and I'm purposely cheap with software to fund my hardware and keyboards.
In the past, I've used paid versions AVG, Avast, and Kaspersky at some point. My experience with them is at least 7 or so years out of date since I became cheap as aforementioned, but I never had terrible experiences with any of them but they were all quite bloated.
« Last Edit: Tue, 11 August 2020, 16:29:16 by sharktastica »
Offline Leslieann
« Reply #24 on: Tue, 11 August 2020, 22:11:16 »
If they were, 90% of techs would be out of work.
That alone cuts probably 80-90% of the garbage right there.
Beware though, once you use a good adblocker you won't be able to go back. I absolutely can't stand using the internet without one anymore, it's amazing the difference. The internet is a cesspool of ads.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Maledicted
« Reply #25 on: Wed, 12 August 2020, 10:21:58 »
Does the free version of Malwarebytes finally have a real-time scanner? I refuse to consider it an antivirus until it does. Was Avast already bloated 7 years ago? I think it is certainly still much better than most, even with its irritating nag popups telling you to upgrade. I miss the days of its original GUI, the one that looked like a stylized media player. It was so well optimized then.
Yup, on all counts. Ublock Origin misses some here and there too though, and consumes more system resources than if most ads were filtered out by a Pi-hole setup first.
« Reply #26 on: Wed, 12 August 2020, 12:26:27 »
True, but that shouldn't stop education IMO.
Ditto.
It doesn't, and I agree with your assessment. But it works well as strictly an anti-malware scanner that doesn't fight Windows Defender. IIRC, the bloat was coming but again, it's been so long I don't completely remember other than it wasn't a completely terrible experience.
I love Pi-hole! But from a mass consumer standpoint, if there's an ongoing struggle to get people using adblockers on their current browsers, what hope is there for them to buy a Raspberry Pi or old laptop to run Linux on and set Pi-hole up.
Offline Maledicted
« Reply #27 on: Wed, 12 August 2020, 19:56:02 »
Yes, fair. I have used Malwarebytes before on systems I already know are infected. It does a great job there. I seem to generalize the more popular antiviruses as being bloated. Norton certainly is the freaking antichrist in that regard, and my perception has always been that McAfee sucks in that regard too, but I'm used to seeing this on students' personal computers that have seen little-to-no maintenance for 5+ years straight, were often bottom-of-the-barrel even when they got them, and may even be infected anyway since half of them don't even know what an antivirus is and a huge chunk of them let the free trial that likely came pre-installed on their system lapse God-knows-how-long-ago. We use Kaspersky at work, which has always seemed very efficient, although it has its quirks. I tried to get them to go for the free Avast licenses and support for education but was shot down. Kaspersky has some wonderful management tools, so it makes sense.
There's 0 hope of that, but we've got quite a lot of tech people on here. Back when we were still allowing students to install extensions a year or so ago, I would still most commonly see adblock plus, and even that was uncommon. Ublock Origin was a unicorn.
Offline Maledicted
« Reply #28 on: Wed, 12 August 2020, 19:56:33 »
There's 0 hope of that, but we've got quite a lot of tech people on here. Back when we were still allowing students to install extensions a year or so ago, I would still most commonly see Adblock Plus, and even that was uncommon. Ublock Origin was a unicorn.
« Last Edit: Thu, 13 August 2020, 09:38:32 by Maledicted »
Offline Leslieann
« Reply #29 on: Wed, 12 August 2020, 22:22:05 »
You don't need a pihole to reduce the load.
Use Adguard DNS, plug these into your router DNS settings. Not as good as pihole but with ublock and this it's pretty close.
176.103.130.130
176.103.130.131
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Maledicted
« Reply #30 on: Thu, 13 August 2020, 09:43:22 »
176.103.130.130
176.103.130.131
That's tempting for the time being, since I am not even using my Pi and pfSense box at the moment, just a cheap old TP-Link router I have had for ages. A free service that helps you block ads you would normally see on free services is beautifully ironic.
I hadn't heard of AdGuard DNS, thank you.
« Reply #31 on: Sat, 15 August 2020, 10:26:21 »
Trying  out this adguard dns,   how do I know it's working though?
Offline Maledicted
« Reply #32 on: Sat, 15 August 2020, 17:23:08 »
I'm using it at home already now. It seems to work pretty well. I know it is blocking all of the ads in my mother's solitaire "app", which were previously only blocked by Pi-hole when I still had it up and running. There are adblocker test pages as well. google it and try a few. I noticed that Adguard left the advertisement elements in the page on the one I quickly tested with, but they were unpopulated. Turning Ublock origin back on after testing removed what remained, which is part of the reason I usually use Pi-hole in conjunction with the Ublock Origin extension, to grab whatever may slip through the cracks.
What I really should do is try casting Youtube to my tv some more, since there's basically no way to block those ads without a DNS solution.
« Reply #33 on: Sun, 16 August 2020, 07:41:10 »
Tested a few andod games, def blocking ads.  can't even click on the watch video buttons now. Kekekee.
Offline SBJ
  • Tactile pls
« Reply #34 on: Sun, 16 August 2020, 10:27:36 »
HitmanPro.Alert - it has performed pretty good so far in my tests.
Offline yui
« Reply #35 on: Thu, 27 August 2020, 05:06:51 »
from my experience i have used on Windows:
 avast, but since they added that keylogger i do not trust them anymore.
 AVG, but it was not that great.
 Comodo, do not install their browser but the antivirus is actually good.
 ClamWin, probably one of the worse at detecting "virus" but no shady company behind it.
 Windows Defender, from the test i saw probably not much better than clamwin but with a much shadier company behind it.
 Malwarbyte, only ever used it as a 2nd antimalware when i had doubt about my main one, seemed pretty good at the time better than AVG.
 Avira, seems to work fairly decently, detects web ad based "virus" in memory somewhat regularly.
 FortiClient, seems to actually not be as good at detecting resident stuff in memory than Avira.
And on linux i only used avast and Comodo as proper AV, with the lack of downloading executable from random sources i never had any detect anything, i am not quite sure if a proper antivirus is even needed with either SElinux or AppArmor
and the is a youtube channel specialized in testing AV, i think it is the PC Security Channel, may want to give a look https://www.thepcsecuritychannel.com/tests
and yeah TP VMs are not the be all end all of security, pretty much all of the intel security flaws can be accessed from inside VM in javascript as is row-hammer, so getting out of the VM and loading into system memory is at least in theory possible.
Offline Kavik
« Reply #36 on: Thu, 27 August 2020, 13:09:40 »
I use Avast. I'm not sure how I decided on it, maybe because the UI isn't too intrusive unless it actually blocks something. It does pop up wanting me to buy it every few months or renew my registration. It's not a problem for me, but it seems to confuse my mom every time it happens on her computer.
I think an adblocker is probably one of the best ways to avoid junk though. I've been using an adblocker for so long that I'm always very surprised what websites look like when I see them without one. How do people even use the Internet without one? Even legitimate websites have fake (or at least deceptive) download links sometimes or crap that pops into the exact spot I want to click as I'm clicking.
Offline SVanE
« Reply #37 on: Wed, 02 September 2020, 15:23:54 »
Got kaspersky, got a discount code 6 years ago , so it's just normal to have it for me
Sendt fra min SM-G950F med Tapatalk
Offline Leslieann
« Reply #38 on: Wed, 02 September 2020, 23:13:39 »
I don`t use it at all.
I think that it is possible to maintain pc without antivirus if you are not watching trash like porn,drug and gun websites and ESPECIALLY YOU ARE NOT following weird links. To check whether link is safe you must click on it with a right mouse button and go for the last option. Then you should use google for acknowledging if that link is safe or not. :-*
Not only is this wrong but you're basing it on bad information.
Porn is actually now one of the safest places online.
Years ago porn sites were terrible but they got tired of that reputation and actually got together and formed a coalition to vet advertisers, as such they became one of the safest ad networks online. Churches and small forums on the other hand have become a haven for getting viruses. Most church websites are run by volunteers who know nothing of online security and will accept any ad money offered. Internet security doesn't follow conventional norms. It used to be hackers did what people thought but automation has made that thinking pointless. You cannot hide through obscurity, that little mom and pop website no one would care to hack is now seen as an easy target and with automation and A.I. it's really easy to find and attack them.
Your "weird links" idea, same issue. Spammers and hackers have gotten wise to this, what, did you think they wouldn't? And now do all they can to obscure that, which is actually pathetically easy. And Google is not the end-all be-all authority on security, in fact they're one of the worst. They have almost zero human oversight on anything so when there is something missed or misidentified it can be quiet difficult to get it into or out of the system. Worse, once the scammers figure out how to bypass it it's a free-for-all, which is why CAPTCHA keeps having to change.
You are actually the worst person in terms of safety, you know more than enough to be dangerous but you don't yet realize how much you don't know.
I'll simply finish with this...
How do you know your system is clean? You've effectively buried your head in the sand.  Now if you were on Linux or Mac I could dismiss what you say, on them, that method of security actually works fine, but not on Windows. Windows has far, far too big a target on it's back along with Swiss Cheese security and a dumpster fire of an update system all handled by a company who really doesn't even care enough to properly test their updates.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline yui
« Reply #39 on: Thu, 03 September 2020, 00:56:25 »
true 5 to 10 years ago, no longer true, most of the **** you can get online nowadays is through JavaScript adverts on legitimate pages, so link checking is useless as the site itself is safe, just the ads on it are not, and by only loading the site you get infected (no need to click anything) as Leslieann said, porn is way too big for that to fly as should be google adsence but smaller ad agencies may fall/have fallen for it, still phishing links exist but are becoming rarer. and download and run viruses are almost non existent anymore. this is why anti viruses are important, and actually even on linux and mac, although less so with their much tighter security, as javascript, specter-like attacks and rowhammer are cross platform
Offline greys
« Reply #40 on: Mon, 07 September 2020, 05:59:22 »
I use ESET Internet security for a lng time and don't have any regrets. It works well
Offline SmoothFaces
« Reply #41 on: Sun, 29 November 2020, 19:27:40 »
been using the free version of AVG for most of my life it works just fine
Offline dgneo
  • Supervillain
« Reply #42 on: Sun, 29 November 2020, 20:49:04 »
defender
Offline noorejji
« Reply #43 on: Mon, 30 November 2020, 01:15:21 »
Common Sense 20
Jokes aside, I mainly filter web content as much as I can without breaking the pages. Both for security, privacy and sanity. With development moving so fast it’s hard to keep up on the latest, and it’s just depressing most of the time. Some amount of risk is inevitable when using the web. I’ve been thinking about using a Mac Mini for browsing and other light usage, but that’s a bit expensive right.
  • PC Cannibal
« Reply #44 on: Mon, 07 December 2020, 11:24:23 »
ESET is used on family members who's version Common Sense hasn't been updated yet. I just use Defender on the machines I use at work and am the sole user at home.  I don't click on things as much as my version of Common sense is up to date (for the most part).
Offline el_murdoque
« Reply #45 on: Wed, 09 December 2020, 08:00:54 »
My Win10 runs wide open with only the windows defender at default settings. Inside a VirtualBox, though. The physical computer runs Linux.
Offline PTRS
« Reply #46 on: Tue, 22 December 2020, 01:18:12 »
Windows Defender+brain
i dont click in sus links or download apps from no name websites
Offline Leslieann
« Reply #47 on: Tue, 22 December 2020, 01:26:45 »
Ahhh, the good ol' Ostrich approach.
Yeah, that doesn't work.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline yui
« Reply #48 on: Tue, 22 December 2020, 06:26:40 »
realistically nothing actually just works, i use 2 antiviruses + noscript and yet still got infected by a miner by connecting to a friend network, neither antivirus detected it, just the pc went rather slow and hot, and low and behold a process running 99% cpu at all time.
Windows defender is rather bad but still better than nothing.
Offline Leslieann
« Reply #49 on: Tue, 22 December 2020, 07:27:31 »
It's not better than nothing, it IS nothing.
Any attacker hacking Win10 will attack Defender at the same time as the os because they have to since it's integral to the system. It's not added security, it's baked in, it's the default. It's the same as relying on Win7 and Windows 8 stock security, all they did was add a fancy name to it. Is it safer than Win7 and Win8, well I would hope so considering those are 8 and 10 years old. If it wasn't better it means they learned nothing about security since.
You have been sold a bag of B.S.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
