Author Topic: [IC] KK64 keyboard kit [USB hub Design]  (Read 19916 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Tue, 11 August 2020, 05:21:26 »
KK64 Keyboard Kit Album: https://imgur.com/a/LUNms03
If you would love to receive an update, please fill in this IC FORM or Join our discord server HERE.
Spec:
Aluminum 6063
Type-C
Wired
Single backlight (Need to purchase and install switch LED yourself)
KK75 Software - Remap keys, Marco, Musical rhythm(Note: If we have over 100 orders, we will provide QMK version instead of KK64 software)
Support PCB Mounted Stabilizers
Keyboard Angle: 7.49 degrees(Angle adjustable with the slots)
Keyboard size: 309.18*149.57*34.66 mm
Case:
Angel White
Elegant Grey
Mysterious Black
Prussian Blue
Pink
Passionate Red
The standard kit comes with:
Aluminum alloy case * 1(Top Mount)
Non-hot-swap PCB * 1
Aluminum Plate * 1
Hub*1
Bracket*1
Price:
keyboard kit:US$220-US$250+Paypal fee+shipping fee
MOQ: No limit
Estimated GB: if we get positive feedback from IC, we will open the GB asap
If you have any suggestions, please feel free to comment.  ;)
« Last Edit: Wed, 12 August 2020, 20:44:00 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline Bonsa
Re: [IC] KK64 keyboard kit
« Reply #1 on: Tue, 11 August 2020, 05:31:05 »
wow
Offline piit79
« Reply #2 on: Tue, 11 August 2020, 05:40:27 »
Looks classy and pretty unique, I like it!
I wish more boards included USB hubs, that's very useful. Well done!
Offline huey
« Reply #3 on: Tue, 11 August 2020, 05:42:10 »
Interesting board, here are some points of consideration:
 - The adjustable angle is interesting but I think it's a bit of a brutal and jarring implementation, nor do I care much for the bracket.
 - The USB hub is certainly interesting and maybe useful/desirable for some, but I'm unsure if this is the target audience for them.
 - "(Note: If we have over 100 orders, we will provide QMK version instead of KK64 software)" Please don't use proprietary software. QMK/VIA is a community staple that is a standard in which most pretty much expected for custom boards. This also feels like you're holding it at ransom; Like if you don't sell enough, you won't bother.
 - This IC doesn't specifically mention what kind of mount it is, but I can see it is tray mount. I think a top mount would be a much better fit and looks like it can be achievable.
 - I'm skeptical at the price, though I hope it'll be achievable.
 - The LED slots(?) at the front of the board are a big no no in my eyes. The front bezel looks too thick to me and removing them would kill two birds with one stone.
« Last Edit: Tue, 11 August 2020, 05:44:36 by huey »
Offline marshskitow
« Reply #4 on: Tue, 11 August 2020, 06:41:29 »
I am surprised by the cost. Hope it’s true .
Is there iso ?
Envoyé de mon iPhone en utilisant Tapatalk
Offline danieljgrouse
« Reply #5 on: Tue, 11 August 2020, 07:07:36 »
The layout in the renders with keycaps and the renders of the plate don't match. What layouts does it actually support?
Offline fcoury
« Reply #6 on: Tue, 11 August 2020, 08:22:31 »
Love the design, my only wish was that you'd consider a regular ansi or tsangan layout instead of the 68 keys :)
Offline neutralstate
« Reply #7 on: Tue, 11 August 2020, 09:54:36 »
yup would prefer tsangan as well
edit: a sound test would be nice too!
« Last Edit: Tue, 11 August 2020, 10:05:03 by neutralstate »
Offline paperassgasket
« Reply #8 on: Tue, 11 August 2020, 12:09:14 »
Watching this one closely for sure. It's not often you get an integrated usb hub.
What's the front height of the board?
Offline chanceofthat
« Reply #9 on: Tue, 11 August 2020, 16:47:59 »
I wish the USB hub was Type C instead, if it were this would be a definite cop.
Offline john08099
  • Velocifire MK
Re: [IC] KK64 keyboard kit (USB hub design)
« Reply #10 on: Tue, 11 August 2020, 20:20:58 »
Thank you, we are actually considering to change one USB port to Type-c, then we will have 3 USB port, 1 more type-c port. How do you like this change?
Offline john08099
  • Velocifire MK
« Reply #11 on: Tue, 11 August 2020, 20:29:23 »
We are considering changing one USB port to type-c, you want more type-c?
Offline dibstern
Re: [IC] KK64 keyboard kit [USB hub Design]
« Reply #12 on: Tue, 11 August 2020, 20:44:48 »
Yes, +1 on this, also the USB hub on the left instead of the right doesn't make much sense when mice are almost always positioned on the right
Offline bball2
« Reply #13 on: Tue, 11 August 2020, 23:59:08 »
Looks super interesting, would definitely be in if you guys can hit that price range :-O
Offline kmao
« Reply #14 on: Wed, 12 August 2020, 03:05:07 »
I am in
Offline vaf1en
« Reply #15 on: Wed, 12 August 2020, 03:30:28 »
This looks interesting and is definitely one that stands out compared to other boards in IC.
I would like one.
Others have mentioned it as well, but I would like to second the motion that QMK needs to be guaranteed and not a 'maybe' hinging on some MOQ being met.
Offline geekit
« Reply #16 on: Wed, 12 August 2020, 05:37:08 »
I assume it's GK64 layout, with 2U left shift & 1U right shift.
Offline X_point
« Reply #17 on: Wed, 12 August 2020, 15:34:52 »
would be an instabuy with a tsangan/hhkb/wkl layout... I use the r-shift too often to change it to a 1u.. v interesting design though..
Offline Tvehelli
« Reply #18 on: Wed, 12 August 2020, 16:12:48 »
I am a fan of the overall design, but one thing I would prefer to see is the keyboard set at a set typing angle and allowing you to remove the bolts that poke out the side to then be flush with the case. Really hope you will go with QMK regardless of what the order number turns out to be. Overall if you manage to make it to that price point I would definitely like to try and get my hands on one so I'll be watching this one closely.
« Last Edit: Wed, 12 August 2020, 20:55:23 by Tvehelli »
Offline Tymm0
    • Teal Technik
« Reply #19 on: Wed, 12 August 2020, 16:22:56 »
Appreciate the unique design. Would be interesting to see what the bottom looks like and what mounting type as asked above. I do like the usb hub and changing one to USB-C would be a cool idea. Very neat to see a larger company interested in the custom space.
tealtechnik.com
Offline akira1883
« Reply #20 on: Wed, 12 August 2020, 20:18:35 »
what do you think about port for memory card reader??
Offline john08099
  • Velocifire MK
« Reply #21 on: Wed, 12 August 2020, 20:39:49 »
Top MOUNT ;)
Offline gorbachev
« Reply #22 on: Wed, 12 August 2020, 20:52:33 »
Very interesting, unique design.
Offline This_Neon
« Reply #23 on: Thu, 13 August 2020, 03:59:05 »
Do you know what an MOQ is??
« Last Edit: Thu, 13 August 2020, 04:08:18 by This_Neon »
Offline john08099
  • Velocifire MK
« Reply #24 on: Fri, 14 August 2020, 03:43:38 »
No MOQ. If MOQ over 100 orders, we will provide QMK version instead of KK64 software
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #25 on: Fri, 14 August 2020, 04:09:00 »
Why not just have qmk and via compatibility from the start. This would ensure you get more sales.
Offline VagueOrigin
« Reply #26 on: Fri, 14 August 2020, 05:22:12 »
Yeahhhh... don't quite get that one. Either use it or don't.
Sent from my SM-G975U using Tapatalk
« Reply #27 on: Fri, 14 August 2020, 19:39:36 »
very interested in this, but is there any prototype or typing test that we can see / hear?
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #28 on: Sun, 16 August 2020, 10:12:40 »
I really would have liked to see this design in 65% :(
Offline john08099
  • Velocifire MK
« Reply #29 on: Mon, 17 August 2020, 04:30:26 »
Not sure, we need to confirm the final design.
Offline Retne
« Reply #30 on: Mon, 17 August 2020, 13:30:05 »
I like the idea of having a USB hub on the keyboard but I'm not a big fan of 60%s.
Also I think you should just support QMK out the gate instead of trying to have it behind an MOQ.  Isn't it more work to make your own firmware than to use something already available like QMK unless you are using a non-supported MCU?
Offline ddrfraser1
  • RIP Neil
« Reply #31 on: Mon, 17 August 2020, 14:24:57 »
Whoa, this looks kick ass! Good job.  :thumb:
Offline john08099
  • Velocifire MK
« Reply #32 on: Mon, 17 August 2020, 21:08:51 »
QMK PCB requires a MOQ, but if using current one there will not have such requirement and can secure this GB will happen since we already have this software for previous kits. We will try our best to meet the MOQ or we just store some if orders are near MOQ :))
Offline TheBossWasHere
« Reply #33 on: Sat, 22 August 2020, 22:10:15 »
What is the actual layout of the board? The renders with and without keycaps show different layouts.
