Author Topic: [IC] GMK Sunset Surfing (GB Live!)  (Read 53468 times)
Offline archerypro459
« on: Thu, 24 September 2020, 18:50:34 »
GMK Sunset Surfing (April 27th- May 28th)
Story and Inspiration:
This set was inspired by surfers like Greg Noll and the golden age of Hawaii big wave surfing. I wanted to pay tribute to the feelings of catching a wave when the only source of light is a beautiful sunset. I was also inspired by California and Hawaii surf culture, especially Malibu and Aviator Nation.
Vendors:
NA: Kono
Canada: Ashkeebs
EU: Mykeyboard.eu
Australia: Switchkeys
Asia: THIC THOCK
Shipping expected in April 2022
Base:
Mono Alphas:
40’s:
Spacebars:
Novelties:
Desk Mat:
by BubiDiBup
Board Renders:
Nemui by Bachoo
TGR Alice by Yuktsi
Rama U-80 by Rama Works
Sunsetter by DotMatrix
Vendors:
NA: Kono
Canada: Ashkeebs
EU: Mykeyboard.eu
Asia: THIC THOCK
ETA is late Q1 2021
Collaborations: Link
Custom Cable from Define Cables:
Special Thanks
Ashkeebs
Grtx
PRJKT_ (for renders and input)
Bachoo
Dicynodont
Everyone at the keycap designers discord
Join Discord for updates
https://discord.gg/eZcfpt2fXu
« Last Edit: Tue, 04 May 2021, 17:55:18 by archerypro459 »
Offline cijanzen
Re: [IC] GMK Sunset Surfing
« Reply #1 on: Thu, 24 September 2020, 18:54:49 »
Monochrome Yuri!
Offline Blastoise
« Reply #2 on: Thu, 24 September 2020, 19:47:09 »
Really excited for this set! Let me know if you need any help!
« Last Edit: Thu, 24 September 2020, 20:13:13 by Blastoise »
Offline darthcapn
« Reply #3 on: Thu, 24 September 2020, 20:10:09 »
In!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline depletedvespene
    • Keyboard-related resources.
« Reply #4 on: Thu, 24 September 2020, 20:26:45 »
Please take notice about the pipe character inconsistency — about half the \| keys use the proper vertical bar ('|'), while the rest use the broken bar ('¦'). Choose one or the other (the former, not the latter!), but don't use both to represent the same legend.
Also, R3 \|, yadda yadda yadda.
Offline Janoma
  • certified nerd
« Reply #5 on: Thu, 24 September 2020, 20:49:34 »
Call me blind, but I don't see inspiration from waves or sunsets at all :confused:.
To me sunsets are defined by a more gradient nature, and really so are waves.
If you want to stick with a more surfing theme, I suggest maybe adding a gradient of some sort to the keys or changing the colors a bit
Of course this is all my opinion, so take it with a grain of salt.
« Reply #6 on: Thu, 24 September 2020, 20:53:49 »
In!
Glad you guys like it!
« Reply #7 on: Thu, 24 September 2020, 20:54:31 »
Thanks for the input. I will fix right away
Offline DrHigsby
  • The doctor is in.
« Reply #8 on: Thu, 24 September 2020, 21:37:22 »
Your 40s kit needs 40s specific spacebars in it. Otherwise 40s users will HAVE to purchase base, 40s kit, and spacebars to cover their board (3 kits for 1 small keyboard).
The 40s kit will need the following spacebars:
  • 1x 2u (two would be preferable, but you’ll want at least one)
  • 2x 1u
  • 1x 2.25u
  • 1x 2.75u
  • 1x 1.75u
I recommend looking at what GMK Deku did with its 40s kit as it was a good 40s kit.
« Reply #9 on: Thu, 24 September 2020, 21:49:22 »
  • 2x 1u
  • 1x 2.25u
  • 1x 2.75u
  • 1x 1.75u
I will look into that. Thanks
Offline psxndc
« Reply #10 on: Thu, 24 September 2020, 22:07:44 »
I liked the idea of the orange in each key being the sun hitting the little waves, but I was thinking  "where's the sun itself?" Maybe an orange num row or an orange F5 through F8 and pinkish F1-F4 and F9-F12 would give that vibe.
Ortho. Always.
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #11 on: Thu, 24 September 2020, 23:01:27 »
Loving this subdued colorway. It reminds me of the last ripple light before the sun fully drops over the horizon. I'd keep the colors as-is, and if people give more feedback on the questionable naming, maybe drop the surf angle from the name and just keep that as inspiration. "GMK Last Light" has a good ring to it.
Few observations/suggestions:
- Seems some of the legends at least in the Base kit render are mis-proportioned (ISO Enter, 1u Ctrl, 1u Backspace, for example)
- There seems to be extra 1u `~ and 1.5u \| keys in the Base kit
- I may suggest changing the extra Alphas kit to "Accent Alphas"; typically "Mono" alphas would be what is in the Base kit: alphas and modifiers that have the same cap color
- As a Mac and Tsangan guy, I enjoy 1.5u Code and an extra 1u Alt keys in the main kit, if possible
- Would also suggest a 1.5u Function key
Excited to see where this goes!
Offline IOVERCALLHISTIOCYTES
« Reply #12 on: Fri, 25 September 2020, 01:44:09 »
the alternative to putting split bars in the 40s kit is to add them to base and put some accent bars in the spacebar set. Keeping the accent bars with the accent alphas kit and adding split/1u/1.75u bars to the 40s kit makes the most sense if you've got the interest to run the accent alphas. I'd be hard pressed to believe a blue base kit won't hit 250 MOQ...
  • 🕸 developer
    • Discord
« Reply #13 on: Fri, 25 September 2020, 03:05:28 »
Has there been a set that ran with split spacebars in a base kit? Most buys I've browsed and been a part of have usually kept split bars in the spacebar kit. For example GMK Grand Prix has 40-related spacebars in the 40s kit, and spacebars had 6u center/off-center in base and accent colors.
It may also be worth playing around with 6.25u/7u spacebars in blue and accent orange in the base kit, sos every base kit gets the most popular sizes in both colors.
Offline Tom Sparrow
  • This is the way!
    • More stuff from me
« Reply #14 on: Fri, 25 September 2020, 04:20:06 »
Very nice colours, I am looking forward to have the waves on my desk!
Offline Surostu
  • switchkeys.au x keyboardfinder.com
    • keyboardfinder
« Reply #15 on: Fri, 25 September 2020, 04:30:07 »
Both vendors announced :thumb:
Would you consider dropping numpad to get costs down?
Offline Araset
« Reply #16 on: Fri, 25 September 2020, 04:32:49 »
Super nice! Consider Rama colab for artisans
Offline LZRD
« Reply #17 on: Fri, 25 September 2020, 05:32:06 »
I agree, would love to see numpad as a seperate kit!
« Reply #18 on: Fri, 25 September 2020, 07:52:38 »
Fixed!
« Reply #19 on: Fri, 25 September 2020, 11:54:59 »
GMK Oni, Belafonte, Lux, also the giant base kits from Matrix labs (GMK matrix, wild) have split bars in base. Been a recent thing...
Offline BirgusLatro
Re: [IC] GMK Sunset Surfing (New Board Renders)
« Reply #20 on: Fri, 25 September 2020, 14:51:59 »
Getting major Goku / DBZ vibes...  :thumb:
Offline kwhilden
« Reply #21 on: Fri, 25 September 2020, 15:55:49 »
Da Bull inspired. Nice
Offline Buburoo
« Reply #22 on: Fri, 25 September 2020, 16:15:05 »
Your base kit is a little scuffed...
  • Should be ¬/` instead of ¬/1
  • Duplicate 1.5 ANSI Pipe
  • Missing </> key for terminal ISO
  • Inconsistent legend sizes
  • Numpad enter is misaligned/trying to escape the key
  • CapsLock instead of Caps Lock
  • Prt Sc instead fo Prt Scr/Print
As others have pointed out as well inconsistent pipe/broken pipe & many of your keys are inconsistent sizes (Accent Esc for example)
I personally think this shows a bit of a rush job, which is disappointing considering how nice this colourway is.
« Reply #23 on: Fri, 25 September 2020, 16:28:33 »
Thanks for the feedback. It will all be fixed shortly. I'm glad you like the set!
Offline kwhilden
« Reply #24 on: Fri, 25 September 2020, 16:50:31 »
Also, what are your thoughts for the novelties? Hopefully they will be cool and authentic to surf culture. And not the cheesy stereotypes that non-surfers think represents surfing. Let me know if you want the thoughts of a hardcore surfer
« Reply #25 on: Fri, 25 September 2020, 16:59:12 »
Pm me your discord
« Reply #26 on: Sat, 26 September 2020, 23:16:28 »
Fixed!
Offline riku.
« Reply #27 on: Sun, 27 September 2020, 05:25:00 »
set looks nice.
is there an IC for that board, nemui?
Offline SMOKEY
« Reply #28 on: Sun, 27 September 2020, 13:15:27 »
Awesome set!
I, for my part, really would love to see the orange spacebars avail w/o having to buy the whole alt alphas kit.
« Reply #29 on: Wed, 30 September 2020, 09:41:30 »
Awesome set!
Thanks. For kitting, it looks like the orange kit will have alphas and f row and a Numpad. The orange spacebars will potentially be in the base.
Offline Contrakey
    • Contrakey
« Reply #30 on: Wed, 30 September 2020, 16:35:38 »
I wish I had orange accents on my desk so I could match this set but I still might consider buying.
Offline Surefoot
« Reply #31 on: Wed, 30 September 2020, 16:40:32 »
Orange highlights, this is not very common, i like this.
« Reply #32 on: Wed, 30 September 2020, 21:00:58 »
I love this! Orange and blue are THE BEST combo
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #33 on: Wed, 30 September 2020, 21:12:40 »
Love the orange.
Offline hark
« Reply #34 on: Thu, 01 October 2020, 02:05:24 »
This looks sick, I love the Mono Alphas :)
Re: [IC] GMK Sunset Surfing (New Board Renders/All vendors announcement)
« Reply #35 on: Sat, 03 October 2020, 18:03:46 »
Update: Decided on icon only mods so I got some new renders done. Also all of the vendors are announced. Currently working with 2 artists for desk mat and novelties respectively. Also doing a collab with Define cables. Have a nice rest of your weekend everyone!
Offline Fattysco
Re: [IC] GMK Sunset Surfing (New Board Renders/All vendors announced)
« Reply #36 on: Mon, 05 October 2020, 09:13:40 »
GMK Chicago Bears
Offline ponchofreedo
    • it me
« Reply #37 on: Mon, 05 October 2020, 18:08:26 »
Monochrome Yuri!
exactly what i was thinking
Offline 3yatt
« Reply #38 on: Tue, 17 November 2020, 10:41:08 »
So it was suggested in a their Discord channel, but I think we need to see a render of this on a Sunsetter with the orange badge. It's meant to be. Also, can we please get this put on MGB? :]
« Reply #39 on: Tue, 17 November 2020, 11:52:54 »
what discord channel? Also, I'll try to reach out to the creator of sunsetter. Maybe I can get a render ;D
Offline klementtan
« Reply #40 on: Tue, 17 November 2020, 11:59:48 »
Please consider 1.5u code for MacOs hhkb layout users
Offline cadrev
« Reply #41 on: Tue, 17 November 2020, 13:02:07 »
wow in for sure! my wallet is crying right now!
Offline 3yatt
« Reply #42 on: Sat, 21 November 2020, 20:23:50 »
 The Charue Design Discord. Do you have a way to get into contact? I can let the maker know :)
« Last Edit: Sat, 21 November 2020, 21:03:44 by 3yatt »
Offline 3yatt
« Reply #43 on: Sat, 21 November 2020, 21:02:35 »
« Reply #44 on: Thu, 03 December 2020, 06:51:20 »
Just added some beautiful board vendors done by the folks over at Kono. Check it out!
« Reply #45 on: Tue, 09 February 2021, 15:50:55 »
Hey guys, please join the discord for more updates on this set. https://discord.gg/7yF9MArwVa as the set is launching on April 6th.
Re: [IC] GMK Sunset Surfing (Deskmat Revealed)
« Reply #46 on: Wed, 10 February 2021, 07:50:51 »
Just released the deskmat. Take a look!
Offline azzipa
« Reply #47 on: Wed, 10 February 2021, 09:17:44 »
Just here to check out the swell and enjoy the nice offshore breeze  :thumb:
« Last Edit: Wed, 17 February 2021, 17:31:26 by azzipa »
Offline r13lbag
« Reply #48 on: Tue, 23 February 2021, 20:08:15 »
Waiting!
« Reply #49 on: Thu, 18 March 2021, 06:42:47 »
Novelties just got released. Check them out!
