Author Topic: Lube help  (Read 2012 times)
Offline Error213
Lube help
« on: Sat, 22 August 2020, 13:13:53 »
I saw in a previous post that I made someone said something about a brand of lube called finish line. Is their non aerosol wet lube safe for switches?
Offline jamster
Re: Lube help
« Reply #1 on: Sat, 22 August 2020, 21:01:44 »
Given that this is probably a bicycle chain lube that very few people in GH are familiar with (they'd have to be a bicycle enthusiast), you need to at least provide a product link, and preferably a link to the material data sheet.
Offline jamster
Re: Lube help
« Reply #2 on: Sat, 22 August 2020, 21:07:17 »
3 step process for rejecting lubes for switches:
Google the SDS sheet for the product name.
Do a word search in the pdf for "petroleum".
If the word turns up, don't use it.
« Last Edit: Sat, 22 August 2020, 21:09:50 by jamster »
Offline Leslieann
Re: Lube help
« Reply #3 on: Sat, 22 August 2020, 21:18:31 »
Spray lube is meant to be used in places where you can use it to flush out contaminants and coat with lube. There's no way to flush out contaminants in a switch without taking it apart. See the comments here:  https://geekhack.org/index.php?topic=108113.0
Also, you cannot properly lube from the outside. See here: https://geekhack.org/index.php?topic=107654.0
A for Finish Line, again, not a spray.
You want Finish Line Flouro Extreme, it's a bit thinner than Krytox 205 and a lot cheaper (very similar otherwise). You will still need to open the switch, you can't just apply from the outside.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Sup
Re: Lube help
« Reply #4 on: Sat, 22 August 2020, 21:49:01 »
At this point i think we should make a pinned post called don't spray lube your keyboard for god sake it will turn out for the worst or something lol.
« Last Edit: Sun, 23 August 2020, 12:31:46 by Sup »
current
Coming soon
