Author Topic: [GB] Duck Orion V2.5 TKL Kustom Keyboard [ALL SHIPPED]  (Read 146607 times)
Offline JubJubCity
Re: [GB] Duck Orion V2.5 TKL Kustom Keyboard [SHIPPING]
« Reply #250 on: Sun, 23 May 2021, 18:34:17 »
Do the indicator leds still work with qmk ?
QMK will allow you to set RGB controls on the board but it you cannot set a static color as you could with other Duck boards. Even with the software O2D it will not allow you to set a static color so it seems as though the option was removed for this board or maybe the version I am using is the not correct.
« Last Edit: Wed, 26 May 2021, 15:51:13 by JubJubCity »
« Reply #251 on: Wed, 26 May 2021, 14:10:24 »
QMK will allow you to set RGB controls on the board but it you cannot set a static color as you could with other ****s boards. Even with the software O2D it will not allow you to set a static color so it seems as though the option was removed for this board or maybe the version I am using is the not correct.
o2d pcbs have always had indicator LED problems when ported to QMK
Offline whykayallday
« Reply #252 on: Thu, 27 May 2021, 02:15:08 »
Silvers are shipped  ;D
Offline Natac24
« Reply #253 on: Fri, 28 May 2021, 12:24:27 »
the qmk firmware for orion V3 works with v2.5 as well.
However, as an ISO user, i cant get split lshift to work. Has anyone solved that?
Offline chowbabyloving
« Reply #254 on: Fri, 28 May 2021, 23:00:37 »
I didn’t get a tracking number for my silver one, are we supposed to get tracking numbers ?
Offline jaesen
  • holy ****, this hobby is expensive
KBD8x mkii | Duck Orion v2.5 | Satisfaction 75 | IRON165 | Aurora Input Series 65 | Vega | LZ Phase
Wishlist: Constellation
Offline Minam
« Reply #256 on: Sat, 29 May 2021, 01:25:11 »
Got my silver yesterday and everything looks good.
Re: [GB] Duck Orion V2.5 TKL Kustom Keyboard [ALL SHIPPED]
« Reply #257 on: Mon, 31 May 2021, 18:01:14 »
My silver one arrived, but it looks like I am missing 2 of the shorter screws for the front of the case.  Is there anyway to get replacements?
Offline patzorz
  • lowkey addicted
    • Instagram
« Reply #258 on: Thu, 03 June 2021, 02:05:52 »
Mine has arrived too :3 Can't wait to build.
7V - Duck Orion v2.5 - GeonWorks F2-84 -  Satisfaction75 - Zenith - Polaris - Vega - Hex4B - TGR x KLC Dolice - Tomo - Thermal -  Prophet -  Hex3C
« Reply #259 on: Thu, 03 June 2021, 13:11:53 »
Silver came in flawless. thanks for organizing the gb elton
Offline andrewregal
« Reply #260 on: Fri, 04 June 2021, 00:31:10 »
My silver arrived today! But similar to chowbabyloving I'm missing 2 of the shorter outer case screws for the lower lip
Discord: andrewregal#7830
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #261 on: Fri, 04 June 2021, 00:50:34 »
i was missing a plate screw. ordered these as replacement: https://www.mcmaster.com/94500A262/
still need to build my board. might spin an h87c that fits. also need to do some FR4 plates, the plate mount tabs and spacebar orientation (north now) are different, so my existing jane v1/orion plates won't work. that'll be fixed soon enough :)
Offline honoka
« Reply #262 on: Fri, 04 June 2021, 04:19:58 »
Aftermarket PCB's are always welcomed. I'll buy a couple just to sit on probably. If they have ISO-support of course  ;)
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #263 on: Fri, 04 June 2021, 07:46:36 »
Thank you hiney
« Reply #264 on: Sat, 05 June 2021, 10:17:45 »
Will your pcbs work with the indicator leds?
Offline yrneh
« Reply #265 on: Sat, 05 June 2021, 12:11:50 »
How do I get the indicator LEDs to work? I must be an idiot.
« Reply #266 on: Sat, 05 June 2021, 16:33:34 »
The caps lock, scroll lock and num lock work out of box. The layer ones do as well.
Are you sure you didn’t reverse the led +/- when you put them in?
Offline Opacity
« Reply #267 on: Sat, 05 June 2021, 21:47:15 »
Would anyone happen to have a link to the latest version of the 02D keymapper that works with this PCB? Google is finding me versions from 2014 and 2018.
Thanks in advance!
Edit: Actually, the versions for Orion v2 and v3 work just fine.
« Last Edit: Sun, 06 June 2021, 16:18:16 by Opacity »
« Reply #268 on: Sat, 05 June 2021, 21:49:12 »
Also is there a file for the outer plate available ?
Offline Vadurr
  • Valar Morghulis
« Reply #269 on: Sat, 12 June 2021, 21:07:21 »
Hey Elton, I sent you an email in regards to my order.
Offline andrewregal
« Reply #270 on: Fri, 18 June 2021, 17:54:52 »
Was there anyone else who was missing case screws? And if so, was anyone able to find where to get replacements?
« Reply #271 on: Fri, 18 June 2021, 23:16:01 »
Case screws are as follows:
Socket Head Cap M3x12mm
Flat Head M3x10mm
Flat Head M3x6mm
You can buy stainless steel replacements from https://monsterbolts.com/
Offline FlitzDeelman
« Reply #272 on: Sat, 19 June 2021, 14:59:06 »
Hi all, is there anybody making weights for the Orion 2.5? I know about this guy, that makes uncoated brass weights, which will get patina over time.
https://www.reddit.com/r/mechmarket/comments/n7f5y8/bulk_duck_orion25_accessories_internal_external/?utm_source=share&utm_medium=ios_app&utm_name=iossmf
The patina is not a showstopper, in fact I may like it. But I normally like to look at a few options before I pull the trigger.
Any further suggestions?
« Last Edit: Sat, 19 June 2021, 15:00:38 by FlitzDeelman »
Offline audax989
  • NOM NOM NOM
« Reply #273 on: Sun, 20 June 2021, 12:05:22 »
Check out No. 23. Recently bought some weights from him.
Offline Vadurr
  • Valar Morghulis
« Reply #274 on: Sun, 20 June 2021, 12:37:11 »
The link he provided is No.23
Offline Minam
« Reply #275 on: Sun, 20 June 2021, 16:19:11 »
So can we control the indicator lights with QMK? I wish there was a definitive answer...
Offline audax989
  • NOM NOM NOM
« Reply #276 on: Tue, 20 July 2021, 00:30:43 »
Anyone know what the ETA shipping date for the extras are?
Offline Suavity
  • Smile more! 🙂
« Reply #277 on: Tue, 20 July 2021, 05:07:34 »
IIRC, it should be at the end of next month. I asked the same question to Elton and was told ~2 months from submission of invoice payment.
Offline Opacity
« Reply #278 on: Wed, 21 July 2021, 13:21:37 »
For what it's worth, you can force a static color by editing the individual values "RGB Color Preset" in 02D KeyMapper.
Offline JubJubCity
« Reply #279 on: Wed, 21 July 2021, 16:55:10 »
Which version? I tried the latest version and prior ones I had but none worked for me so I went with QMK.
Offline Opacity
« Reply #280 on: Wed, 21 July 2021, 19:37:57 »
I'm using 02D version 1.10.653. To be clear, you have to go to the "RGB Color Preset" screen in the "Tools" menu, as shown in the screenshot I've attached, then edit the color hex for each light. For the life of me I couldn't figure out the on-board keyboard controls.
Offline JubJubCity
« Reply #281 on: Wed, 21 July 2021, 21:51:05 »
Nice thanks, i will try that version and see if it will work for me.
Offline haxyer
« Reply #282 on: Sun, 15 August 2021, 23:05:59 »
does anyone knows where to get replacement feet for this ? I accidentally tore 1 of the feet
Offline JubJubCity
« Reply #283 on: Mon, 16 August 2021, 09:46:01 »
Probably Amazon as the feet are made by 3m
« Reply #284 on: Mon, 16 August 2021, 11:42:01 »
Do you have a link or a product name / code? Mine is being shipped, but I’d be interested in this too.
Offline JubJubCity
« Reply #285 on: Mon, 16 August 2021, 18:19:09 »
Dont have the link, but messaging elton could prove fruitful.
Offline shuijiao
  • ergo clear
« Reply #286 on: Wed, 01 September 2021, 16:58:18 »
this may be super late and whatnot, but did anyone notice that the screws to hold the board together are 3m for the top screws, but are 2.5m for the bottom ones? was looking to get some replacement ones, and noticed that it says that they are both 3m, however upon having the board in hand the top ones appear to be bigger than the bottom ones.
Peerless80, Type S, Pro 2, Pro 1, Duck Viper v3, Duck Orion V2.5, Matrix 2.0 Additional, Matrix Falcon
Offline nebluh
« Reply #287 on: Wed, 01 September 2021, 21:36:11 »
what leds should i use for the indicator leds? sorry if silly question
« Reply #288 on: Thu, 02 September 2021, 11:39:24 »
any single color 1.8mm LED should work great, i have used them on duck boards in the past
many vendors have them, but you can also score them from electronics stores like mouser, adafruit, etc. i think they are available on amazon too
just remember that they are directional. you can double check which direction to put them in by plugging in the PCB, then touching the legs to the pads to see if it turns on
Offline Mr.Elli0t
« Reply #289 on: Tue, 14 September 2021, 13:27:18 »
Hello, I'm looking to add lights to the top corner next to the esc key, and the section above the arrows. Can I add any color lights, and what lights are suggested?
I appreciate any help.
Offline JubJubCity
« Reply #290 on: Tue, 14 September 2021, 15:19:44 »
Any light colors will work as for the type I have used varying types and all have worked so not sure if one is better than the other.
« Last Edit: Wed, 15 September 2021, 11:15:27 by JubJubCity »
Offline Mr.Elli0t
« Reply #291 on: Tue, 14 September 2021, 15:23:58 »
Any light colors will work as for the type I have used varying types and all have works so not sure if one is better than the other.
Thank you for the quick reply!
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #292 on: Sun, 26 September 2021, 06:32:03 »
Thanks so much for the opportunity to get the board. I love it  :-*
Offline Vadurr
  • Valar Morghulis
« Reply #293 on: Sat, 09 October 2021, 16:09:09 »
Anyone happen to know the front height of this board?
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #294 on: Sun, 17 October 2021, 06:22:51 »
Just a quick question,
are the internal weight and external accents compatible with Orion v3?
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline Zestrion
« Reply #295 on: Sat, 30 October 2021, 01:47:52 »
Got VIA working with the board along with the lock indicators, but backlight doesn't seem to be working as well as the layer indicators. Anyone else have simillar issues?
Saw that there were issues with indicator LEDS when porting to QMK, but wasn't sure if this stemmed to backlight either. Just wanted to check to see if anyone had similar issues.
« Reply #296 on: Mon, 01 November 2021, 10:10:42 »
VIA is essentially just a QMK GUI, so that tracks
LED issues on ported PCBs of all kinds are pretty common, indicator or no
Offline Opacity
« Reply #297 on: Wed, 10 November 2021, 09:02:33 »
Sorry if I've missed them somewhere, but are the plates for this publicly available? I'd like to have an FR4 plate made.
Offline chriskeebs1911
  • steppedchris on Discord
« Reply #298 on: Wed, 10 November 2021, 10:49:36 »
https://kbdlab.co.kr/index.php?mid=board_JkGZ32&document_srl=3172541
Offline andrewregal
« Reply #299 on: Wed, 10 November 2021, 11:35:50 »
In case anyone is interested, Snow is currently doing an international order run for Orion PCBs and FR4 plates:
https://discord.gg/2HyxNWcWV9
https://forms.gle/ee23aweUB2UFHhCSA
